GRIDS and Graticule
Brent Fraser
bfraser at GEOANALYTIC.COM
Tue Jun 28 16:19:21 EDT 2005
François,
I think the MIN/MAXARCS parameter values in the map file are just "hints"
for the grid/graticule portion of mapserver, it will show a few more or less
lines to ensure the lines are drawn at "good" intervals. Using a value of
MAXARCS 5 and zooming in and out, I get from 3 to 9 lines.
Here's an example of a grid layer for the Itasca demo/workshop:
LAYER
NAME "grid"
METADATA
"DESCRIPTION" "Grid"
END
TYPE LINE
STATUS ON
CLASS
NAME "Graticule"
COLOR 150 150 150
LABEL
COLOR 150 150 150
# FONT arial
TYPE bitmap
SIZE medium
POSITION AUTO
PARTIALS FALSE
BUFFER 5
OUTLINECOLOR 255 255 255
END
END
# PROJECTION
# "init=epsg:4269"
# END
GRID
# LABELFORMAT "%g°"
# MAXARCS 5
LABELFORMAT "%7.0f m" # show UTM coords
MININTERVAL 20000 # fixed grid no matter what the scale
END
END # Layer
If you want show a Decimal Degree graticule, change it to:
PROJECTION
"init=epsg:4269"
END
GRID
LABELFORMAT "%g°"
MAXARCS 5
# LABELFORMAT "%7.0f m" # show UTM coords
# MININTERVAL 20000 # fixed grid no matter what the scale
Brent Fraser
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, June 28, 2005 11:33 AM
Subject: Re: [UMN_MAPSERVER-USERS] GRIDS and Graticule
> Le 12962ième jour après Epoch,
> Brent Fraser écrivait:
> > François,
> > Here's the documentation explanation, along with some of my notes on
the
> > parameters:
> Many thanks for your reply.
> > MINARCS [double]
> > The minimum number of arcs to draw.
> > The minimum number of graticule lines to draw on the map. Use this
> > parameter to get more lines.
> > MAXARCS [double]
> > The maximum number of arcs to draw.
> > The maximum number of graticule lines to draw on the map. Use this
> > parameter to get fewer lines.
> Thanks for the explanation. Unfortunately it is what I have
> understood. And it doesn't works for me.
> When I use "MAXARCS 10" for example, and zooming out on the map, there
> is lot (more than 10) graticule lines.
> I use MAPSERVER V4.4.1 (stock Debian packets)
> > MININTERVAL [double]
> > MAXINTERVAL [double]
> Idem.
> > MINSUBDIVIDE [double]
> > MAXSUBDIVIDE [double]
> Not yet used... I'm waiting for previous parms to work. ;)
> Your aims are high, and you are capable of much.
