Perl Mapscript 4.4 Issues
Lowell Filak
lfilak at MEDINACO.ORG
Mon Jun 20 08:39:03 EDT 2005
The following message was sent by Rob Ellis <robin.ellis at NRM.QLD.GOV.AU>
on Sun, 19 Jun 2005 20:57:19 -0500.
> On Mon, 25 Apr 2005 08:18:22 -0400, Lowell Filak <lfilak at MEDINACO.ORG>
> wrote:
> >The following message was sent by Stephen Woodbridge
> ><woodbri at SWOODBRIDGE.COM> on Sun, 24 Apr 2005 23:23:26 -0400.
> >> Hi all,
> >> I'm looking at the SWIGMapScript doc and have run into a few problems.
> >> $mapObj->setExtent($minx, $miny, $maxx, $maxy);
> >> and throws an error:
> >> Can't locate auto/mapscript/mapObj/setExtent.al in @INC (@INC contains:
> >> /etc/perl /usr/local/lib/perl/5.8.4 /usr/local/share/perl/5.8.4
> >> /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8
> >> /usr/local/lib/site_perl /usr/local/lib/perl/5.8.0
> >> /usr/local/share/perl/5.8.0 .) at index.cgi line 255
> >> Also looking at the document it looks like there is an
> >> $layerObj->setExtent(...) which doesn't seem to be correct.
> >> The classObj doc says it "Provides access to all class parameters
> >> (color, symbol, label, & etc...)." but there is no doc to indicate
there
> >> is a symbol property, nor is there any of doc/properties for color,
> >> overlaycolor, size, overlaysize. I think these were moved to styleObjs
> >> so it might be appropriate to comment on that.
> >Steve,
> >What version are you using?
> >I just double checked and there is most certainly a 'setExtent' for the
> >mapObj in the mapscript.pm.
> >You are correct on the classObj not. It is an old note that needs to be
> >deleted. Sorry for the confusion.
> >Lowell
> Sorry to take you guys back to something that you've allready sorted out,
> but I'm a little confused. I've upgraded to MS4.4.2 but am getting the
> following message when trying to use Perl Mapscript, and from the previous
> messages it looks as though I might just need to alter mapscript.pm:
> Can't locate auto/mapscript/classObj/swig_styles.al
> Am I right in interpreting the previous emails when I assume that I
need to
> remove refernces to classObj in mapscript.pm, or am I way off?
Rob,
I usually see this error after upgrading and trying to reference a
member or method that no longer exists.
