Hi Umberto,
When I copy the so file to the /usr/lib/j2sdk1.5-sun/jre/lib/i386/
directory, it is working! So much thanks to you!
And now I am use the method you offered from the web to prevent load
two times now.
And if you have some simple example with jsp to show and zoom and pan
a map file?
Best regard,
Yours sincerely,
Liangxu Wang
