java mapscript error
orkun
temiz at DEPREM.GOV.TR
Tue Jun 21 10:30:10 EDT 2005
Umberto Nicoletti wrote:
>>I am sorry to take up your time
>>I made a fresh compilation without encountering any problem
>>till ./java/make.
>You have to be in mapscript/java directory when you run make!!!!
./java is ./mapscript/java
>Execute the commands as I have written them (LITERALLY, you can copy
>and paste ) in my previous post. If still it does not work post the
>relevant parts of your shell history so I can see what you have done
>exactly.
>Do you have javac? Try running javac at the command prompt.
..../mapserver-4.6.0/mapscript/java$ javac -version
javac 1.5.0_03
>Regards,
>Umberto
>>there are so many errors in /mapserver-4.6.0/mapscript/java directory
>>when I enter make in this way:
I am sending error file in attachment.
regards
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
gcc -fpic -c -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DNEED_STRLCAT -DUSE_EPPL -DUSE_PROJ -DUSE_WMS_SVR -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_OGR -DUSE_GDAL -DUSE_THREAD -I/usr/local/gd-2.0.33 -I/usr/local/include -I/include -I/include/linux -fno-strict-aliasing mapscript_wrap.c
mapscript_wrap.c:24:17: jni.h: No such file or directory
mapscript_wrap.c:48: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaThrowException':
mapscript_wrap.c:49: error: `jclass' undeclared (first use in this function)
mapscript_wrap.c:49: error: (Each undeclared identifier is reported only once
mapscript_wrap.c:49: error: for each function it appears in.)
mapscript_wrap.c:49: error: parse error before "excep"
mapscript_wrap.c:63: error: `code' undeclared (first use in this function)
mapscript_wrap.c:66: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:67: error: `excep' undeclared (first use in this function)
mapscript_wrap.c:69: error: `msg' undeclared (first use in this function)
mapscript_wrap.c: At top level:
mapscript_wrap.c:107: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaException':
mapscript_wrap.c:109: error: `code' undeclared (first use in this function)
mapscript_wrap.c:137: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:137: error: `msg' undeclared (first use in this function)
mapscript_wrap.c:239: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayInSchar':
mapscript_wrap.c:241: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:241: error: parse error before "sz"
mapscript_wrap.c:242: error: `input' undeclared (first use in this function)
mapscript_wrap.c:243: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:246: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:247: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:250: error: `carr' undeclared (first use in this function)
mapscript_wrap.c:260: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayArgoutSchar':
mapscript_wrap.c:262: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:262: error: parse error before "sz"
mapscript_wrap.c:263: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:264: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:264: error: `jbyte' undeclared (first use in this function)
mapscript_wrap.c:264: error: parse error before "carr"
mapscript_wrap.c:265: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:265: error: `input' undeclared (first use in this function)
mapscript_wrap.c:268: error: parse error before "SWIG_JavaArrayOutSchar"
mapscript_wrap.c:268: error: parse error before '*' token
mapscript_wrap.c:268: warning: return type defaults to `int'
mapscript_wrap.c: In function `SWIG_JavaArrayOutSchar':
mapscript_wrap.c:269: error: `jbyte' undeclared (first use in this function)
mapscript_wrap.c:269: error: `arr' undeclared (first use in this function)
mapscript_wrap.c:271: error: `jbyteArray' undeclared (first use in this function)
mapscript_wrap.c:271: error: parse error before "jresult"
mapscript_wrap.c:272: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:273: warning: return makes integer from pointer without a cast
mapscript_wrap.c:274: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:276: warning: return makes integer from pointer without a cast
mapscript_wrap.c:277: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:278: error: parse error before "result"
mapscript_wrap.c:285: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayInUchar':
mapscript_wrap.c:287: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:287: error: parse error before "sz"
mapscript_wrap.c:288: error: `input' undeclared (first use in this function)
mapscript_wrap.c:289: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:292: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:293: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:296: error: `carr' undeclared (first use in this function)
mapscript_wrap.c:306: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayArgoutUchar':
mapscript_wrap.c:308: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:308: error: parse error before "sz"
mapscript_wrap.c:309: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:310: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:310: error: `jshort' undeclared (first use in this function)
mapscript_wrap.c:310: error: parse error before "carr"
mapscript_wrap.c:311: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:311: error: `input' undeclared (first use in this function)
mapscript_wrap.c:314: error: parse error before "SWIG_JavaArrayOutUchar"
mapscript_wrap.c:314: error: parse error before '*' token
mapscript_wrap.c:314: warning: return type defaults to `int'
mapscript_wrap.c: In function `SWIG_JavaArrayOutUchar':
mapscript_wrap.c:315: error: `jshort' undeclared (first use in this function)
mapscript_wrap.c:315: error: `arr' undeclared (first use in this function)
mapscript_wrap.c:317: error: `jshortArray' undeclared (first use in this function)
mapscript_wrap.c:317: error: parse error before "jresult"
mapscript_wrap.c:318: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:319: warning: return makes integer from pointer without a cast
mapscript_wrap.c:320: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:322: warning: return makes integer from pointer without a cast
mapscript_wrap.c:323: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:324: error: parse error before "result"
mapscript_wrap.c:331: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayInShort':
mapscript_wrap.c:333: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:333: error: parse error before "sz"
mapscript_wrap.c:334: error: `input' undeclared (first use in this function)
mapscript_wrap.c:335: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:338: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:339: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:342: error: `carr' undeclared (first use in this function)
mapscript_wrap.c:352: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayArgoutShort':
mapscript_wrap.c:354: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:354: error: parse error before "sz"
mapscript_wrap.c:355: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:356: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:356: error: `jshort' undeclared (first use in this function)
mapscript_wrap.c:356: error: parse error before "carr"
mapscript_wrap.c:357: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:357: error: `input' undeclared (first use in this function)
mapscript_wrap.c:360: error: parse error before "SWIG_JavaArrayOutShort"
mapscript_wrap.c:360: error: parse error before '*' token
mapscript_wrap.c:360: warning: return type defaults to `int'
mapscript_wrap.c: In function `SWIG_JavaArrayOutShort':
mapscript_wrap.c:361: error: `jshort' undeclared (first use in this function)
mapscript_wrap.c:361: error: `arr' undeclared (first use in this function)
mapscript_wrap.c:363: error: `jshortArray' undeclared (first use in this function)
mapscript_wrap.c:363: error: parse error before "jresult"
mapscript_wrap.c:364: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:365: warning: return makes integer from pointer without a cast
mapscript_wrap.c:366: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:368: warning: return makes integer from pointer without a cast
mapscript_wrap.c:369: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:370: error: parse error before "result"
mapscript_wrap.c:377: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayInUshort':
mapscript_wrap.c:379: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:379: error: parse error before "sz"
mapscript_wrap.c:380: error: `input' undeclared (first use in this function)
mapscript_wrap.c:381: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:384: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:385: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:388: error: `carr' undeclared (first use in this function)
mapscript_wrap.c:398: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayArgoutUshort':
mapscript_wrap.c:400: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:400: error: parse error before "sz"
mapscript_wrap.c:401: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:402: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:402: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:402: error: parse error before "carr"
mapscript_wrap.c:403: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:403: error: `input' undeclared (first use in this function)
mapscript_wrap.c:406: error: parse error before "SWIG_JavaArrayOutUshort"
mapscript_wrap.c:406: error: parse error before '*' token
mapscript_wrap.c:406: warning: return type defaults to `int'
mapscript_wrap.c: In function `SWIG_JavaArrayOutUshort':
mapscript_wrap.c:407: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:407: error: `arr' undeclared (first use in this function)
mapscript_wrap.c:409: error: `jintArray' undeclared (first use in this function)
mapscript_wrap.c:409: error: parse error before "jresult"
mapscript_wrap.c:410: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:411: warning: return makes integer from pointer without a cast
mapscript_wrap.c:412: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:414: warning: return makes integer from pointer without a cast
mapscript_wrap.c:415: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:416: error: parse error before "result"
mapscript_wrap.c:423: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayInInt':
mapscript_wrap.c:425: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:425: error: parse error before "sz"
mapscript_wrap.c:426: error: `input' undeclared (first use in this function)
mapscript_wrap.c:427: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:430: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:431: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:434: error: `carr' undeclared (first use in this function)
mapscript_wrap.c:444: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayArgoutInt':
mapscript_wrap.c:446: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:446: error: parse error before "sz"
mapscript_wrap.c:447: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:448: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:448: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:448: error: parse error before "carr"
mapscript_wrap.c:449: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:449: error: `input' undeclared (first use in this function)
mapscript_wrap.c:452: error: parse error before "SWIG_JavaArrayOutInt"
mapscript_wrap.c:452: error: parse error before '*' token
mapscript_wrap.c:452: warning: return type defaults to `int'
mapscript_wrap.c: In function `SWIG_JavaArrayOutInt':
mapscript_wrap.c:453: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:453: error: `arr' undeclared (first use in this function)
mapscript_wrap.c:455: error: `jintArray' undeclared (first use in this function)
mapscript_wrap.c:455: error: parse error before "jresult"
mapscript_wrap.c:456: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:457: warning: return makes integer from pointer without a cast
mapscript_wrap.c:458: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:460: warning: return makes integer from pointer without a cast
mapscript_wrap.c:461: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:462: error: parse error before "result"
mapscript_wrap.c:469: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayInUint':
mapscript_wrap.c:471: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:471: error: parse error before "sz"
mapscript_wrap.c:472: error: `input' undeclared (first use in this function)
mapscript_wrap.c:473: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:476: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:477: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:480: error: `carr' undeclared (first use in this function)
mapscript_wrap.c:490: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayArgoutUint':
mapscript_wrap.c:492: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:492: error: parse error before "sz"
mapscript_wrap.c:493: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:494: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:494: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:494: error: parse error before "carr"
mapscript_wrap.c:495: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:495: error: `input' undeclared (first use in this function)
mapscript_wrap.c:498: error: parse error before "SWIG_JavaArrayOutUint"
mapscript_wrap.c:498: error: parse error before '*' token
mapscript_wrap.c:498: warning: return type defaults to `int'
mapscript_wrap.c: In function `SWIG_JavaArrayOutUint':
mapscript_wrap.c:499: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:499: error: `arr' undeclared (first use in this function)
mapscript_wrap.c:501: error: `jlongArray' undeclared (first use in this function)
mapscript_wrap.c:501: error: parse error before "jresult"
mapscript_wrap.c:502: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:503: warning: return makes integer from pointer without a cast
mapscript_wrap.c:504: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:506: warning: return makes integer from pointer without a cast
mapscript_wrap.c:507: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:508: error: parse error before "result"
mapscript_wrap.c:515: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayInLong':
mapscript_wrap.c:517: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:517: error: parse error before "sz"
mapscript_wrap.c:518: error: `input' undeclared (first use in this function)
mapscript_wrap.c:519: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:522: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:523: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:526: error: `carr' undeclared (first use in this function)
mapscript_wrap.c:536: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayArgoutLong':
mapscript_wrap.c:538: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:538: error: parse error before "sz"
mapscript_wrap.c:539: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:540: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:540: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:540: error: parse error before "carr"
mapscript_wrap.c:541: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:541: error: `input' undeclared (first use in this function)
mapscript_wrap.c:544: error: parse error before "SWIG_JavaArrayOutLong"
mapscript_wrap.c:544: error: parse error before '*' token
mapscript_wrap.c:544: warning: return type defaults to `int'
mapscript_wrap.c: In function `SWIG_JavaArrayOutLong':
mapscript_wrap.c:545: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:545: error: `arr' undeclared (first use in this function)
mapscript_wrap.c:547: error: `jintArray' undeclared (first use in this function)
mapscript_wrap.c:547: error: parse error before "jresult"
mapscript_wrap.c:548: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:549: warning: return makes integer from pointer without a cast
mapscript_wrap.c:550: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:552: warning: return makes integer from pointer without a cast
mapscript_wrap.c:553: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:554: error: parse error before "result"
mapscript_wrap.c:561: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayInUlong':
mapscript_wrap.c:563: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:563: error: parse error before "sz"
mapscript_wrap.c:564: error: `input' undeclared (first use in this function)
mapscript_wrap.c:565: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:568: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:569: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:572: error: `carr' undeclared (first use in this function)
mapscript_wrap.c:582: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayArgoutUlong':
mapscript_wrap.c:584: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:584: error: parse error before "sz"
mapscript_wrap.c:585: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:586: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:586: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:586: error: parse error before "carr"
mapscript_wrap.c:587: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:587: error: `input' undeclared (first use in this function)
mapscript_wrap.c:590: error: parse error before "SWIG_JavaArrayOutUlong"
mapscript_wrap.c:590: error: parse error before '*' token
mapscript_wrap.c:590: warning: return type defaults to `int'
mapscript_wrap.c: In function `SWIG_JavaArrayOutUlong':
mapscript_wrap.c:591: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:591: error: `arr' undeclared (first use in this function)
mapscript_wrap.c:593: error: `jlongArray' undeclared (first use in this function)
mapscript_wrap.c:593: error: parse error before "jresult"
mapscript_wrap.c:594: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:595: warning: return makes integer from pointer without a cast
mapscript_wrap.c:596: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:598: warning: return makes integer from pointer without a cast
mapscript_wrap.c:599: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:600: error: parse error before "result"
mapscript_wrap.c:607: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayInLonglong':
mapscript_wrap.c:609: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:609: error: parse error before "sz"
mapscript_wrap.c:610: error: `input' undeclared (first use in this function)
mapscript_wrap.c:611: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:614: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:615: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:618: error: `carr' undeclared (first use in this function)
mapscript_wrap.c:618: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:618: error: parse error before ')' token
mapscript_wrap.c:628: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayArgoutLonglong':
mapscript_wrap.c:630: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:630: error: parse error before "sz"
mapscript_wrap.c:631: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:632: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:632: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:632: error: parse error before "carr"
mapscript_wrap.c:633: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:633: error: `input' undeclared (first use in this function)
mapscript_wrap.c:636: error: parse error before "SWIG_JavaArrayOutLonglong"
mapscript_wrap.c:636: error: parse error before '*' token
mapscript_wrap.c:636: warning: return type defaults to `int'
mapscript_wrap.c: In function `SWIG_JavaArrayOutLonglong':
mapscript_wrap.c:637: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:637: error: `arr' undeclared (first use in this function)
mapscript_wrap.c:639: error: `jlongArray' undeclared (first use in this function)
mapscript_wrap.c:639: error: parse error before "jresult"
mapscript_wrap.c:640: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:641: warning: return makes integer from pointer without a cast
mapscript_wrap.c:642: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:644: warning: return makes integer from pointer without a cast
mapscript_wrap.c:645: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:646: error: parse error before "result"
mapscript_wrap.c:653: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayInFloat':
mapscript_wrap.c:655: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:655: error: parse error before "sz"
mapscript_wrap.c:656: error: `input' undeclared (first use in this function)
mapscript_wrap.c:657: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:660: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:661: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:664: error: `carr' undeclared (first use in this function)
mapscript_wrap.c:674: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayArgoutFloat':
mapscript_wrap.c:676: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:676: error: parse error before "sz"
mapscript_wrap.c:677: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:678: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:678: error: `jfloat' undeclared (first use in this function)
mapscript_wrap.c:678: error: parse error before "carr"
mapscript_wrap.c:679: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:679: error: `input' undeclared (first use in this function)
mapscript_wrap.c:682: error: parse error before "SWIG_JavaArrayOutFloat"
mapscript_wrap.c:682: error: parse error before '*' token
mapscript_wrap.c:682: warning: return type defaults to `int'
mapscript_wrap.c: In function `SWIG_JavaArrayOutFloat':
mapscript_wrap.c:683: error: `jfloat' undeclared (first use in this function)
mapscript_wrap.c:683: error: `arr' undeclared (first use in this function)
mapscript_wrap.c:685: error: `jfloatArray' undeclared (first use in this function)
mapscript_wrap.c:685: error: parse error before "jresult"
mapscript_wrap.c:686: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:687: warning: return makes integer from pointer without a cast
mapscript_wrap.c:688: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:690: warning: return makes integer from pointer without a cast
mapscript_wrap.c:691: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:692: error: parse error before "result"
mapscript_wrap.c:699: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayInDouble':
mapscript_wrap.c:701: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:701: error: parse error before "sz"
mapscript_wrap.c:702: error: `input' undeclared (first use in this function)
mapscript_wrap.c:703: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:706: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:707: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:710: error: `carr' undeclared (first use in this function)
mapscript_wrap.c:720: error: parse error before '*' token
mapscript_wrap.c: In function `SWIG_JavaArrayArgoutDouble':
mapscript_wrap.c:722: error: `jsize' undeclared (first use in this function)
mapscript_wrap.c:722: error: parse error before "sz"
mapscript_wrap.c:723: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:724: error: `jarr' undeclared (first use in this function)
mapscript_wrap.c:724: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:724: error: parse error before "carr"
mapscript_wrap.c:725: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:725: error: `input' undeclared (first use in this function)
mapscript_wrap.c:728: error: parse error before "SWIG_JavaArrayOutDouble"
mapscript_wrap.c:728: error: parse error before '*' token
mapscript_wrap.c:728: warning: return type defaults to `int'
mapscript_wrap.c: In function `SWIG_JavaArrayOutDouble':
mapscript_wrap.c:729: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:729: error: `arr' undeclared (first use in this function)
mapscript_wrap.c:731: error: `jdoubleArray' undeclared (first use in this function)
mapscript_wrap.c:731: error: parse error before "jresult"
mapscript_wrap.c:732: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:733: warning: return makes integer from pointer without a cast
mapscript_wrap.c:734: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:736: warning: return makes integer from pointer without a cast
mapscript_wrap.c:737: error: `sz' undeclared (first use in this function)
mapscript_wrap.c:738: error: parse error before "result"
mapscript_wrap.c:3116: error: parse error before "jlong"
mapscript_wrap.c:3116: error: parse error before '*' token
mapscript_wrap.c:3116: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1intarray':
mapscript_wrap.c:3117: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:3117: error: parse error before "jresult"
mapscript_wrap.c:3121: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3122: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3123: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:3126: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3131: error: syntax error before "void"
mapscript_wrap.c:3131: error: parse error before '*' token
mapscript_wrap.c:3131: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1intarray':
mapscript_wrap.c:3134: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3135: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3136: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:3142: error: parse error before "jint"
mapscript_wrap.c:3142: error: parse error before '*' token
mapscript_wrap.c:3142: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_intarray_1getitem':
mapscript_wrap.c:3143: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3143: error: parse error before "jresult"
mapscript_wrap.c:3148: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3149: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3150: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:3151: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:3154: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3154: error: parse error before "result"
mapscript_wrap.c:3159: error: syntax error before "void"
mapscript_wrap.c:3159: error: parse error before '*' token
mapscript_wrap.c:3159: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_intarray_1setitem':
mapscript_wrap.c:3164: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3165: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3166: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:3167: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:3168: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:3174: error: parse error before "jlong"
mapscript_wrap.c:3174: error: parse error before '*' token
mapscript_wrap.c:3174: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_intarray_1cast':
mapscript_wrap.c:3175: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:3175: error: parse error before "jresult"
mapscript_wrap.c:3179: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3180: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3181: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:3184: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3189: error: parse error before "jlong"
mapscript_wrap.c:3189: error: parse error before '*' token
mapscript_wrap.c:3189: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_intarray_1frompointer':
mapscript_wrap.c:3190: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:3190: error: parse error before "jresult"
mapscript_wrap.c:3194: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3195: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3196: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:3199: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3204: error: parse error before "jstring"
mapscript_wrap.c:3204: error: parse error before '*' token
mapscript_wrap.c:3204: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1VERSION':
mapscript_wrap.c:3205: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:3205: error: parse error before "jresult"
mapscript_wrap.c:3208: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3209: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3246: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3252: error: parse error before "jint"
mapscript_wrap.c:3252: error: parse error before '*' token
mapscript_wrap.c:3252: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1TRUE':
mapscript_wrap.c:3253: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3253: error: parse error before "jresult"
mapscript_wrap.c:3256: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3257: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3293: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3293: error: parse error before "result"
mapscript_wrap.c:3298: error: parse error before "jint"
mapscript_wrap.c:3298: error: parse error before '*' token
mapscript_wrap.c:3298: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1FALSE':
mapscript_wrap.c:3299: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3299: error: parse error before "jresult"
mapscript_wrap.c:3302: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3303: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3339: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3339: error: parse error before "result"
mapscript_wrap.c:3344: error: parse error before "jint"
mapscript_wrap.c:3344: error: parse error before '*' token
mapscript_wrap.c:3344: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1ON':
mapscript_wrap.c:3345: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3345: error: parse error before "jresult"
mapscript_wrap.c:3348: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3349: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3385: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3385: error: parse error before "result"
mapscript_wrap.c:3390: error: parse error before "jint"
mapscript_wrap.c:3390: error: parse error before '*' token
mapscript_wrap.c:3390: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1OFF':
mapscript_wrap.c:3391: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3391: error: parse error before "jresult"
mapscript_wrap.c:3394: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3395: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3431: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3431: error: parse error before "result"
mapscript_wrap.c:3436: error: parse error before "jint"
mapscript_wrap.c:3436: error: parse error before '*' token
mapscript_wrap.c:3436: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1DEFAULT':
mapscript_wrap.c:3437: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3437: error: parse error before "jresult"
mapscript_wrap.c:3440: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3441: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3477: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3477: error: parse error before "result"
mapscript_wrap.c:3482: error: parse error before "jint"
mapscript_wrap.c:3482: error: parse error before '*' token
mapscript_wrap.c:3482: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1EMBED':
mapscript_wrap.c:3483: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3483: error: parse error before "jresult"
mapscript_wrap.c:3486: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3487: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3523: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3523: error: parse error before "result"
mapscript_wrap.c:3528: error: parse error before "jint"
mapscript_wrap.c:3528: error: parse error before '*' token
mapscript_wrap.c:3528: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1DELETE':
mapscript_wrap.c:3529: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3529: error: parse error before "jresult"
mapscript_wrap.c:3532: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3533: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3569: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3569: error: parse error before "result"
mapscript_wrap.c:3574: error: parse error before "jint"
mapscript_wrap.c:3574: error: parse error before '*' token
mapscript_wrap.c:3574: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1YES':
mapscript_wrap.c:3575: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3575: error: parse error before "jresult"
mapscript_wrap.c:3578: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3579: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3615: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3615: error: parse error before "result"
mapscript_wrap.c:3620: error: parse error before "jint"
mapscript_wrap.c:3620: error: parse error before '*' token
mapscript_wrap.c:3620: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1NO':
mapscript_wrap.c:3621: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3621: error: parse error before "jresult"
mapscript_wrap.c:3624: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3625: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3661: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3661: error: parse error before "result"
mapscript_wrap.c:3666: error: parse error before "jint"
mapscript_wrap.c:3666: error: parse error before '*' token
mapscript_wrap.c:3666: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SINGLE':
mapscript_wrap.c:3667: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3667: error: parse error before "jresult"
mapscript_wrap.c:3670: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3671: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3707: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3707: error: parse error before "result"
mapscript_wrap.c:3712: error: parse error before "jint"
mapscript_wrap.c:3712: error: parse error before '*' token
mapscript_wrap.c:3712: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1MULTIPLE':
mapscript_wrap.c:3713: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3713: error: parse error before "jresult"
mapscript_wrap.c:3716: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3717: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3753: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3753: error: parse error before "result"
mapscript_wrap.c:3758: error: parse error before "jint"
mapscript_wrap.c:3758: error: parse error before '*' token
mapscript_wrap.c:3758: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1GD_1ALPHA':
mapscript_wrap.c:3759: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3759: error: parse error before "jresult"
mapscript_wrap.c:3762: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3763: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3799: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3799: error: parse error before "result"
mapscript_wrap.c:3804: error: parse error before "jstring"
mapscript_wrap.c:3804: error: parse error before '*' token
mapscript_wrap.c:3804: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1fontSetObj_1filename':
mapscript_wrap.c:3805: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:3805: error: parse error before "jresult"
mapscript_wrap.c:3809: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3810: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3811: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:3815: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3821: error: parse error before "jint"
mapscript_wrap.c:3821: error: parse error before '*' token
mapscript_wrap.c:3821: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1fontSetObj_1numfonts':
mapscript_wrap.c:3822: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:3822: error: parse error before "jresult"
mapscript_wrap.c:3826: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3827: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3828: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:3831: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3831: error: parse error before "result"
mapscript_wrap.c:3836: error: syntax error before "void"
mapscript_wrap.c:3836: error: parse error before '*' token
mapscript_wrap.c:3836: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1fontSetObj_1fonts':
mapscript_wrap.c:3840: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3841: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3842: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:3843: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:3849: error: parse error before "jlong"
mapscript_wrap.c:3849: error: parse error before '*' token
mapscript_wrap.c:3849: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1fontSetObj_1fonts':
mapscript_wrap.c:3850: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:3850: error: parse error before "jresult"
mapscript_wrap.c:3854: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3855: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3856: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:3859: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3864: error: parse error before "jlong"
mapscript_wrap.c:3864: error: parse error before '*' token
mapscript_wrap.c:3864: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1fontSetObj':
mapscript_wrap.c:3865: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:3865: error: parse error before "jresult"
mapscript_wrap.c:3868: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3869: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3905: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:3910: error: syntax error before "void"
mapscript_wrap.c:3910: error: parse error before '*' token
mapscript_wrap.c:3910: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1fontSetObj':
mapscript_wrap.c:3913: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3914: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3915: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:3954: error: syntax error before "void"
mapscript_wrap.c:3954: error: parse error before '*' token
mapscript_wrap.c:3954: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1name':
mapscript_wrap.c:3958: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3959: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3960: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:3963: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:3965: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:3983: error: parse error before "jstring"
mapscript_wrap.c:3983: error: parse error before '*' token
mapscript_wrap.c:3983: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1name':
mapscript_wrap.c:3984: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:3984: error: parse error before "jresult"
mapscript_wrap.c:3988: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:3989: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:3990: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:3994: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4000: error: syntax error before "void"
mapscript_wrap.c:4000: error: parse error before '*' token
mapscript_wrap.c:4000: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1mimetype':
mapscript_wrap.c:4004: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4005: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4006: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4009: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4011: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:4029: error: parse error before "jstring"
mapscript_wrap.c:4029: error: parse error before '*' token
mapscript_wrap.c:4029: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1mimetype':
mapscript_wrap.c:4030: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:4030: error: parse error before "jresult"
mapscript_wrap.c:4034: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4035: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4036: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4040: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4046: error: syntax error before "void"
mapscript_wrap.c:4046: error: parse error before '*' token
mapscript_wrap.c:4046: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1driver':
mapscript_wrap.c:4050: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4051: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4052: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4055: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4057: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:4075: error: parse error before "jstring"
mapscript_wrap.c:4075: error: parse error before '*' token
mapscript_wrap.c:4075: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1driver':
mapscript_wrap.c:4076: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:4076: error: parse error before "jresult"
mapscript_wrap.c:4080: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4081: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4082: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4086: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4092: error: syntax error before "void"
mapscript_wrap.c:4092: error: parse error before '*' token
mapscript_wrap.c:4092: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1extension':
mapscript_wrap.c:4096: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4097: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4098: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4101: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4103: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:4121: error: parse error before "jstring"
mapscript_wrap.c:4121: error: parse error before '*' token
mapscript_wrap.c:4121: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1extension':
mapscript_wrap.c:4122: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:4122: error: parse error before "jresult"
mapscript_wrap.c:4126: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4127: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4128: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4132: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4138: error: syntax error before "void"
mapscript_wrap.c:4138: error: parse error before '*' token
mapscript_wrap.c:4138: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1renderer':
mapscript_wrap.c:4142: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4143: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4144: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4145: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4151: error: parse error before "jint"
mapscript_wrap.c:4151: error: parse error before '*' token
mapscript_wrap.c:4151: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1renderer':
mapscript_wrap.c:4152: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4152: error: parse error before "jresult"
mapscript_wrap.c:4156: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4157: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4158: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4161: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4161: error: parse error before "result"
mapscript_wrap.c:4166: error: syntax error before "void"
mapscript_wrap.c:4166: error: parse error before '*' token
mapscript_wrap.c:4166: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1imagemode':
mapscript_wrap.c:4170: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4171: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4172: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4173: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4179: error: parse error before "jint"
mapscript_wrap.c:4179: error: parse error before '*' token
mapscript_wrap.c:4179: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1imagemode':
mapscript_wrap.c:4180: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4180: error: parse error before "jresult"
mapscript_wrap.c:4184: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4185: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4186: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4189: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4189: error: parse error before "result"
mapscript_wrap.c:4194: error: syntax error before "void"
mapscript_wrap.c:4194: error: parse error before '*' token
mapscript_wrap.c:4194: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1transparent':
mapscript_wrap.c:4198: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4199: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4200: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4201: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4207: error: parse error before "jint"
mapscript_wrap.c:4207: error: parse error before '*' token
mapscript_wrap.c:4207: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1transparent':
mapscript_wrap.c:4208: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4208: error: parse error before "jresult"
mapscript_wrap.c:4212: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4213: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4214: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4217: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4217: error: parse error before "result"
mapscript_wrap.c:4222: error: syntax error before "void"
mapscript_wrap.c:4222: error: parse error before '*' token
mapscript_wrap.c:4222: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1bands':
mapscript_wrap.c:4226: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4227: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4228: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4229: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4235: error: parse error before "jint"
mapscript_wrap.c:4235: error: parse error before '*' token
mapscript_wrap.c:4235: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1bands':
mapscript_wrap.c:4236: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4236: error: parse error before "jresult"
mapscript_wrap.c:4240: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4241: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4242: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4245: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4245: error: parse error before "result"
mapscript_wrap.c:4250: error: syntax error before "void"
mapscript_wrap.c:4250: error: parse error before '*' token
mapscript_wrap.c:4250: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1numformatoptions':
mapscript_wrap.c:4254: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4255: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4256: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4257: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4263: error: parse error before "jint"
mapscript_wrap.c:4263: error: parse error before '*' token
mapscript_wrap.c:4263: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1numformatoptions':
mapscript_wrap.c:4264: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4264: error: parse error before "jresult"
mapscript_wrap.c:4268: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4269: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4270: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4273: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4273: error: parse error before "result"
mapscript_wrap.c:4278: error: syntax error before "void"
mapscript_wrap.c:4278: error: parse error before '*' token
mapscript_wrap.c:4278: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1formatoptions':
mapscript_wrap.c:4282: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4283: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4284: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4285: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4291: error: parse error before "jlong"
mapscript_wrap.c:4291: error: parse error before '*' token
mapscript_wrap.c:4291: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1formatoptions':
mapscript_wrap.c:4292: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:4292: error: parse error before "jresult"
mapscript_wrap.c:4296: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4297: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4298: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4301: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4306: error: syntax error before "void"
mapscript_wrap.c:4306: error: parse error before '*' token
mapscript_wrap.c:4306: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1refcount':
mapscript_wrap.c:4310: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4311: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4312: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4313: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4319: error: parse error before "jint"
mapscript_wrap.c:4319: error: parse error before '*' token
mapscript_wrap.c:4319: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1refcount':
mapscript_wrap.c:4320: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4320: error: parse error before "jresult"
mapscript_wrap.c:4324: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4325: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4326: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4329: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4329: error: parse error before "result"
mapscript_wrap.c:4334: error: syntax error before "void"
mapscript_wrap.c:4334: error: parse error before '*' token
mapscript_wrap.c:4334: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1inmapfile':
mapscript_wrap.c:4338: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4339: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4340: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4341: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4347: error: parse error before "jint"
mapscript_wrap.c:4347: error: parse error before '*' token
mapscript_wrap.c:4347: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1inmapfile':
mapscript_wrap.c:4348: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4348: error: parse error before "jresult"
mapscript_wrap.c:4352: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4353: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4354: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4357: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4357: error: parse error before "result"
mapscript_wrap.c:4362: error: parse error before "jlong"
mapscript_wrap.c:4362: error: parse error before '*' token
mapscript_wrap.c:4362: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1outputFormatObj':
mapscript_wrap.c:4363: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:4363: error: parse error before "jresult"
mapscript_wrap.c:4368: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4369: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4372: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4379: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4419: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c: At top level:
mapscript_wrap.c:4430: error: syntax error before "void"
mapscript_wrap.c:4430: error: parse error before '*' token
mapscript_wrap.c:4430: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1outputFormatObj':
mapscript_wrap.c:4433: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4434: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4435: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4474: error: syntax error before "void"
mapscript_wrap.c:4474: error: parse error before '*' token
mapscript_wrap.c:4474: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_outputFormatObj_1setOption':
mapscript_wrap.c:4479: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4480: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4481: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4484: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4486: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:4491: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:4493: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:4540: error: parse error before "jint"
mapscript_wrap.c:4540: error: parse error before '*' token
mapscript_wrap.c:4540: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_outputFormatObj_1validate':
mapscript_wrap.c:4541: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4541: error: parse error before "jresult"
mapscript_wrap.c:4545: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4546: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4547: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4583: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4583: error: parse error before "result"
mapscript_wrap.c:4588: error: parse error before "jstring"
mapscript_wrap.c:4588: error: parse error before '*' token
mapscript_wrap.c:4588: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_outputFormatObj_1getOption':
mapscript_wrap.c:4589: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:4589: error: parse error before "jresult"
mapscript_wrap.c:4595: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4596: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4597: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4600: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4607: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:4648: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4661: error: parse error before "jint"
mapscript_wrap.c:4661: error: parse error before '*' token
mapscript_wrap.c:4661: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1NOOVERRIDE':
mapscript_wrap.c:4662: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4662: error: parse error before "jresult"
mapscript_wrap.c:4665: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4666: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4702: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4702: error: parse error before "result"
mapscript_wrap.c:4707: error: syntax error before "void"
mapscript_wrap.c:4707: error: parse error before '*' token
mapscript_wrap.c:4707: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1queryMapObj_1height':
mapscript_wrap.c:4711: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4712: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4713: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4714: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4720: error: parse error before "jint"
mapscript_wrap.c:4720: error: parse error before '*' token
mapscript_wrap.c:4720: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1queryMapObj_1height':
mapscript_wrap.c:4721: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4721: error: parse error before "jresult"
mapscript_wrap.c:4725: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4726: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4727: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4730: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4730: error: parse error before "result"
mapscript_wrap.c:4735: error: syntax error before "void"
mapscript_wrap.c:4735: error: parse error before '*' token
mapscript_wrap.c:4735: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1queryMapObj_1width':
mapscript_wrap.c:4739: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4740: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4741: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4742: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4748: error: parse error before "jint"
mapscript_wrap.c:4748: error: parse error before '*' token
mapscript_wrap.c:4748: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1queryMapObj_1width':
mapscript_wrap.c:4749: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4749: error: parse error before "jresult"
mapscript_wrap.c:4753: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4754: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4755: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4758: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4758: error: parse error before "result"
mapscript_wrap.c:4763: error: syntax error before "void"
mapscript_wrap.c:4763: error: parse error before '*' token
mapscript_wrap.c:4763: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1queryMapObj_1status':
mapscript_wrap.c:4767: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4768: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4769: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4770: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4776: error: parse error before "jint"
mapscript_wrap.c:4776: error: parse error before '*' token
mapscript_wrap.c:4776: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1queryMapObj_1status':
mapscript_wrap.c:4777: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4777: error: parse error before "jresult"
mapscript_wrap.c:4781: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4782: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4783: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4786: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4786: error: parse error before "result"
mapscript_wrap.c:4791: error: syntax error before "void"
mapscript_wrap.c:4791: error: parse error before '*' token
mapscript_wrap.c:4791: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1queryMapObj_1style':
mapscript_wrap.c:4795: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4796: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4797: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4798: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4804: error: parse error before "jint"
mapscript_wrap.c:4804: error: parse error before '*' token
mapscript_wrap.c:4804: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1queryMapObj_1style':
mapscript_wrap.c:4805: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4805: error: parse error before "jresult"
mapscript_wrap.c:4809: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4810: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4811: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4814: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4814: error: parse error before "result"
mapscript_wrap.c:4819: error: syntax error before "void"
mapscript_wrap.c:4819: error: parse error before '*' token
mapscript_wrap.c:4819: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1queryMapObj_1color':
mapscript_wrap.c:4823: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4824: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4825: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4826: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4832: error: parse error before "jlong"
mapscript_wrap.c:4832: error: parse error before '*' token
mapscript_wrap.c:4832: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1queryMapObj_1color':
mapscript_wrap.c:4833: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:4833: error: parse error before "jresult"
mapscript_wrap.c:4837: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4838: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4839: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4842: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4847: error: parse error before "jlong"
mapscript_wrap.c:4847: error: parse error before '*' token
mapscript_wrap.c:4847: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1queryMapObj':
mapscript_wrap.c:4848: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:4848: error: parse error before "jresult"
mapscript_wrap.c:4851: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4852: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4888: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4893: error: syntax error before "void"
mapscript_wrap.c:4893: error: parse error before '*' token
mapscript_wrap.c:4893: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1queryMapObj':
mapscript_wrap.c:4896: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4897: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4898: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4937: error: syntax error before "void"
mapscript_wrap.c:4937: error: parse error before '*' token
mapscript_wrap.c:4937: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1font':
mapscript_wrap.c:4941: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4942: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4943: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4946: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4948: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:4966: error: parse error before "jstring"
mapscript_wrap.c:4966: error: parse error before '*' token
mapscript_wrap.c:4966: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1font':
mapscript_wrap.c:4967: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:4967: error: parse error before "jresult"
mapscript_wrap.c:4971: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4972: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4973: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4977: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:4983: error: syntax error before "void"
mapscript_wrap.c:4983: error: parse error before '*' token
mapscript_wrap.c:4983: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1type':
mapscript_wrap.c:4987: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:4988: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:4989: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:4990: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:4996: error: parse error before "jint"
mapscript_wrap.c:4996: error: parse error before '*' token
mapscript_wrap.c:4996: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1type':
mapscript_wrap.c:4997: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:4997: error: parse error before "jresult"
mapscript_wrap.c:5001: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5002: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5003: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5006: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5006: error: parse error before "result"
mapscript_wrap.c:5011: error: syntax error before "void"
mapscript_wrap.c:5011: error: parse error before '*' token
mapscript_wrap.c:5011: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1color':
mapscript_wrap.c:5015: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5016: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5017: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5018: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5024: error: parse error before "jlong"
mapscript_wrap.c:5024: error: parse error before '*' token
mapscript_wrap.c:5024: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1color':
mapscript_wrap.c:5025: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:5025: error: parse error before "jresult"
mapscript_wrap.c:5029: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5030: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5031: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5034: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5039: error: syntax error before "void"
mapscript_wrap.c:5039: error: parse error before '*' token
mapscript_wrap.c:5039: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1outlinecolor':
mapscript_wrap.c:5043: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5044: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5045: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5046: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5052: error: parse error before "jlong"
mapscript_wrap.c:5052: error: parse error before '*' token
mapscript_wrap.c:5052: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1outlinecolor':
mapscript_wrap.c:5053: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:5053: error: parse error before "jresult"
mapscript_wrap.c:5057: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5058: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5059: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5062: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5067: error: syntax error before "void"
mapscript_wrap.c:5067: error: parse error before '*' token
mapscript_wrap.c:5067: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1shadowcolor':
mapscript_wrap.c:5071: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5072: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5073: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5074: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5080: error: parse error before "jlong"
mapscript_wrap.c:5080: error: parse error before '*' token
mapscript_wrap.c:5080: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1shadowcolor':
mapscript_wrap.c:5081: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:5081: error: parse error before "jresult"
mapscript_wrap.c:5085: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5086: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5087: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5090: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5095: error: syntax error before "void"
mapscript_wrap.c:5095: error: parse error before '*' token
mapscript_wrap.c:5095: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1shadowsizex':
mapscript_wrap.c:5099: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5100: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5101: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5102: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5108: error: parse error before "jint"
mapscript_wrap.c:5108: error: parse error before '*' token
mapscript_wrap.c:5108: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1shadowsizex':
mapscript_wrap.c:5109: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5109: error: parse error before "jresult"
mapscript_wrap.c:5113: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5114: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5115: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5118: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5118: error: parse error before "result"
mapscript_wrap.c:5123: error: syntax error before "void"
mapscript_wrap.c:5123: error: parse error before '*' token
mapscript_wrap.c:5123: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1shadowsizey':
mapscript_wrap.c:5127: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5128: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5129: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5130: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5136: error: parse error before "jint"
mapscript_wrap.c:5136: error: parse error before '*' token
mapscript_wrap.c:5136: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1shadowsizey':
mapscript_wrap.c:5137: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5137: error: parse error before "jresult"
mapscript_wrap.c:5141: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5142: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5143: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5146: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5146: error: parse error before "result"
mapscript_wrap.c:5151: error: syntax error before "void"
mapscript_wrap.c:5151: error: parse error before '*' token
mapscript_wrap.c:5151: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1backgroundcolor':
mapscript_wrap.c:5155: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5156: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5157: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5158: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5164: error: parse error before "jlong"
mapscript_wrap.c:5164: error: parse error before '*' token
mapscript_wrap.c:5164: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1backgroundcolor':
mapscript_wrap.c:5165: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:5165: error: parse error before "jresult"
mapscript_wrap.c:5169: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5170: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5171: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5174: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5179: error: syntax error before "void"
mapscript_wrap.c:5179: error: parse error before '*' token
mapscript_wrap.c:5179: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1backgroundshadowcolor':
mapscript_wrap.c:5183: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5184: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5185: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5186: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5192: error: parse error before "jlong"
mapscript_wrap.c:5192: error: parse error before '*' token
mapscript_wrap.c:5192: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1backgroundshadowcolor':
mapscript_wrap.c:5193: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:5193: error: parse error before "jresult"
mapscript_wrap.c:5197: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5198: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5199: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5202: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5207: error: syntax error before "void"
mapscript_wrap.c:5207: error: parse error before '*' token
mapscript_wrap.c:5207: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1backgroundshadowsizex':
mapscript_wrap.c:5211: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5212: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5213: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5214: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5220: error: parse error before "jint"
mapscript_wrap.c:5220: error: parse error before '*' token
mapscript_wrap.c:5220: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1backgroundshadowsizex':
mapscript_wrap.c:5221: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5221: error: parse error before "jresult"
mapscript_wrap.c:5225: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5226: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5227: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5230: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5230: error: parse error before "result"
mapscript_wrap.c:5235: error: syntax error before "void"
mapscript_wrap.c:5235: error: parse error before '*' token
mapscript_wrap.c:5235: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1backgroundshadowsizey':
mapscript_wrap.c:5239: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5240: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5241: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5242: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5248: error: parse error before "jint"
mapscript_wrap.c:5248: error: parse error before '*' token
mapscript_wrap.c:5248: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1backgroundshadowsizey':
mapscript_wrap.c:5249: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5249: error: parse error before "jresult"
mapscript_wrap.c:5253: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5254: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5255: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5258: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5258: error: parse error before "result"
mapscript_wrap.c:5263: error: syntax error before "void"
mapscript_wrap.c:5263: error: parse error before '*' token
mapscript_wrap.c:5263: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1size':
mapscript_wrap.c:5267: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5268: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5269: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5270: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5276: error: parse error before "jint"
mapscript_wrap.c:5276: error: parse error before '*' token
mapscript_wrap.c:5276: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1size':
mapscript_wrap.c:5277: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5277: error: parse error before "jresult"
mapscript_wrap.c:5281: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5282: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5283: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5286: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5286: error: parse error before "result"
mapscript_wrap.c:5291: error: syntax error before "void"
mapscript_wrap.c:5291: error: parse error before '*' token
mapscript_wrap.c:5291: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1minsize':
mapscript_wrap.c:5295: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5296: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5297: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5298: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5304: error: parse error before "jint"
mapscript_wrap.c:5304: error: parse error before '*' token
mapscript_wrap.c:5304: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1minsize':
mapscript_wrap.c:5305: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5305: error: parse error before "jresult"
mapscript_wrap.c:5309: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5310: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5311: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5314: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5314: error: parse error before "result"
mapscript_wrap.c:5319: error: syntax error before "void"
mapscript_wrap.c:5319: error: parse error before '*' token
mapscript_wrap.c:5319: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1maxsize':
mapscript_wrap.c:5323: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5324: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5325: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5326: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5332: error: parse error before "jint"
mapscript_wrap.c:5332: error: parse error before '*' token
mapscript_wrap.c:5332: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1maxsize':
mapscript_wrap.c:5333: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5333: error: parse error before "jresult"
mapscript_wrap.c:5337: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5338: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5339: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5342: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5342: error: parse error before "result"
mapscript_wrap.c:5347: error: syntax error before "void"
mapscript_wrap.c:5347: error: parse error before '*' token
mapscript_wrap.c:5347: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1position':
mapscript_wrap.c:5351: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5352: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5353: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5354: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5360: error: parse error before "jint"
mapscript_wrap.c:5360: error: parse error before '*' token
mapscript_wrap.c:5360: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1position':
mapscript_wrap.c:5361: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5361: error: parse error before "jresult"
mapscript_wrap.c:5365: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5366: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5367: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5370: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5370: error: parse error before "result"
mapscript_wrap.c:5375: error: syntax error before "void"
mapscript_wrap.c:5375: error: parse error before '*' token
mapscript_wrap.c:5375: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1offsetx':
mapscript_wrap.c:5379: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5380: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5381: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5382: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5388: error: parse error before "jint"
mapscript_wrap.c:5388: error: parse error before '*' token
mapscript_wrap.c:5388: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1offsetx':
mapscript_wrap.c:5389: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5389: error: parse error before "jresult"
mapscript_wrap.c:5393: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5394: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5395: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5398: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5398: error: parse error before "result"
mapscript_wrap.c:5403: error: syntax error before "void"
mapscript_wrap.c:5403: error: parse error before '*' token
mapscript_wrap.c:5403: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1offsety':
mapscript_wrap.c:5407: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5408: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5409: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5410: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5416: error: parse error before "jint"
mapscript_wrap.c:5416: error: parse error before '*' token
mapscript_wrap.c:5416: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1offsety':
mapscript_wrap.c:5417: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5417: error: parse error before "jresult"
mapscript_wrap.c:5421: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5422: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5423: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5426: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5426: error: parse error before "result"
mapscript_wrap.c:5431: error: syntax error before "void"
mapscript_wrap.c:5431: error: parse error before '*' token
mapscript_wrap.c:5431: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1angle':
mapscript_wrap.c:5435: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5436: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5437: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5438: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5444: error: parse error before "jdouble"
mapscript_wrap.c:5444: error: parse error before '*' token
mapscript_wrap.c:5444: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1angle':
mapscript_wrap.c:5445: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:5445: error: parse error before "jresult"
mapscript_wrap.c:5449: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5450: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5451: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5454: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5454: error: parse error before "result"
mapscript_wrap.c:5459: error: syntax error before "void"
mapscript_wrap.c:5459: error: parse error before '*' token
mapscript_wrap.c:5459: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1autoangle':
mapscript_wrap.c:5463: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5464: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5465: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5466: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5472: error: parse error before "jint"
mapscript_wrap.c:5472: error: parse error before '*' token
mapscript_wrap.c:5472: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1autoangle':
mapscript_wrap.c:5473: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5473: error: parse error before "jresult"
mapscript_wrap.c:5477: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5478: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5479: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5482: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5482: error: parse error before "result"
mapscript_wrap.c:5487: error: syntax error before "void"
mapscript_wrap.c:5487: error: parse error before '*' token
mapscript_wrap.c:5487: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1buffer':
mapscript_wrap.c:5491: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5492: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5493: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5494: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5500: error: parse error before "jint"
mapscript_wrap.c:5500: error: parse error before '*' token
mapscript_wrap.c:5500: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1buffer':
mapscript_wrap.c:5501: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5501: error: parse error before "jresult"
mapscript_wrap.c:5505: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5506: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5507: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5510: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5510: error: parse error before "result"
mapscript_wrap.c:5515: error: syntax error before "void"
mapscript_wrap.c:5515: error: parse error before '*' token
mapscript_wrap.c:5515: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1antialias':
mapscript_wrap.c:5519: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5520: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5521: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5522: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5528: error: parse error before "jint"
mapscript_wrap.c:5528: error: parse error before '*' token
mapscript_wrap.c:5528: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1antialias':
mapscript_wrap.c:5529: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5529: error: parse error before "jresult"
mapscript_wrap.c:5533: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5534: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5535: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5538: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5538: error: parse error before "result"
mapscript_wrap.c:5543: error: syntax error before "void"
mapscript_wrap.c:5543: error: parse error before '*' token
mapscript_wrap.c:5543: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1wrap':
mapscript_wrap.c:5547: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5548: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5549: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5550: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5556: error: parse error before "jchar"
mapscript_wrap.c:5556: error: parse error before '*' token
mapscript_wrap.c:5556: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1wrap':
mapscript_wrap.c:5557: error: `jchar' undeclared (first use in this function)
mapscript_wrap.c:5557: error: parse error before "jresult"
mapscript_wrap.c:5561: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5562: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5563: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5566: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5566: error: parse error before "result"
mapscript_wrap.c:5571: error: syntax error before "void"
mapscript_wrap.c:5571: error: parse error before '*' token
mapscript_wrap.c:5571: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1minfeaturesize':
mapscript_wrap.c:5575: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5576: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5577: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5578: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5584: error: parse error before "jint"
mapscript_wrap.c:5584: error: parse error before '*' token
mapscript_wrap.c:5584: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1minfeaturesize':
mapscript_wrap.c:5585: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5585: error: parse error before "jresult"
mapscript_wrap.c:5589: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5590: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5591: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5594: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5594: error: parse error before "result"
mapscript_wrap.c:5599: error: syntax error before "void"
mapscript_wrap.c:5599: error: parse error before '*' token
mapscript_wrap.c:5599: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1autominfeaturesize':
mapscript_wrap.c:5603: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5604: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5605: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5606: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5612: error: parse error before "jint"
mapscript_wrap.c:5612: error: parse error before '*' token
mapscript_wrap.c:5612: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1autominfeaturesize':
mapscript_wrap.c:5613: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5613: error: parse error before "jresult"
mapscript_wrap.c:5617: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5618: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5619: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5622: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5622: error: parse error before "result"
mapscript_wrap.c:5627: error: syntax error before "void"
mapscript_wrap.c:5627: error: parse error before '*' token
mapscript_wrap.c:5627: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1mindistance':
mapscript_wrap.c:5631: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5632: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5633: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5634: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5640: error: parse error before "jint"
mapscript_wrap.c:5640: error: parse error before '*' token
mapscript_wrap.c:5640: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1mindistance':
mapscript_wrap.c:5641: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5641: error: parse error before "jresult"
mapscript_wrap.c:5645: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5646: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5647: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5650: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5650: error: parse error before "result"
mapscript_wrap.c:5655: error: syntax error before "void"
mapscript_wrap.c:5655: error: parse error before '*' token
mapscript_wrap.c:5655: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1partials':
mapscript_wrap.c:5659: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5660: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5661: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5662: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5668: error: parse error before "jint"
mapscript_wrap.c:5668: error: parse error before '*' token
mapscript_wrap.c:5668: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1partials':
mapscript_wrap.c:5669: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5669: error: parse error before "jresult"
mapscript_wrap.c:5673: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5674: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5675: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5678: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5678: error: parse error before "result"
mapscript_wrap.c:5683: error: syntax error before "void"
mapscript_wrap.c:5683: error: parse error before '*' token
mapscript_wrap.c:5683: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1force':
mapscript_wrap.c:5687: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5688: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5689: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5690: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5696: error: parse error before "jint"
mapscript_wrap.c:5696: error: parse error before '*' token
mapscript_wrap.c:5696: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1force':
mapscript_wrap.c:5697: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:5697: error: parse error before "jresult"
mapscript_wrap.c:5701: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5702: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5703: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5706: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5706: error: parse error before "result"
mapscript_wrap.c:5711: error: syntax error before "void"
mapscript_wrap.c:5711: error: parse error before '*' token
mapscript_wrap.c:5711: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1encoding':
mapscript_wrap.c:5715: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5716: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5717: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5720: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5722: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:5740: error: parse error before "jstring"
mapscript_wrap.c:5740: error: parse error before '*' token
mapscript_wrap.c:5740: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1encoding':
mapscript_wrap.c:5741: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:5741: error: parse error before "jresult"
mapscript_wrap.c:5745: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5746: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5747: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5751: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5757: error: parse error before "jlong"
mapscript_wrap.c:5757: error: parse error before '*' token
mapscript_wrap.c:5757: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1labelObj':
mapscript_wrap.c:5758: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:5758: error: parse error before "jresult"
mapscript_wrap.c:5761: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5762: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5798: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5803: error: syntax error before "void"
mapscript_wrap.c:5803: error: parse error before '*' token
mapscript_wrap.c:5803: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1labelObj':
mapscript_wrap.c:5806: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5807: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5808: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5847: error: syntax error before "void"
mapscript_wrap.c:5847: error: parse error before '*' token
mapscript_wrap.c:5847: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1log':
mapscript_wrap.c:5851: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5852: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5853: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5856: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5858: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:5876: error: parse error before "jstring"
mapscript_wrap.c:5876: error: parse error before '*' token
mapscript_wrap.c:5876: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1log':
mapscript_wrap.c:5877: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:5877: error: parse error before "jresult"
mapscript_wrap.c:5881: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5882: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5883: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5887: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5893: error: syntax error before "void"
mapscript_wrap.c:5893: error: parse error before '*' token
mapscript_wrap.c:5893: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1imagepath':
mapscript_wrap.c:5897: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5898: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5899: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5902: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5904: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:5922: error: parse error before "jstring"
mapscript_wrap.c:5922: error: parse error before '*' token
mapscript_wrap.c:5922: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1imagepath':
mapscript_wrap.c:5923: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:5923: error: parse error before "jresult"
mapscript_wrap.c:5927: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5928: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5929: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5933: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5939: error: syntax error before "void"
mapscript_wrap.c:5939: error: parse error before '*' token
mapscript_wrap.c:5939: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1imageurl':
mapscript_wrap.c:5943: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5944: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5945: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5948: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5950: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:5968: error: parse error before "jstring"
mapscript_wrap.c:5968: error: parse error before '*' token
mapscript_wrap.c:5968: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1imageurl':
mapscript_wrap.c:5969: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:5969: error: parse error before "jresult"
mapscript_wrap.c:5973: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5974: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5975: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5979: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:5985: error: syntax error before "void"
mapscript_wrap.c:5985: error: parse error before '*' token
mapscript_wrap.c:5985: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1map':
mapscript_wrap.c:5989: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:5990: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:5991: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:5992: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:5998: error: parse error before "jlong"
mapscript_wrap.c:5998: error: parse error before '*' token
mapscript_wrap.c:5998: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1map':
mapscript_wrap.c:5999: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:5999: error: parse error before "jresult"
mapscript_wrap.c:6003: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6004: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6005: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6008: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6013: error: syntax error before "void"
mapscript_wrap.c:6013: error: parse error before '*' token
mapscript_wrap.c:6013: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1template':
mapscript_wrap.c:6017: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6018: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6019: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6022: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6024: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:6042: error: parse error before "jstring"
mapscript_wrap.c:6042: error: parse error before '*' token
mapscript_wrap.c:6042: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1template':
mapscript_wrap.c:6043: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:6043: error: parse error before "jresult"
mapscript_wrap.c:6047: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6048: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6049: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6053: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6059: error: syntax error before "void"
mapscript_wrap.c:6059: error: parse error before '*' token
mapscript_wrap.c:6059: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1header':
mapscript_wrap.c:6063: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6064: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6065: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6068: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6070: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:6088: error: parse error before "jstring"
mapscript_wrap.c:6088: error: parse error before '*' token
mapscript_wrap.c:6088: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1header':
mapscript_wrap.c:6089: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:6089: error: parse error before "jresult"
mapscript_wrap.c:6093: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6094: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6095: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6099: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6105: error: syntax error before "void"
mapscript_wrap.c:6105: error: parse error before '*' token
mapscript_wrap.c:6105: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1footer':
mapscript_wrap.c:6109: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6110: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6111: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6114: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6116: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:6134: error: parse error before "jstring"
mapscript_wrap.c:6134: error: parse error before '*' token
mapscript_wrap.c:6134: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1footer':
mapscript_wrap.c:6135: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:6135: error: parse error before "jresult"
mapscript_wrap.c:6139: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6140: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6141: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6145: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c: At top level:
mapscript_wrap.c:6151: error: syntax error before "void"
mapscript_wrap.c:6151: error: parse error before '*' token
mapscript_wrap.c:6151: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1empty':
mapscript_wrap.c:6155: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6156: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6157: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6160: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6162: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:6180: error: parse error before "jstring"
mapscript_wrap.c:6180: error: parse error before '*' token
mapscript_wrap.c:6180: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1empty':
mapscript_wrap.c:6181: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:6181: error: parse error before "jresult"
mapscript_wrap.c:6185: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6186: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6187: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6191: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6197: error: syntax error before "void"
mapscript_wrap.c:6197: error: parse error before '*' token
mapscript_wrap.c:6197: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1error':
mapscript_wrap.c:6201: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6202: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6203: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6206: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6208: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:6226: error: parse error before "jstring"
mapscript_wrap.c:6226: error: parse error before '*' token
mapscript_wrap.c:6226: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1error':
mapscript_wrap.c:6227: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:6227: error: parse error before "jresult"
mapscript_wrap.c:6231: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6232: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6233: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6237: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6243: error: syntax error before "void"
mapscript_wrap.c:6243: error: parse error before '*' token
mapscript_wrap.c:6243: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1extent':
mapscript_wrap.c:6247: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6248: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6249: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6250: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6256: error: parse error before "jlong"
mapscript_wrap.c:6256: error: parse error before '*' token
mapscript_wrap.c:6256: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1extent':
mapscript_wrap.c:6257: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:6257: error: parse error before "jresult"
mapscript_wrap.c:6261: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6262: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6263: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6266: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6271: error: syntax error before "void"
mapscript_wrap.c:6271: error: parse error before '*' token
mapscript_wrap.c:6271: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1minscale':
mapscript_wrap.c:6275: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6276: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6277: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6278: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6284: error: parse error before "jdouble"
mapscript_wrap.c:6284: error: parse error before '*' token
mapscript_wrap.c:6284: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1minscale':
mapscript_wrap.c:6285: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:6285: error: parse error before "jresult"
mapscript_wrap.c:6289: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6290: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6291: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6294: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6294: error: parse error before "result"
mapscript_wrap.c:6299: error: syntax error before "void"
mapscript_wrap.c:6299: error: parse error before '*' token
mapscript_wrap.c:6299: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1maxscale':
mapscript_wrap.c:6303: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6304: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6305: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6306: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6312: error: parse error before "jdouble"
mapscript_wrap.c:6312: error: parse error before '*' token
mapscript_wrap.c:6312: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1maxscale':
mapscript_wrap.c:6313: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:6313: error: parse error before "jresult"
mapscript_wrap.c:6317: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6318: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6319: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6322: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6322: error: parse error before "result"
mapscript_wrap.c:6327: error: syntax error before "void"
mapscript_wrap.c:6327: error: parse error before '*' token
mapscript_wrap.c:6327: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1mintemplate':
mapscript_wrap.c:6331: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6332: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6333: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6336: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6338: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:6356: error: parse error before "jstring"
mapscript_wrap.c:6356: error: parse error before '*' token
mapscript_wrap.c:6356: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1mintemplate':
mapscript_wrap.c:6357: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:6357: error: parse error before "jresult"
mapscript_wrap.c:6361: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6362: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6363: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6367: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6373: error: syntax error before "void"
mapscript_wrap.c:6373: error: parse error before '*' token
mapscript_wrap.c:6373: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1maxtemplate':
mapscript_wrap.c:6377: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6378: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6379: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6382: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6384: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:6402: error: parse error before "jstring"
mapscript_wrap.c:6402: error: parse error before '*' token
mapscript_wrap.c:6402: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1maxtemplate':
mapscript_wrap.c:6403: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:6403: error: parse error before "jresult"
mapscript_wrap.c:6407: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6408: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6409: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6413: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6419: error: syntax error before "void"
mapscript_wrap.c:6419: error: parse error before '*' token
mapscript_wrap.c:6419: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1queryformat':
mapscript_wrap.c:6423: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6424: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6425: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6428: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6430: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:6448: error: parse error before "jstring"
mapscript_wrap.c:6448: error: parse error before '*' token
mapscript_wrap.c:6448: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1queryformat':
mapscript_wrap.c:6449: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:6449: error: parse error before "jresult"
mapscript_wrap.c:6453: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6454: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6455: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6459: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6465: error: syntax error before "void"
mapscript_wrap.c:6465: error: parse error before '*' token
mapscript_wrap.c:6465: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1webObj_1metadata':
mapscript_wrap.c:6469: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6470: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6471: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6472: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6478: error: parse error before "jlong"
mapscript_wrap.c:6478: error: parse error before '*' token
mapscript_wrap.c:6478: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1webObj_1metadata':
mapscript_wrap.c:6479: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:6479: error: parse error before "jresult"
mapscript_wrap.c:6483: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6484: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6485: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6488: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6493: error: parse error before "jlong"
mapscript_wrap.c:6493: error: parse error before '*' token
mapscript_wrap.c:6493: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1webObj':
mapscript_wrap.c:6494: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:6494: error: parse error before "jresult"
mapscript_wrap.c:6497: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6498: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6534: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6539: error: syntax error before "void"
mapscript_wrap.c:6539: error: parse error before '*' token
mapscript_wrap.c:6539: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1webObj':
mapscript_wrap.c:6542: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6543: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6544: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6583: error: syntax error before "void"
mapscript_wrap.c:6583: error: parse error before '*' token
mapscript_wrap.c:6583: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1color':
mapscript_wrap.c:6587: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6588: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6589: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6590: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6596: error: parse error before "jlong"
mapscript_wrap.c:6596: error: parse error before '*' token
mapscript_wrap.c:6596: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1color':
mapscript_wrap.c:6597: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:6597: error: parse error before "jresult"
mapscript_wrap.c:6601: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6602: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6603: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6606: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6611: error: syntax error before "void"
mapscript_wrap.c:6611: error: parse error before '*' token
mapscript_wrap.c:6611: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1backgroundcolor':
mapscript_wrap.c:6615: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6616: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6617: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6618: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6624: error: parse error before "jlong"
mapscript_wrap.c:6624: error: parse error before '*' token
mapscript_wrap.c:6624: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1backgroundcolor':
mapscript_wrap.c:6625: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:6625: error: parse error before "jresult"
mapscript_wrap.c:6629: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6630: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6631: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6634: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6639: error: syntax error before "void"
mapscript_wrap.c:6639: error: parse error before '*' token
mapscript_wrap.c:6639: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1outlinecolor':
mapscript_wrap.c:6643: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6644: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6645: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6646: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6652: error: parse error before "jlong"
mapscript_wrap.c:6652: error: parse error before '*' token
mapscript_wrap.c:6652: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1outlinecolor':
mapscript_wrap.c:6653: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:6653: error: parse error before "jresult"
mapscript_wrap.c:6657: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6658: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6659: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6662: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6667: error: syntax error before "void"
mapscript_wrap.c:6667: error: parse error before '*' token
mapscript_wrap.c:6667: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1mincolor':
mapscript_wrap.c:6671: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6672: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6673: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6674: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6680: error: parse error before "jlong"
mapscript_wrap.c:6680: error: parse error before '*' token
mapscript_wrap.c:6680: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1mincolor':
mapscript_wrap.c:6681: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:6681: error: parse error before "jresult"
mapscript_wrap.c:6685: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6686: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6687: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6690: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6695: error: syntax error before "void"
mapscript_wrap.c:6695: error: parse error before '*' token
mapscript_wrap.c:6695: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1maxcolor':
mapscript_wrap.c:6699: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6700: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6701: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6702: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6708: error: parse error before "jlong"
mapscript_wrap.c:6708: error: parse error before '*' token
mapscript_wrap.c:6708: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1maxcolor':
mapscript_wrap.c:6709: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:6709: error: parse error before "jresult"
mapscript_wrap.c:6713: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6714: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6715: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6718: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6723: error: syntax error before "void"
mapscript_wrap.c:6723: error: parse error before '*' token
mapscript_wrap.c:6723: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1minvalue':
mapscript_wrap.c:6727: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6728: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6729: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6730: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6736: error: parse error before "jdouble"
mapscript_wrap.c:6736: error: parse error before '*' token
mapscript_wrap.c:6736: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1minvalue':
mapscript_wrap.c:6737: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:6737: error: parse error before "jresult"
mapscript_wrap.c:6741: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6742: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6743: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6746: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6746: error: parse error before "result"
mapscript_wrap.c:6751: error: syntax error before "void"
mapscript_wrap.c:6751: error: parse error before '*' token
mapscript_wrap.c:6751: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1maxvalue':
mapscript_wrap.c:6755: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6756: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6757: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6758: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6764: error: parse error before "jdouble"
mapscript_wrap.c:6764: error: parse error before '*' token
mapscript_wrap.c:6764: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1maxvalue':
mapscript_wrap.c:6765: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:6765: error: parse error before "jresult"
mapscript_wrap.c:6769: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6770: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6771: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6774: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6774: error: parse error before "result"
mapscript_wrap.c:6779: error: syntax error before "void"
mapscript_wrap.c:6779: error: parse error before '*' token
mapscript_wrap.c:6779: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1rangeitem':
mapscript_wrap.c:6783: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6784: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6785: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6788: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6790: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:6808: error: parse error before "jstring"
mapscript_wrap.c:6808: error: parse error before '*' token
mapscript_wrap.c:6808: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1rangeitem':
mapscript_wrap.c:6809: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:6809: error: parse error before "jresult"
mapscript_wrap.c:6813: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6814: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6815: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6819: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6825: error: syntax error before "void"
mapscript_wrap.c:6825: error: parse error before '*' token
mapscript_wrap.c:6825: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1rangeitemindex':
mapscript_wrap.c:6829: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6830: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6831: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6832: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6838: error: parse error before "jint"
mapscript_wrap.c:6838: error: parse error before '*' token
mapscript_wrap.c:6838: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1rangeitemindex':
mapscript_wrap.c:6839: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:6839: error: parse error before "jresult"
mapscript_wrap.c:6843: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6844: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6845: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6848: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6848: error: parse error before "result"
mapscript_wrap.c:6853: error: syntax error before "void"
mapscript_wrap.c:6853: error: parse error before '*' token
mapscript_wrap.c:6853: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1symbol':
mapscript_wrap.c:6857: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6858: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6859: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6860: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6866: error: parse error before "jint"
mapscript_wrap.c:6866: error: parse error before '*' token
mapscript_wrap.c:6866: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1symbol':
mapscript_wrap.c:6867: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:6867: error: parse error before "jresult"
mapscript_wrap.c:6871: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6872: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6873: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6876: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6876: error: parse error before "result"
mapscript_wrap.c:6881: error: syntax error before "void"
mapscript_wrap.c:6881: error: parse error before '*' token
mapscript_wrap.c:6881: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1symbolname':
mapscript_wrap.c:6885: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6886: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6887: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6890: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6892: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:6910: error: parse error before "jstring"
mapscript_wrap.c:6910: error: parse error before '*' token
mapscript_wrap.c:6910: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1symbolname':
mapscript_wrap.c:6911: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:6911: error: parse error before "jresult"
mapscript_wrap.c:6915: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6916: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6917: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6921: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6927: error: syntax error before "void"
mapscript_wrap.c:6927: error: parse error before '*' token
mapscript_wrap.c:6927: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1size':
mapscript_wrap.c:6931: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6932: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6933: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6934: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6940: error: parse error before "jint"
mapscript_wrap.c:6940: error: parse error before '*' token
mapscript_wrap.c:6940: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1size':
mapscript_wrap.c:6941: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:6941: error: parse error before "jresult"
mapscript_wrap.c:6945: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6946: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6947: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6950: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6950: error: parse error before "result"
mapscript_wrap.c:6955: error: syntax error before "void"
mapscript_wrap.c:6955: error: parse error before '*' token
mapscript_wrap.c:6955: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1minsize':
mapscript_wrap.c:6959: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6960: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6961: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6962: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6968: error: parse error before "jint"
mapscript_wrap.c:6968: error: parse error before '*' token
mapscript_wrap.c:6968: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1minsize':
mapscript_wrap.c:6969: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:6969: error: parse error before "jresult"
mapscript_wrap.c:6973: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6974: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6975: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6978: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:6978: error: parse error before "result"
mapscript_wrap.c:6983: error: syntax error before "void"
mapscript_wrap.c:6983: error: parse error before '*' token
mapscript_wrap.c:6983: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1maxsize':
mapscript_wrap.c:6987: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:6988: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:6989: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:6990: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:6996: error: parse error before "jint"
mapscript_wrap.c:6996: error: parse error before '*' token
mapscript_wrap.c:6996: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1maxsize':
mapscript_wrap.c:6997: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:6997: error: parse error before "jresult"
mapscript_wrap.c:7001: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7002: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7003: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7006: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7006: error: parse error before "result"
mapscript_wrap.c:7011: error: syntax error before "void"
mapscript_wrap.c:7011: error: parse error before '*' token
mapscript_wrap.c:7011: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1width':
mapscript_wrap.c:7015: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7016: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7017: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7018: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7024: error: parse error before "jint"
mapscript_wrap.c:7024: error: parse error before '*' token
mapscript_wrap.c:7024: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1width':
mapscript_wrap.c:7025: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:7025: error: parse error before "jresult"
mapscript_wrap.c:7029: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7030: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7031: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7034: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7034: error: parse error before "result"
mapscript_wrap.c:7039: error: syntax error before "void"
mapscript_wrap.c:7039: error: parse error before '*' token
mapscript_wrap.c:7039: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1minwidth':
mapscript_wrap.c:7043: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7044: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7045: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7046: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7052: error: parse error before "jint"
mapscript_wrap.c:7052: error: parse error before '*' token
mapscript_wrap.c:7052: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1minwidth':
mapscript_wrap.c:7053: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:7053: error: parse error before "jresult"
mapscript_wrap.c:7057: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7058: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7059: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7062: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7062: error: parse error before "result"
mapscript_wrap.c:7067: error: syntax error before "void"
mapscript_wrap.c:7067: error: parse error before '*' token
mapscript_wrap.c:7067: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1maxwidth':
mapscript_wrap.c:7071: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7072: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7073: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7074: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7080: error: parse error before "jint"
mapscript_wrap.c:7080: error: parse error before '*' token
mapscript_wrap.c:7080: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1maxwidth':
mapscript_wrap.c:7081: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:7081: error: parse error before "jresult"
mapscript_wrap.c:7085: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7086: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7087: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7090: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7090: error: parse error before "result"
mapscript_wrap.c:7095: error: syntax error before "void"
mapscript_wrap.c:7095: error: parse error before '*' token
mapscript_wrap.c:7095: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1offsetx':
mapscript_wrap.c:7099: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7100: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7101: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7102: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7108: error: parse error before "jint"
mapscript_wrap.c:7108: error: parse error before '*' token
mapscript_wrap.c:7108: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1offsetx':
mapscript_wrap.c:7109: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:7109: error: parse error before "jresult"
mapscript_wrap.c:7113: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7114: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7115: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7118: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7118: error: parse error before "result"
mapscript_wrap.c:7123: error: syntax error before "void"
mapscript_wrap.c:7123: error: parse error before '*' token
mapscript_wrap.c:7123: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1offsety':
mapscript_wrap.c:7127: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7128: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7129: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7130: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7136: error: parse error before "jint"
mapscript_wrap.c:7136: error: parse error before '*' token
mapscript_wrap.c:7136: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1offsety':
mapscript_wrap.c:7137: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:7137: error: parse error before "jresult"
mapscript_wrap.c:7141: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7142: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7143: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7146: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7146: error: parse error before "result"
mapscript_wrap.c:7151: error: syntax error before "void"
mapscript_wrap.c:7151: error: parse error before '*' token
mapscript_wrap.c:7151: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1angle':
mapscript_wrap.c:7155: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7156: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7157: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7158: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7164: error: parse error before "jdouble"
mapscript_wrap.c:7164: error: parse error before '*' token
mapscript_wrap.c:7164: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1angle':
mapscript_wrap.c:7165: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:7165: error: parse error before "jresult"
mapscript_wrap.c:7169: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7170: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7171: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7174: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7174: error: parse error before "result"
mapscript_wrap.c:7179: error: syntax error before "void"
mapscript_wrap.c:7179: error: parse error before '*' token
mapscript_wrap.c:7179: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1antialias':
mapscript_wrap.c:7183: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7184: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7185: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7186: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7192: error: parse error before "jint"
mapscript_wrap.c:7192: error: parse error before '*' token
mapscript_wrap.c:7192: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1antialias':
mapscript_wrap.c:7193: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:7193: error: parse error before "jresult"
mapscript_wrap.c:7197: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7198: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7199: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7202: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7202: error: parse error before "result"
mapscript_wrap.c:7207: error: syntax error before "void"
mapscript_wrap.c:7207: error: parse error before '*' token
mapscript_wrap.c:7207: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1angleitem':
mapscript_wrap.c:7211: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7212: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7213: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7216: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7218: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:7236: error: parse error before "jstring"
mapscript_wrap.c:7236: error: parse error before '*' token
mapscript_wrap.c:7236: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1angleitem':
mapscript_wrap.c:7237: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:7237: error: parse error before "jresult"
mapscript_wrap.c:7241: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7242: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7243: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7247: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7253: error: syntax error before "void"
mapscript_wrap.c:7253: error: parse error before '*' token
mapscript_wrap.c:7253: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1styleObj_1sizeitem':
mapscript_wrap.c:7257: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7258: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7259: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7262: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7264: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:7282: error: parse error before "jstring"
mapscript_wrap.c:7282: error: parse error before '*' token
mapscript_wrap.c:7282: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1styleObj_1sizeitem':
mapscript_wrap.c:7283: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:7283: error: parse error before "jresult"
mapscript_wrap.c:7287: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7288: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7289: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7293: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7299: error: parse error before "jlong"
mapscript_wrap.c:7299: error: parse error before '*' token
mapscript_wrap.c:7299: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1styleObj':
mapscript_wrap.c:7300: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:7300: error: parse error before "jresult"
mapscript_wrap.c:7304: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7305: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7306: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7342: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7347: error: syntax error before "void"
mapscript_wrap.c:7347: error: parse error before '*' token
mapscript_wrap.c:7347: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1styleObj':
mapscript_wrap.c:7350: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7351: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7352: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7391: error: parse error before "jlong"
mapscript_wrap.c:7391: error: parse error before '*' token
mapscript_wrap.c:7391: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_styleObj_1cloneStyle':
mapscript_wrap.c:7392: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:7392: error: parse error before "jresult"
mapscript_wrap.c:7396: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7397: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7398: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7434: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7439: error: syntax error before "void"
mapscript_wrap.c:7439: error: parse error before '*' token
mapscript_wrap.c:7439: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1classObj_1status':
mapscript_wrap.c:7443: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7444: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7445: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7446: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7452: error: parse error before "jint"
mapscript_wrap.c:7452: error: parse error before '*' token
mapscript_wrap.c:7452: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1classObj_1status':
mapscript_wrap.c:7453: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:7453: error: parse error before "jresult"
mapscript_wrap.c:7457: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7458: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7459: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7462: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7462: error: parse error before "result"
mapscript_wrap.c:7467: error: syntax error before "void"
mapscript_wrap.c:7467: error: parse error before '*' token
mapscript_wrap.c:7467: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1classObj_1numstyles':
mapscript_wrap.c:7471: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7472: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7473: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7474: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7480: error: parse error before "jint"
mapscript_wrap.c:7480: error: parse error before '*' token
mapscript_wrap.c:7480: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1classObj_1numstyles':
mapscript_wrap.c:7481: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:7481: error: parse error before "jresult"
mapscript_wrap.c:7485: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7486: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7487: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7490: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7490: error: parse error before "result"
mapscript_wrap.c:7495: error: syntax error before "void"
mapscript_wrap.c:7495: error: parse error before '*' token
mapscript_wrap.c:7495: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1classObj_1label':
mapscript_wrap.c:7499: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7500: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7501: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7502: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7508: error: parse error before "jlong"
mapscript_wrap.c:7508: error: parse error before '*' token
mapscript_wrap.c:7508: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1classObj_1label':
mapscript_wrap.c:7509: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:7509: error: parse error before "jresult"
mapscript_wrap.c:7513: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7514: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7515: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7518: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7523: error: syntax error before "void"
mapscript_wrap.c:7523: error: parse error before '*' token
mapscript_wrap.c:7523: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1classObj_1name':
mapscript_wrap.c:7527: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7528: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7529: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7532: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7534: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:7552: error: parse error before "jstring"
mapscript_wrap.c:7552: error: parse error before '*' token
mapscript_wrap.c:7552: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1classObj_1name':
mapscript_wrap.c:7553: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:7553: error: parse error before "jresult"
mapscript_wrap.c:7557: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7558: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7559: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7563: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7569: error: syntax error before "void"
mapscript_wrap.c:7569: error: parse error before '*' token
mapscript_wrap.c:7569: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1classObj_1title':
mapscript_wrap.c:7573: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7574: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7575: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7578: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7580: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:7598: error: parse error before "jstring"
mapscript_wrap.c:7598: error: parse error before '*' token
mapscript_wrap.c:7598: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1classObj_1title':
mapscript_wrap.c:7599: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:7599: error: parse error before "jresult"
mapscript_wrap.c:7603: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7604: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7605: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7609: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7615: error: syntax error before "void"
mapscript_wrap.c:7615: error: parse error before '*' token
mapscript_wrap.c:7615: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1classObj_1template':
mapscript_wrap.c:7619: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7620: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7621: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7624: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7626: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:7644: error: parse error before "jstring"
mapscript_wrap.c:7644: error: parse error before '*' token
mapscript_wrap.c:7644: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1classObj_1template':
mapscript_wrap.c:7645: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:7645: error: parse error before "jresult"
mapscript_wrap.c:7649: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7650: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7651: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7655: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7661: error: syntax error before "void"
mapscript_wrap.c:7661: error: parse error before '*' token
mapscript_wrap.c:7661: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1classObj_1type':
mapscript_wrap.c:7665: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7666: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7667: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7668: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7674: error: parse error before "jint"
mapscript_wrap.c:7674: error: parse error before '*' token
mapscript_wrap.c:7674: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1classObj_1type':
mapscript_wrap.c:7675: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:7675: error: parse error before "jresult"
mapscript_wrap.c:7679: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7680: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7681: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7684: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7684: error: parse error before "result"
mapscript_wrap.c:7689: error: syntax error before "void"
mapscript_wrap.c:7689: error: parse error before '*' token
mapscript_wrap.c:7689: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1classObj_1metadata':
mapscript_wrap.c:7693: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7694: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7695: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7696: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7702: error: parse error before "jlong"
mapscript_wrap.c:7702: error: parse error before '*' token
mapscript_wrap.c:7702: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1classObj_1metadata':
mapscript_wrap.c:7703: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:7703: error: parse error before "jresult"
mapscript_wrap.c:7707: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7708: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7709: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7712: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7717: error: syntax error before "void"
mapscript_wrap.c:7717: error: parse error before '*' token
mapscript_wrap.c:7717: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1classObj_1minscale':
mapscript_wrap.c:7721: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7722: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7723: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7724: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7730: error: parse error before "jdouble"
mapscript_wrap.c:7730: error: parse error before '*' token
mapscript_wrap.c:7730: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1classObj_1minscale':
mapscript_wrap.c:7731: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:7731: error: parse error before "jresult"
mapscript_wrap.c:7735: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7736: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7737: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7740: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7740: error: parse error before "result"
mapscript_wrap.c:7745: error: syntax error before "void"
mapscript_wrap.c:7745: error: parse error before '*' token
mapscript_wrap.c:7745: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1classObj_1maxscale':
mapscript_wrap.c:7749: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7750: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7751: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7752: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7758: error: parse error before "jdouble"
mapscript_wrap.c:7758: error: parse error before '*' token
mapscript_wrap.c:7758: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1classObj_1maxscale':
mapscript_wrap.c:7759: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:7759: error: parse error before "jresult"
mapscript_wrap.c:7763: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7764: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7765: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7768: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7768: error: parse error before "result"
mapscript_wrap.c: At top level:
mapscript_wrap.c:7773: error: syntax error before "void"
mapscript_wrap.c:7773: error: parse error before '*' token
mapscript_wrap.c:7773: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1classObj_1layer':
mapscript_wrap.c:7777: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7778: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7779: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7780: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7786: error: parse error before "jlong"
mapscript_wrap.c:7786: error: parse error before '*' token
mapscript_wrap.c:7786: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1classObj_1layer':
mapscript_wrap.c:7787: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:7787: error: parse error before "jresult"
mapscript_wrap.c:7791: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7792: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7793: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7796: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7801: error: syntax error before "void"
mapscript_wrap.c:7801: error: parse error before '*' token
mapscript_wrap.c:7801: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1classObj_1debug':
mapscript_wrap.c:7805: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7806: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7807: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7808: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7814: error: parse error before "jint"
mapscript_wrap.c:7814: error: parse error before '*' token
mapscript_wrap.c:7814: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1classObj_1debug':
mapscript_wrap.c:7815: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:7815: error: parse error before "jresult"
mapscript_wrap.c:7819: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7820: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7821: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7824: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7824: error: parse error before "result"
mapscript_wrap.c:7829: error: syntax error before "void"
mapscript_wrap.c:7829: error: parse error before '*' token
mapscript_wrap.c:7829: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1classObj_1keyimage':
mapscript_wrap.c:7833: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7834: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7835: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7838: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:7840: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:7858: error: parse error before "jstring"
mapscript_wrap.c:7858: error: parse error before '*' token
mapscript_wrap.c:7858: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1classObj_1keyimage':
mapscript_wrap.c:7859: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:7859: error: parse error before "jresult"
mapscript_wrap.c:7863: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7864: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7865: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7869: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7875: error: parse error before "jlong"
mapscript_wrap.c:7875: error: parse error before '*' token
mapscript_wrap.c:7875: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1classObj':
mapscript_wrap.c:7876: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:7876: error: parse error before "jresult"
mapscript_wrap.c:7880: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7881: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7882: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7918: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:7923: error: syntax error before "void"
mapscript_wrap.c:7923: error: parse error before '*' token
mapscript_wrap.c:7923: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1classObj':
mapscript_wrap.c:7926: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7927: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7928: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:7967: error: parse error before "jlong"
mapscript_wrap.c:7967: error: parse error before '*' token
mapscript_wrap.c:7967: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1cloneClass':
mapscript_wrap.c:7968: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:7968: error: parse error before "jresult"
mapscript_wrap.c:7972: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:7973: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:7974: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8010: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8015: error: parse error before "jint"
mapscript_wrap.c:8015: error: parse error before '*' token
mapscript_wrap.c:8015: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1setExpression':
mapscript_wrap.c:8016: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:8016: error: parse error before "jresult"
mapscript_wrap.c:8021: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8022: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8023: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8026: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:8066: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8066: error: parse error before "result"
mapscript_wrap.c:8074: error: parse error before "jstring"
mapscript_wrap.c:8074: error: parse error before '*' token
mapscript_wrap.c:8074: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1getExpressionString':
mapscript_wrap.c:8075: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:8075: error: parse error before "jresult"
mapscript_wrap.c:8079: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8080: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8081: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8118: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8125: error: parse error before "jint"
mapscript_wrap.c:8125: error: parse error before '*' token
mapscript_wrap.c:8125: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1setText':
mapscript_wrap.c:8126: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:8126: error: parse error before "jresult"
mapscript_wrap.c:8132: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8133: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8134: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8135: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:8138: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:8178: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8178: error: parse error before "result"
mapscript_wrap.c:8186: error: parse error before "jstring"
mapscript_wrap.c:8186: error: parse error before '*' token
mapscript_wrap.c:8186: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1getMetaData':
mapscript_wrap.c:8187: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:8187: error: parse error before "jresult"
mapscript_wrap.c:8192: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8193: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8194: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8197: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:8238: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8247: error: parse error before "jint"
mapscript_wrap.c:8247: error: parse error before '*' token
mapscript_wrap.c:8247: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1setMetaData':
mapscript_wrap.c:8248: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:8248: error: parse error before "jresult"
mapscript_wrap.c:8254: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8255: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8256: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8259: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:8266: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:8306: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8306: error: parse error before "result"
mapscript_wrap.c:8317: error: parse error before "jstring"
mapscript_wrap.c:8317: error: parse error before '*' token
mapscript_wrap.c:8317: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1getFirstMetaDataKey':
mapscript_wrap.c:8318: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:8318: error: parse error before "jresult"
mapscript_wrap.c:8322: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8323: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8324: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8361: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8367: error: parse error before "jstring"
mapscript_wrap.c:8367: error: parse error before '*' token
mapscript_wrap.c:8367: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1getNextMetaDataKey':
mapscript_wrap.c:8368: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:8368: error: parse error before "jresult"
mapscript_wrap.c:8373: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8374: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8375: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8378: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:8419: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8428: error: parse error before "jint"
mapscript_wrap.c:8428: error: parse error before '*' token
mapscript_wrap.c:8428: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1drawLegendIcon':
mapscript_wrap.c:8429: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:8429: error: parse error before "jresult"
mapscript_wrap.c:8440: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8441: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8442: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8443: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:8444: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:8445: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:8446: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:8447: error: `jarg6' undeclared (first use in this function)
mapscript_wrap.c:8448: error: `jarg7' undeclared (first use in this function)
mapscript_wrap.c:8449: error: `jarg8' undeclared (first use in this function)
mapscript_wrap.c:8485: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8485: error: parse error before "result"
mapscript_wrap.c:8490: error: parse error before "jlong"
mapscript_wrap.c:8490: error: parse error before '*' token
mapscript_wrap.c:8490: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1createLegendIcon':
mapscript_wrap.c:8491: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:8491: error: parse error before "jresult"
mapscript_wrap.c:8499: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8500: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8501: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8502: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:8503: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:8504: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:8505: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:8541: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8546: error: parse error before "jlong"
mapscript_wrap.c:8546: error: parse error before '*' token
mapscript_wrap.c:8546: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1getStyle':
mapscript_wrap.c:8547: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:8547: error: parse error before "jresult"
mapscript_wrap.c:8552: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8553: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8554: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8555: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:8591: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8596: error: parse error before "jint"
mapscript_wrap.c:8596: error: parse error before '*' token
mapscript_wrap.c:8596: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1insertStyle':
mapscript_wrap.c:8597: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:8597: error: parse error before "jresult"
mapscript_wrap.c:8603: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8604: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8605: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8606: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:8607: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:8643: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8643: error: parse error before "result"
mapscript_wrap.c:8648: error: parse error before "jlong"
mapscript_wrap.c:8648: error: parse error before '*' token
mapscript_wrap.c:8648: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1removeStyle':
mapscript_wrap.c:8649: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:8649: error: parse error before "jresult"
mapscript_wrap.c:8654: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8655: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8656: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8657: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:8693: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8698: error: parse error before "jint"
mapscript_wrap.c:8698: error: parse error before '*' token
mapscript_wrap.c:8698: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1moveStyleUp':
mapscript_wrap.c:8699: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:8699: error: parse error before "jresult"
mapscript_wrap.c:8704: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8705: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8706: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8707: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:8743: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8743: error: parse error before "result"
mapscript_wrap.c:8748: error: parse error before "jint"
mapscript_wrap.c:8748: error: parse error before '*' token
mapscript_wrap.c:8748: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_classObj_1moveStyleDown':
mapscript_wrap.c:8749: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:8749: error: parse error before "jresult"
mapscript_wrap.c:8754: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8755: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8756: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8757: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:8793: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8793: error: parse error before "result"
mapscript_wrap.c:8798: error: parse error before "jstring"
mapscript_wrap.c:8798: error: parse error before '*' token
mapscript_wrap.c:8798: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheMemberObj_1text':
mapscript_wrap.c:8799: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:8799: error: parse error before "jresult"
mapscript_wrap.c:8803: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8804: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8805: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8809: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8815: error: parse error before "jdouble"
mapscript_wrap.c:8815: error: parse error before '*' token
mapscript_wrap.c:8815: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheMemberObj_1featuresize':
mapscript_wrap.c:8816: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:8816: error: parse error before "jresult"
mapscript_wrap.c:8820: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8821: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8822: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8825: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8825: error: parse error before "result"
mapscript_wrap.c:8830: error: parse error before "jlong"
mapscript_wrap.c:8830: error: parse error before '*' token
mapscript_wrap.c:8830: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheMemberObj_1styles':
mapscript_wrap.c:8831: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:8831: error: parse error before "jresult"
mapscript_wrap.c:8835: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8836: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8837: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8840: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8845: error: parse error before "jint"
mapscript_wrap.c:8845: error: parse error before '*' token
mapscript_wrap.c:8845: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheMemberObj_1numstyles':
mapscript_wrap.c:8846: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:8846: error: parse error before "jresult"
mapscript_wrap.c:8850: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8851: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8852: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8855: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8855: error: parse error before "result"
mapscript_wrap.c:8860: error: parse error before "jlong"
mapscript_wrap.c:8860: error: parse error before '*' token
mapscript_wrap.c:8860: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheMemberObj_1label':
mapscript_wrap.c:8861: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:8861: error: parse error before "jresult"
mapscript_wrap.c:8865: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8866: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8867: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8870: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8875: error: parse error before "jint"
mapscript_wrap.c:8875: error: parse error before '*' token
mapscript_wrap.c:8875: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheMemberObj_1layerindex':
mapscript_wrap.c:8876: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:8876: error: parse error before "jresult"
mapscript_wrap.c:8880: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8881: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8882: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8885: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8885: error: parse error before "result"
mapscript_wrap.c:8890: error: parse error before "jint"
mapscript_wrap.c:8890: error: parse error before '*' token
mapscript_wrap.c:8890: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheMemberObj_1classindex':
mapscript_wrap.c:8891: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:8891: error: parse error before "jresult"
mapscript_wrap.c:8895: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8896: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8897: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8900: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8900: error: parse error before "result"
mapscript_wrap.c:8905: error: parse error before "jint"
mapscript_wrap.c:8905: error: parse error before '*' token
mapscript_wrap.c:8905: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheMemberObj_1tileindex':
mapscript_wrap.c:8906: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:8906: error: parse error before "jresult"
mapscript_wrap.c:8910: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8911: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8912: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8915: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8915: error: parse error before "result"
mapscript_wrap.c:8920: error: parse error before "jint"
mapscript_wrap.c:8920: error: parse error before '*' token
mapscript_wrap.c:8920: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheMemberObj_1shapeindex':
mapscript_wrap.c:8921: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:8921: error: parse error before "jresult"
mapscript_wrap.c:8925: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8926: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8927: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8930: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8930: error: parse error before "result"
mapscript_wrap.c:8935: error: parse error before "jlong"
mapscript_wrap.c:8935: error: parse error before '*' token
mapscript_wrap.c:8935: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheMemberObj_1point':
mapscript_wrap.c:8936: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:8936: error: parse error before "jresult"
mapscript_wrap.c:8940: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8941: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8942: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8945: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8950: error: parse error before "jlong"
mapscript_wrap.c:8950: error: parse error before '*' token
mapscript_wrap.c:8950: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheMemberObj_1poly':
mapscript_wrap.c:8951: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:8951: error: parse error before "jresult"
mapscript_wrap.c:8955: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8956: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8957: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8960: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8965: error: parse error before "jint"
mapscript_wrap.c:8965: error: parse error before '*' token
mapscript_wrap.c:8965: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheMemberObj_1status':
mapscript_wrap.c:8966: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:8966: error: parse error before "jresult"
mapscript_wrap.c:8970: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8971: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:8972: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:8975: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:8975: error: parse error before "result"
mapscript_wrap.c:8980: error: parse error before "jlong"
mapscript_wrap.c:8980: error: parse error before '*' token
mapscript_wrap.c:8980: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1labelCacheMemberObj':
mapscript_wrap.c:8981: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:8981: error: parse error before "jresult"
mapscript_wrap.c:8984: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:8985: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9021: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9026: error: syntax error before "void"
mapscript_wrap.c:9026: error: parse error before '*' token
mapscript_wrap.c:9026: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1labelCacheMemberObj':
mapscript_wrap.c:9029: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9030: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9031: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9070: error: parse error before "jint"
mapscript_wrap.c:9070: error: parse error before '*' token
mapscript_wrap.c:9070: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1markerCacheMemberObj_1id':
mapscript_wrap.c:9071: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:9071: error: parse error before "jresult"
mapscript_wrap.c:9075: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9076: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9077: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9080: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9080: error: parse error before "result"
mapscript_wrap.c:9085: error: parse error before "jlong"
mapscript_wrap.c:9085: error: parse error before '*' token
mapscript_wrap.c:9085: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1markerCacheMemberObj_1poly':
mapscript_wrap.c:9086: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:9086: error: parse error before "jresult"
mapscript_wrap.c:9090: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9091: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9092: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9095: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9100: error: parse error before "jlong"
mapscript_wrap.c:9100: error: parse error before '*' token
mapscript_wrap.c:9100: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1markerCacheMemberObj':
mapscript_wrap.c:9101: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:9101: error: parse error before "jresult"
mapscript_wrap.c:9104: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9105: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9141: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9146: error: syntax error before "void"
mapscript_wrap.c:9146: error: parse error before '*' token
mapscript_wrap.c:9146: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1markerCacheMemberObj':
mapscript_wrap.c:9149: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9150: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9151: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9190: error: parse error before "jlong"
mapscript_wrap.c:9190: error: parse error before '*' token
mapscript_wrap.c:9190: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheObj_1labels':
mapscript_wrap.c:9191: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:9191: error: parse error before "jresult"
mapscript_wrap.c:9195: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9196: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9197: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9200: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9205: error: parse error before "jint"
mapscript_wrap.c:9205: error: parse error before '*' token
mapscript_wrap.c:9205: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheObj_1numlabels':
mapscript_wrap.c:9206: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:9206: error: parse error before "jresult"
mapscript_wrap.c:9210: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9211: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9212: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9215: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9215: error: parse error before "result"
mapscript_wrap.c:9220: error: parse error before "jint"
mapscript_wrap.c:9220: error: parse error before '*' token
mapscript_wrap.c:9220: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheObj_1cachesize':
mapscript_wrap.c:9221: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:9221: error: parse error before "jresult"
mapscript_wrap.c:9225: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9226: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9227: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9230: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9230: error: parse error before "result"
mapscript_wrap.c:9235: error: parse error before "jlong"
mapscript_wrap.c:9235: error: parse error before '*' token
mapscript_wrap.c:9235: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheObj_1markers':
mapscript_wrap.c:9236: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:9236: error: parse error before "jresult"
mapscript_wrap.c:9240: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9241: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9242: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9245: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9250: error: parse error before "jint"
mapscript_wrap.c:9250: error: parse error before '*' token
mapscript_wrap.c:9250: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheObj_1nummarkers':
mapscript_wrap.c:9251: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:9251: error: parse error before "jresult"
mapscript_wrap.c:9255: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9256: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9257: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9260: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9260: error: parse error before "result"
mapscript_wrap.c:9265: error: parse error before "jint"
mapscript_wrap.c:9265: error: parse error before '*' token
mapscript_wrap.c:9265: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelCacheObj_1markercachesize':
mapscript_wrap.c:9266: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:9266: error: parse error before "jresult"
mapscript_wrap.c:9270: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9271: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9272: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9275: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9275: error: parse error before "result"
mapscript_wrap.c:9280: error: syntax error before "void"
mapscript_wrap.c:9280: error: parse error before '*' token
mapscript_wrap.c:9280: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_labelCacheObj_1freeCache':
mapscript_wrap.c:9283: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9284: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9285: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9324: error: parse error before "jlong"
mapscript_wrap.c:9324: error: parse error before '*' token
mapscript_wrap.c:9324: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1labelCacheObj':
mapscript_wrap.c:9325: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:9325: error: parse error before "jresult"
mapscript_wrap.c:9328: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9329: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9365: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9370: error: syntax error before "void"
mapscript_wrap.c:9370: error: parse error before '*' token
mapscript_wrap.c:9370: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1labelCacheObj':
mapscript_wrap.c:9373: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9374: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9375: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9414: error: parse error before "jint"
mapscript_wrap.c:9414: error: parse error before '*' token
mapscript_wrap.c:9414: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1resultCacheMemberObj_1shapeindex':
mapscript_wrap.c:9415: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:9415: error: parse error before "jresult"
mapscript_wrap.c:9419: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9420: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9421: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9424: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9424: error: parse error before "result"
mapscript_wrap.c:9429: error: parse error before "jint"
mapscript_wrap.c:9429: error: parse error before '*' token
mapscript_wrap.c:9429: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1resultCacheMemberObj_1tileindex':
mapscript_wrap.c:9430: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:9430: error: parse error before "jresult"
mapscript_wrap.c:9434: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9435: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9436: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9439: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9439: error: parse error before "result"
mapscript_wrap.c:9444: error: parse error before "jchar"
mapscript_wrap.c:9444: error: parse error before '*' token
mapscript_wrap.c:9444: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1resultCacheMemberObj_1classindex':
mapscript_wrap.c:9445: error: `jchar' undeclared (first use in this function)
mapscript_wrap.c:9445: error: parse error before "jresult"
mapscript_wrap.c:9449: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9450: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9451: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9454: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9454: error: parse error before "result"
mapscript_wrap.c:9459: error: parse error before "jlong"
mapscript_wrap.c:9459: error: parse error before '*' token
mapscript_wrap.c:9459: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1resultCacheMemberObj':
mapscript_wrap.c:9460: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:9460: error: parse error before "jresult"
mapscript_wrap.c:9463: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9464: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9500: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9505: error: syntax error before "void"
mapscript_wrap.c:9505: error: parse error before '*' token
mapscript_wrap.c:9505: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1resultCacheMemberObj':
mapscript_wrap.c:9508: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9509: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9510: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9549: error: parse error before "jint"
mapscript_wrap.c:9549: error: parse error before '*' token
mapscript_wrap.c:9549: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1resultCacheObj_1numresults':
mapscript_wrap.c:9550: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:9550: error: parse error before "jresult"
mapscript_wrap.c:9554: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9555: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9556: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9559: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9559: error: parse error before "result"
mapscript_wrap.c:9564: error: parse error before "jlong"
mapscript_wrap.c:9564: error: parse error before '*' token
mapscript_wrap.c:9564: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1resultCacheObj_1bounds':
mapscript_wrap.c:9565: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:9565: error: parse error before "jresult"
mapscript_wrap.c:9569: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9570: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9571: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9574: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9579: error: parse error before "jlong"
mapscript_wrap.c:9579: error: parse error before '*' token
mapscript_wrap.c:9579: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_resultCacheObj_1getResult':
mapscript_wrap.c:9580: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:9580: error: parse error before "jresult"
mapscript_wrap.c:9585: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9586: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9587: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9588: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:9624: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9629: error: parse error before "jlong"
mapscript_wrap.c:9629: error: parse error before '*' token
mapscript_wrap.c:9629: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1resultCacheObj':
mapscript_wrap.c:9630: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:9630: error: parse error before "jresult"
mapscript_wrap.c:9633: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9634: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9670: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9675: error: syntax error before "void"
mapscript_wrap.c:9675: error: parse error before '*' token
mapscript_wrap.c:9675: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1resultCacheObj':
mapscript_wrap.c:9678: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9679: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9680: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9719: error: syntax error before "void"
mapscript_wrap.c:9719: error: parse error before '*' token
mapscript_wrap.c:9719: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolSetObj_1filename':
mapscript_wrap.c:9723: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9724: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9725: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9728: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:9730: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:9748: error: parse error before "jstring"
mapscript_wrap.c:9748: error: parse error before '*' token
mapscript_wrap.c:9748: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolSetObj_1filename':
mapscript_wrap.c:9749: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:9749: error: parse error before "jresult"
mapscript_wrap.c:9753: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9754: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9755: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9759: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9765: error: syntax error before "void"
mapscript_wrap.c:9765: error: parse error before '*' token
mapscript_wrap.c:9765: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolSetObj_1imagecachesize':
mapscript_wrap.c:9769: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9770: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9771: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9772: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:9778: error: parse error before "jint"
mapscript_wrap.c:9778: error: parse error before '*' token
mapscript_wrap.c:9778: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolSetObj_1imagecachesize':
mapscript_wrap.c:9779: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:9779: error: parse error before "jresult"
mapscript_wrap.c:9783: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9784: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9785: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9788: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9788: error: parse error before "result"
mapscript_wrap.c:9793: error: parse error before "jint"
mapscript_wrap.c:9793: error: parse error before '*' token
mapscript_wrap.c:9793: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolSetObj_1numsymbols':
mapscript_wrap.c:9794: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:9794: error: parse error before "jresult"
mapscript_wrap.c:9798: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9799: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9800: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9803: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9803: error: parse error before "result"
mapscript_wrap.c:9808: error: syntax error before "void"
mapscript_wrap.c:9808: error: parse error before '*' token
mapscript_wrap.c:9808: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolSetObj_1symbol':
mapscript_wrap.c:9812: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9813: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9814: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9815: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:9825: error: parse error before "jlong"
mapscript_wrap.c:9825: error: parse error before '*' token
mapscript_wrap.c:9825: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolSetObj_1symbol':
mapscript_wrap.c:9826: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:9826: error: parse error before "jresult"
mapscript_wrap.c:9830: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9831: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9832: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9835: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9840: error: parse error before "jlong"
mapscript_wrap.c:9840: error: parse error before '*' token
mapscript_wrap.c:9840: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1symbolSetObj':
mapscript_wrap.c:9841: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:9841: error: parse error before "jresult"
mapscript_wrap.c:9845: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9846: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9849: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9889: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9897: error: syntax error before "void"
mapscript_wrap.c:9897: error: parse error before '*' token
mapscript_wrap.c:9897: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1symbolSetObj':
mapscript_wrap.c:9900: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9901: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9902: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9941: error: parse error before "jlong"
mapscript_wrap.c:9941: error: parse error before '*' token
mapscript_wrap.c:9941: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_symbolSetObj_1getSymbol':
mapscript_wrap.c:9942: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:9942: error: parse error before "jresult"
mapscript_wrap.c:9947: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9948: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9949: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:9950: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:9986: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:9991: error: parse error before "jlong"
mapscript_wrap.c:9991: error: parse error before '*' token
mapscript_wrap.c:9991: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_symbolSetObj_1getSymbolByName':
mapscript_wrap.c:9992: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:9992: error: parse error before "jresult"
mapscript_wrap.c:9997: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:9998: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:9999: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10002: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10042: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10050: error: parse error before "jint"
mapscript_wrap.c:10050: error: parse error before '*' token
mapscript_wrap.c:10050: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_symbolSetObj_1index':
mapscript_wrap.c:10051: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10051: error: parse error before "jresult"
mapscript_wrap.c:10056: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10057: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10058: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10061: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10101: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10101: error: parse error before "result"
mapscript_wrap.c:10109: error: parse error before "jint"
mapscript_wrap.c:10109: error: parse error before '*' token
mapscript_wrap.c:10109: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_symbolSetObj_1appendSymbol':
mapscript_wrap.c:10110: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10110: error: parse error before "jresult"
mapscript_wrap.c:10115: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10116: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10117: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10118: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10154: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10154: error: parse error before "result"
mapscript_wrap.c:10159: error: parse error before "jlong"
mapscript_wrap.c:10159: error: parse error before '*' token
mapscript_wrap.c:10159: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_symbolSetObj_1removeSymbol':
mapscript_wrap.c:10160: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:10160: error: parse error before "jresult"
mapscript_wrap.c:10165: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10166: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10167: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10168: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10204: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10209: error: parse error before "jint"
mapscript_wrap.c:10209: error: parse error before '*' token
mapscript_wrap.c:10209: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_symbolSetObj_1save':
mapscript_wrap.c:10210: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10210: error: parse error before "jresult"
mapscript_wrap.c:10215: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10216: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10217: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10220: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10260: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10260: error: parse error before "result"
mapscript_wrap.c:10268: error: syntax error before "void"
mapscript_wrap.c:10268: error: parse error before '*' token
mapscript_wrap.c:10268: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1referenceMapObj_1extent':
mapscript_wrap.c:10272: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10273: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10274: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10275: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10281: error: parse error before "jlong"
mapscript_wrap.c:10281: error: parse error before '*' token
mapscript_wrap.c:10281: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1referenceMapObj_1extent':
mapscript_wrap.c:10282: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:10282: error: parse error before "jresult"
mapscript_wrap.c:10286: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10287: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10288: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10291: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10296: error: syntax error before "void"
mapscript_wrap.c:10296: error: parse error before '*' token
mapscript_wrap.c:10296: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1referenceMapObj_1height':
mapscript_wrap.c:10300: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10301: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10302: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10303: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10309: error: parse error before "jint"
mapscript_wrap.c:10309: error: parse error before '*' token
mapscript_wrap.c:10309: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1referenceMapObj_1height':
mapscript_wrap.c:10310: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10310: error: parse error before "jresult"
mapscript_wrap.c:10314: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10315: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10316: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10319: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10319: error: parse error before "result"
mapscript_wrap.c:10324: error: syntax error before "void"
mapscript_wrap.c:10324: error: parse error before '*' token
mapscript_wrap.c:10324: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1referenceMapObj_1width':
mapscript_wrap.c:10328: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10329: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10330: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10331: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10337: error: parse error before "jint"
mapscript_wrap.c:10337: error: parse error before '*' token
mapscript_wrap.c:10337: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1referenceMapObj_1width':
mapscript_wrap.c:10338: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10338: error: parse error before "jresult"
mapscript_wrap.c:10342: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10343: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10344: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10347: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10347: error: parse error before "result"
mapscript_wrap.c: At top level:
mapscript_wrap.c:10352: error: syntax error before "void"
mapscript_wrap.c:10352: error: parse error before '*' token
mapscript_wrap.c:10352: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1referenceMapObj_1color':
mapscript_wrap.c:10356: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10357: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10358: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10359: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10365: error: parse error before "jlong"
mapscript_wrap.c:10365: error: parse error before '*' token
mapscript_wrap.c:10365: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1referenceMapObj_1color':
mapscript_wrap.c:10366: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:10366: error: parse error before "jresult"
mapscript_wrap.c:10370: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10371: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10372: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10375: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10380: error: syntax error before "void"
mapscript_wrap.c:10380: error: parse error before '*' token
mapscript_wrap.c:10380: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1referenceMapObj_1outlinecolor':
mapscript_wrap.c:10384: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10385: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10386: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10387: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10393: error: parse error before "jlong"
mapscript_wrap.c:10393: error: parse error before '*' token
mapscript_wrap.c:10393: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1referenceMapObj_1outlinecolor':
mapscript_wrap.c:10394: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:10394: error: parse error before "jresult"
mapscript_wrap.c:10398: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10399: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10400: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10403: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10408: error: syntax error before "void"
mapscript_wrap.c:10408: error: parse error before '*' token
mapscript_wrap.c:10408: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1referenceMapObj_1image':
mapscript_wrap.c:10412: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10413: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10414: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10417: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10419: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:10437: error: parse error before "jstring"
mapscript_wrap.c:10437: error: parse error before '*' token
mapscript_wrap.c:10437: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1referenceMapObj_1image':
mapscript_wrap.c:10438: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:10438: error: parse error before "jresult"
mapscript_wrap.c:10442: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10443: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10444: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10448: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10454: error: syntax error before "void"
mapscript_wrap.c:10454: error: parse error before '*' token
mapscript_wrap.c:10454: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1referenceMapObj_1status':
mapscript_wrap.c:10458: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10459: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10460: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10461: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10467: error: parse error before "jint"
mapscript_wrap.c:10467: error: parse error before '*' token
mapscript_wrap.c:10467: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1referenceMapObj_1status':
mapscript_wrap.c:10468: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10468: error: parse error before "jresult"
mapscript_wrap.c:10472: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10473: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10474: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10477: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10477: error: parse error before "result"
mapscript_wrap.c:10482: error: syntax error before "void"
mapscript_wrap.c:10482: error: parse error before '*' token
mapscript_wrap.c:10482: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1referenceMapObj_1marker':
mapscript_wrap.c:10486: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10487: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10488: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10489: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10495: error: parse error before "jint"
mapscript_wrap.c:10495: error: parse error before '*' token
mapscript_wrap.c:10495: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1referenceMapObj_1marker':
mapscript_wrap.c:10496: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10496: error: parse error before "jresult"
mapscript_wrap.c:10500: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10501: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10502: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10505: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10505: error: parse error before "result"
mapscript_wrap.c:10510: error: syntax error before "void"
mapscript_wrap.c:10510: error: parse error before '*' token
mapscript_wrap.c:10510: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1referenceMapObj_1markername':
mapscript_wrap.c:10514: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10515: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10516: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10519: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10521: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:10539: error: parse error before "jstring"
mapscript_wrap.c:10539: error: parse error before '*' token
mapscript_wrap.c:10539: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1referenceMapObj_1markername':
mapscript_wrap.c:10540: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:10540: error: parse error before "jresult"
mapscript_wrap.c:10544: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10545: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10546: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10550: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10556: error: syntax error before "void"
mapscript_wrap.c:10556: error: parse error before '*' token
mapscript_wrap.c:10556: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1referenceMapObj_1markersize':
mapscript_wrap.c:10560: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10561: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10562: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10563: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10569: error: parse error before "jint"
mapscript_wrap.c:10569: error: parse error before '*' token
mapscript_wrap.c:10569: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1referenceMapObj_1markersize':
mapscript_wrap.c:10570: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10570: error: parse error before "jresult"
mapscript_wrap.c:10574: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10575: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10576: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10579: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10579: error: parse error before "result"
mapscript_wrap.c:10584: error: syntax error before "void"
mapscript_wrap.c:10584: error: parse error before '*' token
mapscript_wrap.c:10584: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1referenceMapObj_1minboxsize':
mapscript_wrap.c:10588: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10589: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10590: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10591: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10597: error: parse error before "jint"
mapscript_wrap.c:10597: error: parse error before '*' token
mapscript_wrap.c:10597: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1referenceMapObj_1minboxsize':
mapscript_wrap.c:10598: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10598: error: parse error before "jresult"
mapscript_wrap.c:10602: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10603: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10604: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10607: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10607: error: parse error before "result"
mapscript_wrap.c:10612: error: syntax error before "void"
mapscript_wrap.c:10612: error: parse error before '*' token
mapscript_wrap.c:10612: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1referenceMapObj_1maxboxsize':
mapscript_wrap.c:10616: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10617: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10618: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10619: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10625: error: parse error before "jint"
mapscript_wrap.c:10625: error: parse error before '*' token
mapscript_wrap.c:10625: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1referenceMapObj_1maxboxsize':
mapscript_wrap.c:10626: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10626: error: parse error before "jresult"
mapscript_wrap.c:10630: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10631: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10632: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10635: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10635: error: parse error before "result"
mapscript_wrap.c:10640: error: syntax error before "void"
mapscript_wrap.c:10640: error: parse error before '*' token
mapscript_wrap.c:10640: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1referenceMapObj_1map':
mapscript_wrap.c:10644: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10645: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10646: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10647: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10653: error: parse error before "jlong"
mapscript_wrap.c:10653: error: parse error before '*' token
mapscript_wrap.c:10653: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1referenceMapObj_1map':
mapscript_wrap.c:10654: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:10654: error: parse error before "jresult"
mapscript_wrap.c:10658: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10659: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10660: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10663: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10668: error: parse error before "jlong"
mapscript_wrap.c:10668: error: parse error before '*' token
mapscript_wrap.c:10668: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1referenceMapObj':
mapscript_wrap.c:10669: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:10669: error: parse error before "jresult"
mapscript_wrap.c:10672: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10673: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10709: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10714: error: syntax error before "void"
mapscript_wrap.c:10714: error: parse error before '*' token
mapscript_wrap.c:10714: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1referenceMapObj':
mapscript_wrap.c:10717: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10718: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10719: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10758: error: syntax error before "void"
mapscript_wrap.c:10758: error: parse error before '*' token
mapscript_wrap.c:10758: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1scalebarObj_1imagecolor':
mapscript_wrap.c:10762: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10763: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10764: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10765: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10771: error: parse error before "jlong"
mapscript_wrap.c:10771: error: parse error before '*' token
mapscript_wrap.c:10771: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1scalebarObj_1imagecolor':
mapscript_wrap.c:10772: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:10772: error: parse error before "jresult"
mapscript_wrap.c:10776: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10777: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10778: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10781: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10786: error: syntax error before "void"
mapscript_wrap.c:10786: error: parse error before '*' token
mapscript_wrap.c:10786: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1scalebarObj_1height':
mapscript_wrap.c:10790: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10791: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10792: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10793: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10799: error: parse error before "jint"
mapscript_wrap.c:10799: error: parse error before '*' token
mapscript_wrap.c:10799: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1scalebarObj_1height':
mapscript_wrap.c:10800: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10800: error: parse error before "jresult"
mapscript_wrap.c:10804: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10805: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10806: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10809: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10809: error: parse error before "result"
mapscript_wrap.c:10814: error: syntax error before "void"
mapscript_wrap.c:10814: error: parse error before '*' token
mapscript_wrap.c:10814: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1scalebarObj_1width':
mapscript_wrap.c:10818: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10819: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10820: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10821: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10827: error: parse error before "jint"
mapscript_wrap.c:10827: error: parse error before '*' token
mapscript_wrap.c:10827: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1scalebarObj_1width':
mapscript_wrap.c:10828: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10828: error: parse error before "jresult"
mapscript_wrap.c:10832: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10833: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10834: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10837: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10837: error: parse error before "result"
mapscript_wrap.c:10842: error: syntax error before "void"
mapscript_wrap.c:10842: error: parse error before '*' token
mapscript_wrap.c:10842: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1scalebarObj_1style':
mapscript_wrap.c:10846: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10847: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10848: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10849: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10855: error: parse error before "jint"
mapscript_wrap.c:10855: error: parse error before '*' token
mapscript_wrap.c:10855: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1scalebarObj_1style':
mapscript_wrap.c:10856: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10856: error: parse error before "jresult"
mapscript_wrap.c:10860: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10861: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10862: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10865: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10865: error: parse error before "result"
mapscript_wrap.c:10870: error: syntax error before "void"
mapscript_wrap.c:10870: error: parse error before '*' token
mapscript_wrap.c:10870: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1scalebarObj_1intervals':
mapscript_wrap.c:10874: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10875: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10876: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10877: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10883: error: parse error before "jint"
mapscript_wrap.c:10883: error: parse error before '*' token
mapscript_wrap.c:10883: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1scalebarObj_1intervals':
mapscript_wrap.c:10884: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:10884: error: parse error before "jresult"
mapscript_wrap.c:10888: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10889: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10890: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10893: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10893: error: parse error before "result"
mapscript_wrap.c:10898: error: syntax error before "void"
mapscript_wrap.c:10898: error: parse error before '*' token
mapscript_wrap.c:10898: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1scalebarObj_1label':
mapscript_wrap.c:10902: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10903: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10904: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10905: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10911: error: parse error before "jlong"
mapscript_wrap.c:10911: error: parse error before '*' token
mapscript_wrap.c:10911: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1scalebarObj_1label':
mapscript_wrap.c:10912: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:10912: error: parse error before "jresult"
mapscript_wrap.c:10916: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10917: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10918: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10921: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10926: error: syntax error before "void"
mapscript_wrap.c:10926: error: parse error before '*' token
mapscript_wrap.c:10926: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1scalebarObj_1color':
mapscript_wrap.c:10930: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10931: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10932: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10933: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10939: error: parse error before "jlong"
mapscript_wrap.c:10939: error: parse error before '*' token
mapscript_wrap.c:10939: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1scalebarObj_1color':
mapscript_wrap.c:10940: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:10940: error: parse error before "jresult"
mapscript_wrap.c:10944: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10945: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10946: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10949: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10954: error: syntax error before "void"
mapscript_wrap.c:10954: error: parse error before '*' token
mapscript_wrap.c:10954: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1scalebarObj_1backgroundcolor':
mapscript_wrap.c:10958: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10959: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10960: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10961: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10967: error: parse error before "jlong"
mapscript_wrap.c:10967: error: parse error before '*' token
mapscript_wrap.c:10967: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1scalebarObj_1backgroundcolor':
mapscript_wrap.c:10968: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:10968: error: parse error before "jresult"
mapscript_wrap.c:10972: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10973: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10974: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10977: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:10982: error: syntax error before "void"
mapscript_wrap.c:10982: error: parse error before '*' token
mapscript_wrap.c:10982: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1scalebarObj_1outlinecolor':
mapscript_wrap.c:10986: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:10987: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:10988: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:10989: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:10995: error: parse error before "jlong"
mapscript_wrap.c:10995: error: parse error before '*' token
mapscript_wrap.c:10995: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1scalebarObj_1outlinecolor':
mapscript_wrap.c:10996: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:10996: error: parse error before "jresult"
mapscript_wrap.c:11000: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11001: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11002: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11005: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11010: error: syntax error before "void"
mapscript_wrap.c:11010: error: parse error before '*' token
mapscript_wrap.c:11010: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1scalebarObj_1units':
mapscript_wrap.c:11014: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11015: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11016: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11017: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11023: error: parse error before "jint"
mapscript_wrap.c:11023: error: parse error before '*' token
mapscript_wrap.c:11023: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1scalebarObj_1units':
mapscript_wrap.c:11024: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:11024: error: parse error before "jresult"
mapscript_wrap.c:11028: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11029: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11030: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11033: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11033: error: parse error before "result"
mapscript_wrap.c:11038: error: syntax error before "void"
mapscript_wrap.c:11038: error: parse error before '*' token
mapscript_wrap.c:11038: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1scalebarObj_1status':
mapscript_wrap.c:11042: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11043: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11044: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11045: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11051: error: parse error before "jint"
mapscript_wrap.c:11051: error: parse error before '*' token
mapscript_wrap.c:11051: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1scalebarObj_1status':
mapscript_wrap.c:11052: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:11052: error: parse error before "jresult"
mapscript_wrap.c:11056: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11057: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11058: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11061: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11061: error: parse error before "result"
mapscript_wrap.c:11066: error: syntax error before "void"
mapscript_wrap.c:11066: error: parse error before '*' token
mapscript_wrap.c:11066: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1scalebarObj_1position':
mapscript_wrap.c:11070: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11071: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11072: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11073: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11079: error: parse error before "jint"
mapscript_wrap.c:11079: error: parse error before '*' token
mapscript_wrap.c:11079: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1scalebarObj_1position':
mapscript_wrap.c:11080: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:11080: error: parse error before "jresult"
mapscript_wrap.c:11084: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11085: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11086: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11089: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11089: error: parse error before "result"
mapscript_wrap.c:11094: error: syntax error before "void"
mapscript_wrap.c:11094: error: parse error before '*' token
mapscript_wrap.c:11094: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1scalebarObj_1postlabelcache':
mapscript_wrap.c:11098: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11099: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11100: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11101: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11107: error: parse error before "jint"
mapscript_wrap.c:11107: error: parse error before '*' token
mapscript_wrap.c:11107: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1scalebarObj_1postlabelcache':
mapscript_wrap.c:11108: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:11108: error: parse error before "jresult"
mapscript_wrap.c:11112: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11113: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11114: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11117: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11117: error: parse error before "result"
mapscript_wrap.c:11122: error: parse error before "jlong"
mapscript_wrap.c:11122: error: parse error before '*' token
mapscript_wrap.c:11122: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1scalebarObj':
mapscript_wrap.c:11123: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:11123: error: parse error before "jresult"
mapscript_wrap.c:11126: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11127: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11163: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11168: error: syntax error before "void"
mapscript_wrap.c:11168: error: parse error before '*' token
mapscript_wrap.c:11168: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1scalebarObj':
mapscript_wrap.c:11171: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11172: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11173: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11212: error: syntax error before "void"
mapscript_wrap.c:11212: error: parse error before '*' token
mapscript_wrap.c:11212: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1imagecolor':
mapscript_wrap.c:11216: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11217: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11218: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11219: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11225: error: parse error before "jlong"
mapscript_wrap.c:11225: error: parse error before '*' token
mapscript_wrap.c:11225: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1imagecolor':
mapscript_wrap.c:11226: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:11226: error: parse error before "jresult"
mapscript_wrap.c:11230: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11231: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11232: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11235: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11240: error: syntax error before "void"
mapscript_wrap.c:11240: error: parse error before '*' token
mapscript_wrap.c:11240: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1label':
mapscript_wrap.c:11244: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11245: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11246: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11247: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11253: error: parse error before "jlong"
mapscript_wrap.c:11253: error: parse error before '*' token
mapscript_wrap.c:11253: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1label':
mapscript_wrap.c:11254: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:11254: error: parse error before "jresult"
mapscript_wrap.c:11258: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11259: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11260: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11263: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11268: error: syntax error before "void"
mapscript_wrap.c:11268: error: parse error before '*' token
mapscript_wrap.c:11268: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1keysizex':
mapscript_wrap.c:11272: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11273: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11274: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11275: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11281: error: parse error before "jint"
mapscript_wrap.c:11281: error: parse error before '*' token
mapscript_wrap.c:11281: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1keysizex':
mapscript_wrap.c:11282: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:11282: error: parse error before "jresult"
mapscript_wrap.c:11286: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11287: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11288: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11291: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11291: error: parse error before "result"
mapscript_wrap.c:11296: error: syntax error before "void"
mapscript_wrap.c:11296: error: parse error before '*' token
mapscript_wrap.c:11296: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1keysizey':
mapscript_wrap.c:11300: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11301: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11302: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11303: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11309: error: parse error before "jint"
mapscript_wrap.c:11309: error: parse error before '*' token
mapscript_wrap.c:11309: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1keysizey':
mapscript_wrap.c:11310: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:11310: error: parse error before "jresult"
mapscript_wrap.c:11314: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11315: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11316: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11319: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11319: error: parse error before "result"
mapscript_wrap.c:11324: error: syntax error before "void"
mapscript_wrap.c:11324: error: parse error before '*' token
mapscript_wrap.c:11324: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1keyspacingx':
mapscript_wrap.c:11328: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11329: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11330: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11331: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11337: error: parse error before "jint"
mapscript_wrap.c:11337: error: parse error before '*' token
mapscript_wrap.c:11337: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1keyspacingx':
mapscript_wrap.c:11338: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:11338: error: parse error before "jresult"
mapscript_wrap.c:11342: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11343: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11344: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11347: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11347: error: parse error before "result"
mapscript_wrap.c:11352: error: syntax error before "void"
mapscript_wrap.c:11352: error: parse error before '*' token
mapscript_wrap.c:11352: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1keyspacingy':
mapscript_wrap.c:11356: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11357: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11358: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11359: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11365: error: parse error before "jint"
mapscript_wrap.c:11365: error: parse error before '*' token
mapscript_wrap.c:11365: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1keyspacingy':
mapscript_wrap.c:11366: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:11366: error: parse error before "jresult"
mapscript_wrap.c:11370: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11371: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11372: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11375: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11375: error: parse error before "result"
mapscript_wrap.c:11380: error: syntax error before "void"
mapscript_wrap.c:11380: error: parse error before '*' token
mapscript_wrap.c:11380: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1outlinecolor':
mapscript_wrap.c:11384: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11385: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11386: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11387: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11393: error: parse error before "jlong"
mapscript_wrap.c:11393: error: parse error before '*' token
mapscript_wrap.c:11393: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1outlinecolor':
mapscript_wrap.c:11394: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:11394: error: parse error before "jresult"
mapscript_wrap.c:11398: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11399: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11400: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11403: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11408: error: syntax error before "void"
mapscript_wrap.c:11408: error: parse error before '*' token
mapscript_wrap.c:11408: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1status':
mapscript_wrap.c:11412: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11413: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11414: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11415: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11421: error: parse error before "jint"
mapscript_wrap.c:11421: error: parse error before '*' token
mapscript_wrap.c:11421: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1status':
mapscript_wrap.c:11422: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:11422: error: parse error before "jresult"
mapscript_wrap.c:11426: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11427: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11428: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11431: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11431: error: parse error before "result"
mapscript_wrap.c:11436: error: syntax error before "void"
mapscript_wrap.c:11436: error: parse error before '*' token
mapscript_wrap.c:11436: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1height':
mapscript_wrap.c:11440: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11441: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11442: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11443: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11449: error: parse error before "jint"
mapscript_wrap.c:11449: error: parse error before '*' token
mapscript_wrap.c:11449: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1height':
mapscript_wrap.c:11450: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:11450: error: parse error before "jresult"
mapscript_wrap.c:11454: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11455: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11456: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11459: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11459: error: parse error before "result"
mapscript_wrap.c:11464: error: syntax error before "void"
mapscript_wrap.c:11464: error: parse error before '*' token
mapscript_wrap.c:11464: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1width':
mapscript_wrap.c:11468: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11469: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11470: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11471: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11477: error: parse error before "jint"
mapscript_wrap.c:11477: error: parse error before '*' token
mapscript_wrap.c:11477: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1width':
mapscript_wrap.c:11478: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:11478: error: parse error before "jresult"
mapscript_wrap.c:11482: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11483: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11484: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11487: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11487: error: parse error before "result"
mapscript_wrap.c:11492: error: syntax error before "void"
mapscript_wrap.c:11492: error: parse error before '*' token
mapscript_wrap.c:11492: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1position':
mapscript_wrap.c:11496: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11497: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11498: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11499: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11505: error: parse error before "jint"
mapscript_wrap.c:11505: error: parse error before '*' token
mapscript_wrap.c:11505: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1position':
mapscript_wrap.c:11506: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:11506: error: parse error before "jresult"
mapscript_wrap.c:11510: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11511: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11512: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11515: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11515: error: parse error before "result"
mapscript_wrap.c:11520: error: syntax error before "void"
mapscript_wrap.c:11520: error: parse error before '*' token
mapscript_wrap.c:11520: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1postlabelcache':
mapscript_wrap.c:11524: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11525: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11526: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11527: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11533: error: parse error before "jint"
mapscript_wrap.c:11533: error: parse error before '*' token
mapscript_wrap.c:11533: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1postlabelcache':
mapscript_wrap.c:11534: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:11534: error: parse error before "jresult"
mapscript_wrap.c:11538: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11539: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11540: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11543: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11543: error: parse error before "result"
mapscript_wrap.c:11548: error: syntax error before "void"
mapscript_wrap.c:11548: error: parse error before '*' token
mapscript_wrap.c:11548: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1template':
mapscript_wrap.c:11552: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11553: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11554: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11557: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11559: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:11577: error: parse error before "jstring"
mapscript_wrap.c:11577: error: parse error before '*' token
mapscript_wrap.c:11577: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1template':
mapscript_wrap.c:11578: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:11578: error: parse error before "jresult"
mapscript_wrap.c:11582: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11583: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11584: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11588: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11594: error: syntax error before "void"
mapscript_wrap.c:11594: error: parse error before '*' token
mapscript_wrap.c:11594: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1legendObj_1map':
mapscript_wrap.c:11598: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11599: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11600: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11601: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11607: error: parse error before "jlong"
mapscript_wrap.c:11607: error: parse error before '*' token
mapscript_wrap.c:11607: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1legendObj_1map':
mapscript_wrap.c:11608: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:11608: error: parse error before "jresult"
mapscript_wrap.c:11612: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11613: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11614: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11617: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11622: error: parse error before "jlong"
mapscript_wrap.c:11622: error: parse error before '*' token
mapscript_wrap.c:11622: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1legendObj':
mapscript_wrap.c:11623: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:11623: error: parse error before "jresult"
mapscript_wrap.c:11626: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11627: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11663: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11668: error: syntax error before "void"
mapscript_wrap.c:11668: error: parse error before '*' token
mapscript_wrap.c:11668: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1legendObj':
mapscript_wrap.c:11671: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11672: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11673: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11712: error: syntax error before "void"
mapscript_wrap.c:11712: error: parse error before '*' token
mapscript_wrap.c:11712: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1dwhichlatitude':
mapscript_wrap.c:11716: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11717: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11718: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11719: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11725: error: parse error before "jdouble"
mapscript_wrap.c:11725: error: parse error before '*' token
mapscript_wrap.c:11725: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1dwhichlatitude':
mapscript_wrap.c:11726: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:11726: error: parse error before "jresult"
mapscript_wrap.c:11730: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11731: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11732: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11735: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11735: error: parse error before "result"
mapscript_wrap.c:11740: error: syntax error before "void"
mapscript_wrap.c:11740: error: parse error before '*' token
mapscript_wrap.c:11740: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1dwhichlongitude':
mapscript_wrap.c:11744: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11745: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11746: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11747: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11753: error: parse error before "jdouble"
mapscript_wrap.c:11753: error: parse error before '*' token
mapscript_wrap.c:11753: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1dwhichlongitude':
mapscript_wrap.c:11754: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:11754: error: parse error before "jresult"
mapscript_wrap.c:11758: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11759: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11760: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11763: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11763: error: parse error before "result"
mapscript_wrap.c:11768: error: syntax error before "void"
mapscript_wrap.c:11768: error: parse error before '*' token
mapscript_wrap.c:11768: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1dstartlatitude':
mapscript_wrap.c:11772: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11773: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11774: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11775: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11781: error: parse error before "jdouble"
mapscript_wrap.c:11781: error: parse error before '*' token
mapscript_wrap.c:11781: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1dstartlatitude':
mapscript_wrap.c:11782: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:11782: error: parse error before "jresult"
mapscript_wrap.c:11786: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11787: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11788: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11791: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11791: error: parse error before "result"
mapscript_wrap.c:11796: error: syntax error before "void"
mapscript_wrap.c:11796: error: parse error before '*' token
mapscript_wrap.c:11796: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1dstartlongitude':
mapscript_wrap.c:11800: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11801: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11802: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11803: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11809: error: parse error before "jdouble"
mapscript_wrap.c:11809: error: parse error before '*' token
mapscript_wrap.c:11809: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1dstartlongitude':
mapscript_wrap.c:11810: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:11810: error: parse error before "jresult"
mapscript_wrap.c:11814: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11815: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11816: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11819: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11819: error: parse error before "result"
mapscript_wrap.c:11824: error: syntax error before "void"
mapscript_wrap.c:11824: error: parse error before '*' token
mapscript_wrap.c:11824: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1dendlatitude':
mapscript_wrap.c:11828: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11829: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11830: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11831: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c: At top level:
mapscript_wrap.c:11837: error: parse error before "jdouble"
mapscript_wrap.c:11837: error: parse error before '*' token
mapscript_wrap.c:11837: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1dendlatitude':
mapscript_wrap.c:11838: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:11838: error: parse error before "jresult"
mapscript_wrap.c:11842: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11843: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11844: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11847: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11847: error: parse error before "result"
mapscript_wrap.c:11852: error: syntax error before "void"
mapscript_wrap.c:11852: error: parse error before '*' token
mapscript_wrap.c:11852: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1dendlongitude':
mapscript_wrap.c:11856: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11857: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11858: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11859: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11865: error: parse error before "jdouble"
mapscript_wrap.c:11865: error: parse error before '*' token
mapscript_wrap.c:11865: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1dendlongitude':
mapscript_wrap.c:11866: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:11866: error: parse error before "jresult"
mapscript_wrap.c:11870: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11871: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11872: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11875: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11875: error: parse error before "result"
mapscript_wrap.c:11880: error: syntax error before "void"
mapscript_wrap.c:11880: error: parse error before '*' token
mapscript_wrap.c:11880: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1dincrementlatitude':
mapscript_wrap.c:11884: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11885: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11886: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11887: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11893: error: parse error before "jdouble"
mapscript_wrap.c:11893: error: parse error before '*' token
mapscript_wrap.c:11893: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1dincrementlatitude':
mapscript_wrap.c:11894: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:11894: error: parse error before "jresult"
mapscript_wrap.c:11898: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11899: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11900: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11903: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11903: error: parse error before "result"
mapscript_wrap.c:11908: error: syntax error before "void"
mapscript_wrap.c:11908: error: parse error before '*' token
mapscript_wrap.c:11908: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1dincrementlongitude':
mapscript_wrap.c:11912: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11913: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11914: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11915: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11921: error: parse error before "jdouble"
mapscript_wrap.c:11921: error: parse error before '*' token
mapscript_wrap.c:11921: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1dincrementlongitude':
mapscript_wrap.c:11922: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:11922: error: parse error before "jresult"
mapscript_wrap.c:11926: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11927: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11928: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11931: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11931: error: parse error before "result"
mapscript_wrap.c:11936: error: syntax error before "void"
mapscript_wrap.c:11936: error: parse error before '*' token
mapscript_wrap.c:11936: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1minarcs':
mapscript_wrap.c:11940: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11941: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11942: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11943: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11949: error: parse error before "jdouble"
mapscript_wrap.c:11949: error: parse error before '*' token
mapscript_wrap.c:11949: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1minarcs':
mapscript_wrap.c:11950: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:11950: error: parse error before "jresult"
mapscript_wrap.c:11954: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11955: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11956: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11959: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11959: error: parse error before "result"
mapscript_wrap.c:11964: error: syntax error before "void"
mapscript_wrap.c:11964: error: parse error before '*' token
mapscript_wrap.c:11964: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1maxarcs':
mapscript_wrap.c:11968: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11969: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11970: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11971: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:11977: error: parse error before "jdouble"
mapscript_wrap.c:11977: error: parse error before '*' token
mapscript_wrap.c:11977: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1maxarcs':
mapscript_wrap.c:11978: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:11978: error: parse error before "jresult"
mapscript_wrap.c:11982: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11983: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11984: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11987: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:11987: error: parse error before "result"
mapscript_wrap.c:11992: error: syntax error before "void"
mapscript_wrap.c:11992: error: parse error before '*' token
mapscript_wrap.c:11992: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1minincrement':
mapscript_wrap.c:11996: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:11997: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:11998: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:11999: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12005: error: parse error before "jdouble"
mapscript_wrap.c:12005: error: parse error before '*' token
mapscript_wrap.c:12005: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1minincrement':
mapscript_wrap.c:12006: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:12006: error: parse error before "jresult"
mapscript_wrap.c:12010: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12011: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12012: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12015: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12015: error: parse error before "result"
mapscript_wrap.c:12020: error: syntax error before "void"
mapscript_wrap.c:12020: error: parse error before '*' token
mapscript_wrap.c:12020: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1maxincrement':
mapscript_wrap.c:12024: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12025: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12026: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12027: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12033: error: parse error before "jdouble"
mapscript_wrap.c:12033: error: parse error before '*' token
mapscript_wrap.c:12033: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1maxincrement':
mapscript_wrap.c:12034: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:12034: error: parse error before "jresult"
mapscript_wrap.c:12038: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12039: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12040: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12043: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12043: error: parse error before "result"
mapscript_wrap.c:12048: error: syntax error before "void"
mapscript_wrap.c:12048: error: parse error before '*' token
mapscript_wrap.c:12048: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1minsubdivides':
mapscript_wrap.c:12052: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12053: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12054: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12055: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12061: error: parse error before "jdouble"
mapscript_wrap.c:12061: error: parse error before '*' token
mapscript_wrap.c:12061: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1minsubdivides':
mapscript_wrap.c:12062: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:12062: error: parse error before "jresult"
mapscript_wrap.c:12066: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12067: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12068: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12071: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12071: error: parse error before "result"
mapscript_wrap.c:12076: error: syntax error before "void"
mapscript_wrap.c:12076: error: parse error before '*' token
mapscript_wrap.c:12076: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1maxsubdivides':
mapscript_wrap.c:12080: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12081: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12082: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12083: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12089: error: parse error before "jdouble"
mapscript_wrap.c:12089: error: parse error before '*' token
mapscript_wrap.c:12089: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1maxsubdivides':
mapscript_wrap.c:12090: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:12090: error: parse error before "jresult"
mapscript_wrap.c:12094: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12095: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12096: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12099: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12099: error: parse error before "result"
mapscript_wrap.c:12104: error: syntax error before "void"
mapscript_wrap.c:12104: error: parse error before '*' token
mapscript_wrap.c:12104: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1bvertical':
mapscript_wrap.c:12108: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12109: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12110: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12111: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12117: error: parse error before "jint"
mapscript_wrap.c:12117: error: parse error before '*' token
mapscript_wrap.c:12117: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1bvertical':
mapscript_wrap.c:12118: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:12118: error: parse error before "jresult"
mapscript_wrap.c:12122: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12123: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12124: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12127: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12127: error: parse error before "result"
mapscript_wrap.c:12132: error: syntax error before "void"
mapscript_wrap.c:12132: error: parse error before '*' token
mapscript_wrap.c:12132: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1blabelaxes':
mapscript_wrap.c:12136: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12137: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12138: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12139: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12145: error: parse error before "jint"
mapscript_wrap.c:12145: error: parse error before '*' token
mapscript_wrap.c:12145: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1blabelaxes':
mapscript_wrap.c:12146: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:12146: error: parse error before "jresult"
mapscript_wrap.c:12150: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12151: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12152: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12155: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12155: error: parse error before "result"
mapscript_wrap.c:12160: error: syntax error before "void"
mapscript_wrap.c:12160: error: parse error before '*' token
mapscript_wrap.c:12160: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1ilabelstate':
mapscript_wrap.c:12164: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12165: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12166: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12167: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12173: error: parse error before "jint"
mapscript_wrap.c:12173: error: parse error before '*' token
mapscript_wrap.c:12173: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1ilabelstate':
mapscript_wrap.c:12174: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:12174: error: parse error before "jresult"
mapscript_wrap.c:12178: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12179: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12180: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12183: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12183: error: parse error before "result"
mapscript_wrap.c:12188: error: syntax error before "void"
mapscript_wrap.c:12188: error: parse error before '*' token
mapscript_wrap.c:12188: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1ilabeltype':
mapscript_wrap.c:12192: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12193: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12194: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12195: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12201: error: parse error before "jint"
mapscript_wrap.c:12201: error: parse error before '*' token
mapscript_wrap.c:12201: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1ilabeltype':
mapscript_wrap.c:12202: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:12202: error: parse error before "jresult"
mapscript_wrap.c:12206: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12207: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12208: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12211: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12211: error: parse error before "result"
mapscript_wrap.c:12216: error: syntax error before "void"
mapscript_wrap.c:12216: error: parse error before '*' token
mapscript_wrap.c:12216: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1extent':
mapscript_wrap.c:12220: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12221: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12222: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12223: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12229: error: parse error before "jlong"
mapscript_wrap.c:12229: error: parse error before '*' token
mapscript_wrap.c:12229: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1extent':
mapscript_wrap.c:12230: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:12230: error: parse error before "jresult"
mapscript_wrap.c:12234: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12235: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12236: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12239: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12244: error: syntax error before "void"
mapscript_wrap.c:12244: error: parse error before '*' token
mapscript_wrap.c:12244: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1pboundinglines':
mapscript_wrap.c:12248: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12249: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12250: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12251: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12257: error: parse error before "jlong"
mapscript_wrap.c:12257: error: parse error before '*' token
mapscript_wrap.c:12257: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1pboundinglines':
mapscript_wrap.c:12258: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:12258: error: parse error before "jresult"
mapscript_wrap.c:12262: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12263: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12264: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12267: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12272: error: syntax error before "void"
mapscript_wrap.c:12272: error: parse error before '*' token
mapscript_wrap.c:12272: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1pboundingpoints':
mapscript_wrap.c:12276: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12277: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12278: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12279: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12285: error: parse error before "jlong"
mapscript_wrap.c:12285: error: parse error before '*' token
mapscript_wrap.c:12285: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1pboundingpoints':
mapscript_wrap.c:12286: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:12286: error: parse error before "jresult"
mapscript_wrap.c:12290: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12291: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12292: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12295: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12300: error: syntax error before "void"
mapscript_wrap.c:12300: error: parse error before '*' token
mapscript_wrap.c:12300: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1graticuleObj_1labelformat':
mapscript_wrap.c:12304: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12305: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12306: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12309: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12311: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:12329: error: parse error before "jstring"
mapscript_wrap.c:12329: error: parse error before '*' token
mapscript_wrap.c:12329: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1graticuleObj_1labelformat':
mapscript_wrap.c:12330: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:12330: error: parse error before "jresult"
mapscript_wrap.c:12334: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12335: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12336: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12340: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12346: error: parse error before "jlong"
mapscript_wrap.c:12346: error: parse error before '*' token
mapscript_wrap.c:12346: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1graticuleObj':
mapscript_wrap.c:12347: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:12347: error: parse error before "jresult"
mapscript_wrap.c:12350: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12351: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12387: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12392: error: syntax error before "void"
mapscript_wrap.c:12392: error: parse error before '*' token
mapscript_wrap.c:12392: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1graticuleObj':
mapscript_wrap.c:12395: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12396: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12397: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12436: error: syntax error before "void"
mapscript_wrap.c:12436: error: parse error before '*' token
mapscript_wrap.c:12436: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1classitem':
mapscript_wrap.c:12440: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12441: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12442: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12445: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12447: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:12465: error: parse error before "jstring"
mapscript_wrap.c:12465: error: parse error before '*' token
mapscript_wrap.c:12465: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1classitem':
mapscript_wrap.c:12466: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:12466: error: parse error before "jresult"
mapscript_wrap.c:12470: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12471: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12472: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12476: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12482: error: parse error before "jint"
mapscript_wrap.c:12482: error: parse error before '*' token
mapscript_wrap.c:12482: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1numclasses':
mapscript_wrap.c:12483: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:12483: error: parse error before "jresult"
mapscript_wrap.c:12487: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12488: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12489: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12492: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12492: error: parse error before "result"
mapscript_wrap.c:12497: error: parse error before "jint"
mapscript_wrap.c:12497: error: parse error before '*' token
mapscript_wrap.c:12497: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1index':
mapscript_wrap.c:12498: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:12498: error: parse error before "jresult"
mapscript_wrap.c:12502: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12503: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12504: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12507: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12507: error: parse error before "result"
mapscript_wrap.c:12512: error: parse error before "jlong"
mapscript_wrap.c:12512: error: parse error before '*' token
mapscript_wrap.c:12512: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1map':
mapscript_wrap.c:12513: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:12513: error: parse error before "jresult"
mapscript_wrap.c:12517: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12518: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12519: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12522: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12527: error: syntax error before "void"
mapscript_wrap.c:12527: error: parse error before '*' token
mapscript_wrap.c:12527: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1header':
mapscript_wrap.c:12531: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12532: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12533: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12536: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12538: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:12556: error: parse error before "jstring"
mapscript_wrap.c:12556: error: parse error before '*' token
mapscript_wrap.c:12556: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1header':
mapscript_wrap.c:12557: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:12557: error: parse error before "jresult"
mapscript_wrap.c:12561: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12562: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12563: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12567: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12573: error: syntax error before "void"
mapscript_wrap.c:12573: error: parse error before '*' token
mapscript_wrap.c:12573: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1footer':
mapscript_wrap.c:12577: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12578: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12579: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12582: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12584: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:12602: error: parse error before "jstring"
mapscript_wrap.c:12602: error: parse error before '*' token
mapscript_wrap.c:12602: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1footer':
mapscript_wrap.c:12603: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:12603: error: parse error before "jresult"
mapscript_wrap.c:12607: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12608: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12609: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12613: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12619: error: syntax error before "void"
mapscript_wrap.c:12619: error: parse error before '*' token
mapscript_wrap.c:12619: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1template':
mapscript_wrap.c:12623: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12624: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12625: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12628: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12630: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:12648: error: parse error before "jstring"
mapscript_wrap.c:12648: error: parse error before '*' token
mapscript_wrap.c:12648: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1template':
mapscript_wrap.c:12649: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:12649: error: parse error before "jresult"
mapscript_wrap.c:12653: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12654: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12655: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12659: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12665: error: syntax error before "void"
mapscript_wrap.c:12665: error: parse error before '*' token
mapscript_wrap.c:12665: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1name':
mapscript_wrap.c:12669: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12670: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12671: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12674: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12676: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:12694: error: parse error before "jstring"
mapscript_wrap.c:12694: error: parse error before '*' token
mapscript_wrap.c:12694: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1name':
mapscript_wrap.c:12695: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:12695: error: parse error before "jresult"
mapscript_wrap.c:12699: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12700: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12701: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12705: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12711: error: syntax error before "void"
mapscript_wrap.c:12711: error: parse error before '*' token
mapscript_wrap.c:12711: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1group':
mapscript_wrap.c:12715: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12716: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12717: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12720: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12722: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:12740: error: parse error before "jstring"
mapscript_wrap.c:12740: error: parse error before '*' token
mapscript_wrap.c:12740: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1group':
mapscript_wrap.c:12741: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:12741: error: parse error before "jresult"
mapscript_wrap.c:12745: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12746: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12747: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12751: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12757: error: syntax error before "void"
mapscript_wrap.c:12757: error: parse error before '*' token
mapscript_wrap.c:12757: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1status':
mapscript_wrap.c:12761: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12762: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12763: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12764: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12770: error: parse error before "jint"
mapscript_wrap.c:12770: error: parse error before '*' token
mapscript_wrap.c:12770: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1status':
mapscript_wrap.c:12771: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:12771: error: parse error before "jresult"
mapscript_wrap.c:12775: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12776: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12777: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12780: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12780: error: parse error before "result"
mapscript_wrap.c:12785: error: syntax error before "void"
mapscript_wrap.c:12785: error: parse error before '*' token
mapscript_wrap.c:12785: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1data':
mapscript_wrap.c:12789: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12790: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12791: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12794: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12796: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:12814: error: parse error before "jstring"
mapscript_wrap.c:12814: error: parse error before '*' token
mapscript_wrap.c:12814: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1data':
mapscript_wrap.c:12815: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:12815: error: parse error before "jresult"
mapscript_wrap.c:12819: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12820: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12821: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12825: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12831: error: syntax error before "void"
mapscript_wrap.c:12831: error: parse error before '*' token
mapscript_wrap.c:12831: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1type':
mapscript_wrap.c:12835: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12836: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12837: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12838: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12844: error: parse error before "jint"
mapscript_wrap.c:12844: error: parse error before '*' token
mapscript_wrap.c:12844: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1type':
mapscript_wrap.c:12845: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:12845: error: parse error before "jresult"
mapscript_wrap.c:12849: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12850: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12851: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12854: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12854: error: parse error before "result"
mapscript_wrap.c:12859: error: syntax error before "void"
mapscript_wrap.c:12859: error: parse error before '*' token
mapscript_wrap.c:12859: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1tolerance':
mapscript_wrap.c:12863: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12864: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12865: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12866: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12872: error: parse error before "jdouble"
mapscript_wrap.c:12872: error: parse error before '*' token
mapscript_wrap.c:12872: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1tolerance':
mapscript_wrap.c:12873: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:12873: error: parse error before "jresult"
mapscript_wrap.c:12877: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12878: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12879: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12882: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12882: error: parse error before "result"
mapscript_wrap.c:12887: error: syntax error before "void"
mapscript_wrap.c:12887: error: parse error before '*' token
mapscript_wrap.c:12887: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1toleranceunits':
mapscript_wrap.c:12891: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12892: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12893: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12894: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12900: error: parse error before "jint"
mapscript_wrap.c:12900: error: parse error before '*' token
mapscript_wrap.c:12900: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1toleranceunits':
mapscript_wrap.c:12901: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:12901: error: parse error before "jresult"
mapscript_wrap.c:12905: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12906: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12907: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12910: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12910: error: parse error before "result"
mapscript_wrap.c:12915: error: syntax error before "void"
mapscript_wrap.c:12915: error: parse error before '*' token
mapscript_wrap.c:12915: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1symbolscale':
mapscript_wrap.c:12919: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12920: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12921: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12922: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12928: error: parse error before "jdouble"
mapscript_wrap.c:12928: error: parse error before '*' token
mapscript_wrap.c:12928: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1symbolscale':
mapscript_wrap.c:12929: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:12929: error: parse error before "jresult"
mapscript_wrap.c:12933: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12934: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12935: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12938: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12938: error: parse error before "result"
mapscript_wrap.c:12943: error: syntax error before "void"
mapscript_wrap.c:12943: error: parse error before '*' token
mapscript_wrap.c:12943: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1minscale':
mapscript_wrap.c:12947: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12948: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12949: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12950: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12956: error: parse error before "jdouble"
mapscript_wrap.c:12956: error: parse error before '*' token
mapscript_wrap.c:12956: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1minscale':
mapscript_wrap.c:12957: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:12957: error: parse error before "jresult"
mapscript_wrap.c:12961: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12962: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12963: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12966: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12966: error: parse error before "result"
mapscript_wrap.c:12971: error: syntax error before "void"
mapscript_wrap.c:12971: error: parse error before '*' token
mapscript_wrap.c:12971: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1maxscale':
mapscript_wrap.c:12975: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12976: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12977: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12978: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:12984: error: parse error before "jdouble"
mapscript_wrap.c:12984: error: parse error before '*' token
mapscript_wrap.c:12984: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1maxscale':
mapscript_wrap.c:12985: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:12985: error: parse error before "jresult"
mapscript_wrap.c:12989: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:12990: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:12991: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:12994: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:12994: error: parse error before "result"
mapscript_wrap.c:12999: error: syntax error before "void"
mapscript_wrap.c:12999: error: parse error before '*' token
mapscript_wrap.c:12999: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1labelminscale':
mapscript_wrap.c:13003: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13004: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13005: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13006: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13012: error: parse error before "jdouble"
mapscript_wrap.c:13012: error: parse error before '*' token
mapscript_wrap.c:13012: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1labelminscale':
mapscript_wrap.c:13013: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:13013: error: parse error before "jresult"
mapscript_wrap.c:13017: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13018: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13019: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13022: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13022: error: parse error before "result"
mapscript_wrap.c:13027: error: syntax error before "void"
mapscript_wrap.c:13027: error: parse error before '*' token
mapscript_wrap.c:13027: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1labelmaxscale':
mapscript_wrap.c:13031: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13032: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13033: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13034: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13040: error: parse error before "jdouble"
mapscript_wrap.c:13040: error: parse error before '*' token
mapscript_wrap.c:13040: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1labelmaxscale':
mapscript_wrap.c:13041: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:13041: error: parse error before "jresult"
mapscript_wrap.c:13045: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13046: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13047: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13050: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13050: error: parse error before "result"
mapscript_wrap.c:13055: error: syntax error before "void"
mapscript_wrap.c:13055: error: parse error before '*' token
mapscript_wrap.c:13055: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1sizeunits':
mapscript_wrap.c:13059: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13060: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13061: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13062: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13068: error: parse error before "jint"
mapscript_wrap.c:13068: error: parse error before '*' token
mapscript_wrap.c:13068: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1sizeunits':
mapscript_wrap.c:13069: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13069: error: parse error before "jresult"
mapscript_wrap.c:13073: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13074: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13075: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13078: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13078: error: parse error before "result"
mapscript_wrap.c:13083: error: syntax error before "void"
mapscript_wrap.c:13083: error: parse error before '*' token
mapscript_wrap.c:13083: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1maxfeatures':
mapscript_wrap.c:13087: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13088: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13089: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13090: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13096: error: parse error before "jint"
mapscript_wrap.c:13096: error: parse error before '*' token
mapscript_wrap.c:13096: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1maxfeatures':
mapscript_wrap.c:13097: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13097: error: parse error before "jresult"
mapscript_wrap.c:13101: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13102: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13103: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13106: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13106: error: parse error before "result"
mapscript_wrap.c:13111: error: syntax error before "void"
mapscript_wrap.c:13111: error: parse error before '*' token
mapscript_wrap.c:13111: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1offsite':
mapscript_wrap.c:13115: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13116: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13117: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13118: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13124: error: parse error before "jlong"
mapscript_wrap.c:13124: error: parse error before '*' token
mapscript_wrap.c:13124: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1offsite':
mapscript_wrap.c:13125: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:13125: error: parse error before "jresult"
mapscript_wrap.c:13129: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13130: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13131: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13134: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13139: error: syntax error before "void"
mapscript_wrap.c:13139: error: parse error before '*' token
mapscript_wrap.c:13139: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1transform':
mapscript_wrap.c:13143: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13144: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13145: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13146: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13152: error: parse error before "jint"
mapscript_wrap.c:13152: error: parse error before '*' token
mapscript_wrap.c:13152: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1transform':
mapscript_wrap.c:13153: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13153: error: parse error before "jresult"
mapscript_wrap.c:13157: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13158: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13159: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13162: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13162: error: parse error before "result"
mapscript_wrap.c:13167: error: syntax error before "void"
mapscript_wrap.c:13167: error: parse error before '*' token
mapscript_wrap.c:13167: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1labelcache':
mapscript_wrap.c:13171: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13172: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13173: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13174: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13180: error: parse error before "jint"
mapscript_wrap.c:13180: error: parse error before '*' token
mapscript_wrap.c:13180: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1labelcache':
mapscript_wrap.c:13181: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13181: error: parse error before "jresult"
mapscript_wrap.c:13185: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13186: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13187: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13190: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13190: error: parse error before "result"
mapscript_wrap.c:13195: error: syntax error before "void"
mapscript_wrap.c:13195: error: parse error before '*' token
mapscript_wrap.c:13195: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1postlabelcache':
mapscript_wrap.c:13199: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13200: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13201: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13202: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13208: error: parse error before "jint"
mapscript_wrap.c:13208: error: parse error before '*' token
mapscript_wrap.c:13208: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1postlabelcache':
mapscript_wrap.c:13209: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13209: error: parse error before "jresult"
mapscript_wrap.c:13213: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13214: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13215: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13218: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13218: error: parse error before "result"
mapscript_wrap.c:13223: error: syntax error before "void"
mapscript_wrap.c:13223: error: parse error before '*' token
mapscript_wrap.c:13223: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1labelitem':
mapscript_wrap.c:13227: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13228: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13229: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13232: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13234: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:13252: error: parse error before "jstring"
mapscript_wrap.c:13252: error: parse error before '*' token
mapscript_wrap.c:13252: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1labelitem':
mapscript_wrap.c:13253: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:13253: error: parse error before "jresult"
mapscript_wrap.c:13257: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13258: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13259: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13263: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c: At top level:
mapscript_wrap.c:13269: error: syntax error before "void"
mapscript_wrap.c:13269: error: parse error before '*' token
mapscript_wrap.c:13269: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1labelsizeitem':
mapscript_wrap.c:13273: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13274: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13275: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13278: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13280: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:13298: error: parse error before "jstring"
mapscript_wrap.c:13298: error: parse error before '*' token
mapscript_wrap.c:13298: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1labelsizeitem':
mapscript_wrap.c:13299: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:13299: error: parse error before "jresult"
mapscript_wrap.c:13303: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13304: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13305: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13309: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13315: error: syntax error before "void"
mapscript_wrap.c:13315: error: parse error before '*' token
mapscript_wrap.c:13315: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1labelangleitem':
mapscript_wrap.c:13319: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13320: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13321: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13324: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13326: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:13344: error: parse error before "jstring"
mapscript_wrap.c:13344: error: parse error before '*' token
mapscript_wrap.c:13344: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1labelangleitem':
mapscript_wrap.c:13345: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:13345: error: parse error before "jresult"
mapscript_wrap.c:13349: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13350: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13351: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13355: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13361: error: syntax error before "void"
mapscript_wrap.c:13361: error: parse error before '*' token
mapscript_wrap.c:13361: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1labelitemindex':
mapscript_wrap.c:13365: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13366: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13367: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13368: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13374: error: parse error before "jint"
mapscript_wrap.c:13374: error: parse error before '*' token
mapscript_wrap.c:13374: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1labelitemindex':
mapscript_wrap.c:13375: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13375: error: parse error before "jresult"
mapscript_wrap.c:13379: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13380: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13381: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13384: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13384: error: parse error before "result"
mapscript_wrap.c:13389: error: syntax error before "void"
mapscript_wrap.c:13389: error: parse error before '*' token
mapscript_wrap.c:13389: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1labelsizeitemindex':
mapscript_wrap.c:13393: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13394: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13395: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13396: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13402: error: parse error before "jint"
mapscript_wrap.c:13402: error: parse error before '*' token
mapscript_wrap.c:13402: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1labelsizeitemindex':
mapscript_wrap.c:13403: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13403: error: parse error before "jresult"
mapscript_wrap.c:13407: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13408: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13409: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13412: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13412: error: parse error before "result"
mapscript_wrap.c:13417: error: syntax error before "void"
mapscript_wrap.c:13417: error: parse error before '*' token
mapscript_wrap.c:13417: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1labelangleitemindex':
mapscript_wrap.c:13421: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13422: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13423: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13424: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13430: error: parse error before "jint"
mapscript_wrap.c:13430: error: parse error before '*' token
mapscript_wrap.c:13430: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1labelangleitemindex':
mapscript_wrap.c:13431: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13431: error: parse error before "jresult"
mapscript_wrap.c:13435: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13436: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13437: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13440: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13440: error: parse error before "result"
mapscript_wrap.c:13445: error: syntax error before "void"
mapscript_wrap.c:13445: error: parse error before '*' token
mapscript_wrap.c:13445: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1tileitem':
mapscript_wrap.c:13449: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13450: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13451: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13454: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13456: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:13474: error: parse error before "jstring"
mapscript_wrap.c:13474: error: parse error before '*' token
mapscript_wrap.c:13474: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1tileitem':
mapscript_wrap.c:13475: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:13475: error: parse error before "jresult"
mapscript_wrap.c:13479: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13480: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13481: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13485: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13491: error: syntax error before "void"
mapscript_wrap.c:13491: error: parse error before '*' token
mapscript_wrap.c:13491: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1tileindex':
mapscript_wrap.c:13495: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13496: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13497: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13500: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13502: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:13520: error: parse error before "jstring"
mapscript_wrap.c:13520: error: parse error before '*' token
mapscript_wrap.c:13520: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1tileindex':
mapscript_wrap.c:13521: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:13521: error: parse error before "jresult"
mapscript_wrap.c:13525: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13526: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13527: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13531: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13537: error: syntax error before "void"
mapscript_wrap.c:13537: error: parse error before '*' token
mapscript_wrap.c:13537: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1units':
mapscript_wrap.c:13541: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13542: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13543: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13544: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13550: error: parse error before "jint"
mapscript_wrap.c:13550: error: parse error before '*' token
mapscript_wrap.c:13550: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1units':
mapscript_wrap.c:13551: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13551: error: parse error before "jresult"
mapscript_wrap.c:13555: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13556: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13557: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13560: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13560: error: parse error before "result"
mapscript_wrap.c:13565: error: syntax error before "void"
mapscript_wrap.c:13565: error: parse error before '*' token
mapscript_wrap.c:13565: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1connection':
mapscript_wrap.c:13569: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13570: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13571: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13574: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13576: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:13594: error: parse error before "jstring"
mapscript_wrap.c:13594: error: parse error before '*' token
mapscript_wrap.c:13594: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1connection':
mapscript_wrap.c:13595: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:13595: error: parse error before "jresult"
mapscript_wrap.c:13599: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13600: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13601: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13605: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13611: error: syntax error before "void"
mapscript_wrap.c:13611: error: parse error before '*' token
mapscript_wrap.c:13611: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1connectiontype':
mapscript_wrap.c:13615: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13616: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13617: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13618: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13624: error: parse error before "jint"
mapscript_wrap.c:13624: error: parse error before '*' token
mapscript_wrap.c:13624: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1connectiontype':
mapscript_wrap.c:13625: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13625: error: parse error before "jresult"
mapscript_wrap.c:13629: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13630: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13631: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13634: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13634: error: parse error before "result"
mapscript_wrap.c:13639: error: parse error before "jint"
mapscript_wrap.c:13639: error: parse error before '*' token
mapscript_wrap.c:13639: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1numitems':
mapscript_wrap.c:13640: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13640: error: parse error before "jresult"
mapscript_wrap.c:13644: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13645: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13646: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13649: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13649: error: parse error before "result"
mapscript_wrap.c:13654: error: syntax error before "void"
mapscript_wrap.c:13654: error: parse error before '*' token
mapscript_wrap.c:13654: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1bandsitem':
mapscript_wrap.c:13658: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13659: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13660: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13663: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13665: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:13683: error: parse error before "jstring"
mapscript_wrap.c:13683: error: parse error before '*' token
mapscript_wrap.c:13683: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1bandsitem':
mapscript_wrap.c:13684: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:13684: error: parse error before "jresult"
mapscript_wrap.c:13688: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13689: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13690: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13694: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13700: error: syntax error before "void"
mapscript_wrap.c:13700: error: parse error before '*' token
mapscript_wrap.c:13700: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1filteritem':
mapscript_wrap.c:13704: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13705: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13706: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13709: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13711: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:13729: error: parse error before "jstring"
mapscript_wrap.c:13729: error: parse error before '*' token
mapscript_wrap.c:13729: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1filteritem':
mapscript_wrap.c:13730: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:13730: error: parse error before "jresult"
mapscript_wrap.c:13734: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13735: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13736: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13740: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13746: error: syntax error before "void"
mapscript_wrap.c:13746: error: parse error before '*' token
mapscript_wrap.c:13746: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1styleitem':
mapscript_wrap.c:13750: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13751: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13752: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13755: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13757: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:13775: error: parse error before "jstring"
mapscript_wrap.c:13775: error: parse error before '*' token
mapscript_wrap.c:13775: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1styleitem':
mapscript_wrap.c:13776: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:13776: error: parse error before "jresult"
mapscript_wrap.c:13780: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13781: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13782: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13786: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13792: error: syntax error before "void"
mapscript_wrap.c:13792: error: parse error before '*' token
mapscript_wrap.c:13792: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1requires':
mapscript_wrap.c:13796: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13797: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13798: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13801: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13803: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:13821: error: parse error before "jstring"
mapscript_wrap.c:13821: error: parse error before '*' token
mapscript_wrap.c:13821: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1requires':
mapscript_wrap.c:13822: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:13822: error: parse error before "jresult"
mapscript_wrap.c:13826: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13827: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13828: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13832: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13838: error: syntax error before "void"
mapscript_wrap.c:13838: error: parse error before '*' token
mapscript_wrap.c:13838: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1labelrequires':
mapscript_wrap.c:13842: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13843: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13844: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13847: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13849: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:13867: error: parse error before "jstring"
mapscript_wrap.c:13867: error: parse error before '*' token
mapscript_wrap.c:13867: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1labelrequires':
mapscript_wrap.c:13868: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:13868: error: parse error before "jresult"
mapscript_wrap.c:13872: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13873: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13874: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13878: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13884: error: syntax error before "void"
mapscript_wrap.c:13884: error: parse error before '*' token
mapscript_wrap.c:13884: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1metadata':
mapscript_wrap.c:13888: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13889: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13890: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13891: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13897: error: parse error before "jlong"
mapscript_wrap.c:13897: error: parse error before '*' token
mapscript_wrap.c:13897: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1metadata':
mapscript_wrap.c:13898: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:13898: error: parse error before "jresult"
mapscript_wrap.c:13902: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13903: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13904: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13907: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13912: error: syntax error before "void"
mapscript_wrap.c:13912: error: parse error before '*' token
mapscript_wrap.c:13912: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1transparency':
mapscript_wrap.c:13916: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13917: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13918: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13919: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13925: error: parse error before "jint"
mapscript_wrap.c:13925: error: parse error before '*' token
mapscript_wrap.c:13925: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1transparency':
mapscript_wrap.c:13926: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13926: error: parse error before "jresult"
mapscript_wrap.c:13930: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13931: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13932: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13935: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13935: error: parse error before "result"
mapscript_wrap.c:13940: error: syntax error before "void"
mapscript_wrap.c:13940: error: parse error before '*' token
mapscript_wrap.c:13940: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1dump':
mapscript_wrap.c:13944: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13945: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13946: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13947: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13953: error: parse error before "jint"
mapscript_wrap.c:13953: error: parse error before '*' token
mapscript_wrap.c:13953: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1dump':
mapscript_wrap.c:13954: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13954: error: parse error before "jresult"
mapscript_wrap.c:13958: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13959: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13960: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13963: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13963: error: parse error before "result"
mapscript_wrap.c:13968: error: syntax error before "void"
mapscript_wrap.c:13968: error: parse error before '*' token
mapscript_wrap.c:13968: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1layerObj_1debug':
mapscript_wrap.c:13972: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13973: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13974: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13975: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:13981: error: parse error before "jint"
mapscript_wrap.c:13981: error: parse error before '*' token
mapscript_wrap.c:13981: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1debug':
mapscript_wrap.c:13982: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13982: error: parse error before "jresult"
mapscript_wrap.c:13986: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:13987: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:13988: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:13991: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:13991: error: parse error before "result"
mapscript_wrap.c:13996: error: parse error before "jint"
mapscript_wrap.c:13996: error: parse error before '*' token
mapscript_wrap.c:13996: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1numprocessing':
mapscript_wrap.c:13997: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:13997: error: parse error before "jresult"
mapscript_wrap.c:14001: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14002: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14003: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14006: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14006: error: parse error before "result"
mapscript_wrap.c:14011: error: parse error before "jint"
mapscript_wrap.c:14011: error: parse error before '*' token
mapscript_wrap.c:14011: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1layerObj_1numjoins':
mapscript_wrap.c:14012: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:14012: error: parse error before "jresult"
mapscript_wrap.c:14016: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14017: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14018: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14021: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14021: error: parse error before "result"
mapscript_wrap.c:14026: error: parse error before "jlong"
mapscript_wrap.c:14026: error: parse error before '*' token
mapscript_wrap.c:14026: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1layerObj':
mapscript_wrap.c:14027: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:14027: error: parse error before "jresult"
mapscript_wrap.c:14031: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14032: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14033: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14069: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14074: error: syntax error before "void"
mapscript_wrap.c:14074: error: parse error before '*' token
mapscript_wrap.c:14074: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1layerObj':
mapscript_wrap.c:14077: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14078: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14079: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14118: error: parse error before "jlong"
mapscript_wrap.c:14118: error: parse error before '*' token
mapscript_wrap.c:14118: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1cloneLayer':
mapscript_wrap.c:14119: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:14119: error: parse error before "jresult"
mapscript_wrap.c:14123: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14124: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14125: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14161: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14166: error: parse error before "jint"
mapscript_wrap.c:14166: error: parse error before '*' token
mapscript_wrap.c:14166: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1insertClass':
mapscript_wrap.c:14167: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:14167: error: parse error before "jresult"
mapscript_wrap.c:14173: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14174: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14175: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14176: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:14177: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:14213: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14213: error: parse error before "result"
mapscript_wrap.c:14218: error: parse error before "jlong"
mapscript_wrap.c:14218: error: parse error before '*' token
mapscript_wrap.c:14218: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1removeClass':
mapscript_wrap.c:14219: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:14219: error: parse error before "jresult"
mapscript_wrap.c:14224: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14225: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14226: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14227: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:14263: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14268: error: parse error before "jint"
mapscript_wrap.c:14268: error: parse error before '*' token
mapscript_wrap.c:14268: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1open':
mapscript_wrap.c:14269: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:14269: error: parse error before "jresult"
mapscript_wrap.c:14273: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14274: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14275: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14311: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14311: error: parse error before "result"
mapscript_wrap.c:14316: error: syntax error before "void"
mapscript_wrap.c:14316: error: parse error before '*' token
mapscript_wrap.c:14316: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1close':
mapscript_wrap.c:14319: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14320: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14321: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14360: error: parse error before "jlong"
mapscript_wrap.c:14360: error: parse error before '*' token
mapscript_wrap.c:14360: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getFeature':
mapscript_wrap.c:14361: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:14361: error: parse error before "jresult"
mapscript_wrap.c:14367: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14368: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14369: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14370: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:14371: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:14407: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14412: error: parse error before "jint"
mapscript_wrap.c:14412: error: parse error before '*' token
mapscript_wrap.c:14412: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getShape':
mapscript_wrap.c:14413: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:14413: error: parse error before "jresult"
mapscript_wrap.c:14420: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14421: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14422: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14423: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:14424: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:14425: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:14461: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14461: error: parse error before "result"
mapscript_wrap.c:14466: error: parse error before "jint"
mapscript_wrap.c:14466: error: parse error before '*' token
mapscript_wrap.c:14466: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getNumResults':
mapscript_wrap.c:14467: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:14467: error: parse error before "jresult"
mapscript_wrap.c:14471: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14472: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14473: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14509: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14509: error: parse error before "result"
mapscript_wrap.c:14514: error: parse error before "jlong"
mapscript_wrap.c:14514: error: parse error before '*' token
mapscript_wrap.c:14514: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getResult':
mapscript_wrap.c:14515: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:14515: error: parse error before "jresult"
mapscript_wrap.c:14520: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14521: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14522: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14523: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:14559: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14564: error: parse error before "jlong"
mapscript_wrap.c:14564: error: parse error before '*' token
mapscript_wrap.c:14564: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getClass':
mapscript_wrap.c:14565: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:14565: error: parse error before "jresult"
mapscript_wrap.c:14570: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14571: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14572: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14573: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:14609: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14614: error: parse error before "jstring"
mapscript_wrap.c:14614: error: parse error before '*' token
mapscript_wrap.c:14614: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getItem':
mapscript_wrap.c:14615: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:14615: error: parse error before "jresult"
mapscript_wrap.c:14620: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14621: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14622: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14623: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:14660: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14666: error: parse error before "jint"
mapscript_wrap.c:14666: error: parse error before '*' token
mapscript_wrap.c:14666: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1draw':
mapscript_wrap.c:14667: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:14667: error: parse error before "jresult"
mapscript_wrap.c:14673: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14674: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14675: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14676: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:14677: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:14713: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14713: error: parse error before "result"
mapscript_wrap.c:14718: error: parse error before "jint"
mapscript_wrap.c:14718: error: parse error before '*' token
mapscript_wrap.c:14718: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1drawQuery':
mapscript_wrap.c:14719: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:14719: error: parse error before "jresult"
mapscript_wrap.c:14725: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14726: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14727: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14728: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:14729: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:14765: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14765: error: parse error before "result"
mapscript_wrap.c:14770: error: parse error before "jint"
mapscript_wrap.c:14770: error: parse error before '*' token
mapscript_wrap.c:14770: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1queryByAttributes':
mapscript_wrap.c:14771: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:14771: error: parse error before "jresult"
mapscript_wrap.c:14779: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14780: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14781: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14782: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:14785: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:14792: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:14797: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:14833: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14833: error: parse error before "result"
mapscript_wrap.c:14844: error: parse error before "jint"
mapscript_wrap.c:14844: error: parse error before '*' token
mapscript_wrap.c:14844: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1queryByPoint':
mapscript_wrap.c:14845: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:14845: error: parse error before "jresult"
mapscript_wrap.c:14853: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14854: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14855: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14856: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:14857: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:14858: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:14859: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:14895: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14895: error: parse error before "result"
mapscript_wrap.c:14900: error: parse error before "jint"
mapscript_wrap.c:14900: error: parse error before '*' token
mapscript_wrap.c:14900: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1queryByRect':
mapscript_wrap.c:14901: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:14901: error: parse error before "jresult"
mapscript_wrap.c:14908: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14909: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14910: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14911: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:14912: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:14953: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:14953: error: parse error before "result"
mapscript_wrap.c:14958: error: parse error before "jint"
mapscript_wrap.c:14958: error: parse error before '*' token
mapscript_wrap.c:14958: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1queryByFeatures':
mapscript_wrap.c:14959: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:14959: error: parse error before "jresult"
mapscript_wrap.c:14965: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:14966: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:14967: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:14968: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:14969: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:15005: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15005: error: parse error before "result"
mapscript_wrap.c:15010: error: parse error before "jint"
mapscript_wrap.c:15010: error: parse error before '*' token
mapscript_wrap.c:15010: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1queryByShape':
mapscript_wrap.c:15011: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:15011: error: parse error before "jresult"
mapscript_wrap.c:15017: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15018: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15019: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15020: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:15021: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:15057: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15057: error: parse error before "result"
mapscript_wrap.c:15062: error: parse error before "jint"
mapscript_wrap.c:15062: error: parse error before '*' token
mapscript_wrap.c:15062: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1queryByIndex':
mapscript_wrap.c:15063: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:15063: error: parse error before "jresult"
mapscript_wrap.c:15071: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15072: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15073: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15074: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:15075: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:15076: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:15077: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:15113: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15113: error: parse error before "result"
mapscript_wrap.c:15118: error: parse error before "jlong"
mapscript_wrap.c:15118: error: parse error before '*' token
mapscript_wrap.c:15118: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getResults':
mapscript_wrap.c:15119: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:15119: error: parse error before "jresult"
mapscript_wrap.c:15123: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15124: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15125: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15161: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15166: error: parse error before "jint"
mapscript_wrap.c:15166: error: parse error before '*' token
mapscript_wrap.c:15166: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1setFilter':
mapscript_wrap.c:15167: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:15167: error: parse error before "jresult"
mapscript_wrap.c:15172: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15173: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15174: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15177: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:15217: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15217: error: parse error before "result"
mapscript_wrap.c:15225: error: parse error before "jstring"
mapscript_wrap.c:15225: error: parse error before '*' token
mapscript_wrap.c:15225: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getFilterString':
mapscript_wrap.c:15226: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:15226: error: parse error before "jresult"
mapscript_wrap.c:15230: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15231: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15232: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15269: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15276: error: parse error before "jint"
mapscript_wrap.c:15276: error: parse error before '*' token
mapscript_wrap.c:15276: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1setWKTProjection':
mapscript_wrap.c:15277: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:15277: error: parse error before "jresult"
mapscript_wrap.c:15282: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15283: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15284: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15287: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:15327: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15327: error: parse error before "result"
mapscript_wrap.c:15335: error: parse error before "jstring"
mapscript_wrap.c:15335: error: parse error before '*' token
mapscript_wrap.c:15335: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getProjection':
mapscript_wrap.c:15336: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:15336: error: parse error before "jresult"
mapscript_wrap.c:15340: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15341: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15342: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15379: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15386: error: parse error before "jint"
mapscript_wrap.c:15386: error: parse error before '*' token
mapscript_wrap.c:15386: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1setProjection':
mapscript_wrap.c:15387: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:15387: error: parse error before "jresult"
mapscript_wrap.c:15392: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15393: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15394: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15397: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:15437: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15437: error: parse error before "result"
mapscript_wrap.c:15445: error: parse error before "jint"
mapscript_wrap.c:15445: error: parse error before '*' token
mapscript_wrap.c:15445: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1addFeature':
mapscript_wrap.c:15446: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:15446: error: parse error before "jresult"
mapscript_wrap.c:15451: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15452: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15453: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15454: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:15490: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15490: error: parse error before "result"
mapscript_wrap.c:15495: error: parse error before "jint"
mapscript_wrap.c:15495: error: parse error before '*' token
mapscript_wrap.c:15495: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getNumFeatures':
mapscript_wrap.c:15496: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:15496: error: parse error before "jresult"
mapscript_wrap.c:15500: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15501: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15502: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15538: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15538: error: parse error before "result"
mapscript_wrap.c:15543: error: parse error before "jlong"
mapscript_wrap.c:15543: error: parse error before '*' token
mapscript_wrap.c:15543: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getExtent':
mapscript_wrap.c:15544: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:15544: error: parse error before "jresult"
mapscript_wrap.c:15548: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15549: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15550: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15586: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15591: error: parse error before "jint"
mapscript_wrap.c:15591: error: parse error before '*' token
mapscript_wrap.c:15591: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1setExtent':
mapscript_wrap.c:15592: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:15592: error: parse error before "jresult"
mapscript_wrap.c:15600: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15601: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15602: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15603: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:15604: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:15605: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:15606: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:15642: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15642: error: parse error before "result"
mapscript_wrap.c:15647: error: parse error before "jstring"
mapscript_wrap.c:15647: error: parse error before '*' token
mapscript_wrap.c:15647: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getMetaData':
mapscript_wrap.c:15648: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:15648: error: parse error before "jresult"
mapscript_wrap.c:15653: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15654: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15655: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15658: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:15699: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15708: error: parse error before "jint"
mapscript_wrap.c:15708: error: parse error before '*' token
mapscript_wrap.c:15708: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1setMetaData':
mapscript_wrap.c:15709: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:15709: error: parse error before "jresult"
mapscript_wrap.c:15715: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15716: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15717: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15720: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:15727: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:15767: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15767: error: parse error before "result"
mapscript_wrap.c:15778: error: parse error before "jint"
mapscript_wrap.c:15778: error: parse error before '*' token
mapscript_wrap.c:15778: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1removeMetaData':
mapscript_wrap.c:15779: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:15779: error: parse error before "jresult"
mapscript_wrap.c:15784: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15785: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15786: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15789: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:15829: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15829: error: parse error before "result"
mapscript_wrap.c:15837: error: parse error before "jstring"
mapscript_wrap.c:15837: error: parse error before '*' token
mapscript_wrap.c:15837: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getFirstMetaDataKey':
mapscript_wrap.c:15838: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:15838: error: parse error before "jresult"
mapscript_wrap.c:15842: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15843: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15844: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15881: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15887: error: parse error before "jstring"
mapscript_wrap.c:15887: error: parse error before '*' token
mapscript_wrap.c:15887: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getNextMetaDataKey':
mapscript_wrap.c:15888: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:15888: error: parse error before "jresult"
mapscript_wrap.c:15893: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15894: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15895: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15898: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:15939: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:15948: error: parse error before "jstring"
mapscript_wrap.c:15948: error: parse error before '*' token
mapscript_wrap.c:15948: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getWMSFeatureInfoURL':
mapscript_wrap.c:15949: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:15949: error: parse error before "jresult"
mapscript_wrap.c:15958: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:15959: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:15960: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:15961: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:15962: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:15963: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:15964: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:15967: error: `jarg6' undeclared (first use in this function)
mapscript_wrap.c:16008: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c: At top level:
mapscript_wrap.c:16018: error: parse error before "jstring"
mapscript_wrap.c:16018: error: parse error before '*' token
mapscript_wrap.c:16018: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1executeWFSGetFeature':
mapscript_wrap.c:16019: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:16019: error: parse error before "jresult"
mapscript_wrap.c:16024: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16025: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16026: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16027: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16064: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16071: error: parse error before "jint"
mapscript_wrap.c:16071: error: parse error before '*' token
mapscript_wrap.c:16071: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1applySLD':
mapscript_wrap.c:16072: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:16072: error: parse error before "jresult"
mapscript_wrap.c:16078: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16079: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16080: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16083: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16090: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:16130: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16130: error: parse error before "result"
mapscript_wrap.c:16141: error: parse error before "jint"
mapscript_wrap.c:16141: error: parse error before '*' token
mapscript_wrap.c:16141: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1applySLDURL':
mapscript_wrap.c:16142: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:16142: error: parse error before "jresult"
mapscript_wrap.c:16148: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16149: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16150: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16153: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16160: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:16200: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16200: error: parse error before "result"
mapscript_wrap.c:16211: error: parse error before "jstring"
mapscript_wrap.c:16211: error: parse error before '*' token
mapscript_wrap.c:16211: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1generateSLD':
mapscript_wrap.c:16212: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:16212: error: parse error before "jresult"
mapscript_wrap.c:16216: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16217: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16218: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16255: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16262: error: parse error before "jint"
mapscript_wrap.c:16262: error: parse error before '*' token
mapscript_wrap.c:16262: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1isVisible':
mapscript_wrap.c:16263: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:16263: error: parse error before "jresult"
mapscript_wrap.c:16267: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16268: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16269: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16305: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16305: error: parse error before "result"
mapscript_wrap.c:16310: error: parse error before "jint"
mapscript_wrap.c:16310: error: parse error before '*' token
mapscript_wrap.c:16310: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1moveClassUp':
mapscript_wrap.c:16311: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:16311: error: parse error before "jresult"
mapscript_wrap.c:16316: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16317: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16318: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16319: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16355: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16355: error: parse error before "result"
mapscript_wrap.c:16360: error: parse error before "jint"
mapscript_wrap.c:16360: error: parse error before '*' token
mapscript_wrap.c:16360: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1moveClassDown':
mapscript_wrap.c:16361: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:16361: error: parse error before "jresult"
mapscript_wrap.c:16366: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16367: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16368: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16369: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16405: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16405: error: parse error before "result"
mapscript_wrap.c:16410: error: syntax error before "void"
mapscript_wrap.c:16410: error: parse error before '*' token
mapscript_wrap.c:16410: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1setProcessingKey':
mapscript_wrap.c:16415: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16416: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16417: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16420: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16422: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:16427: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:16429: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:16476: error: syntax error before "void"
mapscript_wrap.c:16476: error: parse error before '*' token
mapscript_wrap.c:16476: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1setProcessing':
mapscript_wrap.c:16480: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16481: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16482: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16485: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16487: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:16531: error: syntax error before "void"
mapscript_wrap.c:16531: error: parse error before '*' token
mapscript_wrap.c:16531: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1addProcessing':
mapscript_wrap.c:16535: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16536: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16537: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16540: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16542: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:16586: error: parse error before "jstring"
mapscript_wrap.c:16586: error: parse error before '*' token
mapscript_wrap.c:16586: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1getProcessing':
mapscript_wrap.c:16587: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:16587: error: parse error before "jresult"
mapscript_wrap.c:16592: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16593: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16594: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16595: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16632: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16638: error: parse error before "jint"
mapscript_wrap.c:16638: error: parse error before '*' token
mapscript_wrap.c:16638: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_layerObj_1clearProcessing':
mapscript_wrap.c:16639: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:16639: error: parse error before "jresult"
mapscript_wrap.c:16643: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16644: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16645: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16681: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16681: error: parse error before "result"
mapscript_wrap.c:16686: error: syntax error before "void"
mapscript_wrap.c:16686: error: parse error before '*' token
mapscript_wrap.c:16686: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1name':
mapscript_wrap.c:16690: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16691: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16692: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16695: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16697: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:16715: error: parse error before "jstring"
mapscript_wrap.c:16715: error: parse error before '*' token
mapscript_wrap.c:16715: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1name':
mapscript_wrap.c:16716: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:16716: error: parse error before "jresult"
mapscript_wrap.c:16720: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16721: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16722: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16726: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16732: error: syntax error before "void"
mapscript_wrap.c:16732: error: parse error before '*' token
mapscript_wrap.c:16732: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1status':
mapscript_wrap.c:16736: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16737: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16738: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16739: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16745: error: parse error before "jint"
mapscript_wrap.c:16745: error: parse error before '*' token
mapscript_wrap.c:16745: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1status':
mapscript_wrap.c:16746: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:16746: error: parse error before "jresult"
mapscript_wrap.c:16750: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16751: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16752: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16755: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16755: error: parse error before "result"
mapscript_wrap.c:16760: error: syntax error before "void"
mapscript_wrap.c:16760: error: parse error before '*' token
mapscript_wrap.c:16760: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1height':
mapscript_wrap.c:16764: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16765: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16766: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16767: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16773: error: parse error before "jint"
mapscript_wrap.c:16773: error: parse error before '*' token
mapscript_wrap.c:16773: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1height':
mapscript_wrap.c:16774: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:16774: error: parse error before "jresult"
mapscript_wrap.c:16778: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16779: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16780: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16783: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16783: error: parse error before "result"
mapscript_wrap.c:16788: error: syntax error before "void"
mapscript_wrap.c:16788: error: parse error before '*' token
mapscript_wrap.c:16788: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1width':
mapscript_wrap.c:16792: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16793: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16794: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16795: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16801: error: parse error before "jint"
mapscript_wrap.c:16801: error: parse error before '*' token
mapscript_wrap.c:16801: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1width':
mapscript_wrap.c:16802: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:16802: error: parse error before "jresult"
mapscript_wrap.c:16806: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16807: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16808: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16811: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16811: error: parse error before "result"
mapscript_wrap.c:16816: error: syntax error before "void"
mapscript_wrap.c:16816: error: parse error before '*' token
mapscript_wrap.c:16816: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1maxsize':
mapscript_wrap.c:16820: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16821: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16822: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16823: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16829: error: parse error before "jint"
mapscript_wrap.c:16829: error: parse error before '*' token
mapscript_wrap.c:16829: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1maxsize':
mapscript_wrap.c:16830: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:16830: error: parse error before "jresult"
mapscript_wrap.c:16834: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16835: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16836: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16839: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16839: error: parse error before "result"
mapscript_wrap.c:16844: error: parse error before "jint"
mapscript_wrap.c:16844: error: parse error before '*' token
mapscript_wrap.c:16844: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1numlayers':
mapscript_wrap.c:16845: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:16845: error: parse error before "jresult"
mapscript_wrap.c:16849: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16850: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16851: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16854: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16854: error: parse error before "result"
mapscript_wrap.c:16859: error: syntax error before "void"
mapscript_wrap.c:16859: error: parse error before '*' token
mapscript_wrap.c:16859: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1symbolset':
mapscript_wrap.c:16863: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16864: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16865: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16866: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16872: error: parse error before "jlong"
mapscript_wrap.c:16872: error: parse error before '*' token
mapscript_wrap.c:16872: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1symbolset':
mapscript_wrap.c:16873: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:16873: error: parse error before "jresult"
mapscript_wrap.c:16877: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16878: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16879: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16882: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16887: error: syntax error before "void"
mapscript_wrap.c:16887: error: parse error before '*' token
mapscript_wrap.c:16887: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1fontset':
mapscript_wrap.c:16891: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16892: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16893: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16894: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16900: error: parse error before "jlong"
mapscript_wrap.c:16900: error: parse error before '*' token
mapscript_wrap.c:16900: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1fontset':
mapscript_wrap.c:16901: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:16901: error: parse error before "jresult"
mapscript_wrap.c:16905: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16906: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16907: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16910: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16915: error: syntax error before "void"
mapscript_wrap.c:16915: error: parse error before '*' token
mapscript_wrap.c:16915: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1labelcache':
mapscript_wrap.c:16919: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16920: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16921: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16922: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16928: error: parse error before "jlong"
mapscript_wrap.c:16928: error: parse error before '*' token
mapscript_wrap.c:16928: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1labelcache':
mapscript_wrap.c:16929: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:16929: error: parse error before "jresult"
mapscript_wrap.c:16933: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16934: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16935: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16938: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16943: error: syntax error before "void"
mapscript_wrap.c:16943: error: parse error before '*' token
mapscript_wrap.c:16943: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1transparent':
mapscript_wrap.c:16947: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16948: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16949: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16950: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16956: error: parse error before "jint"
mapscript_wrap.c:16956: error: parse error before '*' token
mapscript_wrap.c:16956: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1transparent':
mapscript_wrap.c:16957: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:16957: error: parse error before "jresult"
mapscript_wrap.c:16961: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16962: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16963: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16966: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16966: error: parse error before "result"
mapscript_wrap.c:16971: error: syntax error before "void"
mapscript_wrap.c:16971: error: parse error before '*' token
mapscript_wrap.c:16971: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1interlace':
mapscript_wrap.c:16975: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16976: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16977: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16978: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:16984: error: parse error before "jint"
mapscript_wrap.c:16984: error: parse error before '*' token
mapscript_wrap.c:16984: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1interlace':
mapscript_wrap.c:16985: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:16985: error: parse error before "jresult"
mapscript_wrap.c:16989: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:16990: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:16991: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:16994: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:16994: error: parse error before "result"
mapscript_wrap.c:16999: error: syntax error before "void"
mapscript_wrap.c:16999: error: parse error before '*' token
mapscript_wrap.c:16999: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1imagequality':
mapscript_wrap.c:17003: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17004: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17005: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17006: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17012: error: parse error before "jint"
mapscript_wrap.c:17012: error: parse error before '*' token
mapscript_wrap.c:17012: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1imagequality':
mapscript_wrap.c:17013: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:17013: error: parse error before "jresult"
mapscript_wrap.c:17017: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17018: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17019: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17022: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17022: error: parse error before "result"
mapscript_wrap.c:17027: error: syntax error before "void"
mapscript_wrap.c:17027: error: parse error before '*' token
mapscript_wrap.c:17027: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1extent':
mapscript_wrap.c:17031: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17032: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17033: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17034: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17040: error: parse error before "jlong"
mapscript_wrap.c:17040: error: parse error before '*' token
mapscript_wrap.c:17040: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1extent':
mapscript_wrap.c:17041: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17041: error: parse error before "jresult"
mapscript_wrap.c:17045: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17046: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17047: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17050: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17055: error: syntax error before "void"
mapscript_wrap.c:17055: error: parse error before '*' token
mapscript_wrap.c:17055: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1cellsize':
mapscript_wrap.c:17059: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17060: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17061: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17062: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17068: error: parse error before "jdouble"
mapscript_wrap.c:17068: error: parse error before '*' token
mapscript_wrap.c:17068: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1cellsize':
mapscript_wrap.c:17069: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:17069: error: parse error before "jresult"
mapscript_wrap.c:17073: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17074: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17075: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17078: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17078: error: parse error before "result"
mapscript_wrap.c:17083: error: syntax error before "void"
mapscript_wrap.c:17083: error: parse error before '*' token
mapscript_wrap.c:17083: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1gt':
mapscript_wrap.c:17088: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17089: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17090: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17091: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17094: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:17102: error: parse error before "jlong"
mapscript_wrap.c:17102: error: parse error before '*' token
mapscript_wrap.c:17102: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1gt':
mapscript_wrap.c:17103: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17103: error: parse error before "jresult"
mapscript_wrap.c:17107: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17108: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17109: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17115: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17121: error: syntax error before "void"
mapscript_wrap.c:17121: error: parse error before '*' token
mapscript_wrap.c:17121: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1saved_1extent':
mapscript_wrap.c:17125: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17126: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17127: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17128: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17134: error: parse error before "jlong"
mapscript_wrap.c:17134: error: parse error before '*' token
mapscript_wrap.c:17134: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1saved_1extent':
mapscript_wrap.c:17135: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17135: error: parse error before "jresult"
mapscript_wrap.c:17139: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17140: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17141: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17144: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17149: error: syntax error before "void"
mapscript_wrap.c:17149: error: parse error before '*' token
mapscript_wrap.c:17149: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1units':
mapscript_wrap.c:17153: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17154: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17155: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17156: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17162: error: parse error before "jint"
mapscript_wrap.c:17162: error: parse error before '*' token
mapscript_wrap.c:17162: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1units':
mapscript_wrap.c:17163: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:17163: error: parse error before "jresult"
mapscript_wrap.c:17167: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17168: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17169: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17172: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17172: error: parse error before "result"
mapscript_wrap.c:17177: error: syntax error before "void"
mapscript_wrap.c:17177: error: parse error before '*' token
mapscript_wrap.c:17177: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1scale':
mapscript_wrap.c:17181: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17182: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17183: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17184: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17190: error: parse error before "jdouble"
mapscript_wrap.c:17190: error: parse error before '*' token
mapscript_wrap.c:17190: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1scale':
mapscript_wrap.c:17191: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:17191: error: parse error before "jresult"
mapscript_wrap.c:17195: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17196: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17197: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17200: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17200: error: parse error before "result"
mapscript_wrap.c:17205: error: syntax error before "void"
mapscript_wrap.c:17205: error: parse error before '*' token
mapscript_wrap.c:17205: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1resolution':
mapscript_wrap.c:17209: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17210: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17211: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17212: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17218: error: parse error before "jdouble"
mapscript_wrap.c:17218: error: parse error before '*' token
mapscript_wrap.c:17218: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1resolution':
mapscript_wrap.c:17219: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:17219: error: parse error before "jresult"
mapscript_wrap.c:17223: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17224: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17225: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17228: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17228: error: parse error before "result"
mapscript_wrap.c:17233: error: syntax error before "void"
mapscript_wrap.c:17233: error: parse error before '*' token
mapscript_wrap.c:17233: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1shapepath':
mapscript_wrap.c:17237: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17238: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17239: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17242: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17244: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:17262: error: parse error before "jstring"
mapscript_wrap.c:17262: error: parse error before '*' token
mapscript_wrap.c:17262: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1shapepath':
mapscript_wrap.c:17263: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:17263: error: parse error before "jresult"
mapscript_wrap.c:17267: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17268: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17269: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17273: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17279: error: syntax error before "void"
mapscript_wrap.c:17279: error: parse error before '*' token
mapscript_wrap.c:17279: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1mappath':
mapscript_wrap.c:17283: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17284: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17285: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17288: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17290: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:17308: error: parse error before "jstring"
mapscript_wrap.c:17308: error: parse error before '*' token
mapscript_wrap.c:17308: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1mappath':
mapscript_wrap.c:17309: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:17309: error: parse error before "jresult"
mapscript_wrap.c:17313: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17314: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17315: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17319: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17325: error: syntax error before "void"
mapscript_wrap.c:17325: error: parse error before '*' token
mapscript_wrap.c:17325: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1palette':
mapscript_wrap.c:17330: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17331: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17332: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17333: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17336: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:17344: error: parse error before "jlong"
mapscript_wrap.c:17344: error: parse error before '*' token
mapscript_wrap.c:17344: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1palette':
mapscript_wrap.c:17345: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17345: error: parse error before "jresult"
mapscript_wrap.c:17349: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17350: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17351: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17357: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17363: error: syntax error before "void"
mapscript_wrap.c:17363: error: parse error before '*' token
mapscript_wrap.c:17363: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1imagecolor':
mapscript_wrap.c:17367: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17368: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17369: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17370: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17376: error: parse error before "jlong"
mapscript_wrap.c:17376: error: parse error before '*' token
mapscript_wrap.c:17376: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1imagecolor':
mapscript_wrap.c:17377: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17377: error: parse error before "jresult"
mapscript_wrap.c:17381: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17382: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17383: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17386: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17391: error: parse error before "jint"
mapscript_wrap.c:17391: error: parse error before '*' token
mapscript_wrap.c:17391: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1numoutputformats':
mapscript_wrap.c:17392: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:17392: error: parse error before "jresult"
mapscript_wrap.c:17396: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17397: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17398: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17401: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17401: error: parse error before "result"
mapscript_wrap.c:17406: error: parse error before "jlong"
mapscript_wrap.c:17406: error: parse error before '*' token
mapscript_wrap.c:17406: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1outputformatlist':
mapscript_wrap.c:17407: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17407: error: parse error before "jresult"
mapscript_wrap.c:17411: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17412: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17413: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17416: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17421: error: parse error before "jlong"
mapscript_wrap.c:17421: error: parse error before '*' token
mapscript_wrap.c:17421: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1outputformat':
mapscript_wrap.c:17422: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17422: error: parse error before "jresult"
mapscript_wrap.c:17426: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17427: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17428: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17431: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17436: error: parse error before "jstring"
mapscript_wrap.c:17436: error: parse error before '*' token
mapscript_wrap.c:17436: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1imagetype':
mapscript_wrap.c:17437: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:17437: error: parse error before "jresult"
mapscript_wrap.c:17441: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17442: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17443: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17447: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17453: error: syntax error before "void"
mapscript_wrap.c:17453: error: parse error before '*' token
mapscript_wrap.c:17453: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1reference':
mapscript_wrap.c:17457: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17458: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17459: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17460: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17466: error: parse error before "jlong"
mapscript_wrap.c:17466: error: parse error before '*' token
mapscript_wrap.c:17466: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1reference':
mapscript_wrap.c:17467: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17467: error: parse error before "jresult"
mapscript_wrap.c:17471: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17472: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17473: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17476: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17481: error: syntax error before "void"
mapscript_wrap.c:17481: error: parse error before '*' token
mapscript_wrap.c:17481: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1scalebar':
mapscript_wrap.c:17485: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17486: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17487: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17488: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17494: error: parse error before "jlong"
mapscript_wrap.c:17494: error: parse error before '*' token
mapscript_wrap.c:17494: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1scalebar':
mapscript_wrap.c:17495: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17495: error: parse error before "jresult"
mapscript_wrap.c:17499: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17500: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17501: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17504: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17509: error: syntax error before "void"
mapscript_wrap.c:17509: error: parse error before '*' token
mapscript_wrap.c:17509: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1legend':
mapscript_wrap.c:17513: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17514: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17515: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17516: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17522: error: parse error before "jlong"
mapscript_wrap.c:17522: error: parse error before '*' token
mapscript_wrap.c:17522: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1legend':
mapscript_wrap.c:17523: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17523: error: parse error before "jresult"
mapscript_wrap.c:17527: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17528: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17529: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17532: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17537: error: syntax error before "void"
mapscript_wrap.c:17537: error: parse error before '*' token
mapscript_wrap.c:17537: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1querymap':
mapscript_wrap.c:17541: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17542: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17543: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17544: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17550: error: parse error before "jlong"
mapscript_wrap.c:17550: error: parse error before '*' token
mapscript_wrap.c:17550: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1querymap':
mapscript_wrap.c:17551: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17551: error: parse error before "jresult"
mapscript_wrap.c:17555: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17556: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17557: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17560: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17565: error: syntax error before "void"
mapscript_wrap.c:17565: error: parse error before '*' token
mapscript_wrap.c:17565: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1web':
mapscript_wrap.c:17569: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17570: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17571: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17572: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17578: error: parse error before "jlong"
mapscript_wrap.c:17578: error: parse error before '*' token
mapscript_wrap.c:17578: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1web':
mapscript_wrap.c:17579: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17579: error: parse error before "jresult"
mapscript_wrap.c:17583: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17584: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17585: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17588: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17593: error: syntax error before "void"
mapscript_wrap.c:17593: error: parse error before '*' token
mapscript_wrap.c:17593: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1layerorder':
mapscript_wrap.c:17597: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17598: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17599: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17600: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17606: error: parse error before "jlong"
mapscript_wrap.c:17606: error: parse error before '*' token
mapscript_wrap.c:17606: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1layerorder':
mapscript_wrap.c:17607: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17607: error: parse error before "jresult"
mapscript_wrap.c:17611: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17612: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17613: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17616: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17621: error: syntax error before "void"
mapscript_wrap.c:17621: error: parse error before '*' token
mapscript_wrap.c:17621: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1debug':
mapscript_wrap.c:17625: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17626: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17627: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17628: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17634: error: parse error before "jint"
mapscript_wrap.c:17634: error: parse error before '*' token
mapscript_wrap.c:17634: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1debug':
mapscript_wrap.c:17635: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:17635: error: parse error before "jresult"
mapscript_wrap.c:17639: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17640: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17641: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17644: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17644: error: parse error before "result"
mapscript_wrap.c:17649: error: syntax error before "void"
mapscript_wrap.c:17649: error: parse error before '*' token
mapscript_wrap.c:17649: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1datapattern':
mapscript_wrap.c:17653: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17654: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17655: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17658: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17660: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:17678: error: parse error before "jstring"
mapscript_wrap.c:17678: error: parse error before '*' token
mapscript_wrap.c:17678: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1datapattern':
mapscript_wrap.c:17679: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:17679: error: parse error before "jresult"
mapscript_wrap.c:17683: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17684: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17685: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17689: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17695: error: syntax error before "void"
mapscript_wrap.c:17695: error: parse error before '*' token
mapscript_wrap.c:17695: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1templatepattern':
mapscript_wrap.c:17699: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17700: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17701: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17704: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17706: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:17724: error: parse error before "jstring"
mapscript_wrap.c:17724: error: parse error before '*' token
mapscript_wrap.c:17724: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1templatepattern':
mapscript_wrap.c:17725: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:17725: error: parse error before "jresult"
mapscript_wrap.c:17729: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17730: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17731: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17735: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17741: error: syntax error before "void"
mapscript_wrap.c:17741: error: parse error before '*' token
mapscript_wrap.c:17741: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1mapObj_1configoptions':
mapscript_wrap.c:17745: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17746: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17747: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17748: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17754: error: parse error before "jlong"
mapscript_wrap.c:17754: error: parse error before '*' token
mapscript_wrap.c:17754: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1mapObj_1configoptions':
mapscript_wrap.c:17755: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17755: error: parse error before "jresult"
mapscript_wrap.c:17759: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17760: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17761: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17764: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17769: error: parse error before "jlong"
mapscript_wrap.c:17769: error: parse error before '*' token
mapscript_wrap.c:17769: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1mapObj':
mapscript_wrap.c:17770: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17770: error: parse error before "jresult"
mapscript_wrap.c:17774: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17775: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17778: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17818: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17826: error: syntax error before "void"
mapscript_wrap.c:17826: error: parse error before '*' token
mapscript_wrap.c:17826: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1mapObj':
mapscript_wrap.c:17829: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17830: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17831: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17870: error: parse error before "jlong"
mapscript_wrap.c:17870: error: parse error before '*' token
mapscript_wrap.c:17870: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1cloneMap':
mapscript_wrap.c:17871: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17871: error: parse error before "jresult"
mapscript_wrap.c:17875: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17876: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17877: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17913: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17918: error: parse error before "jint"
mapscript_wrap.c:17918: error: parse error before '*' token
mapscript_wrap.c:17918: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1insertLayer':
mapscript_wrap.c:17919: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:17919: error: parse error before "jresult"
mapscript_wrap.c:17925: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17926: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17927: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17928: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:17929: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:17965: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:17965: error: parse error before "result"
mapscript_wrap.c: At top level:
mapscript_wrap.c:17970: error: parse error before "jlong"
mapscript_wrap.c:17970: error: parse error before '*' token
mapscript_wrap.c:17970: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1removeLayer':
mapscript_wrap.c:17971: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:17971: error: parse error before "jresult"
mapscript_wrap.c:17976: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:17977: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:17978: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:17979: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:18015: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18020: error: parse error before "jint"
mapscript_wrap.c:18020: error: parse error before '*' token
mapscript_wrap.c:18020: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1setExtent':
mapscript_wrap.c:18021: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:18021: error: parse error before "jresult"
mapscript_wrap.c:18029: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18030: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18031: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18032: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:18033: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:18034: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:18035: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:18071: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18071: error: parse error before "result"
mapscript_wrap.c:18076: error: parse error before "jint"
mapscript_wrap.c:18076: error: parse error before '*' token
mapscript_wrap.c:18076: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1setSize':
mapscript_wrap.c:18077: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:18077: error: parse error before "jresult"
mapscript_wrap.c:18083: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18084: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18085: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18086: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:18087: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:18123: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18123: error: parse error before "result"
mapscript_wrap.c:18128: error: parse error before "jint"
mapscript_wrap.c:18128: error: parse error before '*' token
mapscript_wrap.c:18128: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1setRotation':
mapscript_wrap.c:18129: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:18129: error: parse error before "jresult"
mapscript_wrap.c:18134: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18135: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18136: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18137: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:18173: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18173: error: parse error before "result"
mapscript_wrap.c:18178: error: parse error before "jlong"
mapscript_wrap.c:18178: error: parse error before '*' token
mapscript_wrap.c:18178: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1getLayer':
mapscript_wrap.c:18179: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:18179: error: parse error before "jresult"
mapscript_wrap.c:18184: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18185: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18186: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18187: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:18223: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18228: error: parse error before "jlong"
mapscript_wrap.c:18228: error: parse error before '*' token
mapscript_wrap.c:18228: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1getLayerByName':
mapscript_wrap.c:18229: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:18229: error: parse error before "jresult"
mapscript_wrap.c:18234: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18235: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18236: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18239: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:18279: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18287: error: parse error before "jint"
mapscript_wrap.c:18287: error: parse error before '*' token
mapscript_wrap.c:18287: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1getSymbolByName':
mapscript_wrap.c:18288: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:18288: error: parse error before "jresult"
mapscript_wrap.c:18293: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18294: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18295: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18298: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:18338: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18338: error: parse error before "result"
mapscript_wrap.c:18346: error: syntax error before "void"
mapscript_wrap.c:18346: error: parse error before '*' token
mapscript_wrap.c:18346: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1prepareQuery':
mapscript_wrap.c:18349: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18350: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18351: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18390: error: parse error before "jlong"
mapscript_wrap.c:18390: error: parse error before '*' token
mapscript_wrap.c:18390: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1prepareImage':
mapscript_wrap.c:18391: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:18391: error: parse error before "jresult"
mapscript_wrap.c:18395: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18396: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18397: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18433: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18438: error: syntax error before "void"
mapscript_wrap.c:18438: error: parse error before '*' token
mapscript_wrap.c:18438: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1setImageType':
mapscript_wrap.c:18442: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18443: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18444: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18447: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:18449: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:18493: error: syntax error before "void"
mapscript_wrap.c:18493: error: parse error before '*' token
mapscript_wrap.c:18493: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1selectOutputFormat':
mapscript_wrap.c:18497: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18498: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18499: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18502: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:18504: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:18548: error: syntax error before "void"
mapscript_wrap.c:18548: error: parse error before '*' token
mapscript_wrap.c:18548: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1setOutputFormat':
mapscript_wrap.c:18552: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18553: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18554: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18555: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:18594: error: parse error before "jlong"
mapscript_wrap.c:18594: error: parse error before '*' token
mapscript_wrap.c:18594: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1draw':
mapscript_wrap.c:18595: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:18595: error: parse error before "jresult"
mapscript_wrap.c:18599: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18600: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18601: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18637: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18642: error: parse error before "jlong"
mapscript_wrap.c:18642: error: parse error before '*' token
mapscript_wrap.c:18642: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1drawQuery':
mapscript_wrap.c:18643: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:18643: error: parse error before "jresult"
mapscript_wrap.c:18647: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18648: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18649: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18685: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18690: error: parse error before "jlong"
mapscript_wrap.c:18690: error: parse error before '*' token
mapscript_wrap.c:18690: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1drawLegend':
mapscript_wrap.c:18691: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:18691: error: parse error before "jresult"
mapscript_wrap.c:18695: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18696: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18697: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18733: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18738: error: parse error before "jlong"
mapscript_wrap.c:18738: error: parse error before '*' token
mapscript_wrap.c:18738: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1drawScalebar':
mapscript_wrap.c:18739: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:18739: error: parse error before "jresult"
mapscript_wrap.c:18743: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18744: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18745: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18781: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18786: error: parse error before "jlong"
mapscript_wrap.c:18786: error: parse error before '*' token
mapscript_wrap.c:18786: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1drawReferenceMap':
mapscript_wrap.c:18787: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:18787: error: parse error before "jresult"
mapscript_wrap.c:18791: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18792: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18793: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18829: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18834: error: parse error before "jint"
mapscript_wrap.c:18834: error: parse error before '*' token
mapscript_wrap.c:18834: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1embedScalebar':
mapscript_wrap.c:18835: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:18835: error: parse error before "jresult"
mapscript_wrap.c:18840: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18841: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18842: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18843: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:18879: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18879: error: parse error before "result"
mapscript_wrap.c:18884: error: parse error before "jint"
mapscript_wrap.c:18884: error: parse error before '*' token
mapscript_wrap.c:18884: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1embedLegend':
mapscript_wrap.c:18885: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:18885: error: parse error before "jresult"
mapscript_wrap.c:18890: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18891: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18892: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18893: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:18929: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18929: error: parse error before "result"
mapscript_wrap.c:18934: error: parse error before "jint"
mapscript_wrap.c:18934: error: parse error before '*' token
mapscript_wrap.c:18934: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1drawLabelCache':
mapscript_wrap.c:18935: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:18935: error: parse error before "jresult"
mapscript_wrap.c:18940: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18941: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18942: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:18943: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:18979: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:18979: error: parse error before "result"
mapscript_wrap.c:18984: error: parse error before "jlong"
mapscript_wrap.c:18984: error: parse error before '*' token
mapscript_wrap.c:18984: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1nextLabel':
mapscript_wrap.c:18985: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:18985: error: parse error before "jresult"
mapscript_wrap.c:18989: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:18990: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:18991: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19027: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19032: error: parse error before "jint"
mapscript_wrap.c:19032: error: parse error before '*' token
mapscript_wrap.c:19032: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1queryByPoint':
mapscript_wrap.c:19033: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:19033: error: parse error before "jresult"
mapscript_wrap.c:19040: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19041: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19042: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19043: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19044: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:19045: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:19081: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19081: error: parse error before "result"
mapscript_wrap.c:19086: error: parse error before "jint"
mapscript_wrap.c:19086: error: parse error before '*' token
mapscript_wrap.c:19086: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1queryByRect':
mapscript_wrap.c:19087: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:19087: error: parse error before "jresult"
mapscript_wrap.c:19093: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19094: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19095: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19096: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19137: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19137: error: parse error before "result"
mapscript_wrap.c:19142: error: parse error before "jint"
mapscript_wrap.c:19142: error: parse error before '*' token
mapscript_wrap.c:19142: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1queryByFeatures':
mapscript_wrap.c:19143: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:19143: error: parse error before "jresult"
mapscript_wrap.c:19148: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19149: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19150: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19151: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19187: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19187: error: parse error before "result"
mapscript_wrap.c:19192: error: parse error before "jint"
mapscript_wrap.c:19192: error: parse error before '*' token
mapscript_wrap.c:19192: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1queryByShape':
mapscript_wrap.c:19193: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:19193: error: parse error before "jresult"
mapscript_wrap.c:19198: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19199: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19200: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19201: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19237: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19237: error: parse error before "result"
mapscript_wrap.c:19242: error: parse error before "jint"
mapscript_wrap.c:19242: error: parse error before '*' token
mapscript_wrap.c:19242: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1setWKTProjection':
mapscript_wrap.c:19243: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:19243: error: parse error before "jresult"
mapscript_wrap.c:19248: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19249: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19250: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19253: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19293: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19293: error: parse error before "result"
mapscript_wrap.c:19301: error: parse error before "jstring"
mapscript_wrap.c:19301: error: parse error before '*' token
mapscript_wrap.c:19301: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1getProjection':
mapscript_wrap.c:19302: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:19302: error: parse error before "jresult"
mapscript_wrap.c:19306: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19307: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19308: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19345: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19352: error: parse error before "jint"
mapscript_wrap.c:19352: error: parse error before '*' token
mapscript_wrap.c:19352: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1setProjection':
mapscript_wrap.c:19353: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:19353: error: parse error before "jresult"
mapscript_wrap.c:19358: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19359: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19360: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19363: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19403: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19403: error: parse error before "result"
mapscript_wrap.c:19411: error: parse error before "jint"
mapscript_wrap.c:19411: error: parse error before '*' token
mapscript_wrap.c:19411: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1save':
mapscript_wrap.c:19412: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:19412: error: parse error before "jresult"
mapscript_wrap.c:19417: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19418: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19419: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19422: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19462: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19462: error: parse error before "result"
mapscript_wrap.c:19470: error: parse error before "jint"
mapscript_wrap.c:19470: error: parse error before '*' token
mapscript_wrap.c:19470: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1saveQuery':
mapscript_wrap.c:19471: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:19471: error: parse error before "jresult"
mapscript_wrap.c:19476: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19477: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19478: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19481: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19521: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19521: error: parse error before "result"
mapscript_wrap.c:19529: error: parse error before "jint"
mapscript_wrap.c:19529: error: parse error before '*' token
mapscript_wrap.c:19529: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1loadQuery':
mapscript_wrap.c:19530: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:19530: error: parse error before "jresult"
mapscript_wrap.c:19535: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19536: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19537: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19540: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19580: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19580: error: parse error before "result"
mapscript_wrap.c:19588: error: syntax error before "void"
mapscript_wrap.c:19588: error: parse error before '*' token
mapscript_wrap.c:19588: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1freeQuery':
mapscript_wrap.c:19592: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19593: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19594: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19595: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19634: error: parse error before "jint"
mapscript_wrap.c:19634: error: parse error before '*' token
mapscript_wrap.c:19634: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1saveQueryAsGML':
mapscript_wrap.c:19635: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:19635: error: parse error before "jresult"
mapscript_wrap.c:19641: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19642: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19643: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19646: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19653: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:19693: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19693: error: parse error before "result"
mapscript_wrap.c:19704: error: parse error before "jstring"
mapscript_wrap.c:19704: error: parse error before '*' token
mapscript_wrap.c:19704: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1getMetaData':
mapscript_wrap.c:19705: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:19705: error: parse error before "jresult"
mapscript_wrap.c:19710: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19711: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19712: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19715: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19756: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19765: error: parse error before "jint"
mapscript_wrap.c:19765: error: parse error before '*' token
mapscript_wrap.c:19765: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1setMetaData':
mapscript_wrap.c:19766: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:19766: error: parse error before "jresult"
mapscript_wrap.c:19772: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19773: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19774: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19777: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19784: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:19824: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19824: error: parse error before "result"
mapscript_wrap.c:19835: error: parse error before "jint"
mapscript_wrap.c:19835: error: parse error before '*' token
mapscript_wrap.c:19835: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1removeMetaData':
mapscript_wrap.c:19836: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:19836: error: parse error before "jresult"
mapscript_wrap.c:19841: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19842: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19843: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19846: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19886: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19886: error: parse error before "result"
mapscript_wrap.c:19894: error: parse error before "jstring"
mapscript_wrap.c:19894: error: parse error before '*' token
mapscript_wrap.c:19894: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1getFirstMetaDataKey':
mapscript_wrap.c:19895: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:19895: error: parse error before "jresult"
mapscript_wrap.c:19899: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19900: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19901: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19938: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:19944: error: parse error before "jstring"
mapscript_wrap.c:19944: error: parse error before '*' token
mapscript_wrap.c:19944: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1getNextMetaDataKey':
mapscript_wrap.c:19945: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:19945: error: parse error before "jresult"
mapscript_wrap.c:19950: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:19951: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:19952: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:19955: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:19996: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20005: error: parse error before "jint"
mapscript_wrap.c:20005: error: parse error before '*' token
mapscript_wrap.c:20005: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1setSymbolSet':
mapscript_wrap.c:20006: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:20006: error: parse error before "jresult"
mapscript_wrap.c:20011: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20012: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20013: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20016: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20056: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20056: error: parse error before "result"
mapscript_wrap.c:20064: error: parse error before "jint"
mapscript_wrap.c:20064: error: parse error before '*' token
mapscript_wrap.c:20064: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1getNumSymbols':
mapscript_wrap.c:20065: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:20065: error: parse error before "jresult"
mapscript_wrap.c:20069: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20070: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20071: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20107: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20107: error: parse error before "result"
mapscript_wrap.c:20112: error: parse error before "jint"
mapscript_wrap.c:20112: error: parse error before '*' token
mapscript_wrap.c:20112: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1setFontSet':
mapscript_wrap.c:20113: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:20113: error: parse error before "jresult"
mapscript_wrap.c:20118: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20119: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20120: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20123: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20163: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20163: error: parse error before "result"
mapscript_wrap.c:20171: error: parse error before "jint"
mapscript_wrap.c:20171: error: parse error before '*' token
mapscript_wrap.c:20171: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1saveMapContext':
mapscript_wrap.c:20172: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:20172: error: parse error before "jresult"
mapscript_wrap.c:20177: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20178: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20179: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20182: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20222: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20222: error: parse error before "result"
mapscript_wrap.c:20230: error: parse error before "jint"
mapscript_wrap.c:20230: error: parse error before '*' token
mapscript_wrap.c:20230: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1loadMapContext':
mapscript_wrap.c:20231: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:20231: error: parse error before "jresult"
mapscript_wrap.c:20237: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20238: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20239: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20242: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20247: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:20283: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20283: error: parse error before "result"
mapscript_wrap.c:20291: error: parse error before "jint"
mapscript_wrap.c:20291: error: parse error before '*' token
mapscript_wrap.c:20291: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1moveLayerUp':
mapscript_wrap.c:20292: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:20292: error: parse error before "jresult"
mapscript_wrap.c:20297: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20298: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20299: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20300: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20336: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20336: error: parse error before "result"
mapscript_wrap.c:20341: error: parse error before "jint"
mapscript_wrap.c:20341: error: parse error before '*' token
mapscript_wrap.c:20341: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1moveLayerDown':
mapscript_wrap.c:20342: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:20342: error: parse error before "jresult"
mapscript_wrap.c:20347: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20348: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20349: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20350: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20386: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20386: error: parse error before "result"
mapscript_wrap.c:20391: error: parse error before "jlong"
mapscript_wrap.c:20391: error: parse error before '*' token
mapscript_wrap.c:20391: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1getLayersDrawingOrder':
mapscript_wrap.c:20392: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:20392: error: parse error before "jresult"
mapscript_wrap.c:20396: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20397: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20398: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20434: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20439: error: parse error before "jint"
mapscript_wrap.c:20439: error: parse error before '*' token
mapscript_wrap.c:20439: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1setLayersDrawingOrder':
mapscript_wrap.c:20440: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:20440: error: parse error before "jresult"
mapscript_wrap.c:20445: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20446: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20447: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20448: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20484: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20484: error: parse error before "result"
mapscript_wrap.c:20489: error: syntax error before "void"
mapscript_wrap.c:20489: error: parse error before '*' token
mapscript_wrap.c:20489: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1setConfigOption':
mapscript_wrap.c:20494: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20495: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20496: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20499: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20501: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:20506: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:20508: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:20555: error: parse error before "jstring"
mapscript_wrap.c:20555: error: parse error before '*' token
mapscript_wrap.c:20555: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1getConfigOption':
mapscript_wrap.c:20556: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:20556: error: parse error before "jresult"
mapscript_wrap.c:20561: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20562: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20563: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20566: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20607: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20616: error: syntax error before "void"
mapscript_wrap.c:20616: error: parse error before '*' token
mapscript_wrap.c:20616: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1applyConfigOptions':
mapscript_wrap.c:20619: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20620: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20621: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20660: error: parse error before "jint"
mapscript_wrap.c:20660: error: parse error before '*' token
mapscript_wrap.c:20660: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1applySLD':
mapscript_wrap.c:20661: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:20661: error: parse error before "jresult"
mapscript_wrap.c:20666: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20667: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20668: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20671: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20711: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20711: error: parse error before "result"
mapscript_wrap.c:20719: error: parse error before "jint"
mapscript_wrap.c:20719: error: parse error before '*' token
mapscript_wrap.c:20719: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1applySLDURL':
mapscript_wrap.c:20720: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:20720: error: parse error before "jresult"
mapscript_wrap.c:20725: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20726: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20727: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20730: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20770: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20770: error: parse error before "result"
mapscript_wrap.c:20778: error: parse error before "jstring"
mapscript_wrap.c:20778: error: parse error before '*' token
mapscript_wrap.c:20778: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1generateSLD':
mapscript_wrap.c:20779: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:20779: error: parse error before "jresult"
mapscript_wrap.c:20783: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20784: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20785: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20822: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20829: error: parse error before "jstring"
mapscript_wrap.c:20829: error: parse error before '*' token
mapscript_wrap.c:20829: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1processTemplate':
mapscript_wrap.c:20830: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:20830: error: parse error before "jresult"
mapscript_wrap.c:20838: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20839: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20840: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20841: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20842: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:20843: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:20844: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:20881: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20888: error: parse error before "jstring"
mapscript_wrap.c:20888: error: parse error before '*' token
mapscript_wrap.c:20888: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1processLegendTemplate':
mapscript_wrap.c:20889: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:20889: error: parse error before "jresult"
mapscript_wrap.c:20896: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20897: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20898: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20899: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20900: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:20901: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:20938: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:20945: error: parse error before "jstring"
mapscript_wrap.c:20945: error: parse error before '*' token
mapscript_wrap.c:20945: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1processQueryTemplate':
mapscript_wrap.c:20946: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:20946: error: parse error before "jresult"
mapscript_wrap.c:20953: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:20954: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:20955: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:20956: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:20957: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:20958: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:20995: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21002: error: parse error before "jlong"
mapscript_wrap.c:21002: error: parse error before '*' token
mapscript_wrap.c:21002: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1getOutputFormatByName':
mapscript_wrap.c:21003: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:21003: error: parse error before "jresult"
mapscript_wrap.c:21008: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21009: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21010: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21013: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21053: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21061: error: parse error before "jint"
mapscript_wrap.c:21061: error: parse error before '*' token
mapscript_wrap.c:21061: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1appendOutputFormat':
mapscript_wrap.c:21062: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:21062: error: parse error before "jresult"
mapscript_wrap.c:21067: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21068: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21069: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21070: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21106: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21106: error: parse error before "result"
mapscript_wrap.c:21111: error: parse error before "jint"
mapscript_wrap.c:21111: error: parse error before '*' token
mapscript_wrap.c:21111: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1removeOutputFormat':
mapscript_wrap.c:21112: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:21112: error: parse error before "jresult"
mapscript_wrap.c:21117: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21118: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21119: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21122: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21162: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21162: error: parse error before "result"
mapscript_wrap.c:21170: error: parse error before "jint"
mapscript_wrap.c:21170: error: parse error before '*' token
mapscript_wrap.c:21170: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1loadOWSParameters':
mapscript_wrap.c:21171: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:21171: error: parse error before "jresult"
mapscript_wrap.c:21177: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21178: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21179: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21180: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21183: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:21223: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21223: error: parse error before "result"
mapscript_wrap.c:21231: error: parse error before "jint"
mapscript_wrap.c:21231: error: parse error before '*' token
mapscript_wrap.c:21231: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1zoomPoint':
mapscript_wrap.c:21232: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:21232: error: parse error before "jresult"
mapscript_wrap.c:21242: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21243: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21244: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21245: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21246: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:21247: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:21248: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:21249: error: `jarg6' undeclared (first use in this function)
mapscript_wrap.c:21250: error: `jarg7' undeclared (first use in this function)
mapscript_wrap.c:21286: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21286: error: parse error before "result"
mapscript_wrap.c:21291: error: parse error before "jint"
mapscript_wrap.c:21291: error: parse error before '*' token
mapscript_wrap.c:21291: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1zoomRectangle':
mapscript_wrap.c:21292: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:21292: error: parse error before "jresult"
mapscript_wrap.c:21301: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21302: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21303: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21304: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21305: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:21306: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:21307: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:21308: error: `jarg6' undeclared (first use in this function)
mapscript_wrap.c:21344: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21344: error: parse error before "result"
mapscript_wrap.c:21349: error: parse error before "jint"
mapscript_wrap.c:21349: error: parse error before '*' token
mapscript_wrap.c:21349: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1zoomScale':
mapscript_wrap.c:21350: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:21350: error: parse error before "jresult"
mapscript_wrap.c:21360: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21361: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21362: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21363: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21364: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:21365: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:21366: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:21367: error: `jarg6' undeclared (first use in this function)
mapscript_wrap.c:21368: error: `jarg7' undeclared (first use in this function)
mapscript_wrap.c:21404: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21404: error: parse error before "result"
mapscript_wrap.c:21409: error: syntax error before "void"
mapscript_wrap.c:21409: error: parse error before '*' token
mapscript_wrap.c:21409: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1SVGObj_1map':
mapscript_wrap.c:21413: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21414: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21415: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21416: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21422: error: parse error before "jlong"
mapscript_wrap.c:21422: error: parse error before '*' token
mapscript_wrap.c:21422: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1SVGObj_1map':
mapscript_wrap.c:21423: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:21423: error: parse error before "jresult"
mapscript_wrap.c:21427: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21428: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21429: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21432: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21437: error: syntax error before "void"
mapscript_wrap.c:21437: error: parse error before '*' token
mapscript_wrap.c:21437: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1SVGObj_1stream':
mapscript_wrap.c:21441: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21442: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21443: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21444: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21450: error: parse error before "jlong"
mapscript_wrap.c:21450: error: parse error before '*' token
mapscript_wrap.c:21450: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1SVGObj_1stream':
mapscript_wrap.c:21451: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:21451: error: parse error before "jresult"
mapscript_wrap.c:21455: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21456: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21457: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21460: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21465: error: syntax error before "void"
mapscript_wrap.c:21465: error: parse error before '*' token
mapscript_wrap.c:21465: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1SVGObj_1filename':
mapscript_wrap.c:21469: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21470: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21471: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21474: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21476: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:21494: error: parse error before "jstring"
mapscript_wrap.c:21494: error: parse error before '*' token
mapscript_wrap.c:21494: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1SVGObj_1filename':
mapscript_wrap.c:21495: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:21495: error: parse error before "jresult"
mapscript_wrap.c:21499: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21500: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21501: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21505: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21511: error: syntax error before "void"
mapscript_wrap.c:21511: error: parse error before '*' token
mapscript_wrap.c:21511: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1SVGObj_1streamclosed':
mapscript_wrap.c:21515: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21516: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21517: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21518: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21524: error: parse error before "jint"
mapscript_wrap.c:21524: error: parse error before '*' token
mapscript_wrap.c:21524: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1SVGObj_1streamclosed':
mapscript_wrap.c:21525: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:21525: error: parse error before "jresult"
mapscript_wrap.c:21529: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21530: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21531: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21534: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21534: error: parse error before "result"
mapscript_wrap.c:21539: error: syntax error before "void"
mapscript_wrap.c:21539: error: parse error before '*' token
mapscript_wrap.c:21539: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1SVGObj_1compressed':
mapscript_wrap.c:21543: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21544: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21545: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21546: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21552: error: parse error before "jint"
mapscript_wrap.c:21552: error: parse error before '*' token
mapscript_wrap.c:21552: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1SVGObj_1compressed':
mapscript_wrap.c:21553: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:21553: error: parse error before "jresult"
mapscript_wrap.c:21557: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21558: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21559: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21562: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21562: error: parse error before "result"
mapscript_wrap.c: At top level:
mapscript_wrap.c:21567: error: parse error before "jlong"
mapscript_wrap.c:21567: error: parse error before '*' token
mapscript_wrap.c:21567: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1SVGObj':
mapscript_wrap.c:21568: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:21568: error: parse error before "jresult"
mapscript_wrap.c:21571: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21572: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21608: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21613: error: syntax error before "void"
mapscript_wrap.c:21613: error: parse error before '*' token
mapscript_wrap.c:21613: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1SVGObj':
mapscript_wrap.c:21616: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21617: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21618: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21657: error: parse error before "jint"
mapscript_wrap.c:21657: error: parse error before '*' token
mapscript_wrap.c:21657: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1imageObj_1width':
mapscript_wrap.c:21658: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:21658: error: parse error before "jresult"
mapscript_wrap.c:21662: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21663: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21664: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21667: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21667: error: parse error before "result"
mapscript_wrap.c:21672: error: parse error before "jint"
mapscript_wrap.c:21672: error: parse error before '*' token
mapscript_wrap.c:21672: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1imageObj_1height':
mapscript_wrap.c:21673: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:21673: error: parse error before "jresult"
mapscript_wrap.c:21677: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21678: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21679: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21682: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21682: error: parse error before "result"
mapscript_wrap.c:21687: error: parse error before "jstring"
mapscript_wrap.c:21687: error: parse error before '*' token
mapscript_wrap.c:21687: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1imageObj_1imagepath':
mapscript_wrap.c:21688: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:21688: error: parse error before "jresult"
mapscript_wrap.c:21692: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21693: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21694: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21698: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21704: error: parse error before "jstring"
mapscript_wrap.c:21704: error: parse error before '*' token
mapscript_wrap.c:21704: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1imageObj_1imageurl':
mapscript_wrap.c:21705: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:21705: error: parse error before "jresult"
mapscript_wrap.c:21709: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21710: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21711: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21715: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21721: error: syntax error before "void"
mapscript_wrap.c:21721: error: parse error before '*' token
mapscript_wrap.c:21721: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1imageObj_1format':
mapscript_wrap.c:21725: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21726: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21727: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21728: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21734: error: parse error before "jlong"
mapscript_wrap.c:21734: error: parse error before '*' token
mapscript_wrap.c:21734: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1imageObj_1format':
mapscript_wrap.c:21735: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:21735: error: parse error before "jresult"
mapscript_wrap.c:21739: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21740: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21741: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21744: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21749: error: syntax error before "void"
mapscript_wrap.c:21749: error: parse error before '*' token
mapscript_wrap.c:21749: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1imageObj_1renderer':
mapscript_wrap.c:21753: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21754: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21755: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21756: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21762: error: parse error before "jint"
mapscript_wrap.c:21762: error: parse error before '*' token
mapscript_wrap.c:21762: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1imageObj_1renderer':
mapscript_wrap.c:21763: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:21763: error: parse error before "jresult"
mapscript_wrap.c:21767: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21768: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21769: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21772: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21772: error: parse error before "result"
mapscript_wrap.c:21777: error: syntax error before "void"
mapscript_wrap.c:21777: error: parse error before '*' token
mapscript_wrap.c:21777: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1imageObj_1size':
mapscript_wrap.c:21781: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21782: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21783: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21784: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21790: error: parse error before "jint"
mapscript_wrap.c:21790: error: parse error before '*' token
mapscript_wrap.c:21790: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1imageObj_1size':
mapscript_wrap.c:21791: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:21791: error: parse error before "jresult"
mapscript_wrap.c:21795: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21796: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21797: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21800: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21800: error: parse error before "result"
mapscript_wrap.c:21805: error: parse error before "jlong"
mapscript_wrap.c:21805: error: parse error before '*' token
mapscript_wrap.c:21805: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1imageObj':
mapscript_wrap.c:21806: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:21806: error: parse error before "jresult"
mapscript_wrap.c:21813: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21814: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21815: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21816: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21817: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:21820: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:21860: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:21868: error: syntax error before "void"
mapscript_wrap.c:21868: error: parse error before '*' token
mapscript_wrap.c:21868: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1imageObj':
mapscript_wrap.c:21871: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21872: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21873: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21912: error: syntax error before "void"
mapscript_wrap.c:21912: error: parse error before '*' token
mapscript_wrap.c:21912: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_imageObj_1save':
mapscript_wrap.c:21917: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21918: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21919: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21922: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:21924: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:21927: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:21969: error: parse error before "jint"
mapscript_wrap.c:21969: error: parse error before '*' token
mapscript_wrap.c:21969: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_imageObj_1write':
mapscript_wrap.c:21970: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:21970: error: parse error before "jresult"
mapscript_wrap.c:21975: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:21976: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:21977: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:21978: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22014: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22014: error: parse error before "result"
mapscript_wrap.c:22019: error: parse error before "jbyteArray"
mapscript_wrap.c:22019: error: parse error before '*' token
mapscript_wrap.c:22019: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_imageObj_1getBytes':
mapscript_wrap.c:22020: error: `jbyteArray' undeclared (first use in this function)
mapscript_wrap.c:22020: error: parse error before "jresult"
mapscript_wrap.c:22024: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22025: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22026: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22062: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22067: error: parse error before "jint"
mapscript_wrap.c:22067: error: parse error before '*' token
mapscript_wrap.c:22067: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msSaveImage':
mapscript_wrap.c:22068: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:22068: error: parse error before "jresult"
mapscript_wrap.c:22074: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22075: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22076: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22077: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22080: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:22120: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22120: error: parse error before "result"
mapscript_wrap.c:22128: error: syntax error before "void"
mapscript_wrap.c:22128: error: parse error before '*' token
mapscript_wrap.c:22128: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msFreeImage':
mapscript_wrap.c:22131: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22132: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22133: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22172: error: parse error before "jint"
mapscript_wrap.c:22172: error: parse error before '*' token
mapscript_wrap.c:22172: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msSetup':
mapscript_wrap.c:22173: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:22173: error: parse error before "jresult"
mapscript_wrap.c:22176: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22177: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22213: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22213: error: parse error before "result"
mapscript_wrap.c:22218: error: syntax error before "void"
mapscript_wrap.c:22218: error: parse error before '*' token
mapscript_wrap.c:22218: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msCleanup':
mapscript_wrap.c:22219: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22220: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22259: error: syntax error before "void"
mapscript_wrap.c:22259: error: parse error before '*' token
mapscript_wrap.c:22259: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1rectObj_1minx':
mapscript_wrap.c:22263: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22264: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22265: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22266: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22272: error: parse error before "jdouble"
mapscript_wrap.c:22272: error: parse error before '*' token
mapscript_wrap.c:22272: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1rectObj_1minx':
mapscript_wrap.c:22273: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:22273: error: parse error before "jresult"
mapscript_wrap.c:22277: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22278: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22279: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22282: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22282: error: parse error before "result"
mapscript_wrap.c:22287: error: syntax error before "void"
mapscript_wrap.c:22287: error: parse error before '*' token
mapscript_wrap.c:22287: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1rectObj_1miny':
mapscript_wrap.c:22291: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22292: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22293: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22294: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22300: error: parse error before "jdouble"
mapscript_wrap.c:22300: error: parse error before '*' token
mapscript_wrap.c:22300: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1rectObj_1miny':
mapscript_wrap.c:22301: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:22301: error: parse error before "jresult"
mapscript_wrap.c:22305: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22306: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22307: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22310: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22310: error: parse error before "result"
mapscript_wrap.c:22315: error: syntax error before "void"
mapscript_wrap.c:22315: error: parse error before '*' token
mapscript_wrap.c:22315: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1rectObj_1maxx':
mapscript_wrap.c:22319: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22320: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22321: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22322: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22328: error: parse error before "jdouble"
mapscript_wrap.c:22328: error: parse error before '*' token
mapscript_wrap.c:22328: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1rectObj_1maxx':
mapscript_wrap.c:22329: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:22329: error: parse error before "jresult"
mapscript_wrap.c:22333: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22334: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22335: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22338: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22338: error: parse error before "result"
mapscript_wrap.c:22343: error: syntax error before "void"
mapscript_wrap.c:22343: error: parse error before '*' token
mapscript_wrap.c:22343: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1rectObj_1maxy':
mapscript_wrap.c:22347: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22348: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22349: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22350: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22356: error: parse error before "jdouble"
mapscript_wrap.c:22356: error: parse error before '*' token
mapscript_wrap.c:22356: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1rectObj_1maxy':
mapscript_wrap.c:22357: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:22357: error: parse error before "jresult"
mapscript_wrap.c:22361: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22362: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22363: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22366: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22366: error: parse error before "result"
mapscript_wrap.c:22371: error: parse error before "jlong"
mapscript_wrap.c:22371: error: parse error before '*' token
mapscript_wrap.c:22371: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1rectObj':
mapscript_wrap.c:22372: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:22372: error: parse error before "jresult"
mapscript_wrap.c:22380: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22381: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22382: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22383: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22384: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:22385: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:22386: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:22422: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22427: error: syntax error before "void"
mapscript_wrap.c:22427: error: parse error before '*' token
mapscript_wrap.c:22427: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1rectObj':
mapscript_wrap.c:22430: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22431: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22432: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22471: error: parse error before "jint"
mapscript_wrap.c:22471: error: parse error before '*' token
mapscript_wrap.c:22471: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_rectObj_1project':
mapscript_wrap.c:22472: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:22472: error: parse error before "jresult"
mapscript_wrap.c:22478: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22479: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22480: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22481: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22482: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:22518: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22518: error: parse error before "result"
mapscript_wrap.c:22523: error: parse error before "jdouble"
mapscript_wrap.c:22523: error: parse error before '*' token
mapscript_wrap.c:22523: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_rectObj_1fit':
mapscript_wrap.c:22524: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:22524: error: parse error before "jresult"
mapscript_wrap.c:22530: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22531: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22532: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22533: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22534: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:22570: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22570: error: parse error before "result"
mapscript_wrap.c:22575: error: parse error before "jint"
mapscript_wrap.c:22575: error: parse error before '*' token
mapscript_wrap.c:22575: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_rectObj_1draw':
mapscript_wrap.c:22576: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:22576: error: parse error before "jresult"
mapscript_wrap.c:22585: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22586: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22587: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22588: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22589: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:22590: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:22591: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:22594: error: `jarg6' undeclared (first use in this function)
mapscript_wrap.c:22634: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22634: error: parse error before "result"
mapscript_wrap.c:22642: error: parse error before "jlong"
mapscript_wrap.c:22642: error: parse error before '*' token
mapscript_wrap.c:22642: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_rectObj_1toPolygon':
mapscript_wrap.c:22643: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:22643: error: parse error before "jresult"
mapscript_wrap.c:22647: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22648: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22649: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22685: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22690: error: parse error before "jstring"
mapscript_wrap.c:22690: error: parse error before '*' token
mapscript_wrap.c:22690: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_rectObj_1toString':
mapscript_wrap.c:22691: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:22691: error: parse error before "jresult"
mapscript_wrap.c:22695: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22696: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22697: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22734: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22741: error: syntax error before "void"
mapscript_wrap.c:22741: error: parse error before '*' token
mapscript_wrap.c:22741: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1vectorObj_1x':
mapscript_wrap.c:22745: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22746: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22747: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22748: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22754: error: parse error before "jdouble"
mapscript_wrap.c:22754: error: parse error before '*' token
mapscript_wrap.c:22754: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1vectorObj_1x':
mapscript_wrap.c:22755: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:22755: error: parse error before "jresult"
mapscript_wrap.c:22759: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22760: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22761: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22764: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22764: error: parse error before "result"
mapscript_wrap.c:22769: error: syntax error before "void"
mapscript_wrap.c:22769: error: parse error before '*' token
mapscript_wrap.c:22769: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1vectorObj_1y':
mapscript_wrap.c:22773: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22774: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22775: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22776: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22782: error: parse error before "jdouble"
mapscript_wrap.c:22782: error: parse error before '*' token
mapscript_wrap.c:22782: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1vectorObj_1y':
mapscript_wrap.c:22783: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:22783: error: parse error before "jresult"
mapscript_wrap.c:22787: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22788: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22789: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22792: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22792: error: parse error before "result"
mapscript_wrap.c:22797: error: parse error before "jlong"
mapscript_wrap.c:22797: error: parse error before '*' token
mapscript_wrap.c:22797: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1vectorObj':
mapscript_wrap.c:22798: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:22798: error: parse error before "jresult"
mapscript_wrap.c:22801: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22802: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22838: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22843: error: syntax error before "void"
mapscript_wrap.c:22843: error: parse error before '*' token
mapscript_wrap.c:22843: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1vectorObj':
mapscript_wrap.c:22846: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22847: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22848: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22887: error: syntax error before "void"
mapscript_wrap.c:22887: error: parse error before '*' token
mapscript_wrap.c:22887: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1pointObj_1x':
mapscript_wrap.c:22891: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22892: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22893: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22894: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22900: error: parse error before "jdouble"
mapscript_wrap.c:22900: error: parse error before '*' token
mapscript_wrap.c:22900: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1pointObj_1x':
mapscript_wrap.c:22901: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:22901: error: parse error before "jresult"
mapscript_wrap.c:22905: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22906: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22907: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22910: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22910: error: parse error before "result"
mapscript_wrap.c:22915: error: syntax error before "void"
mapscript_wrap.c:22915: error: parse error before '*' token
mapscript_wrap.c:22915: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1pointObj_1y':
mapscript_wrap.c:22919: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22920: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22921: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22922: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22928: error: parse error before "jdouble"
mapscript_wrap.c:22928: error: parse error before '*' token
mapscript_wrap.c:22928: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1pointObj_1y':
mapscript_wrap.c:22929: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:22929: error: parse error before "jresult"
mapscript_wrap.c:22933: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22934: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22935: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22938: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:22938: error: parse error before "result"
mapscript_wrap.c:22943: error: syntax error before "void"
mapscript_wrap.c:22943: error: parse error before '*' token
mapscript_wrap.c:22943: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1pointObj':
mapscript_wrap.c:22946: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22947: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22948: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22987: error: parse error before "jint"
mapscript_wrap.c:22987: error: parse error before '*' token
mapscript_wrap.c:22987: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_pointObj_1project':
mapscript_wrap.c:22988: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:22988: error: parse error before "jresult"
mapscript_wrap.c:22994: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:22995: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:22996: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:22997: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:22998: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:23034: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23034: error: parse error before "result"
mapscript_wrap.c:23039: error: parse error before "jint"
mapscript_wrap.c:23039: error: parse error before '*' token
mapscript_wrap.c:23039: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_pointObj_1draw':
mapscript_wrap.c:23040: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:23040: error: parse error before "jresult"
mapscript_wrap.c:23049: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23050: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23051: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23052: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23053: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:23054: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:23055: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:23058: error: `jarg6' undeclared (first use in this function)
mapscript_wrap.c:23098: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23098: error: parse error before "result"
mapscript_wrap.c:23106: error: parse error before "jdouble"
mapscript_wrap.c:23106: error: parse error before '*' token
mapscript_wrap.c:23106: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_pointObj_1distanceToPoint':
mapscript_wrap.c:23107: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:23107: error: parse error before "jresult"
mapscript_wrap.c:23112: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23113: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23114: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23115: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23151: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23151: error: parse error before "result"
mapscript_wrap.c:23156: error: parse error before "jdouble"
mapscript_wrap.c:23156: error: parse error before '*' token
mapscript_wrap.c:23156: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_pointObj_1distanceToSegment':
mapscript_wrap.c:23157: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:23157: error: parse error before "jresult"
mapscript_wrap.c:23163: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23164: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23165: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23166: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23167: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:23203: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23203: error: parse error before "result"
mapscript_wrap.c:23208: error: parse error before "jdouble"
mapscript_wrap.c:23208: error: parse error before '*' token
mapscript_wrap.c:23208: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_pointObj_1distanceToShape':
mapscript_wrap.c:23209: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:23209: error: parse error before "jresult"
mapscript_wrap.c:23214: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23215: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23216: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23217: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23253: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23253: error: parse error before "result"
mapscript_wrap.c:23258: error: parse error before "jint"
mapscript_wrap.c:23258: error: parse error before '*' token
mapscript_wrap.c:23258: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_pointObj_1setXY':
mapscript_wrap.c:23259: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:23259: error: parse error before "jresult"
mapscript_wrap.c:23266: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23267: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23268: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23269: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23270: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:23271: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:23307: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23307: error: parse error before "result"
mapscript_wrap.c:23312: error: parse error before "jint"
mapscript_wrap.c:23312: error: parse error before '*' token
mapscript_wrap.c:23312: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_pointObj_1setXYZ':
mapscript_wrap.c:23313: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:23313: error: parse error before "jresult"
mapscript_wrap.c:23321: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23322: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23323: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23324: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23325: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:23326: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:23327: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:23363: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23363: error: parse error before "result"
mapscript_wrap.c:23368: error: parse error before "jint"
mapscript_wrap.c:23368: error: parse error before '*' token
mapscript_wrap.c:23368: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_pointObj_1setXYZM':
mapscript_wrap.c:23369: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:23369: error: parse error before "jresult"
mapscript_wrap.c:23377: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23378: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23379: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23380: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23381: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:23382: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:23383: error: `jarg5' undeclared (first use in this function)
mapscript_wrap.c:23419: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23419: error: parse error before "result"
mapscript_wrap.c:23424: error: parse error before "jstring"
mapscript_wrap.c:23424: error: parse error before '*' token
mapscript_wrap.c:23424: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_pointObj_1toString':
mapscript_wrap.c:23425: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:23425: error: parse error before "jresult"
mapscript_wrap.c:23429: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23430: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23431: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23468: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23475: error: parse error before "jlong"
mapscript_wrap.c:23475: error: parse error before '*' token
mapscript_wrap.c:23475: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1pointObj_1_1SWIG_10':
mapscript_wrap.c:23476: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:23476: error: parse error before "jresult"
mapscript_wrap.c:23483: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23484: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23485: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23486: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23487: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:23488: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:23524: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23529: error: parse error before "jlong"
mapscript_wrap.c:23529: error: parse error before '*' token
mapscript_wrap.c:23529: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1pointObj_1_1SWIG_11':
mapscript_wrap.c:23530: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:23530: error: parse error before "jresult"
mapscript_wrap.c:23536: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23537: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23538: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23539: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23540: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:23576: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23581: error: parse error before "jint"
mapscript_wrap.c:23581: error: parse error before '*' token
mapscript_wrap.c:23581: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1lineObj_1numpoints':
mapscript_wrap.c:23582: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:23582: error: parse error before "jresult"
mapscript_wrap.c:23586: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23587: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23588: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23591: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23591: error: parse error before "result"
mapscript_wrap.c:23596: error: parse error before "jlong"
mapscript_wrap.c:23596: error: parse error before '*' token
mapscript_wrap.c:23596: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1lineObj_1point':
mapscript_wrap.c:23597: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:23597: error: parse error before "jresult"
mapscript_wrap.c:23601: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23602: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23603: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23606: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23611: error: parse error before "jlong"
mapscript_wrap.c:23611: error: parse error before '*' token
mapscript_wrap.c:23611: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1lineObj':
mapscript_wrap.c:23612: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:23612: error: parse error before "jresult"
mapscript_wrap.c:23615: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23616: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23652: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23657: error: syntax error before "void"
mapscript_wrap.c:23657: error: parse error before '*' token
mapscript_wrap.c:23657: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1lineObj':
mapscript_wrap.c:23660: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23661: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23662: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23701: error: parse error before "jint"
mapscript_wrap.c:23701: error: parse error before '*' token
mapscript_wrap.c:23701: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_lineObj_1project':
mapscript_wrap.c:23702: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:23702: error: parse error before "jresult"
mapscript_wrap.c:23708: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23709: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23710: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23711: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23712: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:23748: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23748: error: parse error before "result"
mapscript_wrap.c:23753: error: parse error before "jlong"
mapscript_wrap.c:23753: error: parse error before '*' token
mapscript_wrap.c:23753: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_lineObj_1get':
mapscript_wrap.c:23754: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:23754: error: parse error before "jresult"
mapscript_wrap.c:23759: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23760: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23761: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23762: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23798: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23803: error: parse error before "jint"
mapscript_wrap.c:23803: error: parse error before '*' token
mapscript_wrap.c:23803: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_lineObj_1add':
mapscript_wrap.c:23804: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:23804: error: parse error before "jresult"
mapscript_wrap.c:23809: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23810: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23811: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23812: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23848: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23848: error: parse error before "result"
mapscript_wrap.c:23853: error: parse error before "jint"
mapscript_wrap.c:23853: error: parse error before '*' token
mapscript_wrap.c:23853: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_lineObj_1set':
mapscript_wrap.c:23854: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:23854: error: parse error before "jresult"
mapscript_wrap.c:23860: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23861: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23862: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23863: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23864: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:23900: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23900: error: parse error before "result"
mapscript_wrap.c:23905: error: parse error before "jint"
mapscript_wrap.c:23905: error: parse error before '*' token
mapscript_wrap.c:23905: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapeObj_1numlines':
mapscript_wrap.c:23906: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:23906: error: parse error before "jresult"
mapscript_wrap.c:23910: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23911: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23912: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23915: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23915: error: parse error before "result"
mapscript_wrap.c:23920: error: parse error before "jint"
mapscript_wrap.c:23920: error: parse error before '*' token
mapscript_wrap.c:23920: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapeObj_1numvalues':
mapscript_wrap.c:23921: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:23921: error: parse error before "jresult"
mapscript_wrap.c:23925: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23926: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23927: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23930: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23930: error: parse error before "result"
mapscript_wrap.c:23935: error: parse error before "jlong"
mapscript_wrap.c:23935: error: parse error before '*' token
mapscript_wrap.c:23935: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapeObj_1line':
mapscript_wrap.c:23936: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:23936: error: parse error before "jresult"
mapscript_wrap.c:23940: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23941: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23942: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23945: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23950: error: parse error before "jlong"
mapscript_wrap.c:23950: error: parse error before '*' token
mapscript_wrap.c:23950: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapeObj_1values':
mapscript_wrap.c:23951: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:23951: error: parse error before "jresult"
mapscript_wrap.c:23955: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23956: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23957: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23960: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23965: error: syntax error before "void"
mapscript_wrap.c:23965: error: parse error before '*' token
mapscript_wrap.c:23965: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1shapeObj_1bounds':
mapscript_wrap.c:23969: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23970: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23971: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23972: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:23978: error: parse error before "jlong"
mapscript_wrap.c:23978: error: parse error before '*' token
mapscript_wrap.c:23978: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapeObj_1bounds':
mapscript_wrap.c:23979: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:23979: error: parse error before "jresult"
mapscript_wrap.c:23983: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23984: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23985: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:23988: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:23993: error: syntax error before "void"
mapscript_wrap.c:23993: error: parse error before '*' token
mapscript_wrap.c:23993: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1shapeObj_1type':
mapscript_wrap.c:23997: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:23998: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:23999: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24000: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24006: error: parse error before "jint"
mapscript_wrap.c:24006: error: parse error before '*' token
mapscript_wrap.c:24006: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapeObj_1type':
mapscript_wrap.c:24007: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:24007: error: parse error before "jresult"
mapscript_wrap.c:24011: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24012: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24013: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24016: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24016: error: parse error before "result"
mapscript_wrap.c:24021: error: syntax error before "void"
mapscript_wrap.c:24021: error: parse error before '*' token
mapscript_wrap.c:24021: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1shapeObj_1index':
mapscript_wrap.c:24025: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24026: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24027: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24028: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24034: error: parse error before "jint"
mapscript_wrap.c:24034: error: parse error before '*' token
mapscript_wrap.c:24034: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapeObj_1index':
mapscript_wrap.c:24035: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:24035: error: parse error before "jresult"
mapscript_wrap.c:24039: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24040: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24041: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24044: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24044: error: parse error before "result"
mapscript_wrap.c:24049: error: syntax error before "void"
mapscript_wrap.c:24049: error: parse error before '*' token
mapscript_wrap.c:24049: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1shapeObj_1tileindex':
mapscript_wrap.c:24053: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24054: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24055: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24056: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24062: error: parse error before "jint"
mapscript_wrap.c:24062: error: parse error before '*' token
mapscript_wrap.c:24062: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapeObj_1tileindex':
mapscript_wrap.c:24063: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:24063: error: parse error before "jresult"
mapscript_wrap.c:24067: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24068: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24069: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24072: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24072: error: parse error before "result"
mapscript_wrap.c:24077: error: syntax error before "void"
mapscript_wrap.c:24077: error: parse error before '*' token
mapscript_wrap.c:24077: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1shapeObj_1classindex':
mapscript_wrap.c:24081: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24082: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24083: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24084: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24090: error: parse error before "jint"
mapscript_wrap.c:24090: error: parse error before '*' token
mapscript_wrap.c:24090: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapeObj_1classindex':
mapscript_wrap.c:24091: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:24091: error: parse error before "jresult"
mapscript_wrap.c:24095: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24096: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24097: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24100: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24100: error: parse error before "result"
mapscript_wrap.c: At top level:
mapscript_wrap.c:24105: error: syntax error before "void"
mapscript_wrap.c:24105: error: parse error before '*' token
mapscript_wrap.c:24105: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1shapeObj_1text':
mapscript_wrap.c:24109: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24110: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24111: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24114: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24116: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:24134: error: parse error before "jstring"
mapscript_wrap.c:24134: error: parse error before '*' token
mapscript_wrap.c:24134: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapeObj_1text':
mapscript_wrap.c:24135: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:24135: error: parse error before "jresult"
mapscript_wrap.c:24139: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24140: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24141: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24145: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24151: error: parse error before "jlong"
mapscript_wrap.c:24151: error: parse error before '*' token
mapscript_wrap.c:24151: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1shapeObj':
mapscript_wrap.c:24152: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:24152: error: parse error before "jresult"
mapscript_wrap.c:24156: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24157: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24158: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24194: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24199: error: syntax error before "void"
mapscript_wrap.c:24199: error: parse error before '*' token
mapscript_wrap.c:24199: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1shapeObj':
mapscript_wrap.c:24202: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24203: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24204: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24243: error: parse error before "jint"
mapscript_wrap.c:24243: error: parse error before '*' token
mapscript_wrap.c:24243: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1project':
mapscript_wrap.c:24244: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:24244: error: parse error before "jresult"
mapscript_wrap.c:24250: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24251: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24252: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24253: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24254: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:24290: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24290: error: parse error before "result"
mapscript_wrap.c:24295: error: parse error before "jlong"
mapscript_wrap.c:24295: error: parse error before '*' token
mapscript_wrap.c:24295: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1get':
mapscript_wrap.c:24296: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:24296: error: parse error before "jresult"
mapscript_wrap.c:24301: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24302: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24303: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24304: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24340: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24345: error: parse error before "jint"
mapscript_wrap.c:24345: error: parse error before '*' token
mapscript_wrap.c:24345: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1add':
mapscript_wrap.c:24346: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:24346: error: parse error before "jresult"
mapscript_wrap.c:24351: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24352: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24353: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24354: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24390: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24390: error: parse error before "result"
mapscript_wrap.c:24395: error: parse error before "jint"
mapscript_wrap.c:24395: error: parse error before '*' token
mapscript_wrap.c:24395: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1draw':
mapscript_wrap.c:24396: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:24396: error: parse error before "jresult"
mapscript_wrap.c:24403: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24404: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24405: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24406: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24407: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:24408: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:24444: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24444: error: parse error before "result"
mapscript_wrap.c:24449: error: syntax error before "void"
mapscript_wrap.c:24449: error: parse error before '*' token
mapscript_wrap.c:24449: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1setBounds':
mapscript_wrap.c:24452: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24453: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24454: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24493: error: parse error before "jlong"
mapscript_wrap.c:24493: error: parse error before '*' token
mapscript_wrap.c:24493: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1cloneShape':
mapscript_wrap.c:24494: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:24494: error: parse error before "jresult"
mapscript_wrap.c:24498: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24499: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24500: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24536: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24541: error: parse error before "jint"
mapscript_wrap.c:24541: error: parse error before '*' token
mapscript_wrap.c:24541: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1copy':
mapscript_wrap.c:24542: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:24542: error: parse error before "jresult"
mapscript_wrap.c:24547: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24548: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24549: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24550: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24586: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24586: error: parse error before "result"
mapscript_wrap.c:24591: error: parse error before "jlong"
mapscript_wrap.c:24591: error: parse error before '*' token
mapscript_wrap.c:24591: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1buffer':
mapscript_wrap.c:24592: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:24592: error: parse error before "jresult"
mapscript_wrap.c:24597: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24598: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24599: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24600: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24636: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24641: error: parse error before "jlong"
mapscript_wrap.c:24641: error: parse error before '*' token
mapscript_wrap.c:24641: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1convexHull':
mapscript_wrap.c:24642: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:24642: error: parse error before "jresult"
mapscript_wrap.c:24646: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24647: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24648: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24684: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24689: error: parse error before "jstring"
mapscript_wrap.c:24689: error: parse error before '*' token
mapscript_wrap.c:24689: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1getValue':
mapscript_wrap.c:24690: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:24690: error: parse error before "jresult"
mapscript_wrap.c:24695: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24696: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24697: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24698: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24735: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24741: error: parse error before "jint"
mapscript_wrap.c:24741: error: parse error before '*' token
mapscript_wrap.c:24741: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1contains':
mapscript_wrap.c:24742: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:24742: error: parse error before "jresult"
mapscript_wrap.c:24747: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24748: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24749: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24750: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24786: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24786: error: parse error before "result"
mapscript_wrap.c:24791: error: parse error before "jdouble"
mapscript_wrap.c:24791: error: parse error before '*' token
mapscript_wrap.c:24791: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1distanceToPoint':
mapscript_wrap.c:24792: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:24792: error: parse error before "jresult"
mapscript_wrap.c:24797: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24798: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24799: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24800: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24836: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24836: error: parse error before "result"
mapscript_wrap.c:24841: error: parse error before "jdouble"
mapscript_wrap.c:24841: error: parse error before '*' token
mapscript_wrap.c:24841: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1distanceToShape':
mapscript_wrap.c:24842: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:24842: error: parse error before "jresult"
mapscript_wrap.c:24847: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24848: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24849: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24850: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24886: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24886: error: parse error before "result"
mapscript_wrap.c:24891: error: parse error before "jint"
mapscript_wrap.c:24891: error: parse error before '*' token
mapscript_wrap.c:24891: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1intersects':
mapscript_wrap.c:24892: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:24892: error: parse error before "jresult"
mapscript_wrap.c:24897: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24898: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24899: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24900: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24936: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24936: error: parse error before "result"
mapscript_wrap.c:24941: error: parse error before "jint"
mapscript_wrap.c:24941: error: parse error before '*' token
mapscript_wrap.c:24941: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapeObj_1setValue':
mapscript_wrap.c:24942: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:24942: error: parse error before "jresult"
mapscript_wrap.c:24948: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:24949: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:24950: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:24951: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:24954: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:24994: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:24994: error: parse error before "result"
mapscript_wrap.c:25002: error: parse error before "jint"
mapscript_wrap.c:25002: error: parse error before '*' token
mapscript_wrap.c:25002: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SHAPEFILE_1POINT':
mapscript_wrap.c:25003: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25003: error: parse error before "jresult"
mapscript_wrap.c:25006: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25007: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25043: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25043: error: parse error before "result"
mapscript_wrap.c:25048: error: parse error before "jint"
mapscript_wrap.c:25048: error: parse error before '*' token
mapscript_wrap.c:25048: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SHAPEFILE_1ARC':
mapscript_wrap.c:25049: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25049: error: parse error before "jresult"
mapscript_wrap.c:25052: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25053: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25089: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25089: error: parse error before "result"
mapscript_wrap.c:25094: error: parse error before "jint"
mapscript_wrap.c:25094: error: parse error before '*' token
mapscript_wrap.c:25094: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SHAPEFILE_1POLYGON':
mapscript_wrap.c:25095: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25095: error: parse error before "jresult"
mapscript_wrap.c:25098: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25099: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25135: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25135: error: parse error before "result"
mapscript_wrap.c:25140: error: parse error before "jint"
mapscript_wrap.c:25140: error: parse error before '*' token
mapscript_wrap.c:25140: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SHAPEFILE_1MULTIPOINT':
mapscript_wrap.c:25141: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25141: error: parse error before "jresult"
mapscript_wrap.c:25144: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25145: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25181: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25181: error: parse error before "result"
mapscript_wrap.c:25186: error: parse error before "jint"
mapscript_wrap.c:25186: error: parse error before '*' token
mapscript_wrap.c:25186: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SHP_1POINTZ':
mapscript_wrap.c:25187: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25187: error: parse error before "jresult"
mapscript_wrap.c:25190: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25191: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25227: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25227: error: parse error before "result"
mapscript_wrap.c:25232: error: parse error before "jint"
mapscript_wrap.c:25232: error: parse error before '*' token
mapscript_wrap.c:25232: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SHP_1ARCZ':
mapscript_wrap.c:25233: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25233: error: parse error before "jresult"
mapscript_wrap.c:25236: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25237: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25273: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25273: error: parse error before "result"
mapscript_wrap.c:25278: error: parse error before "jint"
mapscript_wrap.c:25278: error: parse error before '*' token
mapscript_wrap.c:25278: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SHP_1POLYGONZ':
mapscript_wrap.c:25279: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25279: error: parse error before "jresult"
mapscript_wrap.c:25282: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25283: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25319: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25319: error: parse error before "result"
mapscript_wrap.c:25324: error: parse error before "jint"
mapscript_wrap.c:25324: error: parse error before '*' token
mapscript_wrap.c:25324: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SHP_1MULTIPOINTZ':
mapscript_wrap.c:25325: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25325: error: parse error before "jresult"
mapscript_wrap.c:25328: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25329: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25365: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25365: error: parse error before "result"
mapscript_wrap.c:25370: error: parse error before "jint"
mapscript_wrap.c:25370: error: parse error before '*' token
mapscript_wrap.c:25370: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SHP_1POINTM':
mapscript_wrap.c:25371: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25371: error: parse error before "jresult"
mapscript_wrap.c:25374: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25375: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25411: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25411: error: parse error before "result"
mapscript_wrap.c:25416: error: parse error before "jint"
mapscript_wrap.c:25416: error: parse error before '*' token
mapscript_wrap.c:25416: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SHP_1ARCM':
mapscript_wrap.c:25417: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25417: error: parse error before "jresult"
mapscript_wrap.c:25420: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25421: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25457: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25457: error: parse error before "result"
mapscript_wrap.c:25462: error: parse error before "jint"
mapscript_wrap.c:25462: error: parse error before '*' token
mapscript_wrap.c:25462: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SHP_1POLYGONM':
mapscript_wrap.c:25463: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25463: error: parse error before "jresult"
mapscript_wrap.c:25466: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25467: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25503: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25503: error: parse error before "result"
mapscript_wrap.c:25508: error: parse error before "jint"
mapscript_wrap.c:25508: error: parse error before '*' token
mapscript_wrap.c:25508: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SHP_1MULTIPOINTM':
mapscript_wrap.c:25509: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25509: error: parse error before "jresult"
mapscript_wrap.c:25512: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25513: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25549: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25549: error: parse error before "result"
mapscript_wrap.c:25554: error: parse error before "jlong"
mapscript_wrap.c:25554: error: parse error before '*' token
mapscript_wrap.c:25554: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1fp':
mapscript_wrap.c:25555: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:25555: error: parse error before "jresult"
mapscript_wrap.c:25559: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25560: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25561: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25564: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25569: error: parse error before "jint"
mapscript_wrap.c:25569: error: parse error before '*' token
mapscript_wrap.c:25569: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1nRecords':
mapscript_wrap.c:25570: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25570: error: parse error before "jresult"
mapscript_wrap.c:25574: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25575: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25576: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25579: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25579: error: parse error before "result"
mapscript_wrap.c:25584: error: parse error before "jint"
mapscript_wrap.c:25584: error: parse error before '*' token
mapscript_wrap.c:25584: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1nRecordLength':
mapscript_wrap.c:25585: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25585: error: parse error before "jresult"
mapscript_wrap.c:25589: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25590: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25591: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25594: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25594: error: parse error before "result"
mapscript_wrap.c:25599: error: parse error before "jint"
mapscript_wrap.c:25599: error: parse error before '*' token
mapscript_wrap.c:25599: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1nHeaderLength':
mapscript_wrap.c:25600: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25600: error: parse error before "jresult"
mapscript_wrap.c:25604: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25605: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25606: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25609: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25609: error: parse error before "result"
mapscript_wrap.c:25614: error: parse error before "jint"
mapscript_wrap.c:25614: error: parse error before '*' token
mapscript_wrap.c:25614: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1nFields':
mapscript_wrap.c:25615: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25615: error: parse error before "jresult"
mapscript_wrap.c:25619: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25620: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25621: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25624: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25624: error: parse error before "result"
mapscript_wrap.c:25629: error: parse error before "jlong"
mapscript_wrap.c:25629: error: parse error before '*' token
mapscript_wrap.c:25629: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1panFieldOffset':
mapscript_wrap.c:25630: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:25630: error: parse error before "jresult"
mapscript_wrap.c:25634: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25635: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25636: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25639: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25644: error: parse error before "jlong"
mapscript_wrap.c:25644: error: parse error before '*' token
mapscript_wrap.c:25644: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1panFieldSize':
mapscript_wrap.c:25645: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:25645: error: parse error before "jresult"
mapscript_wrap.c:25649: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25650: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25651: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25654: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25659: error: parse error before "jlong"
mapscript_wrap.c:25659: error: parse error before '*' token
mapscript_wrap.c:25659: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1panFieldDecimals':
mapscript_wrap.c:25660: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:25660: error: parse error before "jresult"
mapscript_wrap.c:25664: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25665: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25666: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25669: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25674: error: parse error before "jstring"
mapscript_wrap.c:25674: error: parse error before '*' token
mapscript_wrap.c:25674: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1pachFieldType':
mapscript_wrap.c:25675: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:25675: error: parse error before "jresult"
mapscript_wrap.c:25679: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25680: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25681: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25685: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25691: error: parse error before "jstring"
mapscript_wrap.c:25691: error: parse error before '*' token
mapscript_wrap.c:25691: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1pszHeader':
mapscript_wrap.c:25692: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:25692: error: parse error before "jresult"
mapscript_wrap.c:25696: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25697: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25698: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25702: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25708: error: parse error before "jint"
mapscript_wrap.c:25708: error: parse error before '*' token
mapscript_wrap.c:25708: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1nCurrentRecord':
mapscript_wrap.c:25709: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25709: error: parse error before "jresult"
mapscript_wrap.c:25713: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25714: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25715: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25718: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25718: error: parse error before "result"
mapscript_wrap.c:25723: error: parse error before "jint"
mapscript_wrap.c:25723: error: parse error before '*' token
mapscript_wrap.c:25723: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1bCurrentRecordModified':
mapscript_wrap.c:25724: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25724: error: parse error before "jresult"
mapscript_wrap.c:25728: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25729: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25730: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25733: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25733: error: parse error before "result"
mapscript_wrap.c:25738: error: parse error before "jstring"
mapscript_wrap.c:25738: error: parse error before '*' token
mapscript_wrap.c:25738: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1pszCurrentRecord':
mapscript_wrap.c:25739: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:25739: error: parse error before "jresult"
mapscript_wrap.c:25743: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25744: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25745: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25749: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25755: error: parse error before "jint"
mapscript_wrap.c:25755: error: parse error before '*' token
mapscript_wrap.c:25755: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1bNoHeader':
mapscript_wrap.c:25756: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25756: error: parse error before "jresult"
mapscript_wrap.c:25760: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25761: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25762: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25765: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25765: error: parse error before "result"
mapscript_wrap.c:25770: error: parse error before "jint"
mapscript_wrap.c:25770: error: parse error before '*' token
mapscript_wrap.c:25770: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1bUpdated':
mapscript_wrap.c:25771: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25771: error: parse error before "jresult"
mapscript_wrap.c:25775: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25776: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25777: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25780: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25780: error: parse error before "result"
mapscript_wrap.c:25785: error: parse error before "jstring"
mapscript_wrap.c:25785: error: parse error before '*' token
mapscript_wrap.c:25785: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1pszStringField':
mapscript_wrap.c:25786: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:25786: error: parse error before "jresult"
mapscript_wrap.c:25790: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25791: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25792: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25796: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25802: error: parse error before "jint"
mapscript_wrap.c:25802: error: parse error before '*' token
mapscript_wrap.c:25802: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1DBFInfo_1nStringFieldLen':
mapscript_wrap.c:25803: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25803: error: parse error before "jresult"
mapscript_wrap.c:25807: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25808: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25809: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25812: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25812: error: parse error before "result"
mapscript_wrap.c:25817: error: parse error before "jstring"
mapscript_wrap.c:25817: error: parse error before '*' token
mapscript_wrap.c:25817: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_DBFInfo_1getFieldName':
mapscript_wrap.c:25818: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:25818: error: parse error before "jresult"
mapscript_wrap.c:25823: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25824: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25825: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25826: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:25863: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25869: error: parse error before "jint"
mapscript_wrap.c:25869: error: parse error before '*' token
mapscript_wrap.c:25869: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_DBFInfo_1getFieldWidth':
mapscript_wrap.c:25870: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25870: error: parse error before "jresult"
mapscript_wrap.c:25875: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25876: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25877: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25878: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:25914: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25914: error: parse error before "result"
mapscript_wrap.c:25919: error: parse error before "jint"
mapscript_wrap.c:25919: error: parse error before '*' token
mapscript_wrap.c:25919: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_DBFInfo_1getFieldDecimals':
mapscript_wrap.c:25920: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25920: error: parse error before "jresult"
mapscript_wrap.c:25925: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25926: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25927: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25928: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:25964: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:25964: error: parse error before "result"
mapscript_wrap.c:25969: error: parse error before "jint"
mapscript_wrap.c:25969: error: parse error before '*' token
mapscript_wrap.c:25969: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_DBFInfo_1getFieldType':
mapscript_wrap.c:25970: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:25970: error: parse error before "jresult"
mapscript_wrap.c:25975: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:25976: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:25977: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:25978: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:26014: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26014: error: parse error before "result"
mapscript_wrap.c:26019: error: parse error before "jlong"
mapscript_wrap.c:26019: error: parse error before '*' token
mapscript_wrap.c:26019: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1DBFInfo':
mapscript_wrap.c:26020: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:26020: error: parse error before "jresult"
mapscript_wrap.c:26023: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26024: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26060: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26065: error: syntax error before "void"
mapscript_wrap.c:26065: error: parse error before '*' token
mapscript_wrap.c:26065: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1DBFInfo':
mapscript_wrap.c:26068: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26069: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26070: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26109: error: parse error before "jstring"
mapscript_wrap.c:26109: error: parse error before '*' token
mapscript_wrap.c:26109: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapefileObj_1source':
mapscript_wrap.c:26110: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:26110: error: parse error before "jresult"
mapscript_wrap.c:26114: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26115: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26116: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26120: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26126: error: parse error before "jint"
mapscript_wrap.c:26126: error: parse error before '*' token
mapscript_wrap.c:26126: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapefileObj_1type':
mapscript_wrap.c:26127: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:26127: error: parse error before "jresult"
mapscript_wrap.c:26131: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26132: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26133: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26136: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26136: error: parse error before "result"
mapscript_wrap.c:26141: error: parse error before "jint"
mapscript_wrap.c:26141: error: parse error before '*' token
mapscript_wrap.c:26141: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapefileObj_1numshapes':
mapscript_wrap.c:26142: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:26142: error: parse error before "jresult"
mapscript_wrap.c:26146: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26147: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26148: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26151: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26151: error: parse error before "result"
mapscript_wrap.c:26156: error: parse error before "jlong"
mapscript_wrap.c:26156: error: parse error before '*' token
mapscript_wrap.c:26156: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapefileObj_1bounds':
mapscript_wrap.c:26157: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:26157: error: parse error before "jresult"
mapscript_wrap.c:26161: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26162: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26163: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26166: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26171: error: parse error before "jint"
mapscript_wrap.c:26171: error: parse error before '*' token
mapscript_wrap.c:26171: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapefileObj_1lastshape':
mapscript_wrap.c:26172: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:26172: error: parse error before "jresult"
mapscript_wrap.c:26176: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26177: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26178: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26181: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26181: error: parse error before "result"
mapscript_wrap.c:26186: error: parse error before "jstring"
mapscript_wrap.c:26186: error: parse error before '*' token
mapscript_wrap.c:26186: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapefileObj_1status':
mapscript_wrap.c:26187: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:26187: error: parse error before "jresult"
mapscript_wrap.c:26191: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26192: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26193: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26197: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26203: error: parse error before "jlong"
mapscript_wrap.c:26203: error: parse error before '*' token
mapscript_wrap.c:26203: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapefileObj_1statusbounds':
mapscript_wrap.c:26204: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:26204: error: parse error before "jresult"
mapscript_wrap.c:26208: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26209: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26210: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26213: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26218: error: parse error before "jint"
mapscript_wrap.c:26218: error: parse error before '*' token
mapscript_wrap.c:26218: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1shapefileObj_1isopen':
mapscript_wrap.c:26219: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:26219: error: parse error before "jresult"
mapscript_wrap.c:26223: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26224: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26225: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26228: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26228: error: parse error before "result"
mapscript_wrap.c:26233: error: parse error before "jlong"
mapscript_wrap.c:26233: error: parse error before '*' token
mapscript_wrap.c:26233: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1shapefileObj':
mapscript_wrap.c:26234: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:26234: error: parse error before "jresult"
mapscript_wrap.c:26239: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26240: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26243: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26248: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:26284: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26292: error: syntax error before "void"
mapscript_wrap.c:26292: error: parse error before '*' token
mapscript_wrap.c:26292: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1shapefileObj':
mapscript_wrap.c:26295: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26296: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26297: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26336: error: parse error before "jint"
mapscript_wrap.c:26336: error: parse error before '*' token
mapscript_wrap.c:26336: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapefileObj_1get':
mapscript_wrap.c:26337: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:26337: error: parse error before "jresult"
mapscript_wrap.c:26343: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26344: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26345: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26346: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:26347: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:26383: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26383: error: parse error before "result"
mapscript_wrap.c:26388: error: parse error before "jlong"
mapscript_wrap.c:26388: error: parse error before '*' token
mapscript_wrap.c:26388: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapefileObj_1getShape':
mapscript_wrap.c:26389: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:26389: error: parse error before "jresult"
mapscript_wrap.c:26394: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26395: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26396: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26397: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:26433: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26438: error: parse error before "jint"
mapscript_wrap.c:26438: error: parse error before '*' token
mapscript_wrap.c:26438: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapefileObj_1getPoint':
mapscript_wrap.c:26439: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:26439: error: parse error before "jresult"
mapscript_wrap.c:26445: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26446: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26447: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26448: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:26449: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:26485: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26485: error: parse error before "result"
mapscript_wrap.c:26490: error: parse error before "jint"
mapscript_wrap.c:26490: error: parse error before '*' token
mapscript_wrap.c:26490: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapefileObj_1getTransformed':
mapscript_wrap.c:26491: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:26491: error: parse error before "jresult"
mapscript_wrap.c:26498: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26499: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26500: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26501: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:26502: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:26503: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:26539: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26539: error: parse error before "result"
mapscript_wrap.c:26544: error: syntax error before "void"
mapscript_wrap.c:26544: error: parse error before '*' token
mapscript_wrap.c:26544: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapefileObj_1getExtent':
mapscript_wrap.c:26549: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26550: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26551: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26552: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:26553: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:26592: error: parse error before "jint"
mapscript_wrap.c:26592: error: parse error before '*' token
mapscript_wrap.c:26592: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapefileObj_1add':
mapscript_wrap.c:26593: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:26593: error: parse error before "jresult"
mapscript_wrap.c:26598: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26599: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26600: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26601: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:26637: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26637: error: parse error before "result"
mapscript_wrap.c:26642: error: parse error before "jint"
mapscript_wrap.c:26642: error: parse error before '*' token
mapscript_wrap.c:26642: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_shapefileObj_1addPoint':
mapscript_wrap.c:26643: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:26643: error: parse error before "jresult"
mapscript_wrap.c:26648: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26649: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26650: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26651: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:26687: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26687: error: parse error before "result"
mapscript_wrap.c:26692: error: syntax error before "void"
mapscript_wrap.c:26692: error: parse error before '*' token
mapscript_wrap.c:26692: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1msTiledSHPLayerInfo_1shpfile':
mapscript_wrap.c:26696: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26697: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26698: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26699: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:26705: error: parse error before "jlong"
mapscript_wrap.c:26705: error: parse error before '*' token
mapscript_wrap.c:26705: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1msTiledSHPLayerInfo_1shpfile':
mapscript_wrap.c:26706: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:26706: error: parse error before "jresult"
mapscript_wrap.c:26710: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26711: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26712: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26715: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26720: error: syntax error before "void"
mapscript_wrap.c:26720: error: parse error before '*' token
mapscript_wrap.c:26720: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1msTiledSHPLayerInfo_1tileshpfile':
mapscript_wrap.c:26724: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26725: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26726: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26727: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:26733: error: parse error before "jlong"
mapscript_wrap.c:26733: error: parse error before '*' token
mapscript_wrap.c:26733: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1msTiledSHPLayerInfo_1tileshpfile':
mapscript_wrap.c:26734: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:26734: error: parse error before "jresult"
mapscript_wrap.c:26738: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26739: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26740: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26743: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26748: error: syntax error before "void"
mapscript_wrap.c:26748: error: parse error before '*' token
mapscript_wrap.c:26748: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1msTiledSHPLayerInfo_1tilelayerindex':
mapscript_wrap.c:26752: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26753: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26754: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26755: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:26761: error: parse error before "jint"
mapscript_wrap.c:26761: error: parse error before '*' token
mapscript_wrap.c:26761: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1msTiledSHPLayerInfo_1tilelayerindex':
mapscript_wrap.c:26762: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:26762: error: parse error before "jresult"
mapscript_wrap.c:26766: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26767: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26768: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26771: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26771: error: parse error before "result"
mapscript_wrap.c:26776: error: parse error before "jlong"
mapscript_wrap.c:26776: error: parse error before '*' token
mapscript_wrap.c:26776: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1msTiledSHPLayerInfo':
mapscript_wrap.c:26777: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:26777: error: parse error before "jresult"
mapscript_wrap.c:26780: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26781: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26817: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26822: error: syntax error before "void"
mapscript_wrap.c:26822: error: parse error before '*' token
mapscript_wrap.c:26822: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1msTiledSHPLayerInfo':
mapscript_wrap.c:26825: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26826: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26827: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c: At top level:
mapscript_wrap.c:26866: error: parse error before "jint"
mapscript_wrap.c:26866: error: parse error before '*' token
mapscript_wrap.c:26866: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1projectionObj_1numargs':
mapscript_wrap.c:26867: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:26867: error: parse error before "jresult"
mapscript_wrap.c:26871: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26872: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26873: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26876: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26876: error: parse error before "result"
mapscript_wrap.c:26881: error: parse error before "jlong"
mapscript_wrap.c:26881: error: parse error before '*' token
mapscript_wrap.c:26881: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1projectionObj':
mapscript_wrap.c:26882: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:26882: error: parse error before "jresult"
mapscript_wrap.c:26886: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26887: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26890: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26930: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:26938: error: syntax error before "void"
mapscript_wrap.c:26938: error: parse error before '*' token
mapscript_wrap.c:26938: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1projectionObj':
mapscript_wrap.c:26941: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26942: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:26943: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:26982: error: parse error before "jint"
mapscript_wrap.c:26982: error: parse error before '*' token
mapscript_wrap.c:26982: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1MAXSYMBOLS':
mapscript_wrap.c:26983: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:26983: error: parse error before "jresult"
mapscript_wrap.c:26986: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:26987: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27023: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27023: error: parse error before "result"
mapscript_wrap.c:27028: error: parse error before "jint"
mapscript_wrap.c:27028: error: parse error before '*' token
mapscript_wrap.c:27028: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1MAXVECTORPOINTS':
mapscript_wrap.c:27029: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27029: error: parse error before "jresult"
mapscript_wrap.c:27032: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27033: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27069: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27069: error: parse error before "result"
mapscript_wrap.c:27074: error: parse error before "jint"
mapscript_wrap.c:27074: error: parse error before '*' token
mapscript_wrap.c:27074: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1MAXSTYLELENGTH':
mapscript_wrap.c:27075: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27075: error: parse error before "jresult"
mapscript_wrap.c:27078: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27079: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27115: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27115: error: parse error before "result"
mapscript_wrap.c:27120: error: parse error before "jint"
mapscript_wrap.c:27120: error: parse error before '*' token
mapscript_wrap.c:27120: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1IMAGECACHESIZE':
mapscript_wrap.c:27121: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27121: error: parse error before "jresult"
mapscript_wrap.c:27124: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27125: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27161: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27161: error: parse error before "result"
mapscript_wrap.c:27166: error: syntax error before "void"
mapscript_wrap.c:27166: error: parse error before '*' token
mapscript_wrap.c:27166: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1colorObj_1pen':
mapscript_wrap.c:27170: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27171: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27172: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27173: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27179: error: parse error before "jint"
mapscript_wrap.c:27179: error: parse error before '*' token
mapscript_wrap.c:27179: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1colorObj_1pen':
mapscript_wrap.c:27180: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27180: error: parse error before "jresult"
mapscript_wrap.c:27184: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27185: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27186: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27189: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27189: error: parse error before "result"
mapscript_wrap.c:27194: error: syntax error before "void"
mapscript_wrap.c:27194: error: parse error before '*' token
mapscript_wrap.c:27194: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1colorObj_1red':
mapscript_wrap.c:27198: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27199: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27200: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27201: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27207: error: parse error before "jint"
mapscript_wrap.c:27207: error: parse error before '*' token
mapscript_wrap.c:27207: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1colorObj_1red':
mapscript_wrap.c:27208: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27208: error: parse error before "jresult"
mapscript_wrap.c:27212: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27213: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27214: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27217: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27217: error: parse error before "result"
mapscript_wrap.c:27222: error: syntax error before "void"
mapscript_wrap.c:27222: error: parse error before '*' token
mapscript_wrap.c:27222: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1colorObj_1green':
mapscript_wrap.c:27226: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27227: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27228: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27229: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27235: error: parse error before "jint"
mapscript_wrap.c:27235: error: parse error before '*' token
mapscript_wrap.c:27235: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1colorObj_1green':
mapscript_wrap.c:27236: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27236: error: parse error before "jresult"
mapscript_wrap.c:27240: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27241: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27242: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27245: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27245: error: parse error before "result"
mapscript_wrap.c:27250: error: syntax error before "void"
mapscript_wrap.c:27250: error: parse error before '*' token
mapscript_wrap.c:27250: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1colorObj_1blue':
mapscript_wrap.c:27254: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27255: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27256: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27257: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27263: error: parse error before "jint"
mapscript_wrap.c:27263: error: parse error before '*' token
mapscript_wrap.c:27263: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1colorObj_1blue':
mapscript_wrap.c:27264: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27264: error: parse error before "jresult"
mapscript_wrap.c:27268: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27269: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27270: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27273: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27273: error: parse error before "result"
mapscript_wrap.c:27278: error: parse error before "jlong"
mapscript_wrap.c:27278: error: parse error before '*' token
mapscript_wrap.c:27278: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1colorObj':
mapscript_wrap.c:27279: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:27279: error: parse error before "jresult"
mapscript_wrap.c:27286: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27287: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27288: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27289: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27290: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:27291: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:27327: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27332: error: syntax error before "void"
mapscript_wrap.c:27332: error: parse error before '*' token
mapscript_wrap.c:27332: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1colorObj':
mapscript_wrap.c:27335: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27336: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27337: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27376: error: parse error before "jint"
mapscript_wrap.c:27376: error: parse error before '*' token
mapscript_wrap.c:27376: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_colorObj_1setRGB':
mapscript_wrap.c:27377: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27377: error: parse error before "jresult"
mapscript_wrap.c:27384: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27385: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27386: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27387: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27388: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:27389: error: `jarg4' undeclared (first use in this function)
mapscript_wrap.c:27425: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27425: error: parse error before "result"
mapscript_wrap.c:27430: error: parse error before "jint"
mapscript_wrap.c:27430: error: parse error before '*' token
mapscript_wrap.c:27430: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_colorObj_1setHex':
mapscript_wrap.c:27431: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27431: error: parse error before "jresult"
mapscript_wrap.c:27436: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27437: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27438: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27441: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27481: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27481: error: parse error before "result"
mapscript_wrap.c:27489: error: parse error before "jstring"
mapscript_wrap.c:27489: error: parse error before '*' token
mapscript_wrap.c:27489: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_colorObj_1toHex':
mapscript_wrap.c:27490: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:27490: error: parse error before "jresult"
mapscript_wrap.c:27494: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27495: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27496: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27533: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27540: error: syntax error before "void"
mapscript_wrap.c:27540: error: parse error before '*' token
mapscript_wrap.c:27540: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1name':
mapscript_wrap.c:27544: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27545: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27546: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27549: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27551: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:27569: error: parse error before "jstring"
mapscript_wrap.c:27569: error: parse error before '*' token
mapscript_wrap.c:27569: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1name':
mapscript_wrap.c:27570: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:27570: error: parse error before "jresult"
mapscript_wrap.c:27574: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27575: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27576: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27580: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27586: error: syntax error before "void"
mapscript_wrap.c:27586: error: parse error before '*' token
mapscript_wrap.c:27586: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1type':
mapscript_wrap.c:27590: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27591: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27592: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27593: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27599: error: parse error before "jint"
mapscript_wrap.c:27599: error: parse error before '*' token
mapscript_wrap.c:27599: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1type':
mapscript_wrap.c:27600: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27600: error: parse error before "jresult"
mapscript_wrap.c:27604: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27605: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27606: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27609: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27609: error: parse error before "result"
mapscript_wrap.c:27614: error: syntax error before "void"
mapscript_wrap.c:27614: error: parse error before '*' token
mapscript_wrap.c:27614: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1sizex':
mapscript_wrap.c:27618: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27619: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27620: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27621: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27627: error: parse error before "jdouble"
mapscript_wrap.c:27627: error: parse error before '*' token
mapscript_wrap.c:27627: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1sizex':
mapscript_wrap.c:27628: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:27628: error: parse error before "jresult"
mapscript_wrap.c:27632: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27633: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27634: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27637: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27637: error: parse error before "result"
mapscript_wrap.c:27642: error: syntax error before "void"
mapscript_wrap.c:27642: error: parse error before '*' token
mapscript_wrap.c:27642: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1sizey':
mapscript_wrap.c:27646: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27647: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27648: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27649: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27655: error: parse error before "jdouble"
mapscript_wrap.c:27655: error: parse error before '*' token
mapscript_wrap.c:27655: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1sizey':
mapscript_wrap.c:27656: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:27656: error: parse error before "jresult"
mapscript_wrap.c:27660: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27661: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27662: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27665: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27665: error: parse error before "result"
mapscript_wrap.c:27670: error: parse error before "jint"
mapscript_wrap.c:27670: error: parse error before '*' token
mapscript_wrap.c:27670: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1numpoints':
mapscript_wrap.c:27671: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27671: error: parse error before "jresult"
mapscript_wrap.c:27675: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27676: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27677: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27680: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27680: error: parse error before "result"
mapscript_wrap.c:27685: error: syntax error before "void"
mapscript_wrap.c:27685: error: parse error before '*' token
mapscript_wrap.c:27685: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1filled':
mapscript_wrap.c:27689: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27690: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27691: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27692: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27698: error: parse error before "jint"
mapscript_wrap.c:27698: error: parse error before '*' token
mapscript_wrap.c:27698: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1filled':
mapscript_wrap.c:27699: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27699: error: parse error before "jresult"
mapscript_wrap.c:27703: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27704: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27705: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27708: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27708: error: parse error before "result"
mapscript_wrap.c:27713: error: syntax error before "void"
mapscript_wrap.c:27713: error: parse error before '*' token
mapscript_wrap.c:27713: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1stylelength':
mapscript_wrap.c:27717: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27718: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27719: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27720: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27726: error: parse error before "jint"
mapscript_wrap.c:27726: error: parse error before '*' token
mapscript_wrap.c:27726: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1stylelength':
mapscript_wrap.c:27727: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27727: error: parse error before "jresult"
mapscript_wrap.c:27731: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27732: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27733: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27736: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27736: error: parse error before "result"
mapscript_wrap.c:27741: error: syntax error before "void"
mapscript_wrap.c:27741: error: parse error before '*' token
mapscript_wrap.c:27741: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1style':
mapscript_wrap.c:27744: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27744: error: `jarr2' undeclared (first use in this function)
mapscript_wrap.c:27746: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27747: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27748: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27749: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27751: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:27753: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:27764: error: parse error before "jintArray"
mapscript_wrap.c:27764: error: parse error before '*' token
mapscript_wrap.c:27764: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1style':
mapscript_wrap.c:27765: error: `jintArray' undeclared (first use in this function)
mapscript_wrap.c:27765: error: parse error before "jresult"
mapscript_wrap.c:27769: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27770: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27771: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27774: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27779: error: syntax error before "void"
mapscript_wrap.c:27779: error: parse error before '*' token
mapscript_wrap.c:27779: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1imagepath':
mapscript_wrap.c:27783: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27784: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27785: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27788: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27790: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:27808: error: parse error before "jstring"
mapscript_wrap.c:27808: error: parse error before '*' token
mapscript_wrap.c:27808: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1imagepath':
mapscript_wrap.c:27809: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:27809: error: parse error before "jresult"
mapscript_wrap.c:27813: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27814: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27815: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27819: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27825: error: syntax error before "void"
mapscript_wrap.c:27825: error: parse error before '*' token
mapscript_wrap.c:27825: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1transparent':
mapscript_wrap.c:27829: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27830: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27831: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27832: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27838: error: parse error before "jint"
mapscript_wrap.c:27838: error: parse error before '*' token
mapscript_wrap.c:27838: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1transparent':
mapscript_wrap.c:27839: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27839: error: parse error before "jresult"
mapscript_wrap.c:27843: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27844: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27845: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27848: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27848: error: parse error before "result"
mapscript_wrap.c:27853: error: syntax error before "void"
mapscript_wrap.c:27853: error: parse error before '*' token
mapscript_wrap.c:27853: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1transparentcolor':
mapscript_wrap.c:27857: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27858: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27859: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27860: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27866: error: parse error before "jint"
mapscript_wrap.c:27866: error: parse error before '*' token
mapscript_wrap.c:27866: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1transparentcolor':
mapscript_wrap.c:27867: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27867: error: parse error before "jresult"
mapscript_wrap.c:27871: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27872: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27873: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27876: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27876: error: parse error before "result"
mapscript_wrap.c:27881: error: syntax error before "void"
mapscript_wrap.c:27881: error: parse error before '*' token
mapscript_wrap.c:27881: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1character':
mapscript_wrap.c:27885: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27886: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27887: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27890: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27892: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:27910: error: parse error before "jstring"
mapscript_wrap.c:27910: error: parse error before '*' token
mapscript_wrap.c:27910: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1character':
mapscript_wrap.c:27911: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:27911: error: parse error before "jresult"
mapscript_wrap.c:27915: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27916: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27917: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27921: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27927: error: syntax error before "void"
mapscript_wrap.c:27927: error: parse error before '*' token
mapscript_wrap.c:27927: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1antialias':
mapscript_wrap.c:27931: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27932: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27933: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27934: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27940: error: parse error before "jint"
mapscript_wrap.c:27940: error: parse error before '*' token
mapscript_wrap.c:27940: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1antialias':
mapscript_wrap.c:27941: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:27941: error: parse error before "jresult"
mapscript_wrap.c:27945: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27946: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27947: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27950: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:27950: error: parse error before "result"
mapscript_wrap.c:27955: error: syntax error before "void"
mapscript_wrap.c:27955: error: parse error before '*' token
mapscript_wrap.c:27955: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1font':
mapscript_wrap.c:27959: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27960: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27961: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27964: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:27966: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:27984: error: parse error before "jstring"
mapscript_wrap.c:27984: error: parse error before '*' token
mapscript_wrap.c:27984: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1font':
mapscript_wrap.c:27985: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:27985: error: parse error before "jresult"
mapscript_wrap.c:27989: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:27990: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:27991: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:27995: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28001: error: syntax error before "void"
mapscript_wrap.c:28001: error: parse error before '*' token
mapscript_wrap.c:28001: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1gap':
mapscript_wrap.c:28005: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28006: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28007: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28008: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:28014: error: parse error before "jint"
mapscript_wrap.c:28014: error: parse error before '*' token
mapscript_wrap.c:28014: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1gap':
mapscript_wrap.c:28015: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28015: error: parse error before "jresult"
mapscript_wrap.c:28019: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28020: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28021: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28024: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28024: error: parse error before "result"
mapscript_wrap.c:28029: error: syntax error before "void"
mapscript_wrap.c:28029: error: parse error before '*' token
mapscript_wrap.c:28029: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1position':
mapscript_wrap.c:28033: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28034: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28035: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28036: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:28042: error: parse error before "jint"
mapscript_wrap.c:28042: error: parse error before '*' token
mapscript_wrap.c:28042: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1position':
mapscript_wrap.c:28043: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28043: error: parse error before "jresult"
mapscript_wrap.c:28047: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28048: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28049: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28052: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28052: error: parse error before "result"
mapscript_wrap.c:28057: error: syntax error before "void"
mapscript_wrap.c:28057: error: parse error before '*' token
mapscript_wrap.c:28057: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1linecap':
mapscript_wrap.c:28061: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28062: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28063: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28064: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:28070: error: parse error before "jint"
mapscript_wrap.c:28070: error: parse error before '*' token
mapscript_wrap.c:28070: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1linecap':
mapscript_wrap.c:28071: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28071: error: parse error before "jresult"
mapscript_wrap.c:28075: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28076: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28077: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28080: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28080: error: parse error before "result"
mapscript_wrap.c:28085: error: syntax error before "void"
mapscript_wrap.c:28085: error: parse error before '*' token
mapscript_wrap.c:28085: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1linejoin':
mapscript_wrap.c:28089: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28090: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28091: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28092: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:28098: error: parse error before "jint"
mapscript_wrap.c:28098: error: parse error before '*' token
mapscript_wrap.c:28098: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1linejoin':
mapscript_wrap.c:28099: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28099: error: parse error before "jresult"
mapscript_wrap.c:28103: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28104: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28105: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28108: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28108: error: parse error before "result"
mapscript_wrap.c:28113: error: syntax error before "void"
mapscript_wrap.c:28113: error: parse error before '*' token
mapscript_wrap.c:28113: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1symbolObj_1linejoinmaxsize':
mapscript_wrap.c:28117: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28118: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28119: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28120: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:28126: error: parse error before "jdouble"
mapscript_wrap.c:28126: error: parse error before '*' token
mapscript_wrap.c:28126: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1symbolObj_1linejoinmaxsize':
mapscript_wrap.c:28127: error: `jdouble' undeclared (first use in this function)
mapscript_wrap.c:28127: error: parse error before "jresult"
mapscript_wrap.c:28131: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28132: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28133: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28136: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28136: error: parse error before "result"
mapscript_wrap.c:28141: error: parse error before "jlong"
mapscript_wrap.c:28141: error: parse error before '*' token
mapscript_wrap.c:28141: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1symbolObj':
mapscript_wrap.c:28142: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:28142: error: parse error before "jresult"
mapscript_wrap.c:28147: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28148: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28151: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28158: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:28198: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28209: error: syntax error before "void"
mapscript_wrap.c:28209: error: parse error before '*' token
mapscript_wrap.c:28209: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1symbolObj':
mapscript_wrap.c:28212: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28213: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28214: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28253: error: parse error before "jint"
mapscript_wrap.c:28253: error: parse error before '*' token
mapscript_wrap.c:28253: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_symbolObj_1setPoints':
mapscript_wrap.c:28254: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28254: error: parse error before "jresult"
mapscript_wrap.c:28259: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28260: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28261: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28262: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:28298: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28298: error: parse error before "result"
mapscript_wrap.c:28303: error: parse error before "jlong"
mapscript_wrap.c:28303: error: parse error before '*' token
mapscript_wrap.c:28303: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_symbolObj_1getPoints':
mapscript_wrap.c:28304: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:28304: error: parse error before "jresult"
mapscript_wrap.c:28308: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28309: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28310: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28346: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28351: error: parse error before "jint"
mapscript_wrap.c:28351: error: parse error before '*' token
mapscript_wrap.c:28351: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_symbolObj_1setStyle':
mapscript_wrap.c:28352: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28352: error: parse error before "jresult"
mapscript_wrap.c:28358: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28359: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28360: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28361: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:28362: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:28398: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28398: error: parse error before "result"
mapscript_wrap.c:28403: error: parse error before "jlong"
mapscript_wrap.c:28403: error: parse error before '*' token
mapscript_wrap.c:28403: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_symbolObj_1getImage':
mapscript_wrap.c:28404: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:28404: error: parse error before "jresult"
mapscript_wrap.c:28409: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28410: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28411: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28412: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:28448: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28453: error: parse error before "jint"
mapscript_wrap.c:28453: error: parse error before '*' token
mapscript_wrap.c:28453: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_symbolObj_1setImage':
mapscript_wrap.c:28454: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28454: error: parse error before "jresult"
mapscript_wrap.c:28459: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28460: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28461: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:28462: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:28498: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28498: error: parse error before "result"
mapscript_wrap.c:28503: error: parse error before "jint"
mapscript_wrap.c:28503: error: parse error before '*' token
mapscript_wrap.c:28503: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1NOERR':
mapscript_wrap.c:28504: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28504: error: parse error before "jresult"
mapscript_wrap.c:28507: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28508: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28544: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28544: error: parse error before "result"
mapscript_wrap.c:28549: error: parse error before "jint"
mapscript_wrap.c:28549: error: parse error before '*' token
mapscript_wrap.c:28549: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1IOERR':
mapscript_wrap.c:28550: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28550: error: parse error before "jresult"
mapscript_wrap.c:28553: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28554: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28590: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28590: error: parse error before "result"
mapscript_wrap.c:28595: error: parse error before "jint"
mapscript_wrap.c:28595: error: parse error before '*' token
mapscript_wrap.c:28595: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1MEMERR':
mapscript_wrap.c:28596: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28596: error: parse error before "jresult"
mapscript_wrap.c:28599: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28600: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28636: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28636: error: parse error before "result"
mapscript_wrap.c:28641: error: parse error before "jint"
mapscript_wrap.c:28641: error: parse error before '*' token
mapscript_wrap.c:28641: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1TYPEERR':
mapscript_wrap.c:28642: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28642: error: parse error before "jresult"
mapscript_wrap.c:28645: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28646: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28682: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28682: error: parse error before "result"
mapscript_wrap.c:28687: error: parse error before "jint"
mapscript_wrap.c:28687: error: parse error before '*' token
mapscript_wrap.c:28687: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SYMERR':
mapscript_wrap.c:28688: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28688: error: parse error before "jresult"
mapscript_wrap.c:28691: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28692: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28728: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28728: error: parse error before "result"
mapscript_wrap.c:28733: error: parse error before "jint"
mapscript_wrap.c:28733: error: parse error before '*' token
mapscript_wrap.c:28733: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1REGEXERR':
mapscript_wrap.c:28734: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28734: error: parse error before "jresult"
mapscript_wrap.c:28737: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28738: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28774: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28774: error: parse error before "result"
mapscript_wrap.c:28779: error: parse error before "jint"
mapscript_wrap.c:28779: error: parse error before '*' token
mapscript_wrap.c:28779: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1TTFERR':
mapscript_wrap.c:28780: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28780: error: parse error before "jresult"
mapscript_wrap.c:28783: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28784: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28820: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28820: error: parse error before "result"
mapscript_wrap.c:28825: error: parse error before "jint"
mapscript_wrap.c:28825: error: parse error before '*' token
mapscript_wrap.c:28825: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1DBFERR':
mapscript_wrap.c:28826: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28826: error: parse error before "jresult"
mapscript_wrap.c:28829: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28830: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28866: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28866: error: parse error before "result"
mapscript_wrap.c:28871: error: parse error before "jint"
mapscript_wrap.c:28871: error: parse error before '*' token
mapscript_wrap.c:28871: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1GDERR':
mapscript_wrap.c:28872: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28872: error: parse error before "jresult"
mapscript_wrap.c:28875: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28876: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28912: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28912: error: parse error before "result"
mapscript_wrap.c:28917: error: parse error before "jint"
mapscript_wrap.c:28917: error: parse error before '*' token
mapscript_wrap.c:28917: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1IDENTERR':
mapscript_wrap.c:28918: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28918: error: parse error before "jresult"
mapscript_wrap.c:28921: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28922: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:28958: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:28958: error: parse error before "result"
mapscript_wrap.c:28963: error: parse error before "jint"
mapscript_wrap.c:28963: error: parse error before '*' token
mapscript_wrap.c:28963: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1EOFERR':
mapscript_wrap.c:28964: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:28964: error: parse error before "jresult"
mapscript_wrap.c:28967: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:28968: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29004: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29004: error: parse error before "result"
mapscript_wrap.c:29009: error: parse error before "jint"
mapscript_wrap.c:29009: error: parse error before '*' token
mapscript_wrap.c:29009: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1PROJERR':
mapscript_wrap.c:29010: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29010: error: parse error before "jresult"
mapscript_wrap.c:29013: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29014: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29050: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29050: error: parse error before "result"
mapscript_wrap.c:29055: error: parse error before "jint"
mapscript_wrap.c:29055: error: parse error before '*' token
mapscript_wrap.c:29055: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1MISCERR':
mapscript_wrap.c:29056: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29056: error: parse error before "jresult"
mapscript_wrap.c:29059: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29060: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29096: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29096: error: parse error before "result"
mapscript_wrap.c:29101: error: parse error before "jint"
mapscript_wrap.c:29101: error: parse error before '*' token
mapscript_wrap.c:29101: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1CGIERR':
mapscript_wrap.c:29102: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29102: error: parse error before "jresult"
mapscript_wrap.c:29105: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29106: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29142: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29142: error: parse error before "result"
mapscript_wrap.c:29147: error: parse error before "jint"
mapscript_wrap.c:29147: error: parse error before '*' token
mapscript_wrap.c:29147: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1WEBERR':
mapscript_wrap.c:29148: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29148: error: parse error before "jresult"
mapscript_wrap.c:29151: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29152: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29188: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29188: error: parse error before "result"
mapscript_wrap.c:29193: error: parse error before "jint"
mapscript_wrap.c:29193: error: parse error before '*' token
mapscript_wrap.c:29193: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1IMGERR':
mapscript_wrap.c:29194: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29194: error: parse error before "jresult"
mapscript_wrap.c:29197: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29198: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29234: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29234: error: parse error before "result"
mapscript_wrap.c:29239: error: parse error before "jint"
mapscript_wrap.c:29239: error: parse error before '*' token
mapscript_wrap.c:29239: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1HASHERR':
mapscript_wrap.c:29240: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29240: error: parse error before "jresult"
mapscript_wrap.c:29243: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29244: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29280: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29280: error: parse error before "result"
mapscript_wrap.c:29285: error: parse error before "jint"
mapscript_wrap.c:29285: error: parse error before '*' token
mapscript_wrap.c:29285: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1JOINERR':
mapscript_wrap.c:29286: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29286: error: parse error before "jresult"
mapscript_wrap.c:29289: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29290: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29326: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29326: error: parse error before "result"
mapscript_wrap.c:29331: error: parse error before "jint"
mapscript_wrap.c:29331: error: parse error before '*' token
mapscript_wrap.c:29331: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1NOTFOUND':
mapscript_wrap.c:29332: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29332: error: parse error before "jresult"
mapscript_wrap.c:29335: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29336: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29372: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29372: error: parse error before "result"
mapscript_wrap.c:29377: error: parse error before "jint"
mapscript_wrap.c:29377: error: parse error before '*' token
mapscript_wrap.c:29377: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SHPERR':
mapscript_wrap.c:29378: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29378: error: parse error before "jresult"
mapscript_wrap.c:29381: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29382: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29418: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29418: error: parse error before "result"
mapscript_wrap.c: At top level:
mapscript_wrap.c:29423: error: parse error before "jint"
mapscript_wrap.c:29423: error: parse error before '*' token
mapscript_wrap.c:29423: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1PARSEERR':
mapscript_wrap.c:29424: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29424: error: parse error before "jresult"
mapscript_wrap.c:29427: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29428: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29464: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29464: error: parse error before "result"
mapscript_wrap.c:29469: error: parse error before "jint"
mapscript_wrap.c:29469: error: parse error before '*' token
mapscript_wrap.c:29469: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SDEERR':
mapscript_wrap.c:29470: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29470: error: parse error before "jresult"
mapscript_wrap.c:29473: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29474: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29510: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29510: error: parse error before "result"
mapscript_wrap.c:29515: error: parse error before "jint"
mapscript_wrap.c:29515: error: parse error before '*' token
mapscript_wrap.c:29515: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1OGRERR':
mapscript_wrap.c:29516: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29516: error: parse error before "jresult"
mapscript_wrap.c:29519: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29520: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29556: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29556: error: parse error before "result"
mapscript_wrap.c:29561: error: parse error before "jint"
mapscript_wrap.c:29561: error: parse error before '*' token
mapscript_wrap.c:29561: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1QUERYERR':
mapscript_wrap.c:29562: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29562: error: parse error before "jresult"
mapscript_wrap.c:29565: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29566: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29602: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29602: error: parse error before "result"
mapscript_wrap.c:29607: error: parse error before "jint"
mapscript_wrap.c:29607: error: parse error before '*' token
mapscript_wrap.c:29607: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1WMSERR':
mapscript_wrap.c:29608: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29608: error: parse error before "jresult"
mapscript_wrap.c:29611: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29612: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29648: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29648: error: parse error before "result"
mapscript_wrap.c:29653: error: parse error before "jint"
mapscript_wrap.c:29653: error: parse error before '*' token
mapscript_wrap.c:29653: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1WMSCONNERR':
mapscript_wrap.c:29654: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29654: error: parse error before "jresult"
mapscript_wrap.c:29657: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29658: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29694: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29694: error: parse error before "result"
mapscript_wrap.c:29699: error: parse error before "jint"
mapscript_wrap.c:29699: error: parse error before '*' token
mapscript_wrap.c:29699: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1ORACLESPATIALERR':
mapscript_wrap.c:29700: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29700: error: parse error before "jresult"
mapscript_wrap.c:29703: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29704: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29740: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29740: error: parse error before "result"
mapscript_wrap.c:29745: error: parse error before "jint"
mapscript_wrap.c:29745: error: parse error before '*' token
mapscript_wrap.c:29745: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1WFSERR':
mapscript_wrap.c:29746: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29746: error: parse error before "jresult"
mapscript_wrap.c:29749: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29750: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29786: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29786: error: parse error before "result"
mapscript_wrap.c:29791: error: parse error before "jint"
mapscript_wrap.c:29791: error: parse error before '*' token
mapscript_wrap.c:29791: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1WFSCONNERR':
mapscript_wrap.c:29792: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29792: error: parse error before "jresult"
mapscript_wrap.c:29795: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29796: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29832: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29832: error: parse error before "result"
mapscript_wrap.c:29837: error: parse error before "jint"
mapscript_wrap.c:29837: error: parse error before '*' token
mapscript_wrap.c:29837: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1MAPCONTEXTERR':
mapscript_wrap.c:29838: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29838: error: parse error before "jresult"
mapscript_wrap.c:29841: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29842: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29878: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29878: error: parse error before "result"
mapscript_wrap.c:29883: error: parse error before "jint"
mapscript_wrap.c:29883: error: parse error before '*' token
mapscript_wrap.c:29883: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1HTTPERR':
mapscript_wrap.c:29884: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29884: error: parse error before "jresult"
mapscript_wrap.c:29887: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29888: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29924: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29924: error: parse error before "result"
mapscript_wrap.c:29929: error: parse error before "jint"
mapscript_wrap.c:29929: error: parse error before '*' token
mapscript_wrap.c:29929: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1CHILDERR':
mapscript_wrap.c:29930: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29930: error: parse error before "jresult"
mapscript_wrap.c:29933: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29934: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:29970: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:29970: error: parse error before "result"
mapscript_wrap.c:29975: error: parse error before "jint"
mapscript_wrap.c:29975: error: parse error before '*' token
mapscript_wrap.c:29975: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1WCSERR':
mapscript_wrap.c:29976: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:29976: error: parse error before "jresult"
mapscript_wrap.c:29979: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:29980: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30016: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30016: error: parse error before "result"
mapscript_wrap.c:30021: error: parse error before "jint"
mapscript_wrap.c:30021: error: parse error before '*' token
mapscript_wrap.c:30021: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1GEOSERR':
mapscript_wrap.c:30022: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:30022: error: parse error before "jresult"
mapscript_wrap.c:30025: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30026: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30062: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30062: error: parse error before "result"
mapscript_wrap.c:30067: error: parse error before "jint"
mapscript_wrap.c:30067: error: parse error before '*' token
mapscript_wrap.c:30067: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1RECTERR':
mapscript_wrap.c:30068: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:30068: error: parse error before "jresult"
mapscript_wrap.c:30071: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30072: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30108: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30108: error: parse error before "result"
mapscript_wrap.c:30113: error: parse error before "jint"
mapscript_wrap.c:30113: error: parse error before '*' token
mapscript_wrap.c:30113: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1TIMEERR':
mapscript_wrap.c:30114: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:30114: error: parse error before "jresult"
mapscript_wrap.c:30117: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30118: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30154: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30154: error: parse error before "result"
mapscript_wrap.c:30159: error: parse error before "jint"
mapscript_wrap.c:30159: error: parse error before '*' token
mapscript_wrap.c:30159: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1GMLERR':
mapscript_wrap.c:30160: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:30160: error: parse error before "jresult"
mapscript_wrap.c:30163: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30164: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30200: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30200: error: parse error before "result"
mapscript_wrap.c:30205: error: parse error before "jint"
mapscript_wrap.c:30205: error: parse error before '*' token
mapscript_wrap.c:30205: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1NUMERRORCODES':
mapscript_wrap.c:30206: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:30206: error: parse error before "jresult"
mapscript_wrap.c:30209: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30210: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30246: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30246: error: parse error before "result"
mapscript_wrap.c:30251: error: parse error before "jint"
mapscript_wrap.c:30251: error: parse error before '*' token
mapscript_wrap.c:30251: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MESSAGELENGTH':
mapscript_wrap.c:30252: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:30252: error: parse error before "jresult"
mapscript_wrap.c:30255: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30256: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30292: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30292: error: parse error before "result"
mapscript_wrap.c:30297: error: parse error before "jint"
mapscript_wrap.c:30297: error: parse error before '*' token
mapscript_wrap.c:30297: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1ROUTINELENGTH':
mapscript_wrap.c:30298: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:30298: error: parse error before "jresult"
mapscript_wrap.c:30301: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30302: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30338: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30338: error: parse error before "result"
mapscript_wrap.c:30343: error: syntax error before "void"
mapscript_wrap.c:30343: error: parse error before '*' token
mapscript_wrap.c:30343: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1errorObj_1code':
mapscript_wrap.c:30347: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30348: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30349: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:30350: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:30356: error: parse error before "jint"
mapscript_wrap.c:30356: error: parse error before '*' token
mapscript_wrap.c:30356: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1errorObj_1code':
mapscript_wrap.c:30357: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:30357: error: parse error before "jresult"
mapscript_wrap.c:30361: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30362: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30363: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:30366: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30366: error: parse error before "result"
mapscript_wrap.c:30371: error: syntax error before "void"
mapscript_wrap.c:30371: error: parse error before '*' token
mapscript_wrap.c:30371: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1errorObj_1routine':
mapscript_wrap.c:30375: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30376: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30377: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:30380: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:30382: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:30396: error: parse error before "jstring"
mapscript_wrap.c:30396: error: parse error before '*' token
mapscript_wrap.c:30396: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1errorObj_1routine':
mapscript_wrap.c:30397: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:30397: error: parse error before "jresult"
mapscript_wrap.c:30401: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30402: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30403: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:30407: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30413: error: syntax error before "void"
mapscript_wrap.c:30413: error: parse error before '*' token
mapscript_wrap.c:30413: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1errorObj_1message':
mapscript_wrap.c:30417: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30418: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30419: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:30422: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:30424: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:30438: error: parse error before "jstring"
mapscript_wrap.c:30438: error: parse error before '*' token
mapscript_wrap.c:30438: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1errorObj_1message':
mapscript_wrap.c:30439: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:30439: error: parse error before "jresult"
mapscript_wrap.c:30443: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30444: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30445: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:30449: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30455: error: parse error before "jlong"
mapscript_wrap.c:30455: error: parse error before '*' token
mapscript_wrap.c:30455: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1errorObj':
mapscript_wrap.c:30456: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:30456: error: parse error before "jresult"
mapscript_wrap.c:30459: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30460: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30496: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30501: error: syntax error before "void"
mapscript_wrap.c:30501: error: parse error before '*' token
mapscript_wrap.c:30501: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1errorObj':
mapscript_wrap.c:30504: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30505: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30506: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:30545: error: parse error before "jlong"
mapscript_wrap.c:30545: error: parse error before '*' token
mapscript_wrap.c:30545: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_errorObj_1next':
mapscript_wrap.c:30546: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:30546: error: parse error before "jresult"
mapscript_wrap.c:30550: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30551: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30552: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:30588: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30593: error: parse error before "jlong"
mapscript_wrap.c:30593: error: parse error before '*' token
mapscript_wrap.c:30593: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msGetErrorObj':
mapscript_wrap.c:30594: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:30594: error: parse error before "jresult"
mapscript_wrap.c:30597: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30598: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30634: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30639: error: syntax error before "void"
mapscript_wrap.c:30639: error: parse error before '*' token
mapscript_wrap.c:30639: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msResetErrorList':
mapscript_wrap.c:30640: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30641: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30680: error: parse error before "jstring"
mapscript_wrap.c:30680: error: parse error before '*' token
mapscript_wrap.c:30680: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msGetVersion':
mapscript_wrap.c:30681: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:30681: error: parse error before "jresult"
mapscript_wrap.c:30684: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30685: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30722: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30728: error: parse error before "jstring"
mapscript_wrap.c:30728: error: parse error before '*' token
mapscript_wrap.c:30728: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msGetErrorString':
mapscript_wrap.c:30729: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:30729: error: parse error before "jresult"
mapscript_wrap.c:30733: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30734: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30737: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:30778: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30787: error: parse error before "jint"
mapscript_wrap.c:30787: error: parse error before '*' token
mapscript_wrap.c:30787: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1HASHSIZE':
mapscript_wrap.c:30788: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:30788: error: parse error before "jresult"
mapscript_wrap.c:30791: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30792: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30828: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30828: error: parse error before "result"
mapscript_wrap.c:30833: error: parse error before "jint"
mapscript_wrap.c:30833: error: parse error before '*' token
mapscript_wrap.c:30833: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1hashTableObj_1numitems':
mapscript_wrap.c:30834: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:30834: error: parse error before "jresult"
mapscript_wrap.c:30838: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30839: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30840: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:30843: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30843: error: parse error before "result"
mapscript_wrap.c:30848: error: parse error before "jlong"
mapscript_wrap.c:30848: error: parse error before '*' token
mapscript_wrap.c:30848: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1hashTableObj':
mapscript_wrap.c:30849: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:30849: error: parse error before "jresult"
mapscript_wrap.c:30852: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30853: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30889: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30894: error: syntax error before "void"
mapscript_wrap.c:30894: error: parse error before '*' token
mapscript_wrap.c:30894: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1hashTableObj':
mapscript_wrap.c:30897: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30898: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30899: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:30938: error: parse error before "jint"
mapscript_wrap.c:30938: error: parse error before '*' token
mapscript_wrap.c:30938: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_hashTableObj_1set':
mapscript_wrap.c:30939: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:30939: error: parse error before "jresult"
mapscript_wrap.c:30945: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:30946: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:30947: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:30950: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:30957: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:30997: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:30997: error: parse error before "result"
mapscript_wrap.c:31008: error: parse error before "jstring"
mapscript_wrap.c:31008: error: parse error before '*' token
mapscript_wrap.c:31008: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_hashTableObj_1get':
mapscript_wrap.c:31009: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:31009: error: parse error before "jresult"
mapscript_wrap.c:31015: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31016: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31017: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31020: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:31027: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:31068: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31080: error: parse error before "jint"
mapscript_wrap.c:31080: error: parse error before '*' token
mapscript_wrap.c:31080: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_hashTableObj_1remove':
mapscript_wrap.c:31081: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:31081: error: parse error before "jresult"
mapscript_wrap.c:31086: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31087: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31088: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31091: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:31131: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31131: error: parse error before "result"
mapscript_wrap.c:31139: error: syntax error before "void"
mapscript_wrap.c:31139: error: parse error before '*' token
mapscript_wrap.c:31139: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_hashTableObj_1clear':
mapscript_wrap.c:31142: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31143: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31144: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31183: error: parse error before "jstring"
mapscript_wrap.c:31183: error: parse error before '*' token
mapscript_wrap.c:31183: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_hashTableObj_1nextKey':
mapscript_wrap.c:31184: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:31184: error: parse error before "jresult"
mapscript_wrap.c:31189: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31190: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31191: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31194: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:31235: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31244: error: parse error before "jlong"
mapscript_wrap.c:31244: error: parse error before '*' token
mapscript_wrap.c:31244: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msCreateHashTable':
mapscript_wrap.c:31245: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:31245: error: parse error before "jresult"
mapscript_wrap.c:31248: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31249: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31285: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31290: error: parse error before "jint"
mapscript_wrap.c:31290: error: parse error before '*' token
mapscript_wrap.c:31290: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_initHashTable':
mapscript_wrap.c:31291: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:31291: error: parse error before "jresult"
mapscript_wrap.c:31295: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31296: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31297: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31333: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31333: error: parse error before "result"
mapscript_wrap.c:31338: error: syntax error before "void"
mapscript_wrap.c:31338: error: parse error before '*' token
mapscript_wrap.c:31338: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msFreeHashTable':
mapscript_wrap.c:31341: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31342: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31343: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31382: error: syntax error before "void"
mapscript_wrap.c:31382: error: parse error before '*' token
mapscript_wrap.c:31382: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msFreeHashItems':
mapscript_wrap.c:31385: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31386: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31387: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31426: error: parse error before "jlong"
mapscript_wrap.c:31426: error: parse error before '*' token
mapscript_wrap.c:31426: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msInsertHashTable':
mapscript_wrap.c:31427: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:31427: error: parse error before "jresult"
mapscript_wrap.c:31433: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31434: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31435: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31438: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:31445: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:31485: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31496: error: parse error before "jstring"
mapscript_wrap.c:31496: error: parse error before '*' token
mapscript_wrap.c:31496: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msLookupHashTable':
mapscript_wrap.c:31497: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:31497: error: parse error before "jresult"
mapscript_wrap.c:31502: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31503: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31504: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31507: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:31548: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31557: error: parse error before "jint"
mapscript_wrap.c:31557: error: parse error before '*' token
mapscript_wrap.c:31557: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msRemoveHashTable':
mapscript_wrap.c:31558: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:31558: error: parse error before "jresult"
mapscript_wrap.c:31563: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31564: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31565: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31568: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:31608: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31608: error: parse error before "result"
mapscript_wrap.c:31616: error: parse error before "jstring"
mapscript_wrap.c:31616: error: parse error before '*' token
mapscript_wrap.c:31616: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msFirstKeyFromHashTable':
mapscript_wrap.c:31617: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:31617: error: parse error before "jresult"
mapscript_wrap.c:31621: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31622: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31623: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31660: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31666: error: parse error before "jstring"
mapscript_wrap.c:31666: error: parse error before '*' token
mapscript_wrap.c:31666: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msNextKeyFromHashTable':
mapscript_wrap.c:31667: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:31667: error: parse error before "jresult"
mapscript_wrap.c:31672: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31673: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31674: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31677: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:31718: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31727: error: parse error before "jint"
mapscript_wrap.c:31727: error: parse error before '*' token
mapscript_wrap.c:31727: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MAX_1PARAMS':
mapscript_wrap.c:31728: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:31728: error: parse error before "jresult"
mapscript_wrap.c:31731: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31732: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31768: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31768: error: parse error before "result"
mapscript_wrap.c:31773: error: parse error before "jint"
mapscript_wrap.c:31773: error: parse error before '*' token
mapscript_wrap.c:31773: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1OWSRequest_1NumParams':
mapscript_wrap.c:31774: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:31774: error: parse error before "jresult"
mapscript_wrap.c:31778: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31779: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31780: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31783: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31783: error: parse error before "result"
mapscript_wrap.c:31788: error: syntax error before "void"
mapscript_wrap.c:31788: error: parse error before '*' token
mapscript_wrap.c:31788: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1OWSRequest_1type':
mapscript_wrap.c:31792: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31793: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31794: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31795: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:31801: error: parse error before "jint"
mapscript_wrap.c:31801: error: parse error before '*' token
mapscript_wrap.c:31801: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1OWSRequest_1type':
mapscript_wrap.c:31802: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:31802: error: parse error before "jresult"
mapscript_wrap.c:31806: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31807: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31808: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31811: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31811: error: parse error before "result"
mapscript_wrap.c:31816: error: syntax error before "void"
mapscript_wrap.c:31816: error: parse error before '*' token
mapscript_wrap.c:31816: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1OWSRequest_1contenttype':
mapscript_wrap.c:31820: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31821: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31822: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31825: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:31827: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:31845: error: parse error before "jstring"
mapscript_wrap.c:31845: error: parse error before '*' token
mapscript_wrap.c:31845: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1OWSRequest_1contenttype':
mapscript_wrap.c:31846: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:31846: error: parse error before "jresult"
mapscript_wrap.c:31850: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31851: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31852: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31856: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31862: error: syntax error before "void"
mapscript_wrap.c:31862: error: parse error before '*' token
mapscript_wrap.c:31862: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1OWSRequest_1postrequest':
mapscript_wrap.c:31866: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31867: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31868: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31871: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:31873: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:31891: error: parse error before "jstring"
mapscript_wrap.c:31891: error: parse error before '*' token
mapscript_wrap.c:31891: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1OWSRequest_1postrequest':
mapscript_wrap.c:31892: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:31892: error: parse error before "jresult"
mapscript_wrap.c:31896: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31897: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31898: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31902: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31908: error: parse error before "jlong"
mapscript_wrap.c:31908: error: parse error before '*' token
mapscript_wrap.c:31908: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1OWSRequest':
mapscript_wrap.c:31909: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:31909: error: parse error before "jresult"
mapscript_wrap.c:31912: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31913: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31949: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:31954: error: syntax error before "void"
mapscript_wrap.c:31954: error: parse error before '*' token
mapscript_wrap.c:31954: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1OWSRequest':
mapscript_wrap.c:31957: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:31958: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:31959: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:31998: error: syntax error before "void"
mapscript_wrap.c:31998: error: parse error before '*' token
mapscript_wrap.c:31998: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_OWSRequest_1setParameter':
mapscript_wrap.c:32003: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32004: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32005: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32008: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:32010: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:32015: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:32017: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:32064: error: parse error before "jstring"
mapscript_wrap.c:32064: error: parse error before '*' token
mapscript_wrap.c:32064: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_OWSRequest_1getName':
mapscript_wrap.c:32065: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:32065: error: parse error before "jresult"
mapscript_wrap.c:32070: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32071: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32072: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32073: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:32110: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:32116: error: parse error before "jstring"
mapscript_wrap.c:32116: error: parse error before '*' token
mapscript_wrap.c:32116: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_OWSRequest_1getValue':
mapscript_wrap.c:32117: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:32117: error: parse error before "jresult"
mapscript_wrap.c:32122: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32123: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32124: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32125: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:32162: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:32168: error: parse error before "jstring"
mapscript_wrap.c:32168: error: parse error before '*' token
mapscript_wrap.c:32168: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_OWSRequest_1getValueByName':
mapscript_wrap.c:32169: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:32169: error: parse error before "jresult"
mapscript_wrap.c:32174: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32175: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32176: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32179: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:32220: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:32229: error: parse error before "jint"
mapscript_wrap.c:32229: error: parse error before '*' token
mapscript_wrap.c:32229: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_loadParams':
mapscript_wrap.c:32230: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:32230: error: parse error before "jresult"
mapscript_wrap.c:32234: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32235: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32236: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32272: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:32272: error: parse error before "result"
mapscript_wrap.c:32277: error: syntax error before "void"
mapscript_wrap.c:32277: error: parse error before '*' token
mapscript_wrap.c:32277: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_getword':
mapscript_wrap.c:32282: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32283: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32286: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32288: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:32293: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:32295: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:32298: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:32343: error: parse error before "jstring"
mapscript_wrap.c:32343: error: parse error before '*' token
mapscript_wrap.c:32343: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_makeword_1skip':
mapscript_wrap.c:32344: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:32344: error: parse error before "jresult"
mapscript_wrap.c:32350: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32351: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32354: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32359: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:32360: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:32397: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:32406: error: parse error before "jstring"
mapscript_wrap.c:32406: error: parse error before '*' token
mapscript_wrap.c:32406: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_makeword':
mapscript_wrap.c:32407: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:32407: error: parse error before "jresult"
mapscript_wrap.c:32412: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32413: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32416: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32421: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:32458: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:32467: error: parse error before "jstring"
mapscript_wrap.c:32467: error: parse error before '*' token
mapscript_wrap.c:32467: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_fmakeword':
mapscript_wrap.c:32468: error: `jstring' undeclared (first use in this function)
mapscript_wrap.c:32468: error: parse error before "jresult"
mapscript_wrap.c:32474: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32475: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32476: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32477: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:32478: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:32515: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:32521: error: parse error before "jchar"
mapscript_wrap.c:32521: error: parse error before '*' token
mapscript_wrap.c:32521: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_x2c':
mapscript_wrap.c:32522: error: `jchar' undeclared (first use in this function)
mapscript_wrap.c:32522: error: parse error before "jresult"
mapscript_wrap.c:32526: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32527: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32530: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32570: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:32570: error: parse error before "result"
mapscript_wrap.c:32578: error: syntax error before "void"
mapscript_wrap.c:32578: error: parse error before '*' token
mapscript_wrap.c:32578: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_unescape_1url':
mapscript_wrap.c:32581: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32582: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32585: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32587: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:32631: error: syntax error before "void"
mapscript_wrap.c:32631: error: parse error before '*' token
mapscript_wrap.c:32631: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_plustospace':
mapscript_wrap.c:32634: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32635: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32638: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32640: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:32684: error: parse error before "jint"
mapscript_wrap.c:32684: error: parse error before '*' token
mapscript_wrap.c:32684: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_rind':
mapscript_wrap.c:32685: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:32685: error: parse error before "jresult"
mapscript_wrap.c:32690: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32691: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32694: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32699: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:32735: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:32735: error: parse error before "result"
mapscript_wrap.c:32743: error: parse error before "jint"
mapscript_wrap.c:32743: error: parse error before '*' token
mapscript_wrap.c:32743: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI__1getline':
mapscript_wrap.c:32744: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:32744: error: parse error before "jresult"
mapscript_wrap.c:32750: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32751: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32754: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32759: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:32760: error: `jarg3' undeclared (first use in this function)
mapscript_wrap.c:32796: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:32796: error: parse error before "result"
mapscript_wrap.c:32804: error: syntax error before "void"
mapscript_wrap.c:32804: error: parse error before '*' token
mapscript_wrap.c:32804: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_send_1fd':
mapscript_wrap.c:32808: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32809: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32810: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32811: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:32850: error: parse error before "jint"
mapscript_wrap.c:32850: error: parse error before '*' token
mapscript_wrap.c:32850: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_ind':
mapscript_wrap.c:32851: error: `jint' undeclared (first use in this function)
mapscript_wrap.c:32851: error: parse error before "jresult"
mapscript_wrap.c:32856: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32857: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32860: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32865: error: `jarg2' undeclared (first use in this function)
mapscript_wrap.c:32901: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:32901: error: parse error before "result"
mapscript_wrap.c:32909: error: syntax error before "void"
mapscript_wrap.c:32909: error: parse error before '*' token
mapscript_wrap.c:32909: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_escape_1shell_1cmd':
mapscript_wrap.c:32912: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32913: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:32916: error: `jarg1' undeclared (first use in this function)
mapscript_wrap.c:32918: warning: `return' with no value, in function returning non-void
mapscript_wrap.c:32962: error: parse error before "jlong"
mapscript_wrap.c:32962: error: parse error before '*' token
mapscript_wrap.c:32962: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msAllocCgiObj':
mapscript_wrap.c:32963: error: `jlong' undeclared (first use in this function)
mapscript_wrap.c:32963: error: parse error before "jresult"
mapscript_wrap.c:32966: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:32967: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:33003: error: `jresult' undeclared (first use in this function)
mapscript_wrap.c:33008: error: syntax error before "void"
mapscript_wrap.c:33008: error: parse error before '*' token
mapscript_wrap.c:33008: warning: return type defaults to `int'
mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_msFreeCgiObj':
mapscript_wrap.c:33011: error: `jenv' undeclared (first use in this function)
mapscript_wrap.c:33012: error: `jcls' undeclared (first use in this function)
mapscript_wrap.c:33013: error: `jarg1' undeclared (first use in this function)
make: *** [mapscript_so] Error 1
