A confused Network Admin
William Bronsema
wbronsema at DMSOLUTIONS.CA
Wed Mar 2 08:50:46 EST 2005
Also note that the extension_loaded check is not the extension_name (i.e.
php_mapscript_44) rather it is the module name itself. In this case it is
"mapscript". Your code should be:
if(!extension_loaded('mapscript'))
HTH,
Bill
________________________________________________
William A. Bronsema, C.E.T.
Applications and Software Development,
DM Solutions Group Inc.
_____
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Jeff Portwine
Sent: March 2, 2005 8:19 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] A confused Network Admin
Make sure that you have the <?PHP line in front of everything and that the
script is ended with ?>.
I think in the original example he just had <? which should be ok, but I
like to use <?PHP myself. It looks like your script omitted the '<', so it
wasn't being recognized as a php script and was just reading the script as
though it were html and outputting the text to your browser.
Hope this helps,
Jeff
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050302/87902031/attachment.html
