one layer doesn't show up???
w m
wokar1 at YAHOO.COM
Fri Mar 11 00:45:52 EST 2005
i have a mapfile which returns no errors whatsoever.
all the layers work except one, the hotspot layer. if i turn all the other layers off, the hotspot layer still doesnt show up. its type point. it returns no errors only returns a white page if hotspot layer is the only layer turned on. i did ogr info and everything is fine. i created this shp file myself in postgresql by using pgsql2shp
i have no clue wat the problem is.....
u can check out the map here http://132.205.108.60/cgi-bin/mapserv?map=tut4.map&mode=map
thank You
wokar
NAME P1EX1
EXTENT -73.992437 45.138200 -73.174263 45.861800
# EXTENT -97.238976 41.619778 -82.122902 49.38562
#EXTENT 407.997812 4103475.750 443135.000 415.250
#EXTENT 407.997812 4103475.750 443135.000 4157027.250
#EXTENT -4362443.743696 3864199.098181 2916998.546244 9336805.43055
#EXTENT -79.533992 44.991472 -61.467212 54.869379
SIZE 600 700
SHAPEPATH "/var/www/cgi-bin/montreal/"
WEB
IMAGEPATH "/var/www/html/tmp/"
IMAGEURL "/tmp/"
END
LAYER # start of the "land" layer object
NAME "land"
DATA V0LLand
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 56 234 254
OUTLINECOLOR 0 0 0
END # end of class object
END # end of layer object
LAYER # start of the "cropland" layer object
NAME "cropland"
DATA V0CCroplands
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 213 172 13
OUTLINECOLOR 0 0 0
LAYER # start of the "grass" layer object
NAME "grass"
DATA V0GGrasslands
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR -255 120 60
OUTLINECOLOR 0 0 0
LAYER # start of the "trees" layer object
NAME "trees"
DATA V0TTrees
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 101 177 105
OUTLINECOLOR 0 0 0
LAYER # start of the "rivers" layer object
NAME "rivers"
DATA V0WWaterCourses
STATUS DEFAULT
TYPE LINE
CLASS
COLOR 102 215 238
OUTLINECOLOR 0 0 0
LAYER # start of the "inland water bodies" layer object
NAME "water bodies"
DATA V0IInlandWaterBodies
STATUS DEFAULT
TYPE LINE
CLASS
COLOR 0 0 222
OUTLINECOLOR 0 0 0
LAYER # start of the "majorroads" layer object
NAME "majorroads"
DATA V0MMajorRoads
STATUS DEFAULT
TYPE LINE
CLASS
COLOR 0 0 0
OUTLINECOLOR 0 0 0
LAYER # start of the "urban areas" layer object
NAME "urban areas"
DATA V0UUrbanAreas
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 136 137 142
OUTLINECOLOR 0 0 0
LAYER # start of the "bridges" layer object
NAME "bridges"
DATA V0BBridges
STATUS DEFAULT
TYPE LINE
CLASS
COLOR 237 251 60
OUTLINECOLOR 0 0 0
LAYER # start of the "hotspots" layer object
NAME "hotspots"
DATA Hotspots
STATUS DEFAULT
TYPE POINT
CLASS
COLOR 255 255 255
OUTLINECOLOR 0 0 0
LAYER # start of the "Airport1" layer object
NAME "Airport1"
DATA Airports1
STATUS DEFAULT
TYPE POINT
CLASS
COLOR 237 251 60
OUTLINECOLOR 0 0 0
NAME "hotspots"
DATA Hotspots
STATUS DEFAULT
TYPE POINT
CLASS
COLOR 255 255 255
OUTLINECOLOR 0 0 0
NAME "Airport1"
DATA Airports1
STATUS DEFAULT
TYPE POINT
CLASS
COLOR 249 0 0
OUTLINECOLOR 0 0 0
#LAYER # start of the "hotspots" layer object
# NAME "hotspots"
# DATA Hotspots
# STATUS DEFAULT
# TYPE POINT
# CLASS
# COLOR 255 255 255
# OUTLINECOLOR 0 0 0
#END # end of class object
#END # end of layer object
END # end of map file
Do you Yahoo!?
Yahoo! Small Business - Try our new resources site!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050310/674a3042/attachment.html
