MouseOver & Coordinates
Stefan Schwarzer
stefan.schwarzer at GRID.UNEP.CH
Thu Mar 10 09:23:53 EST 2005
Just as a side-note: there was a small errors in the code:
+imgOrig[1])); -- the last ")" is too much;
And, ok, obviously enough, the code must be integrated after inserting
the map-image, not before.
The "theMap" in the first function... is this really correct? And why
is it theMap.getcsz() - thus, a function, not the retrieval of the
value? And where does the getorig() come from? Are these build-in
functions? I get different error messages - "theMap is not defined",
etc...
Sorry, sorry. I really tried my best. But I am not a crack in
Javascript...
Thanks for your help.
Stef
This is what I have now...
<img name="myMap" id="myMap" src="...." ...>
<input type="hidden" name="csz" value="<?php echo (($extent[2] -
$extent[0]) / 400); ?>">
<script language="javascript" type="text/javascript">
function MapElmOverHndl(e) {
var imgOrig = theMap.getorig();
var posx = ((e.offsetX * theMap.getcsz())+imgOrig[0]);
var posy = (((400-e.offsetY) * theMap.getcsz())+imgOrig[1]);
//Dspl.innerHTML=posx+' '+posy;
alert(posx+' '+posy); // only to be sure...
function X_addEventListener(elm, evt, lstnr, useCapture) {
(! elm.addEventListener && d.all)? elm.attachEvent('on'+evt, lstnr) :
elm.addEventListener(evt, lstnr, useCapture);
var d= document;
if (!d.getElementById && d.all) d.getElementById = new Function('id',
'return d.all[id]');
myMapElm= d.getElementById('myMap');
X_addEventListener(myMapElm ,"mousemove", MapElmOverHndl, false);
</script>
> On Thursday 10 March 2005 11:07, Stefan Schwarzer wrote:
>> Hi,
>> I would like to display the coordinates in a corner of the map, when a
>> user moves the mouse over it. Is there any Javascript (or Java) code
>> out there that would do this?
>> Thanks for any suggestions.
>> Stef
> Stefan,
> you need to know the pixel size of your map image in map units (DD,
> meters,..).
> using MapScript you can pass this value along with every new map
> generated
> as a (hidden) value and set a javascript object or variable to this
> value.
> With mapserver CGI you must calculate this value by image size and map
> extent
> yourself.
> Next you define an eventhandler for the mouseover event of your map
> image,
> for instance:
> var posy = (((400-e.offsetY) * theMap.getcsz())+imgOrig[1]));
> 'theMap.getorig()': returns minx, miny (mapunits) of the current image
> 'theMap.getcsz()': returns the cellsize (pixelsize) in mapunits
> '400' is the image height in pixels
> 'Dspl' is a document element like <p>, <td>, <div> or some such.
> Once you got the handler you add this event handler to your map image.
> If your map image got an id of - say - 'myMap':
> for DOM-Browsers you type:
> document.getElementById('myMap').addEventListener("mousemove",MapElmOve
> rHndl , false)
> for IE6 you type:
> document.all['myMap''].attachEvent("onmousemover", MapElmOverHndl);
> A cross browser solution could look similar to:
> var d= document;
> : elm.addEventListener(evt, lstnr, useCapture);
> Now you add the listener by:
> Cheers, Martin
_______________________________________
Stefan Schwarzer
GIS & Data Management
UNEP/DEWA/GRID-Geneva
Chemin des Anemones 11
CH - 1219 Chatelaine
Switzerland
Tel: (+41) 22.917.83.49
Fax: (+41) 22.917.80.29
Internet: http://geodata.grid.unep.ch/
