Adding dynamic points; clicking on point not working
Hoeven, Maarten van der
Maarten.van.der.Hoeven at KNMI.NL
Sat Jun 18 14:25:27 EDT 2005
Dear list,
I'm working with MapServer 4.6.0, PHP-Mapscript (Linux Suse9.2, Apache) and I managed to query my (MySQL) database, and plot dots on the appropriate lat/lon (see query below). However, I still can't manage to retrieve some additional information, when clicking on a dot (displaying all dots on a map is working okay). Im running with a modified Gmap-demo, but the functionality is intact. To be specific, when I click on a point, I got the message "Nothing found at query location."
Can you give me some hints/tipsss/clues? The code below is written by using some earlier examples on the list.
My (1) query and plotting by using PHP-mapscript, and below that (2) my map-file.
Regards,
Maarten van der Hoeven
1. ============
$layerObj = $gpoMap->getLayerByName("points01");
$classObj = $layerObj->getClass(0);
$query = "SELECT sta_id, lat/3600 as y, lon/3600 as x FROM stations;";
$result = mysql_query($query);
$i=0;
while (($row = mysql_fetch_array($result)))
$pointObj = ms_newPointObj();
$pointObj->setXY($row['x'], $row['y']);
$line = ms_newLineObj();
$line->add($pointObj);
$shp = ms_newShapeObj(MS_SHAPE_POINT);
$shp->add($line);
$shp->{index} = $i;
if ($layerObj->addFeature($shp) == -1)
echo "addfeature failed!";
$i++;
$pointObj->draw($gpoMap, $layerObj, $img, 0, 'sta_id');
2. ============
# Start of map file
# $Id: gmap75.map,v 1.23 2003/02/25 19:46:42 daniel Exp $
NAME DEMO
STATUS ON
DEBUG ON
SIZE 400 300
SYMBOLSET ../etc/symbols.sym
EXTENT -70 10 70 80
UNITS dd
SHAPEPATH "../data"
IMAGECOLOR 255 255 255
FONTSET ../etc/fonts.txt
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE PC256
EXTENSION "png"
END
QUERYMAP
STATUS ON
STYLE SELECTED
COLOR 255 0 0
END
# Start of web interface definition
WEB
MINSCALE 2000
MAXSCALE 50000000
IMAGEPATH "/webdata/ecad/htdocs/tmp/"
IMAGEURL "/tmp/"
LOG /tmp/gmap.log
END
# Start of reference map
REFERENCE
IMAGE images/keymap.png
EXTENT -2200000 -712631 3072800 3840000
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
SIZE 120 90
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE SMALL
END
SIZE 350 5
COLOR 255 255 255
BACKGROUNDCOLOR 255 0 0
OUTLINECOLOR 0 0 0
UNITS kilometers
INTERVALS 10
STATUS ON
END
LAYER
NAME points01
METADATA
"RESULT_FIELDS" "sta_id"
END
TEMPLATE void
TYPE POINT
STATUS ON
SYMBOLSCALE 50000
LABELITEM 'sta_id'
CLASSITEM 'sta_id'
CLASS
NAME 'sta_id'
STYLE
OUTLINECOLOR 255 255 255
COLOR 255 0 0
SYMBOL 7
SIZE 8
MAXSIZE 15
MINSIZE 15
END
LABEL
MINFEATURESIZE -1
POSITION UC
PARTIALS FALSE
COLOR '#000080'
SIZE GIANT
END
END
END
END # Map File
