problem drawing shapefile (polygon/line)
Tim Tsai
ttsai at POBOX.COM
Sun Mar 20 05:55:43 EST 2005
Hello. I am stumped on this particular issue running mapserver 4.4.1.
I have a shapefile of polygons representing some water features.
For some reason, I can get the map to draw if I use "TYPE LINE" but
not if I use "TYPE POLYGON" (no objects visible and no error messages).
A quick gdb session shows that the layer and shape drawing routines are
both reached. shape->num_lines seems to be always 1 though everytime
I see it. I am going to spend more time with gdb but am wondering
if anybody has any idea on what this is doing.
Thanks!
Tim
-- from ogrinfo --
% ogrinfo _water.shp
INFO: Open of `_water.shp'
using driver `ESRI Shapefile' successful.
1: _water (Polygon)
-- from my mapfile --
LAYER
DEBUG on
NAME "water"
STATUS default
DATA "_water"
# TYPE POLYGON # doesn't work
TYPE LINE # works
CLASS
DEBUG on
STYLE
COLOR 102 204 255
OUTLINECOLOR 0 0 128
SYMBOL 1
SIZE 3
END
END
END
