error when connecting to demo
Philip Dillon-Thiselton dibblethewrecker at JIWE.ORG
Thu Jun 30 09:50:16 PDT 2005
OK - i figured out that
WMS_ACCESSCONSTRAINTS none
should be
WMS_ACCESSCONSTRAINTS "none"
That should probably be changed in the .zip archive.  After a bit of
jiggling with the index.html file it is all working.
Thanks for the .map file pointer
Phil
Philip Dillon-Thiselton wrote:
> Ok - here is the output below from the itasca.map file - this was
> unchanged from the version in the .zip file until i just changed the
> WMS_ONLINERESOURCE to see if that fixed it - it did not.
> I am using the latest Mapserver and latest demo files from
> workshop.zip - they are built from src by me in linux.
>    METADATA
>      WMS_TITLE "UMN MapServer Itasca Demo"
>      WMS_ABSTRACT "This is a UMN MapServer application for Itasca
> County located in north central Minnesota."
> 73      WMS_ACCESSCONSTRAINTS none
>      # change this value to match your setup
>      WMS_ONLINERESOURCE "http://heaton/mapserver_demo/index.html"
> taatuut at planet.nl wrote:
>> Hello Philip,
>> The error is related to the map file, so take a look around line 73
>> in your map file and/or post the part of the map file that causes the
>> problem to this list.
>> Regards,
>> Emil
>> ----- Oorspronkelijk bericht -----
>> Van: Philip Dillon-Thiselton <dibblethewrecker at JIWE.ORG>
>> Datum: donderdag, juni 30, 2005 4:39 pm
>> Onderwerp: [UMN_MAPSERVER-USERS] error when connecting to demo
>>> Hey all,
>>> I have never even set up an apache server until today so forgive me
>>> if i
>>> missed something obvious.  I have installed the latest demo as
>>> suggestedin the readme and I edited the index.html file as best I
>>> could.However, when I connect teh index page comes up ok but when i
>>> click the
>>> button I get this error:
>>> getString(): Symbol definition error. Parsing error near
>>> (none):(line 73)
>>> I have no idea what that means - i know it doesn't refer to and
>>> error in
>>> index.html. Any help greatly appreciated!
>>> Phil
More information about the MapServer-users mailing list
