REsize window question
Martin Weinelt
mweinelt at PLANIGLOBE.COM
Mon Mar 21 06:10:53 EST 2005
On Friday 18 March 2005 09:35, Stéphane RIFF wrote:
> My mapserver application need to redraw the map when the window is resized.
> My problem is that i don't know how to keep the same extent
> in two map with different size !!!
Using mapserver CGI you just send MAPEXTENT and MAPSIZE
to the CGI (together with layers, etc.) and that's it.
> in fact i don't want the map
> to change its scale when i resize the window.
Keeping mapextent at different mapsize yields another scale, no?
> How can i calculate the newExtent to do that ???
> Is it possible ???
You do not calculate it, you just reuse the image extent from the previous
map (which can be sent by the CGI together with the image).
> How do you handle that kind of function ? example ?
I do it on the client side with js:
function setMapSize() {
// mimg is a div in the doc with the map as background image
mimg.style.backgroundImage='url(images/waiting.gif)';
// a 'wait indicator' is shown until the new image arrives
// w is the browser window
var mh = (w.innerHeight) ? w.innerHeight : d.body.clientHeight;
var mw = (w.innerWidth) ? w.innerWidth : d.body.clientWidth;
mh-=60; mw-=230; // correct for other elements which also need a bit of screen real estate
mimg.style.width=mw; mimg.style.height=mh; // set the div to the new size
myMap.mode='browse'; // myMap is an object which holds some map parameters
myMap.mapsize=[mw,mh]; // ... mapsize for instance
myMap.mapext.set(myMap.imgext.get()); // or map extent - here copied from the last image recieved
var s=myMap.getReqStr('mapsize','mapext'); // this glues a GET-string for the new map request
getMap(s); // invokes the new map
this is just an example, the same purpose can be served in a more traditional way.
Cheers, Martin
