MapServer 4.4.1 Demo
Ken Lord
kenlord at GMAIL.COM
Wed Mar 9 17:03:17 EST 2005
Ok, I think we are on track anyways, When the map fails, what error
is returned?
Ken
On Wed, 9 Mar 2005 16:48:12 -0500, Lisi, Christine
<lisi at mydelraybeach.com> wrote:
> Yes, I always get the index.html page. It's the map and all the other
> functions that don't work. I can use either the IP or the name of the
> server because it's in our DNS.
> This demo site has never worked. It's my first shot at it.
> Christine Lisi
> Application Specialist
> Management Information Systems * City of Delray Beach * 100 NW First
> Avenue, Delray Beach, FL 33444
> Phone, 561-243-7142 * Fax, 561-243-7166 * eMail, Lisi at MyDelrayBeach.com
> -----Original Message-----
> From: Ken Lord [mailto:kenlord at gmail.com]
> Sent: Wednesday, March 09, 2005 4:46 PM
> To: Lisi, Christine; MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] MapServer 4.4.1 Demo
> Are you able to get the index.html page using the http://192..../ path?
> If not then its probably an address thing still. Were you able to
> determine the correct IP address of your webserver to put in place of
> my 192.168.1.103 address?
> If your website worked before over the internet, then I dont think any
> permissions need to be changed to make this work, as you are using the
> same setup.
> In my intranet case, I had set it up on a workstation on our network
> using Apache, and i think it worked right away.
> Can anyone else make a suggestion here?
> Cheers,
> Ken Lord
> Vancouver BC
> On Wed, 9 Mar 2005 16:37:37 -0500, Lisi, Christine
> > I'm really struggling here. I about at my wits end. I tried every
> > which path. The only way I get a map at all is if I use the full path
> > of c:\... to point to the map file and it only works on the local
> > server. Maybe I have a rights issue? Can you share with me your
> rights
> > (NTFS and IIS) on your mining folder?
> > Christine Lisi
> > From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> On
> > Behalf Of Ken Lord
> > Sent: Wednesday, March 09, 2005 3:43 PM
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Great!
> > I'm not a contributor to mapserver code etc, so I'm glad I was able to
> > give a little back by helping you make it work.
> > I have setup mapserver to run as an intranet application, its not too
> > tricky, and the great thing is that over a LAN, it will run amazingly
> > fast.
> > In your index.html file, and your .map file (and anywhere else if
> > needed) you need to change some web addresses to point at the local
> > network IP address of the computer hosting mapserver. Here's the
> > setttings I used:
> > <input type="hidden" name="program"
> > value="http://192.168.1.103/cgi-bin/mapserv.exe">
> > <input type="hidden" name="map_web_imageurl"
> > value="http://192.168.1.103/Mining/temp/">
> > and in the map file..
> > IMAGEURL "http://192.168.1.103/Mining/temp/"
> > Then just view the index.html file in your webbrowser using the
> > appropriate address http://192....../yourfolders/index.html
> > The 192 domain is reserved for internal networks, anyone trying to get
> > to the application from outside your network will just get an error
> > since that address would point them to a machine on their own internal
> > network if it exists.
> > I'm no expert on network things but this worked for me. If there's
> > any important considerations I've overlooked, hopefully someone else
> > will add them.
> > Cheers,
> > Ken Lord
> > Vancouver BC
> > On Wed, 9 Mar 2005 15:19:31 -0500, Lisi, Christine
> > > This worked, Ken, so thank you SOOOO much. It works when I run it
> > from the
> > > web server. But here's my dilemma now. I am not an HTML programmer
> > and I
> > > need to know what syntax to use in the INDEX.HTML file so that this
> > demo is
> > > available INTERNALLY over the web. If I use the full paths in the
> > > INDEX.HTML file (C:\...) or UNC paths (\\SERVERNAME\...) I get the
> > error
> > > that the map cannot be found. Can you tell me the syntax to use for
> > the
> > > paths in this section of the HTML file:
> > > <!-- EDIT THESE HIDDEN VARIABLES -->
> > > <input type="hidden" name="map"
> > > value="\\esgisrv001\inetpub\wwwroot\workshop\itasca.map">
> > > value="\\esgisrv001\inetpub\wwwroot\cgi-bin\mapserv.exe">
> > > <input type="hidden" name="root"
> > > value="\\esgisrv001\inetpub\wwwroot\workshop\">
> > > <input type="hidden" name="map_web_imagepath"
> > > value="\\esgisrv001\inetpub\wwwroot\workshop\tmp\">
> > > Your help is GREATLY appreciated.
> > > Thanks.
> > > Christine Lisi
> > Avenue,
> > > Sent: Wednesday, March 09, 2005 3:09 PM
> > > Hi Christine,
> > > Yes, thats right. That made it work for me on both a windows 2000
> and
> > > windows XP Pro SP1 installation.
> > > There's no harm in leaving both the xerces dll's incase you have
> some
> > > other application using the newer version.
> > > Cheers,
> > > Ken Lord
> > > Vancouver BC
> > > On Wed, 9 Mar 2005 14:01:19 -0500, Lisi, Christine
> > > > Thanks for this information, Ken. I just want to make sure I've
> got
> > > > this right. The download includes many files, but you say to just
> > > > replace the mapserv.exe and any .dll's included in the download
> from
> > > > maptools.org? If this is correct then I will be replacing the
> > following
> > > > files in my existing MapServer folder:
> > > > Mapserv.exe
> > > > Gdal12.dll
> > > > NCScnet.dll
> > > > NCSEcw.dll
> > > > NCSEcwC.dll
> > > > NCSUtil.dll
> > > > Libcurl.dll
> > > > Libpq.dll
> > > > Pdflib.dll
> > > > Xerces-c_1_6_0.dll (existing file is Xerces-c_1_7_0.dll)
> > > > Christine Lisi
> First
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> > > > Behalf Of Ken Lord
> > > > Sent: Wednesday, March 09, 2005 12:33 PM
> > > > Hi!
> > > > This problem has come up a few times in the last couple weeks for
> > > > several people. I worked through it myself.
> > > > It seems to be a problem with how the current windows binaries
> > > > available from the mapserver homepage were compiled.
> > > > Download mapserver 4.4.1 from www.maptools.org/dl
> > > > Use the mapserv.exe and the .dll'sthat are contained within the
> zip
> > > > files that are included in that package.
> > > > This version appears to have been compiled so that it is less
> > > > dependant on external dll's, using a larger exe and fewer dll's.
> > > > ... and it works.
> > > > So, this is the 3rd or 4th time this has come up on the list.
> Think
> > > > it's time to take down/replace the current windows binaries
> > available
> > > > at the mapserver homepage?
> > > > Cheers,
> > > > Ken Lord
> > > > Vancouver BC
> > > > On Wed, 9 Mar 2005 12:03:01 -0500, Lisi, Christine
> > > > > I ran the following command at the command prompt:
> > > > > When I pressed Enter it hesitated for about 5 seconds and
> returned
> > me
> > > > back
> > > > > to a command prompt. If MapServer generated an html file, where
> > would
> > > > it
> > > > > put it?
> > > > > I hadn't applied the WRITE access in IIS, but instead applied it
> > in
> > > > the NTFS
> > > > > file system. I now have applied the WRITE access in IIS (see
> > below):
> > > > > I still get the same error.
> > > > > Christine Lisi
> > First
> > > > Avenue,
> > > > > ________________________________
> > > > > From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> > > > > Sent: Wednesday, March 09, 2005 11:47 AM
> > > > > To: Lisi, Christine; MAPSERVER-USERS at LISTS.UMN.EDU
> > > > > Christine,
> > > > > Did mapserv generate html when you executed it from the
> command
> > > > prompt?
> > > > > The fact that mapserver didn't crash leads me to believe the
> > problem
> > > > is with
> > > > > the IIS configuration of the workshop demo directory, likely
> write
> > > > access to
> > > > > the tmp directory. Did you set write access for the tmp
> directory
> > > > using IIS
> > > > > Manager?
> > > > > Brent
> > > > > ----- Original Message -----
> > > > > From: Lisi, Christine
> > > > > Sent: Wednesday, March 09, 2005 9:31 AM
> > > > > I ran the mapserv QUERY_STRING and it returned to a command
> prompt
> > > > with no
> > > > > errors. I guess I can assume that no .dll's are missing.
> Someone
> > > > else on
> > > > > the list mentioned using forward slashes instead of backslashes
> in
> > the
> > > > html
> > > > > file variables. I will try that. If you have any input on that
> I
> > > > would
> > > > > welcome it.
> > > > > Thanks, Brent.
> > > > > Christine Lisi
> > First
> > > > Avenue,
> > > > On
> > > > > Behalf Of Brent Fraser
> > > > > Sent: Wednesday, March 09, 2005 11:16 AM
> > > > > Christine,
> > > > > In your first example it appears that mapserver was reading
> the
> > map
> > > > file
> > > > > but crashed for some reason. In the second example it couldn't
> > find
> > > > the map
> > > > > file because it expects a file system path not a url. So the
> > first
> > > > example
> > > > > is good, but the second is not (mapserver just handled the
> second
> > case
> > > > a lot
> > > > > better!).
> > > > > The crash is likely due to a missing dll required by mapserver.
> > > > > You can run mapserv.exe from the command line to get messages
> > about
> > > > missing
> > > > > dlls. Here are the steps:
> > > > > 1. Open a command prompt window on your server
> > > > > 2. cd to the location of mapserv.exe
> > > > > 3. type in
> > > > > mapserv QUERY_STRING="
> > > > > 4. Copy the query string from the your browser address bar and
> > paste
> > > > it
> > > > > into the command window. The query string should look like:
> layer=lakespy2&layer=dlgstln2&zoomsize=2&map=%2Finetpub%2Fwwwroot%2Fwork
> shop%2Fitasca.map&program=%2Fcgi-bin%2Fmapserv.exe&root=%2Fworkshop&map_
> web_imagepath=%2Finetpub%2Fwwwroot%2Ftmp%2F&map_web_imageurl=%2Ftmp%2F&m
> > > > ap_web_template=itasca_basic.html
> > > > > 5. Add a double quote to the end of the string and press return.
> > > > > If a dll is missing, the operating system will show a dialog box
> > > > giving the
> > > > > name of the dll.
> > > > > Brent Fraser
> > > > > Sent: Wednesday, March 09, 2005 8:31 AM
> > > > > Subject: [UMN_MAPSERVER-USERS] MapServer 4.4.1 Demo
> > > > > I've installed MapServer and successfully received the "No query
> > > > information
> > > > > to decode. QUERY_STRING is set, but empty." message. Now I am
> > trying
> > > > to
> > > > > get the MapServer 4.4.1 Demo to work. (Windows Server 2003,
> IIS6,
> > > > MapServer
> > > > > 4.4.1)
> > > > > Here are the steps I have taken:
> > > > > 1. Copied the WORKSHOP folder to C:\Inetpub\wwwroot
> > > > > 2. Created a tmp folder inside C:\Inetpub\wwwroot\workshop
> > and
> > > > gave
> > > > > the IUSR account Read/Write/Execute permissions
> > > > > 3. Set default page to INDEX.HTML in IIS
> > > > > 4. Changed Execute Permissions in IIS to allow SCRIPTS and
> > > > > EXECUTABLES.
> > > > > 5. Edited INDEX.HTML file as follows (edits in bold):
> > > > > <!-- EDIT THE FORM ACTION -->
> > > > > <form name="demo" method="GET"
> > > > > action="http:\\esgisrv001\cgi-bin\mapserv.exe"
> > > > onSubmit="submit_form()">
> > > > > <input type="hidden" name="layer" value="lakespy2">
> > > > > <input type="hidden" name="layer" value="dlgstln2">
> > > > > <input type="hidden" name="zoomsize" value=2>
> > > > > value="C:\Inetpub\wwwroot\workshop\itasca.map">
> > > > > value="C:\Inetpub\wwwroot\cgi-bin/mapserv.exe">
> > > > value="C:\Inetpub\wwwroot\workshop\">
> > > > > value="C:\Inetpub\wwwroot\workshop\tmp\">
> > > > > I get the MapServer Itasca Application initial screen, but when
> I
> > > > click to
> > > > > initialize the BASIC APPLICATION using these variables I receive
> > the
> > > > > following error:
> > > > > CGI Error
> > > > > The specified CGI application misbehaved by not returning a
> > complete
> > > > set of
> > > > > HTTP headers.
> > > > > 6. Edited INDEX.HTML file as follows (edits in bold):
> > > > > value="http:\\esgisrv001\workshop\itasca.map">
> > > > > value="http:\\esgisrv001\cgi-bin\mapserv.exe">
> > > > value="http:\\esgisrv001\workshop\">
> > > > > value="http:\\esgisrv001\workshop\tmp\">
> I
> > > > click to
> > the
> > > > > following error:
> > > > > msLoadMap(): Unable to access file.
> > > > (http:\\esgisrv001\workshop\itasca.map)
> > > > > Can anyone help?
> > > > > Thanks.
> > > > > Christine Lisi
> > First
> > > > Avenue,
