inline feature
Bart van den Eijnden
bartvde at XS4ALL.NL
Mon Mar 14 10:44:32 EST 2005
It would help future users if you report back what solved your problem :)
Best regards,
Bart
On Mon, 14 Mar 2005 16:16:29 +0100, Dirk-Jan Huisman <d.huisman at INGBCC.NL>
wrote:
> I found what was wrong.
> Thanks for the help!
> -----Oorspronkelijk bericht-----
> Van: Dirk-Jan Huisman
> Verzonden: maandag 14 maart 2005 14:04
> Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> Onderwerp: Re: [UMN_MAPSERVER-USERS] inline feature
> Hi,
> It still doesn't work. The inline feature disappeare after zooming.
> This is the code.
> LAYER
> NAME "credits"
> STATUS DEFAULT
> TRANSFORM FALSE
> TYPE ANNOTATION
> FEATURE
> POINTS
> 20 20
> END
> TEXT '© 2005'
> END
> CLASS
> LABEL
> TYPE TRUETYPE
> FONT arial
> SIZE 8
> ANTIALIAS TRUE
> COLOR 5 255 5
> POSITION UR
> FORCE TRUE
> END
> END
> END
> I'm using PHP/Mapscript and rosa-applet. Maybe i have to draw it through
> the PHP-code? But how?
> Dirk
> Van: Stephen Woodbridge [mailto:woodbri at SWOODBRIDGE.COM]
> Verzonden: donderdag 10 maart 2005 15:50
> Dirk,
> Just make sure that this is the last layer in your mapfile so when the
> label cache is run it will be the first label draw. Then all the other
> labels will avoid it. If it is not the first, and other labels are drawn
> where it needs to be drawn, then it will get bumped and not draw. You
> can also add FORCE TRUE to the label block.
> -Steve W.
> http://imaptools.com
> Dirk-Jan Huisman wrote:
>> Hi,
>> My LAYER is:
>> LAYER
>> NAME "credits"
>> STATUS DEFAULT
>> TRANSFORM FALSE
>> TYPE ANNOTATION
>> FEATURE
>> POINTS
>> 300 300
>> END
>> TEXT 'Hello world.'
>> END
>> CLASS
>> LABEL
>> TYPE BITMAP
>> COLOR 0 0 0
>> END
>> END
>> END
>> The LAYER in the link below gives the same problem.
>> best regards,
>> Hi,
>> did you try something like described in:
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0103/msg00026.h
>> tml
>> Can you provide more info? The LAYER from your MAP file will help
>> analyzing the problem.
>> Best regards,
>> Bart
>>> Hi all,
>>> I want to draw text (copyright) in my map. In my mapfile I put the
>> code
>>> (FEATURE keyword). The string is drawed once and it looks good. But
>>> after zooming it's gone.
>>> What to do to draw the text again after each request?
>>> Dirk Jan
>> Prins Mauritsstraat 17, Postbus 75, 4140 AB Leerdam
>> Telefoon (0345) 63 96 96, Fax (0345) 63 96 66,
>> E-mail post at ingbcc.nl
>> Internet www.ingbcc.nl
>> Deze e-mail en de eventuele bestanden die meegezonden zijn, zijn
> vertrouwelijk en alleen bedoeld voor het gebruik door de individu of
> instelling aan wie deze e-mail geadresseerd is. Als u deze e-mail
> onterecht ontvangen heeft wilt u het ons dan laten weten.
>> This e-mail and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they are
> addressed. If you have received this e-mail in error please notify the
> system manager.
> system manager.
> system manager.
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
