any alternative of savewebimage() ?
Tamas Szekeres
szekeres.tamas at FREEMAIL.HU
Fri Jun 24 13:03:38 PDT 2005
Sean,
You're right, this method available only with java, csharp, pearl and
python by now. I think the same result can be achieved with passing empty
filename to saveImage using PHP.
Tamas
On Fri, 24 Jun 2005 12:35:11 -0600, Sean Gillies <sgillies at FRII.COM> wrote:
>Tamas,
>As far as I know, the PHP mapscript module does not have
>imageObj::getBytes. BTW, I'll respond to your C# mapscript patch very
>soon. Thanks for submitting it.
>Sean
>On Jun 24, 2005, at 12:04 PM, Tamas Szekeres wrote:
>> Hi,
>> You should try to use imageObj.getBytes (Mapserver 4.6) and write the
>> bytes directly to the binary response stream.
>> Tamas Szekeres
>> On Fri, 24 Jun 2005 10:24:55 +0700, bino_oetomo <bino at INDOAKSES-
>> ONLINE.COM> wrote:
>>> Dear All.
>>> Is there any alternative for savewebimage() so that the graph is not
>> drawed
>>> to temporary file but directly to user-browser ?
>>> Regards
>>> -bino-
More information about the MapServer-users
