MapServer 4.4.1 Demo
Lisi, Christine
lisi at MYDELRAYBEACH.COM
Wed Mar 9 14:01:19 EST 2005
Thanks for this information, Ken. I just want to make sure I've got
this right. The download includes many files, but you say to just
replace the mapserv.exe and any .dll's included in the download from
maptools.org? If this is correct then I will be replacing the following
files in my existing MapServer folder:
Mapserv.exe
Gdal12.dll
NCScnet.dll
NCSEcw.dll
NCSEcwC.dll
NCSUtil.dll
Libcurl.dll
Libpq.dll
Pdflib.dll
Xerces-c_1_6_0.dll (existing file is Xerces-c_1_7_0.dll)
Christine Lisi
Application Specialist
Management Information Systems * City of Delray Beach * 100 NW First
Avenue, Delray Beach, FL 33444
Phone, 561-243-7142 * Fax, 561-243-7166 * eMail, Lisi at MyDelrayBeach.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Ken Lord
Sent: Wednesday, March 09, 2005 12:33 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] MapServer 4.4.1 Demo
Hi!
This problem has come up a few times in the last couple weeks for
several people. I worked through it myself.
It seems to be a problem with how the current windows binaries
available from the mapserver homepage were compiled.
Download mapserver 4.4.1 from www.maptools.org/dl
Use the mapserv.exe and the .dll'sthat are contained within the zip
files that are included in that package.
This version appears to have been compiled so that it is less
dependant on external dll's, using a larger exe and fewer dll's.
... and it works.
So, this is the 3rd or 4th time this has come up on the list. Think
it's time to take down/replace the current windows binaries available
at the mapserver homepage?
Cheers,
Ken Lord
Vancouver BC
On Wed, 9 Mar 2005 12:03:01 -0500, Lisi, Christine
<lisi at mydelraybeach.com> wrote:
> I ran the following command at the command prompt:
> When I pressed Enter it hesitated for about 5 seconds and returned me
back
> to a command prompt. If MapServer generated an html file, where would
it
> put it?
> I hadn't applied the WRITE access in IIS, but instead applied it in
the NTFS
> file system. I now have applied the WRITE access in IIS (see below):
> I still get the same error.
> Christine Lisi
Avenue,
> ________________________________
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Wednesday, March 09, 2005 11:47 AM
> To: Lisi, Christine; MAPSERVER-USERS at LISTS.UMN.EDU
> Christine,
> Did mapserv generate html when you executed it from the command
prompt?
> The fact that mapserver didn't crash leads me to believe the problem
is with
> the IIS configuration of the workshop demo directory, likely write
access to
> the tmp directory. Did you set write access for the tmp directory
using IIS
> Manager?
> Brent
> ----- Original Message -----
> From: Lisi, Christine
> Sent: Wednesday, March 09, 2005 9:31 AM
> I ran the mapserv QUERY_STRING and it returned to a command prompt
with no
> errors. I guess I can assume that no .dll's are missing. Someone
else on
> the list mentioned using forward slashes instead of backslashes in the
html
> file variables. I will try that. If you have any input on that I
would
> welcome it.
> Thanks, Brent.
> Christine Lisi
Avenue,
On
> Behalf Of Brent Fraser
> Sent: Wednesday, March 09, 2005 11:16 AM
> Christine,
> In your first example it appears that mapserver was reading the map
file
> but crashed for some reason. In the second example it couldn't find
the map
> file because it expects a file system path not a url. So the first
example
> is good, but the second is not (mapserver just handled the second case
a lot
> better!).
> The crash is likely due to a missing dll required by mapserver.
> You can run mapserv.exe from the command line to get messages about
missing
> dlls. Here are the steps:
> 1. Open a command prompt window on your server
> 2. cd to the location of mapserv.exe
> 3. type in
> mapserv QUERY_STRING="
> 4. Copy the query string from the your browser address bar and paste
it
> into the command window. The query string should look like:
layer=lakespy2&layer=dlgstln2&zoomsize=2&map=%2Finetpub%2Fwwwroot%2Fwork
shop%2Fitasca.map&program=%2Fcgi-bin%2Fmapserv.exe&root=%2Fworkshop&map_
web_imagepath=%2Finetpub%2Fwwwroot%2Ftmp%2F&map_web_imageurl=%2Ftmp%2F&m
ap_web_template=itasca_basic.html
> 5. Add a double quote to the end of the string and press return.
> If a dll is missing, the operating system will show a dialog box
giving the
> name of the dll.
> Brent Fraser
> Sent: Wednesday, March 09, 2005 8:31 AM
> Subject: [UMN_MAPSERVER-USERS] MapServer 4.4.1 Demo
> I've installed MapServer and successfully received the "No query
information
> to decode. QUERY_STRING is set, but empty." message. Now I am trying
to
> get the MapServer 4.4.1 Demo to work. (Windows Server 2003, IIS6,
> 4.4.1)
> Here are the steps I have taken:
> 1. Copied the WORKSHOP folder to C:\Inetpub\wwwroot
> 2. Created a tmp folder inside C:\Inetpub\wwwroot\workshop and
gave
> the IUSR account Read/Write/Execute permissions
> 3. Set default page to INDEX.HTML in IIS
> 4. Changed Execute Permissions in IIS to allow SCRIPTS and
> EXECUTABLES.
> 5. Edited INDEX.HTML file as follows (edits in bold):
> <!-- EDIT THE FORM ACTION -->
> <form name="demo" method="GET"
> action="http:\\esgisrv001\cgi-bin\mapserv.exe"
onSubmit="submit_form()">
> <input type="hidden" name="layer" value="lakespy2">
> <input type="hidden" name="layer" value="dlgstln2">
> <input type="hidden" name="zoomsize" value=2>
> <!-- EDIT THESE HIDDEN VARIABLES -->
> <input type="hidden" name="map"
> value="C:\Inetpub\wwwroot\workshop\itasca.map">
> <input type="hidden" name="program"
> value="C:\Inetpub\wwwroot\cgi-bin/mapserv.exe">
> <input type="hidden" name="root"
value="C:\Inetpub\wwwroot\workshop\">
> <input type="hidden" name="map_web_imagepath"
> value="C:\Inetpub\wwwroot\workshop\tmp\">
> <input type="hidden" name="map_web_imageurl"
> I get the MapServer Itasca Application initial screen, but when I
click to
> initialize the BASIC APPLICATION using these variables I receive the
> following error:
> CGI Error
> The specified CGI application misbehaved by not returning a complete
set of
> HTTP headers.
> 6. Edited INDEX.HTML file as follows (edits in bold):
> value="http:\\esgisrv001\workshop\itasca.map">
> value="http:\\esgisrv001\cgi-bin\mapserv.exe">
value="http:\\esgisrv001\workshop\">
> value="http:\\esgisrv001\workshop\tmp\">
click to
> following error:
> msLoadMap(): Unable to access file.
(http:\\esgisrv001\workshop\itasca.map)
> Can anyone help?
> Thanks.
> Christine Lisi
Avenue,
