layer type circle
Nicol Hermann
mapserver at GEOWORLD.DE
Fri Mar 11 05:21:10 EST 2005
Hi List,
i would like to use the layer type 'circle'. Attached you find the
mapfile i use. I expect to get a circle whose diameter is determined by
the two vertices of my line (bounding box for the circle).
What i get is as single point (1x1 pixel) in the center of the two
points.
Do i have a wrong understanding of the layer type, do i miss something
or is this a bug?
Many thanks for your help
Nicol
MAP
NAME Germany
EXTENT 5.86628568 47.27360151 15.0486318 55.05826185
SIZE 300 300
UNITS DD
WEB
IMAGEURL "/~nicol/mapserver/phpmapserver/tmp/"
IMAGEPATH "/home/nicol/public_html/mapserver/phpmapserver/tmp/"
END
LAYER
NAME "buffer"
STATUS DEFAULT
TYPE circle
#TYPE line
FEATURE
POINTS
8.2588482 48.87774279
8.2588482 49.1577759
END
TEXT "circle"
END
TEMPLATE "dummy.html"
CLASS
NAME germany
COLOR 0 0 255
OUTLINECOLOR 0 0 0
LABEL
TYPE bitmap
SIZE small
END
END
END
END
