Wishing we had COLORRAMPs or something
Bill Binko
bill at BINKO.NET
Wed Jun 29 02:54:27 EDT 2005
On Wed, 29 Jun 2005, Stephen Woodbridge wrote:
> Argggh! Doesn't look like it works in the version distributed at MUM3 in
> the workshops.
> MapServer version 4.6.0-beta3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> DEBUG=MSDEBUG
> because it does not recognized the COLORRANGE
I would bet that it does. I just looked at 4.6beta3, and you should be
able to use it as I said below.
Just a note, it must go into a STYLE...END block, it cannot go directly
into a CLASS (or LAYER).
Bill
> -Steve W.
> Bill Binko wrote:
> >>Why is this needed? you ask, just make a bunch of classes.
> > Mwuu ha ha (*seang will kill me for this*)
> > Take a look at bug 1305, and see if that will fit your needs.
> > It is close, but not exactly what you want. Most obviously, legend
> > support is non-existant at this point, but I could be motivated to help
> > there if I ever get away from ECW and GeomUnion issues.
> > If you're running 4.6, then support is already in there for you.
> >>For a thematic map, you can select the number of breaks you want to
> >>display, between 2 and 10 say. I already have code to compute the class
> >>breaks and to assign them a number between 0 and numclasses, now I need
> >>to a color in the ramp based on numclasses. If your ramp is RED from 0
> >>to 255, and you have a 2 class ramp the 2 will be 255, but if you
> >>display the same thin with a 10 class ramp 10 will be 255 and 2 will be
> >>like 25.5
> > In this case, you'd want to do something like this:
> > CLASS
> > COLOR 0 0 0 #mapserver wants a default color
> > STYLE
> > COLORRANGE 0 0 0 255 0 0 #start and end colors
> > DATARANGE 0 10 #start and end values
> > RANGEITEM "someField" #the field to use
> > END
> > END
> > No doubt this is not perfect (it has no "breaks": it is continuous).
> > However, having another user try it and provide feedback (into the bug
> > please) can only help.
> > Bill
