No matching record(s) found -- What now?
John
jkim at SCIENCES.SDSU.EDU
Mon Jun 27 03:20:24 EDT 2005
My queryByPoint() is saying "No matching record(s) found", when it should
return a shape. The layer's status is ON and I've verified that the point
that I pass it is located within the extent of the map. What else can I
check?
My PHP code:
$layer = $map->getLayerByName("vegetation");
$layer->queryByPoint($mapPoint, MS_MULTIPLE, -1 );
And my layer definition:
LAYER
NAME vegetation
DATA veg.shp
STATUS ON
TYPE POLYGON
CLASS
COLOR 0 255 0
OUTLINECOLOR 32 32 32
END
END
Do I need to have a template file? What should be in the template file?
-John
