java mapscript error
    Umberto Nicoletti
    umberto.nicoletti at GMAIL.COM
    Tue Jun 21 03:33:08 PDT 2005
Very weird...
Start again with a fresh copy of mapserver and do the following (in order):
./configure [put your conf options here]
make
cd mapscript/java
make interface
make
make test
If this does not work than there is something wrong with your setup
(try a different machine).
Regards,
Umberto
On 6/21/05, orkun <temiz at deprem.gov.tr> wrote:
> Umberto Nicoletti wrote:
> >Note: I have just downloaded mapserver 4.6 and it compiles fine and
> >tests run out of the box, so it is not a problem with mapserver.
> >Can you confirm there is a libmapscript.so in mapscript/java ?
> >Post the java version ( java -version ) output.
> >Regards,
> >Umberto
> >On 6/20/05, orkun <temiz at deprem.gov.tr> wrote:
> >>(sorry if it is sent twice)
> >>thank you again
> >>$ make test
> >>javac -classpath ./:examples/:./mapscript.jar -d examples/ examples/*.java
> >>java -classpath ./:examples/:./mapscript.jar -Djava.library.path=.
> >>DumpShp ../../tests/point.shp
> >>java.lang.UnsatisfiedLinkError: no mapscript in java.library.path
> >>make: *** [test] Error 255
> >>regards
> >>______________________________________
> >>XamimeLT - installed on mailserver for domain @deprem.gov.tr
> >>Queries to: postmaster at deprem.gov.tr
> >>The views and opinions expressed in this e-mail message are the sender's own
> >>and do not necessarily represent the views and the opinions of Earthquake Research Dept.
> >>of General Directorate of Disaster Affairs.
> >>Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
> >>B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
> thank you,
> there is no  libmapscript.so.
> ~$ java -version
> java version "1.5.0_03"
> Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_03-b07)
> Java HotSpot(TM) Client VM (build 1.5.0_03-b07, mixed mode, sharing)
> Is my configuration which I have previously sent ok ?
> regards
> Ahmet
More information about the MapServer-users
