Hi John, Le 12962ième jour après Epoch, John Novak écrivait: > Please attach the .map file you're using I'll do that once I've reduced it. It's 230Ko of data (features layers), and a bad idea on the list. At the same time, I'll put a test url so you can see the result. Thanks a lot.
