OGR-join problem with DBF files
Rainer Spittel
gosia.rainer at T-ONLINE.DE
Mon Mar 7 09:07:35 EST 2005
Hi Frank,
thanks for the fast reply.
I called 'ogrinfo' as you have described before and it's working fine. I
receive a joined output of both files, the shapefile and the dbf.
But the mapserver part is still not running. I added the following lines:
CONNECTIONTYPE OGR
CONNECTION "ms_wasser/baden/badeseenbremen"
DATA "SELECT * FROM badeseenbremen LEFT JOIN bade ON
badeseenbremen.GewaessNr = bade.GewaessNr"
and receive following error message:
Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
'Baden'. in D:\ms4w\apps\wasser_2.0\ms_digitalmap_inc.php on line 755
Warning: [MapServer Error]: msOGRFileOpen(): Open failed for OGR
connection `ms_wasser/baden/badeseenbremen'. File not found or unsupported
format. in D:\ms4w\apps\wasser_2.0\ms_digitalmap_inc.php on line 755
Fatal error: Call to a member function on a non-object in
D:\ms4w\apps\wasser_2.0\ms_digitalmap_inc.php on line 757
When the CONNECTION tag does not link directly to a shape-file (ending
with .shp), I get this message.
I also tried to add the exact sql statement of the ogrinfo statement and
it is not working.
I am still not sure what I can do...
Cheers
Rainer
