Anyone successfully installing MapServer to Fedora 3 Linux?
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Thu Mar 3 08:33:18 EST 2005
i'd suggest takin a look at the FGS MapServer installer for Linux
(http://www.maptools.org/fgs/), if you want an easy solution.
jeff
Jack Ling wrote:
> Hi All,
> I run into problem when installing MapServer to Fedora 3 Linux. Can
> anyone help me?
> 1st, I've the following error of missing libcurl.so.2 (My Fedora 3
> system comes w/ libcurl.so.3 instead) ->
> # rpm -i mapserver-4.4.1-mh1.i686.rpm
> error: Failed dependencies:
> libcurl.so.2 is needed by mapserver-4.4.1-mh1.i686
> Then, I tried to install the latest curl to see if it helps. This time
> tell me libcom_err.so.3()(64bit) ->
> # rpm -i curl-7.13.0-2.cf.x86_64.rpm
> warning: curl-7.13.0-2.cf.x86_64.rpm: V3 DSA signature: NOKEY, key ID b56a8bac
> libcom_err.so.3()(64bit) is needed by curl-7.13.0-2.cf.x86_64
> Finally, searching from websites also mentions that latest curl
> version doesn't come with libcurl.so.2. To fix this, it suggests to
> run the followings ->
> # rpm -Uvh compat-libcurl-7.11.2-3.x86_64.rpm curl-7.13.0-2.cf.x86_64.rpm
> warning: compat-libcurl-7.11.2-3.x86_64.rpm: V3 DSA signature: NOKEY,
> key ID b56a8bac
> libcom_err.so.3()(64bit) is needed by compat-libcurl-7.11.2-3.x86_64
> best regards,
> Jack Ling
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
