java mapscript error
orkun
temiz at DEPREM.GOV.TR
Tue Jun 21 06:15:09 EDT 2005
Umberto Nicoletti wrote:
>Note: I have just downloaded mapserver 4.6 and it compiles fine and
>tests run out of the box, so it is not a problem with mapserver.
>Can you confirm there is a libmapscript.so in mapscript/java ?
>Post the java version ( java -version ) output.
>Regards,
>Umberto
>On 6/20/05, orkun <temiz at deprem.gov.tr> wrote:
>>(sorry if it is sent twice)
>>thank you again
>>$ make test
>>javac -classpath ./:examples/:./mapscript.jar -d examples/ examples/*.java
>>java -classpath ./:examples/:./mapscript.jar -Djava.library.path=.
>>DumpShp ../../tests/point.shp
>>java.lang.UnsatisfiedLinkError: no mapscript in java.library.path
>>make: *** [test] Error 255
>>regards
>>______________________________________
>>XamimeLT - installed on mailserver for domain @deprem.gov.tr
>>Queries to: postmaster at deprem.gov.tr
>>The views and opinions expressed in this e-mail message are the sender's own
>>and do not necessarily represent the views and the opinions of Earthquake Research Dept.
>>of General Directorate of Disaster Affairs.
>>Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
>>B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
thank you,
there is no libmapscript.so.
~$ java -version
java version "1.5.0_03"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_03-b07)
Java HotSpot(TM) Client VM (build 1.5.0_03-b07, mixed mode, sharing)
Is my configuration which I have previously sent ok ?
regards
Ahmet
