MapServer 4.6 on Mac OS X and Oracle Spatial 10g
Fernando Simon
fsimon at UNIVALI.BR
Sun Jun 19 23:16:56 EDT 2005
The correct way how to connect Oracle Spatial is using:
"user/pass at sid". Other ways don't work.
This problem can be related with variables (shell). Generally I set
the Httpd variables too. You need the to set the ORACLE_HOME and
ORACLE_BASE correctly to access Oracle Spatial from Mapserver, for shell
and httpd.conf. You can see this page, as example, how to set this
Oracle variables:
http://www.puschitz.com/InstallingOracle10g.shtml#SettingOracleEnvironments
The user that will run Mapserver need to see (read permission) the
ORACLE_HOME directory.
Thanks.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://g10.cttmar.univali.br - UNIVALI/CTTMAR
Marco Marsella wrote:
> Hi all,
> I am trying to get MapServer use an OracleSpatial 10g DB running on a
> SUN box. I have installed Oracle Instant Client on the Mac and I can
> use sqlplus to connect and query the DB.
> Then I have built MS using the Oracle SDK and tried to connect.
> However, MS reports a problem with the creation of the OCI handlers:
> [Tue Jun 14 15:38:30 2005] [error] PHP Warning: [MapServer Error]:
> msDrawMap(): Failed to draw layer named 'Oracle'.\n in /Users/
> marsella/Sites/mserve/htdocs/common/wrapper/drawmap.php on line 533
> msOracleSpatialLayerOpen(): Cannot create OCI Handlers. Connection
> failure. Check the connection string. Error: .\n in /Users/marsella/
> [Tue Jun 14 15:38:30 2005] [error] PHP Notice: Use of undefined
> constant MS_CHILDERR - assumed 'MS_CHILDERR' in /Users/marsella/Sites/
> mserve/htdocs/common/wrapper/drawmap.php on line 668
> - I have set the following shell variables:
> export DYLD_LIBRARY_PATH="/usr/local/oracle/lib"
> export LD_LIBRARY_PATH="/usr/local/oracle/lib"
> export JAVA_HOME=/Library/Java/Home
> export SQLPATH=/usr/local/oracle
> export TNS_ADMIN=/Users/marsella/Sites/mserve/eclo/etc
> - I have tried SQL*Plus and it works using the following command:
> /usr/local/oracle/sqlplus scott/tiger at locustgis1:1521/ECLO2
> Then I have set the following SetEnvIf clauses in httpd.conf:
> SetEnvIf Request_URI ".*" TNS_ADMIN "/Users/marsella/Sites/mserve/
> eclo/etc"
> SetEnvIf Request_URI ".*" SQLPATH "/usr/local/oracle"
> SetEnvIf Request_URI ".*" LD_LIBRARY_PATH "/usr/local/oracle/lib"
> SetEnvIf Request_URI ".*" DYLD_LIBRARY_PATH "/usr/local/oracle/lib"
> I have checked that the tnsnames.ora file is readable by any user.
> The tnsnames.ora file is:
> ECLO2 =
> (DESCRIPTION =
> (ADDRESS = (PROTOCOL = TCP)(HOST = locustgis1)(PORT = 1521))
> (CONNECT_DATA =
> (SERVER = DEDICATED)
> (SERVICE_NAME = ECLO2)
> The layer is as follows:
> LAYER
> NAME "Oracle"
> TYPE POINT
> STATUS OFF
> CONNECTIONTYPE oraclespatial
> CONNECTION "scott/tiger@//locustgis1:1521/ECLO2" (I also
> tried "scott/tiger at ECLO2" with the same result)
> DATA "shape FROM OPS$LOCUST.test USING SRID 8307"
> CLASS
> NAME "Hoppers"
> SYMBOL "circle"
> COLOR 0 255 0
> END
> END
> and the table test is:
> SQL*Plus: Release 10.1.0.3.0 - Production on Tue Jun 14 15:32:18 2005
> Copyright (c) 1982, 2004, Oracle. All rights reserved.
> Connected to:
> Oracle Database 10g Enterprise Edition Release 10.1.0.2.0 - 64bit
> Production
> With the Partitioning, OLAP and Data Mining options
> SQL> describe OPS$LOCUST.test;
> Name Null? Type
> GA NUMBER(38)
> SHAPE OPS$LOCUST.SDO_GEOMETRY
> Is there anything you see wrong ?
> Thank you very much.
> Marco
