tileindexed layer crashing...
Mark Dieterich
mdieterich at GMAIL.COM
Fri Mar 18 21:25:18 EST 2005
Jeff/Ed,
I wonder if I could leverage some of your knowledge on a problem I'm
having. I'm trying to accomplish something similar to what Jeff is
doing, but have't made it quite as far. I downloaded a bunch of tiger
files, and ran:
* find . -name "*.lka" > roads.txt
* tile4ms roads.txt roads
which generated the roads.qix, roads.shp, roads.shx. Looking at the
roads.shp with ogrinfo produces what I think are reasonable results. I
can load the individual shapfiles which were included in the index just
fine with mapserver. However, when I go to load the tileindex into
mapserver, it returns:
msDrawMap(): Image handling error. Failed to draw layer named 'roads'.
msTiledSHPOpenFile(): SDE error. Tileindex layer must be a shapefile.
I'm certain there is something wrong with my mapfile, but I just can't
put my finger on it. At the moment I have:
MAP
IMAGETYPE PNG
EXTENT -71.352597 41.638137 -71.226191 41.774801
SIZE 1024 768
SHAPEPATH /var/www/data/maps/
IMAGECOLOR 255 255 255
LAYER
NAME roads
TILEINDEX roads
STATUS DEFAULT
TYPE LINE
CLASS
COLOR 150 150 150
END
END
END
Any help debugging this would be greatly appreciated.
Thanks!
Mark
