[mapserver] Java VM Crashes using the Mapscript API
Christian Schroeder
mailings at ABIWOOD99.DE
Tue Jun 21 14:33:32 EDT 2005
Hello Umberto,
thank your for your immediate answer.
I do not call the delete_ methody directly and don't think I am using
special gc parameters.
And... I have read the README file before compiling the mapserver :-)
I will try to get it to work with "synchronized"-flags als Mario Basa
supposed.
Thank you!
Christian
Umberto Nicoletti schrieb:
>Christian,
>are you calling the delete_ methods directly in your code or are you
>using some special gc paramaters?
>As a side note the --use-threads option to configure is *absolutely*
>necessary, as are brakes on your car. I think we should write it in
>the README (as if someone actually cared to read it :-( ).
>Best regards,
>Umberto
>On 6/21/05, Sean Gillies <sgillies at frii.com> wrote:
>>I'm forwarding this to the users list. Hopefully, Umberto will be able
>>to provide some insight.
>>cheers,
>>Sean
>>On Jun 16, 2005, at 5:08 PM, Christian Schröder wrote:
>>>Dear Mr. Gillies,
>>>some weeks ago me and Florian Pepping contacted you because we had
>>>problems using the Java Mapscript API. Thanks to you we could solve
>>>these problems :-)
>>>Now we got our program doing what it's supposed to do but there is
>>>still a big problem left which we were not able to solve yet:
>>>We created a simple servlet which is created inside a Tomcat 5.0
>>>Webserver. This servlet created a map image (png/jpg) and displays
>>>some specified objects on the map. (We use it for location based
>>>services --> "show me the position of the next printer").
>>>After an irregular number of calls of our servlet which uses the Java
>>>Mapscript API the complete Java VM and with it the Tomcat crashes. I
>>>attached the error report below. The program works properly for a
>>>number of calls (between 5 and 1000 :-) ) and after that it crashes.
>>>We have tried several versions of the mapserver (4.4.1, 4.4.2, 4.2.4,
>>>4.6.1 RC1) and compiled the Java Mapscript Module with JDK 1.4.2 and
>>>1.5.0. We also configured mapserver using the --with-threads option,
>>>but all this did not help. By the way the mapserv cgi-module works
>>>properly.
>>>Do you have an idea for this?
>>>Thanks for your anxiety
>>>Christian & Florian
>>>University of Paderborn, Germany
>>>JavaMapscriptLoader: mapscript native library has been loaded.
>>> * mapscript native library loaded *
>>>An unexpected exception has been detected in native code outside the
>>>VM.
>>>Unexpected Signal : 11 occurred at PC=0x3338268
>>>Function=delete_classObj+0x8
>>>Library=/usr/lib/libmapscript.so
>>>Current Java thread:
>>> at edu.umn.gis.mapscript.mapscriptJNI.delete_classObj(Native
>>>Method)
>>> at edu.umn.gis.mapscript.classObj.delete(classObj.java:32)
>>> at edu.umn.gis.mapscript.classObj.finalize(classObj.java:26)
>>> at java.lang.ref.Finalizer.invokeFinalizeMethod(Native Method)
>>> at java.lang.ref.Finalizer.runFinalizer(Finalizer.java:83)
>>> at java.lang.ref.Finalizer.access$100(Finalizer.java:14)
>>> at
>>>java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:160)
>>>Dynamic libraries:
>>>Can not get information for pid = 10558
>>>Heap at VM Abort:
>>>Heap
>>> def new generation total 1152K, used 135K [0x08ae0000, 0x08c20000,
>>>0x08fc0000)
>>> eden space 1024K, 0% used [0x08ae0000, 0x08ae4078, 0x08be0000)
>>> from space 128K, 100% used [0x08c00000, 0x08c20000, 0x08c20000)
>>> to space 128K, 0% used [0x08be0000, 0x08be0000, 0x08c00000)
>>> tenured generation total 15048K, used 13624K [0x08fc0000,
>>>0x09e72000,
>>>0x0cae0000)
>>> the space 15048K, 90% used [0x08fc0000, 0x09d0e1c0, 0x09d0e200,
>>>0x09e72000)
>>> compacting perm gen total 18432K, used 18373K [0x0cae0000,
>>>0x0dce0000,
>>>0x10ae0000)
>>> the space 18432K, 99% used [0x0cae0000, 0x0dcd1618, 0x0dcd1800,
>>>0x0dce0000)
>>>Local Time = Tue Jun 14 15:32:19 2005
>>>Elapsed Time = 246
>>># The exception above was detected in native code outside the VM
>>># Java VM: Java HotSpot(TM) Client VM (1.4.2_08-b03 mixed mode)
>>># An error report file has been saved as /tmp/hs_err_pid10558.log.
>>># Please refer to the file for further information.
>>>On Mar 22, 2005, at 12:02 PM, Florian Pepping wrote:
>>>>Dear Mr. Gillies,
>>>>I'm a student of the University of Paderborn in Germany and member of
>>>> the project group "Location Based Services for Wireless Devices". In
>>>> this project we try to position laptops and other WLAN-enabled
>>>>devices using the signal strength of the WLAN. According to their
>>>>position, we want to offer location based services to the persons
>>>>using the devices (where I am; where's the next printer; is there a
>>>>friend nearby)
>>>>In order to do this, we want to use your mapserver and the Java
>>>>Mapscript API to generate maps according to the actual position and
>>>>situation. We like to customize the map of our building and add
>>>>points, lines and so on.
>>>>We have been able to compile the whole mapserver and the Java
>>>>Mapscript API. A small Java example also works, which presents an
>>>>unchanged map of our building.
