Projection
Rhys Ickeringill
rhysi at OMNILINK.COM.AU
Thu Mar 10 17:38:03 EST 2005
G'day Dirk-Jan,
My comments below:
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, March 11, 2005 2:08 AM
Subject: [UMN_MAPSERVER-USERS] Projection
Hi all,
My projection(British_National_Grid) file should be something like this:
PROJECTION
"proj=tmerc"
"lat_0=49"
"lon_0=-2"
"x_0=400000"
"y_0=-100000"
"k=0.999601272"
"ellps=Airy_1830"
"datum=D_OSGB_1936"
"to_meter=1"
"no_defs
END
I'm using Windows2000 and Apache.
With the install of Mapserver I copy proj/nad to C:\
I have an unknown elliptical parameter ("ellps=Airy_1830") and unknown
datum parameter("datum=D_OSGB_1936").
----- End Message -----
Just had a quick look at the Proj data files and I think your ellps
parameter should be just "airy" rather than "Airy_1830". Your datum
"OSGB_1936" is not defined anywhere as a *named* datum. AFAIK since you're
providing all the other parameters (false eastings, northings, scale factors
etc.), you don't need to have a datum parameter anyway - it just duplicates
the definition of those parameters.
Actually, I think you can replace your entire projection statement with
just:
PROJECTION
"init=epsg:27700"
END
Personally I still prefer the long version like you were using:
PROJECTION
"proj=tmerc"
"lat_0=49"
"lon_0=-2"
"x_0=400000"
"y_0=-100000"
"k=0.999601272"
"ellps=airy"
"to_meter=1"
"no_defs
END
If you're still being told that the ellipsoid you've specified can't be
found, try specifying its' parameters directly (ie. specify two from:
{semi-major axis, semi-minor axis, eccentricity, inverse flattening, ...})
HTH
- Rhys
