Antwort: Re: [UMN_MAPSERVER-USERS] Bug in msCopy
Benedikt Rothe
umn-ms at HYDROTEC.DE
Wed Jun 29 05:43:44 EDT 2005
Hello Umberto
Thank you for yout hint's!
You are right: One should be cautios. But for the moment I have the
impression
that we seeme to have found a way, which don't raise obvious errors in the
first
moment :-)
After the mentioned changes in mapcopy.c the approache
(TomCat/MapScript/Connection-Pooling/MapCloning) seeme to
work for us. (Working with Version 4.6)
But:
- We do need some more stress-testing.(We already made automated
http-requests from a Java-Programs. But this was definitly not enough
and
not "nasty" enough!)
- New problems could raise, if more or other features from
mapserver/mapscript
are used then we actualy do.
- Memory footprint of the running-tomcat has to be watched!. What about
the size
of the application after 100, 500, 600, 800 ... requests? (I'm not
quite shure how to do this!
Watching Java-Programs is difficult because of garbage-collections ...)
Greetings
Benedikt
Umberto Nicoletti <umberto.nicoletti at gmail.com> schrieb am 29.06.2005
11:03:46:
> On 6/29/05, Benedikt Rothe <umn-ms at hydrotec.de> wrote:
> > Dear List
> > We are using MapScript/Tomcat/Java/OracleSpatial.
> > We use mapObj.mapClone() to get a fresh mapObject
> > in each request without reading the Mapfile.
> Benedikt,
> I would not do that (tm). In my apps I recreate a fresh mapObj with
> each request as the overhead is mininum and the benefits high (so
> that the ratio is in favor of this approach).
> Besides this is the only known method to work (as far as I know) and
> this stems from the fact that mapserver was in the beginning (and
> still is, with improvements) a CGI. As you might know cgis are
> processes that are created by the web server to serve a single request
> and then exit, so memory cleanup and thread safety are non-issues for
> them.
> Even in php mapscript php must be used as a cgi (instead of a DSO) to
> make sure that it works.
> > We detected problems after we activated Connection-Pooling:
> > Tomcat crashed in mapObj.delete()
> I would not use connection pooling just because it will not work
> reliably with Java Servlets for the reasons explained above.
> This matter (connection pooling and map cloning) surely requires
> deeper investigation, one of the developers coul step in to give his
> opinion on my statements (which I would sincerely hope were false, but
> fear not). Btw, I seem to recall that the above issues (long lived
> instance against per request instance) were already discussed on the
> list before.
> Best regards,
> Umberto
> > Hole thing turned out to be a bug in mapcopy.c where
> > the joins are copied:
> > MS_COPYSTELEM(numjoins);
> > for (i = 0; i < dst->numprocessing; i++) {
> > return_value = msCopyJoin(&(dst->joins[i]), &(src->joins[i]));
> > This must be changed to
> > for (i = 0; i < dst->numjoins; i++) {
> > There is some other code in mapobject.c, wich didn't
> > raise any problems for us, but from wich I do think
> > that array-allocs are missing.
> > I watched the code an *think* these are are not allocated
> > anywhere. I hope, there is no misleading hint:
> > // I do think, that dst->point is not allocated.
> > // code seems to be unused (?)
> > dst->numpoints = src->numpoints;
> > for (i = 0; i < dst->numpoints; i++) {
> > MS_COPYPOINT(&(dst->point[i]), &(src->point[i]));
> > // I do think, that dst->items and dst->values is
> > // not allocated
> > MS_COPYSTELEM(numitems);
> > for (i = 0; i < dst->numitems; i++) {
> > MS_COPYSTRING(dst->items[i], src->items[i]);
> > MS_COPYSTRING(dst->values[i], src->values[i]);
> > // I'm quite shure, that dst->items is not allocated
> > I hope this is helpful. Greetings
> > Benedikt Rothe
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050629/b639d76d/attachment.html
