Wishing we had COLORRAMPs or something
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Jun 29 00:25:47 EDT 2005
Argggh! Doesn't look like it works in the version distributed at MUM3 in
the workshops.
MapServer version 4.6.0-beta3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
DEBUG=MSDEBUG
because it does not recognized the COLORRANGE
-Steve W.
Bill Binko wrote:
>>Why is this needed? you ask, just make a bunch of classes.
> Mwuu ha ha (*seang will kill me for this*)
> Take a look at bug 1305, and see if that will fit your needs.
> It is close, but not exactly what you want. Most obviously, legend
> support is non-existant at this point, but I could be motivated to help
> there if I ever get away from ECW and GeomUnion issues.
> If you're running 4.6, then support is already in there for you.
>>For a thematic map, you can select the number of breaks you want to
>>display, between 2 and 10 say. I already have code to compute the class
>>breaks and to assign them a number between 0 and numclasses, now I need
>>to a color in the ramp based on numclasses. If your ramp is RED from 0
>>to 255, and you have a 2 class ramp the 2 will be 255, but if you
>>display the same thin with a 10 class ramp 10 will be 255 and 2 will be
>>like 25.5
> In this case, you'd want to do something like this:
> CLASS
> COLOR 0 0 0 #mapserver wants a default color
> STYLE
> COLORRANGE 0 0 0 255 0 0 #start and end colors
> DATARANGE 0 10 #start and end values
> RANGEITEM "someField" #the field to use
> END
> END
> No doubt this is not perfect (it has no "breaks": it is continuous).
> However, having another user try it and provide feedback (into the bug
> please) can only help.
> Bill
