No matching record(s) found -- What now?
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Mon Jun 27 03:24:26 EDT 2005
Add TEMPLATE "blank.html" to your layer otherwise it is not queryable. Blank.html does not have to exist on the filesystem.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> John <jkim at SCIENCES.SDSU.EDU> 06/27/05 09:20am >>>
My queryByPoint() is saying "No matching record(s) found", when it should
return a shape. The layer's status is ON and I've verified that the point
that I pass it is located within the extent of the map. What else can I
check?
My PHP code:
$layer = $map->getLayerByName("vegetation");
$layer->queryByPoint($mapPoint, MS_MULTIPLE, -1 );
And my layer definition:
LAYER
NAME vegetation
DATA veg.shp
STATUS ON
TYPE POLYGON
CLASS
COLOR 0 255 0
OUTLINECOLOR 32 32 32
END
END
Do I need to have a template file? What should be in the template file?
-John
