POSTGIS LAYER...
Philippe Gondek
philippe.gondek at GMAIL.COM
Thu Jun 23 05:47:33 EDT 2005
Here is my mapfile. I want to show the metadata of one of my layers
and perform a queryBy Point. Is my mapfile correct?
MAP
# Start of map file #
NAME SIGMA-BELGIUM
SIZE 640 480
STATUS ON
EXTENT 22265.4 21163 295157 295157
IMAGECOLOR 153 153 153
IMAGETYPE PNG
PROJECTION
"init=epsg:4313"
END
# Start of layer #
LAYER
NAME communes
TYPE POLYGON
CONNECTIONTYPE POSTGIS
CONNECTION "host=localhost port=5432 dbname=lemiam user=phil
password=1707loulou442"
DATA "the_geom from communes as foo using unique
geometry_columns.srid using SRID=9803"
CLASS
Name 'MesCommunes'
STYLE
SIZE 3
OUTLINECOLOR 0 75 128
COLOR 119 119 119
END
END
PROJECTION
"init=epsg:4313"
END
END
LAYER
NAME links
TYPE LINE
DATA "the_geom from links as foo using unique geometry_columns.srid
using SRID=9803"
CLASS
Name 'MesLinks'
STYLE
SIZE 3
COLOR 255 0 0
END
END
PROJECTION
"init=epsg:4313"
END
END
LAYER
NAME centroides
TYPE POINT
DATA "the_geom from centroides as foo using unique
CLASS
Name 'MesCentroides'
STYLE
COLOR 0 255 0
SYMBOL /var/www/localhost/htdocs/sigma/mojira-star.png
SIZE 6
END
END
PROJECTION
"init=epsg:4313"
END
END
# Start of query map #
QUERYMAP
COLOR 255 255 0
SIZE -1 -1
STATUS OFF
STYLE HILITE
END
# Start of reference map #
REFERENCE
COLOR 0 0 180
IMAGE "/var/www/localhost/htdocs/sigma/tmp/regions.png"
MAXBOXSIZE 240
OUTLINECOLOR 255 0 255
SIZE 120 149
STATUS ON
END
# Start of legend #
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar #
SCALEBAR
LABEL
COLOR 0 75 128
SIZE MEDIUM
END
STYLE 0
SIZE 80 2
COLOR 0 75 128
UNITS KILOMETERS
INTERVALS 5
TRANSPARENT TRUE
STATUS TRUE
SIZE 200 3
END
END
