legend icons and transparency alpha for pixmap
Sean Gillies
sgillies at FRII.COM
Wed Mar 2 17:13:15 EST 2005
Ken,
It's fixed in CVS and will be working in the 4.4.2 release.
cheers,
Sean
On Mar 2, 2005, at 3:05 PM, Ken Lord wrote:
> I'd like to second the motion on this bug ..
> In my case im using Mapserver 4.4.1 CGI, and a vector symbol overtop a
> solid colour to symbolize the fill of a polygon.
> The 'TRANSPARENCY ALPHA' setting in the layer, and 'TRANSPARENT ON' in
> my
> RGB jpeg outputformat fixed the appearance on the map, the map is fine,
> but the icons generated in the legend are broken. The vector symbol
> lacks
> the transparency that it has on the map, and blocks out the solid fill
> colour underneath.
> The vector symbol is a simple diagonal line:
> SYMBOL
> NAME 'hatch1'
> TYPE VECTOR
> TRANSPARENT 0
> POINTS
> 0 1
> 1 0
> END
> END
> The typical class in the layer with the problem legend icons looks like
> this:
> CLASS
> EXPRESSION ....
> NAME "...."
> STYLE
> COLOR 250 250 130
> END
> STYLE
> SYMBOL 'hatch1'
> COLOR 153 209 155
> SIZE 3
> END
> STYLE
> OUTLINECOLOR 0 0 0
> SYMBOL "circle"
> SIZE 1
> END
> END
> In this case, the legend icon would appear as white with the '153 209
> 155'
> diagonal lines, outlined in black. If correct it would appear as '250
> 250
> 130' with the '153 209 155' diagonal lines, outlined in black.
> Thanks
> Ken Lord
> Vancouver BC
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
