Mapserver 4.4.1 with postgis 1rc3
Paul Ramsey
pramsey at REFRACTIONS.NET
Tue Mar 15 00:45:45 EST 2005
Steven,
PostGIS stores data in it's own internal structure, neither WKB nor
WKT, what you see on the commandline is the "canonical format" (the
default text representation) which was changed from WKT-ish to WKB-ish
in order to make dump-n-restore more accurate.
Anyways, your problem should *not* exist in RC3, so (a) try the CVS
head of mapserver and (b) try the CVS head of postgis and (c) if you
still get no love send us a dump of your table, or a small portion of
it.
Thanks,
Paul
On 14-Mar-05, at 9:11 PM, Steven Bowden wrote:
> Hi List,
> I am in the process of upgrading from mapserver 3.6.6 and postgis 0.7.1
> running on the one machine to mapserver 4.4.1 and postgis 1rc3, both
> running
> on separate machines.
> I have pretty much got the upgrade of mapserver working ok but I am
> having
> troubles getting the upgrade of postgis working. I can get my
> mapserver3
> and mapserver4 app working using postgis 0.7.1 but I can't get any data
> layers drawing from postgis1rc3.
> Mapserver config
> MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS
> INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> Layer config in map file
> LAYER
> NAME house_nos
> CONNECTIONTYPE postgis
> CONNECTION "user=xxx dbname=xxx host=xxx"
> TYPE annotation
> DEBUG on
> STATUS on
> DATA "the_geom from housenos"
> LABELITEM "tag"
> LABELMAXSCALE 1500
> LABELCACHE on
> CLASS
> LABEL
> TYPE truetype
> POSITION CC
> FONT f16
> FORCE true
> ANTIALIAS true
> SIZE 10
> COLOR 254 0 0
> OUTLINECOLOR 254 254 254
> END
> END
> END
> I suspect that it is something to do with the way that the geometry is
> stored in postgres. In postgis 0.7.1 it is stored as what I assume is
> the
> well known text format but in postgis1rc3 it looks like it is stored
> in well
> known binary format.
> So my questions are:
> Will mapserver 4.4.1 work with postgis1rc3?
> If so what other options do I need to enable in the configuration of
> mapserver?
> Is it possible to mix and match mapserver postgis layers between the
> different postgis versions? ie Layer 1 connects to postgis 0.7.1 and
> Layer 2
> connects to postgis1rc3 both to be drawn on the one map.
> Here is a sample of how the data is stored in postgis 0.7.1
> select * from housenos ;
> gid | tag | the_geom
> 0 | 62 | SRID=-1;POINT(433634.63353 7252530.30099)
> 1 | 60 | SRID=-1;POINT(433632.24681 7252510.01592)
> 2 | 58 | SRID=-1;POINT(433629.46231 7252490.52634)
> Here is how it is stored in postgis1rc3
> 0 | 62 | 01010000009C16BC888A771A41906B43938CAA5B41
> 1 | 60 | 0101000000B9C2BBFC80771A4152D5048187AA5B41
> 2 | 58 | 0101000000EACA67D975771A41F88DAFA182AA5B41
> And here is how it is when it is returned as text
> select gid, tag, astext(the_geom) from housenos ;
> gid | tag | astext
> 0 | 62 | POINT(433634.63353 7252530.30099)
> 1 | 60 | POINT(433632.24681 7252510.01592)
> 2 | 58 | POINT(433629.46231 7252490.52634)
> So I am pretty sure that my postgis setup is ok.
> Any suggestions would be greatly appreciated.
> Regards
> Steve
