different layer units
Ken Lord
kenlord at GMAIL.COM
Tue Mar 15 12:43:34 EST 2005
Hi Kristjan,
You could try to setup the kilometers layer as a WMS layer controlled
by its own mapfile set to output as kilometers. With your original
mapfile set to access that WMS layer.
If that doesnt work ... perhaps there is a projection, or perhaps you
could define a projection that differs from the other only by the
units. Maybe a projection expert could comment on that.
Cheers,
Ken Lord
Vancouver BC
On Tue, 15 Mar 2005 16:40:32 +0200, Kristjan Annus
<kristjan at tarkvarastuudio.ee> wrote:
> Hi,
> I have two type of Mapinfo layers in my map, in one type map coordinates
> are meters and in the other kilometers. Output is set to the meters. Is
> there any chance to view the kilometer-layers without converting them to
> meters in MapInfo? My problem is that the data comes from the different
> sources and needs to be updated now and then - so the conversion is not
> a good option.
> thanks
> Kristjan
