mapscript/java errors
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Mon Jun 20 04:26:12 EDT 2005
You need to compile mapserver first and then cd to mapscript/java. You
should try to run
make interface
before running make in mapscript/java as it will generate/update the
swig-generated interface files. You need a very recent version of swig
to run make interface.
I have not tried mapserver 4.6 yet so there might be unresolved issues
with java maspcript that I am not aware of.
HTH,
Umberto
On 6/20/05, orkun <temiz at deprem.gov.tr> wrote:
> thank you for your interest:
> - linux debian testing
> - mapserver-4.6.0-beta1
> - I changed mapscript/java then entered make and the nightmare started.
> here is my config
> --with-proj \
> --with-threads \
> --with-ogr \
> --with-gd=/usr/local/gd-2.0.33 \
> --with-gdal=/usr/local/bin/gdal-config \
> --with-png \
> --with-php=/usr/local/php-5.0.4/ \
> --with-java=/usr/local/jdk1.5.0_03/
> I have been using phpmapscript. But I am curious about java.
> Can you say that developing and using mapserver with java is better
> than php ?
> regards
> ______________________________________
> XamimeLT - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the sender's own
> and do not necessarily represent the views and the opinions of Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
