Wishing we had COLORRAMPs or something
Bill Binko
bill at BINKO.NET
Tue Jun 28 21:49:16 EDT 2005
> Why is this needed? you ask, just make a bunch of classes.
Mwuu ha ha (*seang will kill me for this*)
Take a look at bug 1305, and see if that will fit your needs.
It is close, but not exactly what you want. Most obviously, legend
support is non-existant at this point, but I could be motivated to help
there if I ever get away from ECW and GeomUnion issues.
If you're running 4.6, then support is already in there for you.
> For a thematic map, you can select the number of breaks you want to
> display, between 2 and 10 say. I already have code to compute the class
> breaks and to assign them a number between 0 and numclasses, now I need
> to a color in the ramp based on numclasses. If your ramp is RED from 0
> to 255, and you have a 2 class ramp the 2 will be 255, but if you
> display the same thin with a 10 class ramp 10 will be 255 and 2 will be
> like 25.5
In this case, you'd want to do something like this:
CLASS
COLOR 0 0 0 #mapserver wants a default color
STYLE
COLORRANGE 0 0 0 255 0 0 #start and end colors
DATARANGE 0 10 #start and end values
RANGEITEM "someField" #the field to use
END
END
No doubt this is not perfect (it has no "breaks": it is continuous).
However, having another user try it and provide feedback (into the bug
please) can only help.
Bill
