php-mapscript: abnormal death
Mark Leslie
mark at REFRACTIONS.NET
Thu Mar 3 16:04:26 EST 2005
My understanding was the OUTPUTFORMAT was implicitly defined, and the
mapfile output format would
be used by default. Of course my understanding is limited, so I tried
it to no avail.
I've found a work around however. It seems that writing to a file works
fine, just not to standard out. I've done
the workaround that I write to a temp file, then read the file directly
to stdout. So far, it's fixed the app, but it's still not
an ideal solution. I've also filed a bug (1269).
Mark
Bart van den Eijnden wrote:
> Hi Mark,
> Have you defined an outputformat in your MAP file (or dynamically in
> php)?
> http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#outputformat
> eg for png 8 bits:
> OUTPUTFORMAT
> NAME png
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE PC256
> EXTENSION "png"
> END
> Maybe you even need to set it (I don't know if this is necessary if there
> is only 1 output format though ...):
> $map->selectOutputFormat('png');
> Hope this helps.
> Best regards,
> Bart
