problem upgrade php-mapscript 4.0 to 4.1.1 $layer->open MyGis
Daniel Lagos
dlagos at FDCCONSULT.COM
Fri Mar 4 08:49:47 EST 2005
Hi list,
I've recently been trying upgrade php-mapscript version 4.0 to 4 .4.1.
When I try to query clicking on one layer with connection type MYGIS I cannot get any data back from the feature data base table because I get error in function:
$layer->open();
query code:
$point = $this->createPoint($x,$y);
@$q_object = $this->map->queryByPoint($point,MS_SINGLE,-1);
$cur_layer = $this->map->getLayerByName($layerName);
$res_layer = $cur_layer->getNumResults();
if($res_layer)
$cur_layer->open(); <-------------------------------------------------------------------- The function error upgrade 4.0 to 4.4.1
$cur_res = $cur_layer->getResult(0);
$result = $cur_res->shapeindex;
$cur_layer->close();
return $result;
Layer defined:
LAYER
NAME "layer_10"
TYPE POINT
LABELMAXSCALE 100000
STATUS OFF
TOLERANCE 10
CONNECTIONTYPE mygis
CONNECTION "localhost:web:user_web:dbGis:bin:"
DATA "geometry from G_Punto feature, G_Punto_bin geometry"
TEMPLATE void
CLASS
NAME "class_1"
SYMBOL "symbol_5"
TEXT ([nombre] - [sucursal])
STYLE
OUTLINECOLOR 0 0 0
COLOR 0 0 255
SIZE 18
MINSIZE 8
MAXSIZE 20
END
LABEL
OUTLINECOLOR 255 255 255
COLOR 127 0 0
SIZE MEDIUM
POSITION AUTO
PARTIALS FALSE
END
END
END
The MapServer 4.4.1 released (2004-12-22) say: Fixed MyGIS build error introduced when adding msLayerIsOpen() (bug 1116). Is there some relations between the error and the bug fixing?.
The old version php-mapscript 4.0 working fine with the same code.
I would be most grateful if anyone could offer any advise.
Thank's.
______________________________________
Daniel A. Lagos H.
Fernández y De Cea Ingenieros Ltda.
Av. Apoquindo 3650, Of. 902, Las Condes
Santiago, Chile
Tel: +56 (2) 435 0099
Fax: +56 (2) 435 0258
www.fdcconsult.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050304/dc7ad5a5/attachment.html
