Fwd: [UMN_MAPSERVER-USERS] Application Data
Giridhar Manepalli gmanepal at GMAIL.COM
Thu Mar 17 17:15:12 PST 2005
---------- Forwarded message ----------
Date: Thu, 17 Mar 2005 17:59:29 -0500
Subject: Re: [UMN_MAPSERVER-USERS] Application Data
To: warmerdam at pobox.com
Thanks Frank,
But how is it possible to convert that CSV data into a shapefile or
POSTGIS supportive table, in order for me to use in a MAPSERVER.
Condition being : data < 1MB
Regards,
Giridhar
On Thu, 17 Mar 2005 17:52:02 -0500, Frank Warmerdam
<fwarmerdam at gmail.com> wrote:
> On Thu, 17 Mar 2005 17:41:24 -0500, Giridhar Manepalli
> <gmanepal at gmail.com> wrote:
> > I would like to know, if it is possible to convert data produced from
> > a third party application to a shapefile or PostGIS table.
> > Hypothetically speaking, the data from the third party application
> > will be in the following format.
> > SSN, Lat, Long, Age etc
> > Imagine that the above data is huge (as large as 100GB), so I need to
> > dump this information to a database.
> > I would like to know, how to use this data from a table to Map it onto
> > a MAPServer.
> > and process queries like:
> > *.)  How many people are at a given location
> Giridhar,
> It is certainly possible in principle to translate this data to PostGIS
> or into a point shapefile, but if it is 100GB of data in that
> compact comma seperated value format, it is going to be alot
> larger in PostGIS or in a shapefile.
> A traditional approach to handling this sort of dataset, if you
> only need summary information is to aggregate it somehow.
> Otherwise you are going to have alot of performance and
> query optimization issues.
> Good luck,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
More information about the MapServer-users mailing list
