Musmap 0.9.0-beta
Mathieu PARENT math.parent at GMAIL.COM
Mon Jun 20 08:09:08 PDT 2005
 Musmap 0.9 is pending now, just some testing is needed to find bugs.
You can find beta version at
https://sourceforge.net/project/showfiles.php?group_id=114970&package_id=124581&release_id=336416
Please help me to make musmap free of bugs (reportings bugs, feature
requests, ...).
Musmap is a web mapping interface which has an advanced users/profiles
management system.
More information at http://musmap.sourceforge.net/
Simple ChangeLog at http://musmap.sourceforge.net/todo/
CVS changelog at
http://musmap.sourceforge.net/cvschangelog/cvschangelogbuilder_musmap.html
I will put a development version online in some weeks (the actual demo is
outdated 0.8.1 version).
Mathieu Parent
Simple Changelog:
New install procedure (easier)
SVG output (in the print dialog)
Real symbol management (not in the template map file) (RFE #1114571)
Date display using client time zone if available
Measure tool now draws polygons (SVG for Gecko and VML for IE)
Read privileges are now effective: not readable objects are not loaded
More complete musmap capabilities description in about.php
OGR support for SQL and GetInformationSchema
GetInformationSchema supported by Shapefiles, dbf, mysql, postgresql
Explorer: Get all table info automaticaly (using GetInformationSchema)
Model: adding connections (parent of data_sources)
Complete rewrite of the model hierarchy API using collections
Explorers: Allow child nodes batch deletion
Import ESRI XML metadata for shapefiles (need PHP5 which has DOM extension)
Zoom to layer
Query results are lost if layer index changes (Bug #1123873)
Ability to change parent node
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050620/ab9c636d/attachment.htm>
More information about the MapServer-users mailing list
