[mapserver] Java VM Crashes using the Mapscript API
Christian Schroeder
mailings at ABIWOOD99.DE
Tue Jun 21 14:29:37 EDT 2005
Hello Mario,
thank you for this tip,
I've read about this problem somewhere else and tagged my whole method
which uses the mapserver calls as "synchronized", but it did'n help.
I will try it the way you supposed to and hope it will not crash then..
Thank you,
Christian,
Germany
Mario Basa schrieb:
>Hello,
>I used to get these problems until I synchronized the cleass doing the
>map operations (synchronize(this)). I also placed tons of try...catch
>hoping that the exceptions can be caught before it brings down tomcat.
>I am using 4.6.0 and it has been very stable for me so far, although I
>haven't put too much stress on the servlet yet.
>mario.
>yokohama,japan.
>On 6/22/05, Sean Gillies <sgillies at frii.com> wrote:
>>I'm forwarding this to the users list. Hopefully, Umberto will be able
>>to provide some insight.
>>cheers,
>>Sean
>>On Jun 16, 2005, at 5:08 PM, Christian Schröder wrote:
>>>Dear Mr. Gillies,
>>>some weeks ago me and Florian Pepping contacted you because we had
>>>problems using the Java Mapscript API. Thanks to you we could solve
>>>these problems :-)
>>>Now we got our program doing what it's supposed to do but there is
>>>still a big problem left which we were not able to solve yet:
>>>We created a simple servlet which is created inside a Tomcat 5.0
>>>Webserver. This servlet created a map image (png/jpg) and displays
>>>some specified objects on the map. (We use it for location based
>>>services --> "show me the position of the next printer").
>>>After an irregular number of calls of our servlet which uses the Java
>>>Mapscript API the complete Java VM and with it the Tomcat crashes. I
>>>attached the error report below. The program works properly for a
>>>number of calls (between 5 and 1000 :-) ) and after that it crashes.
>>>We have tried several versions of the mapserver (4.4.1, 4.4.2, 4.2.4,
>>>4.6.1 RC1) and compiled the Java Mapscript Module with JDK 1.4.2 and
>>>1.5.0. We also configured mapserver using the --with-threads option,
>>>but all this did not help. By the way the mapserv cgi-module works
>>>properly.
>>>Do you have an idea for this?
>>>Thanks for your anxiety
>>>Christian & Florian
>>>University of Paderborn, Germany
>>>JavaMapscriptLoader: mapscript native library has been loaded.
>>> * mapscript native library loaded *
>>>An unexpected exception has been detected in native code outside the
>>>VM.
>>>Unexpected Signal : 11 occurred at PC=0x3338268
>>>Function=delete_classObj+0x8
>>>Library=/usr/lib/libmapscript.so
>>>Current Java thread:
>>> at edu.umn.gis.mapscript.mapscriptJNI.delete_classObj(Native
>>>Method)
>>> at edu.umn.gis.mapscript.classObj.delete(classObj.java:32)
>>> at edu.umn.gis.mapscript.classObj.finalize(classObj.java:26)
>>> at java.lang.ref.Finalizer.invokeFinalizeMethod(Native Method)
>>> at java.lang.ref.Finalizer.runFinalizer(Finalizer.java:83)
>>> at java.lang.ref.Finalizer.access$100(Finalizer.java:14)
>>> at
>>>java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:160)
>>>Dynamic libraries:
>>>Can not get information for pid = 10558
>>>Heap at VM Abort:
>>>Heap
>>> def new generation total 1152K, used 135K [0x08ae0000, 0x08c20000,
>>>0x08fc0000)
>>> eden space 1024K, 0% used [0x08ae0000, 0x08ae4078, 0x08be0000)
>>> from space 128K, 100% used [0x08c00000, 0x08c20000, 0x08c20000)
>>> to space 128K, 0% used [0x08be0000, 0x08be0000, 0x08c00000)
>>> tenured generation total 15048K, used 13624K [0x08fc0000,
>>>0x09e72000,
>>>0x0cae0000)
>>> the space 15048K, 90% used [0x08fc0000, 0x09d0e1c0, 0x09d0e200,
>>>0x09e72000)
>>> compacting perm gen total 18432K, used 18373K [0x0cae0000,
>>>0x0dce0000,
>>>0x10ae0000)
>>> the space 18432K, 99% used [0x0cae0000, 0x0dcd1618, 0x0dcd1800,
>>>0x0dce0000)
>>>Local Time = Tue Jun 14 15:32:19 2005
>>>Elapsed Time = 246
>>># The exception above was detected in native code outside the VM
>>># Java VM: Java HotSpot(TM) Client VM (1.4.2_08-b03 mixed mode)
>>># An error report file has been saved as /tmp/hs_err_pid10558.log.
>>># Please refer to the file for further information.
>>>On Mar 22, 2005, at 12:02 PM, Florian Pepping wrote:
>>>>Dear Mr. Gillies,
>>>>I'm a student of the University of Paderborn in Germany and member of
>>>> the project group "Location Based Services for Wireless Devices". In
>>>> this project we try to position laptops and other WLAN-enabled
>>>>devices using the signal strength of the WLAN. According to their
>>>>position, we want to offer location based services to the persons
>>>>using the devices (where I am; where's the next printer; is there a
>>>>friend nearby)
>>>>In order to do this, we want to use your mapserver and the Java
>>>>Mapscript API to generate maps according to the actual position and
>>>>situation. We like to customize the map of our building and add
>>>>points, lines and so on.
>>>>We have been able to compile the whole mapserver and the Java
>>>>Mapscript API. A small Java example also works, which presents an
>>>>unchanged map of our building.
