PERL - Geo::Shapelib help
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue Mar 8 19:33:41 EST 2005
JFD,
A couple of comments.
1) [lat, long] == [Y, X] so all you X/Y coordinates are being stored as
Y/X which is not a problem in and of itself, until you try to line it up
with other data.
2) from the man page ... Vertices=>[[$x,$y]] which is not what you are
doing below. I think you might want to do something like reverse your
lat-lon's when you create your @verts array
Then when you create your shape:
Vertices => \@verts
Also don't ser the bounds, they will get set automatically based on your
data when you do the save.
-Steve W.
JFD wrote:
> Hello,
> I'm trying to create a polygon shapefile using the PERL module
> Geo::Shapelib and find I can't quite get it.
> At this stage, I'm just trying to create a square polygon to get the hang
> of it, before moving on to bigger and better things. Unfortunately, the
> script bombs on me despite many consultations of the man page and the ESRI
> shapefile whitepaper. My best attemp to accomplish this task is below.
> Any guidance on what I'm doing wrong would be greatly appreciated.
> Thanks,
> JFD
> #!/usr/bin/perl
> # an attempt to create a polygon shapefile
> use strict ;
> use Geo::Shapelib ;
> # points of the polygon
> my @lat = (45.0, 45.0, 55.0, 55.0, 45.0) ;
> my @lon = (-75.0, -85.0, -85.0, -75.0, -75.0) ;
> my @verts = (
> [$lat[0], $lon[0]],
> [$lat[1], $lon[1]],
> [$lat[2], $lon[2]],
> [$lat[3], $lon[3]],
> [$lat[4], $lon[4]]
> #print "@verts\n" ;
> my $shape = new Geo::Shapelib;
> $shape->{Shapetype} = 5;
> $shape->{MinBounds} = [20,-100] ;
> $shape->{MaxBounds} = [80,-10] ;
> $shape->{FieldNames} = ['ID', 'SPD','DIR'];
> $shape->{FieldTypes} = ['Integer','Integer','Integer'];
> push @{$shape->{Shapes}}, {
> SHPType=>5,
> ShapeId=>1,
> Nparts=>0,
> NShapes=>0,
> NVertices=>5,
> Vertices=>[\@lat, \@lon]
> push @{$shape->{ShapeRecords}}, [1,13,250];
> #i++;
> $shape->dump();
> $shape->save('/mydir/test');
