SWIGMapscript: glibc detected malloc memory corruption
Geo-IT GmbH
info at GEO-IT.COM
Sun Jun 26 03:08:59 EDT 2005
Dear experts,
When trying to fetch a shapeObj after a queryByPoint using the shapeindex and
tileindex from the resultCache in a Java mapscript program I get the following
error terminating the whole VM:
*** glibc detected *** malloc(): memory corruption: 0x08314ed0 ***
./runshapetest40.sh: line 13: 26946 Aborted java ShapeObjTest40 $mapfile
$layername
The program was:
// Standard imports
import java.io.*;
import java.util.*;
import java.text.*;
import edu.umn.gis.mapscript.*;
public class ShapeObjTest {
String mapFile = null;
String layerName = null;
static {
try {
System.loadLibrary("mapscript");
System.out.println("Mapscript lib loaded");
} catch (UnsatisfiedLinkError e) {
e.printStackTrace();
System.exit(1);
public ShapeObjTest() {
protected static void log(String msg) {
System.out.println(msg);
protected static void usage() {
System.out.println("USAGE: ShapeObjTest <mapfile> <layername>");
public static void main (String args[] ) {
if (args == null || args.length < 2) {
usage();
System.exit(1);
String mapFile = args[0];
String layerName = args[1];
try {
log("Creating map");
mapObj map = new mapObj(mapFile);
layerObj l = map.getLayerByName(layerName);
l.open();
log("Fetching shapeObj shapeindex 1 tileindex -1");
shape = l.getFeature(1,-1);
l.close();
log("Fetch successful");
} catch (Exception ie) {
ie.printStackTrace();
System.exit(1);
The log shows:
Creating map
Then the error appears on the console.
I use mapserver 4.6.0.
This is the mapfile: (It's the one from Itasca demo, but only with layer
airports)
MAP
# Start of map file
NAME "DEMO"
STATUS ON
EXTENT 388107.634400379 5203120.88405952 500896.339019834 5310243.30613897
SIZE 600 600
SHAPEPATH "data"
IMAGECOLOR 255 255 255
UNITS METERS
# you may need to change this to match your MapServer build
#IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter
discussion
PROJECTION
"proj=utm"
"ellps=GRS80"
"zone=15"
"north"
"no_defs"
# OR:
# "init=epsg:26915"
END
# Start of web interface definition (including WMS enabling metadata)
WEB
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "/tmp"
IMAGEURL "/tmp"
HEADER "demo_header.html"
FOOTER "demo_footer.html"
TEMPLATE "demo.html"
METADATA
"WMS_TITLE" "UMN MapServer Itasca Demo"
"WMS_ABSTRACT" "This is the UMN MapServer demonstration application
for Itasca County located in north central Minnesota."
"WMS_ACCESSCONSTRAINTS" "none"
"WMS_ONLINERESOURCE"
"http://localhost.localdomain/mapserver_demos/itasca/demo_init.html"
"WMS_SRS" "EPSG:26915"
END
END
# Start of reference map
REFERENCE
STATUS ON
IMAGE "graphics/reference.gif"
SIZE 120 120
EXTENT 393234.393701263 5205405.16440722 495769.579718949 5307959.02579127
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
QUERYMAP
STATUS ON
SIZE 200 200
COLOR 255 0 0
STYLE HILITE
END
# Start of legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Start of scalebar
SCALEBAR
STATUS ON
COLOR 0 102 102
OUTLINECOLOR 102 255 0
BACKGROUNDCOLOR 255 51 102
TRANSPARENT OFF
UNITS MILES
INTERVALS 1
SIZE 80 2
STYLE 1
INTERLACE ON
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 0
END
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME "circle"
TYPE ELLIPSE
FILLED TRUE
POINTS
1 1
END
END
# Start of layer definitions
LAYER
NAME "airports"
STATUS OFF
DATA "airports"
TYPE POINT
TOLERANCE 5
HEADER "airports_header.html"
FOOTER "airports_footer.html"
TEMPLATE "ttt.html"
METADATA
"WMS_TITLE" "Airports"
"WMS_ABSTRACT" "Airport runways for Itasca County."
END
CLASS
NAME "Airports"
SYMBOL "circle"
COLOR 128 255 164
SIZE 7
TEMPLATE "airports.html"
END
END
Any help would be greatly appreciated.
Mit freundlichen Gruessen/Kind regards
Andreas Paukner-Ruzicka
(Geschaeftsfuehrer/Managing director)
Geo-IT GmbH - Geoinformatik, IT-Services
Guggenberg 3, D-82380 Peissenberg
Tel: 08803-498372, Fax: 08803-498373
eMail: info at geo-it.com - Homepage: http://www.geo-it.com
