No subject
Shaq Gbadebo
s_gbadebo at HOTMAIL.COM
Tue Mar 8 11:36:42 EST 2005
You are not authorized to send mail to the MAPSERVER-USERS list from
your
s_gbadebo at HOTMAIL.COM account. You might be authorized to send to the list
from
another of your accounts, or perhaps when using another mail program
which
generates slightly different addresses, but LISTSERV has no way to
associate
this other account or address with yours. If you need assistance or if you
have
any question regarding the policy of the MAPSERVER-USERS list, please
contact
the list owners: MAPSERVER-USERS-request at LISTS.UMN.EDU.
To: mapserver-users at lists.umn.edu
Subject: Display data from postgis database
Sent: 08 March 2005 16:27:30
Hello,
I am carrying out a project on displaying maps from a postgis database over
the web with a mapserver. I have installed MapServer-4.0.1, on a LInux
redhat 9 platform. I have also installed version 7.3.4 of postgresql and
postgis. I have successfully loaded shapefiles into the postgis database and
now am just trying to display the maps, Here is a copy of the mapfile I am
using, where am just trying to display on the tables.
MAP
IMAGETYPE PNG
EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514
SIZE 400 300
SHAPEPATH "/home/MapData"
IMAGECOLOR 0 0 255
# PROJECTION
# "proj=laea"
# "ellps=clrk66"
# "lat_0=45"
# "lon_0=-100"
# Alternatively, you can specify an EPSG code.
# "init=epsg:2163"
#END
LAYER
CONNECTIONTYPE postgis
NAME "motor"
CONNECTION "user=postgres password=postgres dbname=fyp
host=localhost.localdomain"
DATA "the_geom FROM motorway"
STATUS ON
TYPE LINE
CLASS
COLOR 255 0 0
END
END
END
This mapfile displays the background but not the actual map. I wondering If
there is anything I have left out. When right click the background of the
map, in the alternative text field it says:
" The image
http://localhost.localdomain/cgi-bin/mapserv?map=/home/Mapfiles/testit.map&mode=map
cannot be displayed, because it contains errors."
I am not sure what exactly this means, any sort of help would be highly
appreciated.
