mapscript/java errors
orkun
temiz at DEPREM.GOV.TR
Mon Jun 20 06:54:53 EDT 2005
Umberto Nicoletti wrote:
>You need to compile mapserver first and then cd to mapscript/java. You
>should try to run
>make interface
>before running make in mapscript/java as it will generate/update the
>swig-generated interface files. You need a very recent version of swig
>to run make interface.
>I have not tried mapserver 4.6 yet so there might be unresolved issues
>with java maspcript that I am not aware of.
>HTH,
>Umberto
>On 6/20/05, orkun <temiz at deprem.gov.tr> wrote:
>>thank you for your interest:
>>- linux debian testing
>>- mapserver-4.6.0-beta1
>>- I changed mapscript/java then entered make and the nightmare started.
>>here is my config
>>--with-proj \
>>--with-threads \
>>--with-ogr \
>>--with-gd=/usr/local/gd-2.0.33 \
>>--with-gdal=/usr/local/bin/gdal-config \
>>--with-png \
>>--with-php=/usr/local/php-5.0.4/ \
>>--with-java=/usr/local/jdk1.5.0_03/
>>I have been using phpmapscript. But I am curious about java.
>>Can you say that developing and using mapserver with java is better
>> than php ?
>>regards
>>______________________________________
>>XamimeLT - installed on mailserver for domain @deprem.gov.tr
>>Queries to: postmaster at deprem.gov.tr
>>The views and opinions expressed in this e-mail message are the sender's own
>>and do not necessarily represent the views and the opinions of Earthquake Research Dept.
>>of General Directorate of Disaster Affairs.
>>Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
>>B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
hello
with make interface, it produced so many *.java files in
../mapscript/java/edu/umn/gis/mapscript/ directory.
not a compiled library as in phpmapscript.so ?
Is there anything as next step ?
regards
Ahmet
