Problem with SIZEITEM
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Tue Jun 28 13:18:27 EDT 2005
I was using SIZEITEM to modify the distance between hatched lines for
the new HATCH symbol type, so i don't think that helps you.
jeff
Pierre Racine wrote:
> Thanks Jeff,
> That's the only way I found to create a proportional symbol map. Is
> there any other way to achieve this?
> Pierre
>> From: Jeff McKenna <jmckenna at dmsolutions.ca>
>> To: Pierre Racine <racine_pierre at HOTMAIL.COM>
>> CC: MAPSERVER-USERS at lists.umn.edu
>> Subject: Re: [UMN_MAPSERVER-USERS] Problem with SIZEITEM
>> Date: Mon, 27 Jun 2005 15:05:55 -0400
>> I've filed a bug about this, because i get the same response that you
>> do on a point file
>> (http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1398).
>> jeff
>>> Hi,
>>> Anybody tried the SIZEITEM with Mapserver 4.6?
>>> If I publish the minimal map file with SIZEITEM based on an integer
>>> attribute, the size of the symbol doesn't change. Worse: if I add a
>>> LABEL
>>> definition, Mapserver crashes, publishing only half a jpeg.
>>> Here is my mapfile with the LABLE definition:
>>> MAP
>>> #IMAGETYPE JPEG
>>> EXTENT 189775 4716305 731662 5472414
>>> SIZE 400 600
>>> SHAPEPATH "data\shp"
>>> FONTSET "D:\ms4w\fonts\fonts.txt"
>>> SYMBOL
>>> NAME "circle"
>>> TYPE ellipse
>>> FILLED true
>>> POINTS
>>> 8 8
>>> END
>>> END
>>> PROJECTION
>>> "init=epsg:102010"
>>> END
>>> LAYER # States polygon layer begins here
>>> NAME escale
>>> DATA escale
>>> STATUS DEFAULT
>>> TYPE POINT
>>> PROJECTION
>>> "init=epsg:102010"
>>> END
>>> LABELITEM "id"
>>> CLASS
>>> STYLE
>>> SYMBOL "circle"
>>> SIZEITEM "duration"
>>> COLOR 1 255 1
>>> #SIZE 28
>>> #MINSIZE 12
>>> OUTLINECOLOR 0 0 0
>>> END
>>> LABEL
>>> COLOR 155 135 0
>>> TYPE TRUETYPE
>>> FONT arial
>>> SIZE 12
>>> FORCE true
>>> POSITION uc
>>> END #LABEL
>>> END #CLASS
>>> END #LAYER
>>> END
>>> Pierre Racine
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
