Unsupported operand types
Jacob Delfos
jacob.delfos at MAUNSELL.COM
Mon Jun 20 20:45:42 EDT 2005
Matthew,
The error you gets occurs when loading the mapfile, so that is where the problem probably is.
I noticed that your fontset does not have quotes around the value. I just tested that, and for me that prevented it from loading.
So this line:
FONTSET ../etc/fonts.txt
must be
FONTSET "../etc/fonts.txt"
regards,
Jacob
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Matthew Roberson
Sent: 20 June 2005 22:28
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Unsupported operand types
I really need some help. I posted this late friday
afternoon, however I am going to repost it in case
anyone who might be able to help me missed it.
I am trying to use the queryByAttributes method of
the LayerObj class of PHP/Mapscript and I am doing
something wrong, because I get the following error:
Fatal error: Unsupported operand types in
C:\ms4w\apps\test\htdocs\LA.phtml on line 12
I am running in Windows XP professional with:
ms4w 1.1
I also get the same error in MacOS X with a custom
compiled version of MapSever.
The Map File is contains:
MAP
NAME LA
IMAGETYPE PNG
SIZE 600 600
IMAGECOLOR 240 240 240
SHAPEPATH "../data"
EXTENT -94.043147 28.925011 -88.817017 33.019457
UNITS METERS
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
LEGEND
STATUS EMBED
POSITION UR
END
SCALEBAR
TRANSPARENT ON
BACKGROUNDCOLOR 0 0 0
STATUS EMBED
POSITION LR
STYLE 1
END
LAYER
NAME "LA zip code boundaries"
TYPE POLYGON
STATUS DEFAULT
DATA "zt22_d00"
LABELITEM "ZCTA"
CLASS
COLOR 254 0 0
LABEL
COLOR 60 60 60
SHADOWCOLOR 218 218 218
SHADOWSIZE 1 1
TYPE TRUETYPE
FONT fritqat
SIZE 8
ANTIALIAS TRUE
POSITION CL
PARTIALS FALSE
MINDISTANCE 5
BUFFER 4
END
OUTLINECOLOR 60 60 60
SYMBOL 0
END
TEMPLATE "x"
END
LAYER
NAME "credits"
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS
10 680
END
TEXT 'Made with Mapserver.'
END
CLASS
LABEL
TYPE BITMAP
POSITION CR
COLOR 0 0 0
END
END
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050621/2e6315d6/attachment.html
