PostGIS Question
Paul Spencer
pspencer at DMSOLUTIONS.CA
Wed Jun 22 07:56:28 EDT 2005
Steve,
I can't answer the question with a high level of certainty, but if you
run postmaster with a certain level of debugging and monitor your logs,
you will see the full SQL statement that gets built for a layer draw and
I believe that it contains this kind of constraint.
If you don't get a better answer here, I'd suggest posting to the
postgis list, I'm not sure how closely Paul R. monitors this list ;)
Paul
Stephen Woodbridge wrote:
> I'm newbie to PostGIS, I am wondering if the mapserver integration uses
> the PostGIS spatial indexes when rendering a map or if it needs to be
> made explicitly in the layer definition?
> Does the final SQL do something like:
> select whatever, the_geom
> from table
> where the_geom && bbox2d(image_extents) and ...
> I am guessing/hoping it probably does. Is there an easy way to get
> mapserver to dump the SQL to a log file for inspection?
> Thanks,
> -Steve W.
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
