No matching record(s) found -- Whatnow?
John Kim
jkim at SCIENCES.SDSU.EDU
Mon Jun 27 10:22:29 PDT 2005
> > My queryByPoint() is saying "No matching record(s) found"...
> > Do I need to have a template file? What should be in the template file?
> Add TEMPLATE "blank.html" to your layer otherwise it is not queryable.
> Blank.html does not have to exist on the filesystem.
> Bart
Whoa, it works! Thanks Bart.
>> One question: why use MS_MULTIPLE? Can queryByPoint() return multiple
>> shapes?
> Depending on the [tolerance] value you set it is possible that you get
> more than
> one result when you execute the query.
> Nicol
Ah! Right! I see. Thank you.
-John
More information about the MapServer-users
