Controlling mapsize in CGI
Jacob Delfos
jacob.delfos at MAUNSELL.COM
Fri Mar 11 03:01:04 EST 2005
Richard,
I don't suppose it could have to do with this:
http://lists.gis.umn.edu/pipermail/mapserver-users/2004-July/014719.html
It seems to be the same error...... although I don't see how it relates.
Check what the URL is to the site after you submit using the code I provided. Does the parameter for map_size look healthy? I don't think it starts to do integer arithmetic because of the + symbol, because it's in quotes. But if it does, put a backslash before the +.
regards,
Jacob
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Richard A. Milewski
Sent: 11 March 2005 14:10
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Controlling mapsize in CGI
Jacob,
Thank you for the help! I tried your code, and it generates the message:
getInteger(): Symbol definition error. Parsing error near (+):(line 266)
The template (.html) file is only 103 lines long, but line 266 is the last
line of the .map file.
Any suggestions?
Thank you.
--RAM
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050311/ee0ae79c/attachment.html
